View Full Version : All Motor
Pages :
3]
- 3.5 shortblock + 3.0 heads
- VQ35 Swap, 95 ECU, retaining VIAS
- help idle
- thinking of 3.5in' my 4th gen
- 4th gen 5 speed conversion
- vq30de s13 swap....or build thread hahaha
- 4.5 Max tuning tips needed:Dyno proven maybe?
- Quickest 00VI question, PIC INSIDE!!!
- Stroker Question ...
- explination on back pressure and aftermarket exhaust vs stock exhaust
- Greddy E-Manage Ultimate - how to identify
- 5.5 gen timing curve
- Question about fidanza flywheel
- Full Swap 3.5 ECU wiring schematic
- Eliminate dry start, solutions inside....
- Not cranking, CEL not lighting, but works with OBD2 scanner plugged in.
- coolant line swap?
- Transmission Gurus Step In
- 00VI Gasket and vacuum lines
- interested in a engine swap
- VQ35DE cams in a DEK #'s? Been done?
- Few Questions about installing a Fuel Cell
- is this a good CAI?
- Best/Necessary Mods to MAKE the N/A Setup RESPONSIVE?
- 00vi High idle (1900 rpm) with TPS disconnected
- Boost-a-spark by KB? Anyone still running this?
- Do 350z Coils drop right in FWD valve covers?
- shooting for 285whp-300whp n/a
- Fidanza Flywheel Touchy in First Gear?
- Are 350z injectors the same as my 04 injectors?
- Emanage Ultimate on a 2002 5.5 Gen Review
- New VQ35 for sale in un-claimed freight
- Need to know the number of each cylinder on the VQ35
- 00VI, To do or not to do.
- Ignition timing (DEK)
- Need opinions on camming a DEK.
- cardana24's 3.5 swap
- Mass Air Flow problems
- how to up the ignition coil voltage.....
- Did a VQ30 -> VQ35 (2002) swap. Can I do 2008?
- 2002 Valve Cover on a 2008 engine?
- Some 00VI questions as I progress...
- 6spd Starter Question....
- Y pipe differences between VQ30 years
- busted cam sensor on3.5 swap help
- Need some info from you 3.5 guys
- need some wiring help
- Anyone have MAF voltage logs?
- Anyone do a VQ30-> VQ37 swap?
- quick question about technosquare....
- 3.5 swap problems
- Rev Up cam timing in a vq30
- VAFCII in and out setting... where???
- 5spd swap.. (just have a question or two)
- 3.5 oil cooler on 3.0?
- 3.5 Swap, Knock Sensor relocation
- Motor buying tips
- Glowing Header
- Fuel rail diff. between DE / DEK rail.
- Smoke coming out from the front valve cover breather.
- putting only the 3.5 block in 4th gen.
- Question about Apexi WS2
- Need a block and crank..
- Cattman headers
- Technosquare ECU question???
- N2MB WOT box
- Emanage ultimate DIY harness
- Dek swap problems
- 3.0 Timing noise, 3.5 engine.
- Injector Question
- Idle Issues w/ 4.5 gen
- 00vi swap this weekend. a few Q's
- OOVI. RPM SIGNAL & FUNCTION TEST
- Automatic transmission rebuild/overhaul
- 70mm TB on a 4th gen 00VI??
- would jumped timing cause no / intermittent spark?
- what components needed with a wideband
- 3.5 swap on 5sp vlsd
- 4th gen - from MEVI to DEK + 3.5 CAMS....problems.
- 4th gen tuning
- Wheres the good motor mounts??
- Need help w/really poor idle after Spacer install and TPS calibration!!
- Coil size between front and rear coils.
- 3.5 timing ring modified to 3.0 flywheel
- VQ35 swap; Verify cam timing.
- O2 sensors critical in a VQ35 swap?
- question for ppl with built motors
- Pathfinder TB idle
- Spray w/ JWT ECU????
- Made my tuning Decision ;) Utec :) couple ?ss
- 3.5 Heads on 3.0?
- 3.5 swap complete. getting MAP/BARO code
- EMU-96 to 2k3 swap-Possible?
- Fastest 4th gen VQ30DE all motor 1/4mile run
- TOB Spacer for a 6spd Swap
- Too many options, not a clue which is best
- Tune Question - Tuning gurus, step inside.
- Tune issue
- need help on 2001 motor swap!
- VQ35 carnage pics.. :)
- Fidanza Flywheel
- Russ's 00vi Swap
- North Jersey (00vi swap)
- P0Rt and Polish..HOW TO?
- 3.5 Swap Auto, Smooth Idle, no IACV
- 1st Fully Built 5.5Gen - NA
- VQ35DE + 6 Speed swap Questions.
- precautionary 3.5 thread
- Has anyone ran their AFR at 13.5:1 all across without pinging?
- RPM switch for 00vi
- Head Gasket Help VQ30
- VQ30 CPS VS. VQ35 CPS
- 00vi swap gone wrong!!! need serious help
- Stock 4th gen auto tranny+ mild bolt on 3.5 = ????????
- Anyone do any testing with the new plastic intake manifold?
- VQ35 Turbo swapped Spec is finished! :)
- Acronyms / Links vq35
- Help w/ DE-K swap
- MAP/BARO
- Yet another 3.5 Swap thread (4th gen chasis, 2008 vq35)
- How to identify VLSD transmission
- vq30 front and rear valve cover swapable??
- Final Questions Before Installing VAFC-II
- VQ35 swapped Spec..
- Will 350z heads work on a FWD VQ35?
- VQ30 with 3.5 heads, and VK45 pistons?
- 2008 VQ35 swap Camshaft Position Sensor Hole
- MAFterburner;who uses it?
- BBMAF and new MAF ECU reflash
- question about my newly-bought VQ35
- Injector question ?
- 00vi Tuning
- vq35 fuel pressure
- ran into problems installing oovi, gurus please help my noob arse
- VI Removal for 3.0s
- Full billet intake manifold..
- 3.9 liter (big bore), CNC head/cammed VQ build..
- Very confusing stalling problem for the minds of A.M....
- Pathfinder throttle body install write up
- Bbmaf & greddy eu settings
- Degree settings for HR cams
- An interesting article written by Steve Dinan
- Kevin's VQ35DE NA Build Epilogue..
- 95-96 JWT ECU question??
- Marc's vq35 build
- Flywheels: (A33B) Maxima vs. (Z33) 350Z
- clutch masters stage 4 + aluminum flywheel install pics
- Piggy-back programer
- Q45 TB vs Pathy TB
- VQ30DE/00VI/VAFC2 TPS problem.
- Myth about cars needing backpressure
- AFC question
- another vq swap...input appreciated.
- A33 DE-K Apexi AFC users
- Overhauling my engine, need some input
- tranny "re-built" TONS of pics 56k
- need help!!!
- Plans for ITBs
- REBUILDING??
- VQ35 / 350Z Heads / 350Z ECU Build
- SAFC help
- COIL Testing?!?!
- Crank all day but car would not start***
- Opinions on wrapping headers?
- Advice For Supercharged VQ30 Engine Upgrades
- Building a Time Attack VQ for Competition - in a B15
- VQ35HR cams swap
- What Camshaft to use?
- Low budget piggyback called the UAFC!
- 5spd A33 i30 question. ( i have the trans for swap, but some ??)
- Idle issues in VI00 swap in 95 maxima
- problems after 5 speed swap
- Obx underdrive pulley
- 1996 SE malfunctioning LSD???
- Bent the Valves in my VG...What Needs to Be Done?
- Clutchmasters stage 4 - who has one?
- Is this bolt/stud removeable?
- rod and main bearing selection
- Calculating VE for the VQ
- Battle of the 3.0s???
- Pathfinder cooling kit
- SAFC 2 Help Needed!!!weid issue with loss of RPM signal
- 6 speed swap timing ring
- Installing new pistons in an unmodified stock block
- ACL Calico Race Bearings or OEM Bearings? Headstuds & Main Bolts?
- Other 3.5 UTEC guys chime in
- New PB at cecil county dragway
- Transgo RE4F04A-HD2 Reprogramming Kit Install
- Is there a aftermarket TCU for us?
- 4/5th gen headers vs 6th gen headers?
- Lm-2:digital air/fuel raito meter
- Tuning Help, acceleration halts at 5k rpms?
- 5.5 gen stock ecu starts to close throttle at high rpms?
- Cheap Lightweight Racing Battery from a Battery Jump Box -->
- Somebody buy this motor! Built RWD VQ35 NEW
- possibly a new oovi idea (need input)
- CEL w/00VI
- DEK fuel rail on 3.5
- Help: UTEC
- auto to manual swap in a 5th gen
- Z350 heads on VQ30DE maxima ???
- 00VI swap EGR guide tube trouble.
- are the VG30E's easily swappable?
- I dropped in a DE-k and it WILL NOT start
- Need Ideas for EGR tubing
- VQ35DE Buildup questions
- installed a walboro burning fuses!
- 01 DEK motor swap cold start issue ?
- 00VI Measurement Request
- Are FWD and RWD VQ block to bellhousing bolt patterns the same?
- Crank wont turn
- UTEC wiring clarification
- Colder Spark Plugs for N/A?
- Another 3.5 swap thread
- vacuum solenoid switch for MEVI
- Difference between the 3.0 and 3.5 chains
- New J&S info link
- Solution for Hesitation problems for VAFC-2 users
- gap between intake manifold and egr guide tube
- A33 IACV idle issues
- Loss of using 3.0 cams in the VQ35 swap
- Does the DEK IACV bolt up to the PF TB?
- changing the shift point on 5spd auto 6th gen?
- My VAFC2 + LC-1 wideband Tuning
- Rev-up Oil pump and oil pressure ISSUES!!! HELP!!
- Resonance Tuning
- Does the Greddy EU read stock front O2 voltage?
- 6 speed in 4th gen VSS
- Finally!
- jim wolf ecu for auto??
- 3" crush bent exhaust on VQ30?
- Anyone willing to trade 3.5 manifolds?
- 4th gen auto FD swap?
- Gutting the 00VI: Whats inside the 00VI?
- Pathfinder TB coolant bypass
- VQ30DE-K Swap Question
- 00vi Swap - Fuel Rail questions
- P0172, P0175, possible tuning needed to fix?
- GI: Q45 throttle body and MAF flanges
- Axle comparo between 5 & 6 speed tranny's...
- SSV4 HELP PLEASE SOMEONE
- car stalls after 00vi install
- need some help/info
- 3.5 Swap Questions
- extending o2 sensor wires??
- manual to auto swap for 4th gen
- 35 swap...no spark
- Tilley Built motor.
- Rev up oil Pump installation?
- Camshaft Confusion.
