PDA
View Full Version : All Motor
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15
  1. Potential ill effects of PCV oil catch?
  2. Knock Sensor
  3. VQ35DE Skyline Intake manifold
  4. VQ30+stock ECU+MEVI dyno?
  5. Another completed 00VI with 0 problems
  6. Vq32?!?!
  7. EU question
  8. Remove power steering belt-increased power?
  9. hooked up vias finally... not working though
  10. EU Bretheren, I have a datalog for you.
  11. Engine Build ?
  12. VQ30 Rebuild Kits
  13. 00'VI / JWT Ecu Setup ?
  14. 00Vi -Strut Bar
  15. 3.5 Swap no start - THE LAST STRAW!!!
  16. 3.5 swap complete, idles too high, can't use 1st gear
  17. ? about rear valve cover when installing 00VI
  18. New 3.5L IM
  19. Just contacted SportCompactCar...
  20. Vacuum Assist Device on 5th gen TB
  21. i can smell fuel while driving..
  22. using vafc-II if there is a bad oxygen sensor?
  23. Help installing a Autometer Air/Fuel Ratio gauge
  24. 00VI parts
  25. ECU Question
  26. **********4th Gen, Doing a 3.5 SWAP!!!**********
  27. Is it a bad ecu, bad wiring harness or could it be the starter???????????
  28. 01 MAF in 4th gen?
  29. Plastics back!!
  30. Engine Size
  31. rpm drop after giving it some gas?
  32. Guys running NO Cruize ?
  33. can clutch hydraulic issue make clutch slip?
  34. need advice on de-k vs 3.5 swap. Cant decide which to go with!
  35. Need Questions Answered Please!!!!
  36. anyone have an smt-7?
  37. With Consult, can throttle pos. and shift pts. be changed?
  38. Exedy clutch won't go on :(
  39. Car in the shop for 5 days now...
  40. problems with motor
  41. swap sensors for the dek swap
  42. 6 spd in a 4th gen
  43. VQ35 S13 swap 90% complete
  44. My 3.5 acts like it has turbo lag!
  45. Calibrating the VAFC2
  46. 3.5 fell out of my Xterra and hit the asphalt...what do I look for?
  47. What parts do I need to safely rev a 3.5 to 7500?
  48. Jus a thought on the 4.0 VQ
  49. VQ30 cold start knock
  50. problems after eu install....
  51. quick gasket question
  52. 3.5 w/ RPM switch...hearing different stories re: how/when IM valve is actuated.Help!
  53. Greddy EU install, need help.
  54. curious
  55. 3.5L: Just installed RPM switch...at what RPM should it actuate???
  56. REF 3.5 or 3.0
  57. New Motor is In !!! Pics !!
  58. 3.5 swap IM question, won't bolt up
  59. Just rec'd MSD Digital Window Switch...installation questions.
  60. 99 ecu
  61. How to remove Valves and valve springs.
  62. 2000 VI swap generic hardware list
  63. Planning a 3.5 swap...what else should I do while the motor's out?
  64. Help diagnose a misfire
  65. 3.5 swap problem again...Fuel delivery?
  66. De-K swap + full 2.5in exhaust = a max that BACKFIRES???
  67. How to: Hook up 00VI ??
  68. 3.5: What does the white paint dot on each coil top signify?
  69. Dowel Pins
  70. vq30dek swap?
  71. 3.5 swap waiting on cam spacers, specs, where to find?
  72. A little help with Diagnosis Please
  73. Can I drill & tap the 2k2 IM?
  74. 3.5: very small oil leak...what can I do?
  75. 3.5L: Is it just me or does oil pickup at startup seem a little slow?
  76. vafcII vs. neo on 06 Max
  77. A BUNCH of extra ECU crap about 3.5 swapping ... you will probably never need it
  78. P-Finder TB and TB spacer?
  79. Summit RPM Switch Backorder
  80. Those with custom transmission setups, step in.
  81. A-little DEK Swap Help...EGR and gally
  82. 3.5 Swap Completed, Credits, Tech Issues and Plans
  83. This question's 4 all of you running an adjustable FPR!
  84. Top Secret Intake Manifold for the 350z
  85. 3.5 swap question: replace O2 sesnors?
  86. WTB: Injector Harnesses/Plugs for DEK/3.5 Motor
  87. mevi question
  88. 3.5 swap + pothole in the road equals...
  89. Spec V 6 Speed Transmission
  90. 3.5 misfiring at low rpms.
  91. VQ30 Oil Pump in VQ35
  92. 2003, 2004 auto tranny work in a 95(3.5) max. ?? .. yay or nay?
  93. rear o2 sensor ?
  94. Anyone Know what the most powerful 5th gen De-k is?
  95. 3.5 swap. Getting code 0701 now! Car runs great...what's up?
  96. Hey guys...name these three (sensors?)!
  97. *cam Spacers From Tilleys99*
  98. 3.5 motor & tranny has to be from same car??????
  99. Something wrong with my 3.5? Help
  100. Think my 3.5 swap's running rich (symptoms within)...SAFC or E-Manage Ultimate?
  101. Using TB Adaptors...
  102. Full 3.5 or reg......
  103. UpRev Cipher Write Up....
  104. UpRev Cipher DDS Write-Up
  105. 3.5 Swap....
  106. 00VI Compilation
  107. What is the proper procedure to check throttle position sensor adjustment?
  108. 3.5 swap done'ish and purring...one minor issue, though...
  109. 00VI PCV Valve setup
  110. Can timing in 06 be adv. w/ obd II?
  111. What's the torque spec for '97 flywheel?
  112. How to properly adjust/set up OBX-R external FPR.
  113. 00VI Wiring Questions
  114. 3.5 owners w/ debuloz/ebay cams
  115. Are '97 3.0 ignition coils the same as those from an '02 3.5 Max/Alt/etc.
  116. 3.5 swap: please check out these 3 sensor readings and let me know what you think!
  117. 350z cams in maxima 3.5???
  118. 3.5 Swap completed...Got fuel cut off problems past 5k rpms.
  119. V afcII..diagram for 00 max?
  120. The 3.5 swap won't start...please HELP!
  121. 3.5 Swap...no fire in 2 cynlinders! Help.
  122. EU Wiring Diagram needed
  123. Hotshot VQ35 headers vs. stock VQ30 for 3.5 swap
  124. pics of my 00vi what dont i need?
  125. 100% DONE and she's alive
  126. Z IM questions
  127. How to set TDC when skipped links?
  128. what year pathfinder TB?
  129. Where to buy ARP rod bolts for VQ35
  130. 00VI swap
  131. 3.5 swap! Has anyone retained the EGR from the 4th gen? How?
  132. EU Update Has Been Released
  133. 99 Maxima Engine
  134. Help! ASAP!Hotshot ypipe, why some have bend and cant and some dont??
  135. She is alive!!
  136. rpm switch differences
  137. how to Tell if a Block is warped.
  138. Need help setting up timing gear on the 3.5 swap!!!
  139. 3.5 swap: Summit RPM Switch/MSD Window Switch question! Help!
  140. Swapping engines
  141. exhaust grounding strap
  142. Physics and air flow experts please chime in....
  143. 3.5 swap parts
  144. 3.5 swap:cranks, sputters, dies.
  145. ECU & Headers
  146. Future 3.5 swap looking for 5spd advice...
  147. Vias Picture
  148. tunning masters please chime in
  149. Help -- complete DEK swap w/transmission
  150. A couple items FS....Nismo Cams and JWT VS's
  151. Need suggestions from the VQ masters
  152. 00vi gasket
  153. So I set the new revlimit record
  154. IACV hose routing on 3.5?
  155. How many revolutions can it take to align timing marks on the 3.5?
  156. Turbo Timer on NA
  157. Turbo Timer on NA
  158. 3.5 Swap done but cant start (no spark)
  159. Misfire code help
  160. 3.5 swap under way...anyone know where I can find (a set of 6) injector plugs?
  161. TB adapter for DEK
  162. noob question: how do you decrease or increase compression?
  163. ECU upgrade ...need help
  164. Another 3.5 swap complete in South Florida
  165. Anyone (w/ experience) interested in coming to MN (on my dime) to help w/ a 3.5 swap?
  166. Performance comp: stock '02/'03 SE MT vs. MT 4th gen 3.5 swap, full exhaust, intake?
  167. question for all vq35 swap guys
  168. E85 questions
  169. Alright guys check my timing(pics inside)
  170. Ts Ecu
  171. Tranny overhaul - extra (3 instead of 2) dowel pin
  172. quick FPR question...
  173. 3.5 swap question
  174. Swapping in a 3.5 in 1 week...have several questions!
  175. STUCK: 3.5 swappers need help removing ex. bolts.
  176. 00VI Adapter Diagrams
  177. Best tuning method?
  178. stock 97 ecu timing and a/f ratio?
  179. Brake problem after 3.5 swap!!
  180. 300zx Injectors
  181. Need Help On Dek Swap Im Stuck!!!!
  182. what type of tool to remove main bearing beam
  183. 2k engine swap parts list and instructions
  184. Dek Swap Progress
  185. New personal best on the dyno...
  186. E-Blue Setup. . .
  187. Motor Break-In Opinions
  188. WWWWWEEEEEEEE have lift off
  189. Need Your Help About Cams!!!
  190. SAFC2 Wiring
  191. No EGR!?!? HELP FAST!!
  192. 3.5 swap for tilley99
  193. Spark Plug Gaps
  194. 3.5 swap starts tomorrow.
  195. Great reading for the tuning n00bs
  196. light flywheel ?????
  197. Installing wideband on an Auto...
  198. need help getting in contact with tilley
  199. Overheating problems, tested the thermostat
  200. It's official...I maxed out the stock fuel pump all motor
  201. switch for 00VI
  202. 00VI Differences
  203. Little help...
  204. Where to get a vq35
  205. Starting a 4th gen 3.5 swap, need help
  206. CAn someone inform me on the DE-k
  207. race gas in a 4.5 gen?
  208. Almost done with wring 3.5 but a question
  209. 00'vi or DE-K?
  210. Injector Connector Options (3.5 swap)
  211. 00vi running Great but with, weird start up
  212. 5.5 6 speed swap... parts list needed
  213. 3.5 clutche(s)
  214. Question For the AUTO TECHS/ TIMING ADVANCE
  215. apexi auto timer (401-A011)
  216. would this motor setup work?
  217. Troubleshooting on the 00VI.
  218. How hot is too hot for a VQ35DE?
  219. Difference bettween Full 3.5 swap&3.5/3.0 modified?
  220. got WBO2 installed, need help with tuning issue...
  221. Anyone looking for pathfinder 3.5 heads?
  222. want to do 3.5&6spd swap,engine blown
  223. want to do 3.5&6spd swap
  224. 00VI install for $$$
  225. 3.5 oil cooler line is bend
  226. Thanks MAXIMA.ORG, and Tilly!
  227. Greddy EU 2-step - good video from the dragstrip
  228. need to determine optimal octane rating
  229. Question about EGR in 3.5
  230. vq35de in 4th gen guidence needed!!
  231. VG30E questions
  232. 00vi parts advice?
  233. Sudden RPM drops and stalling (Auto)
  234. need VQ35 block/crank/oil cooler? i got it
  235. Guys Running NO EGR valve
  236. What option should I get?
  237. Pcv 00vi
  238. SAFC vs. SAFCII
  239. o2 sensor bung welding?
  240. Bored 5th gen TB
  241. VQ30DE-K and VQ30DE TPS the same?
  242. Cleaning a MAF?
  243. ECU: SUPER LIMP MODE, Why?
  244. 6spd in a 4th gen, what axles?
  245. Checking for TDC on a VQ35 with no crank pulley
  246. Need your precious advice on 00VI
  247. Cam timing theory for 3.5 swaps w/out VTC
  248. Can someone w/ 3.5 & aftermarket cams help me out????
  249. Question: blown motor
  250. intake vac hoses
