View Full Version : All Motor
Pages :
9]
- 3.5 Harness.
- My short ram 3.5 IM setup
- 00VI EGR Block Off Plate
- WTB : broken VI's
- How much would i be looking at spending
- What's best way to remove "the shelf?"
- Some electrical issues... Please step in!
- how many miles on your vq35 swap?
- pathfinder VI install
- . . . it was the Pathfinder TB
- downloadable fsm??
- Vq30dd
- Anyone ever have to replace the Vacuum Solenoid for their VI?
- do z32 injectors work with 4th gen MAF?
- wide band question
- de-k injectors in 4th gen w/ stock ecu?
- Hesitation and misfire on cyl 6
- check engine after 3.5 swap
- polishing lower intake manifold?!
- 4th gen wont start after v2 removal
- ok the 2nd cv axel in a month
- Is this common on 4th gen injectors?
- afc
- rebuilt trans pops out of third gear.
- Blown Tranny and/or Clutch.
- Bubbling Coolent?
- RPM questions?
- will a 90 se and 92 se engine swap work?
- Transmission Question
- 8000RPM reliable shortblock
- Swap Specific Questions?
- I think I may have found a typo in the FSM!
- 00VI: vacuum hose check, will crank but not start ? (photos)
- In the middle of VI swap, question on fuel rail
- Spare VQ30DE
- No crank after 5spd swap
- anyone with 99 cali spec with DEK engine?
- 3.0 and 3.5 head bolt thread pitch and diameter the same?
- 3.5 in a 3rd gen
- 98 engine on a 95 max
- Deck the heads?? i think
- plan on doing a 3.5 swap take a look. If you've done a 3.5 swap take a look.
- MEVI installed: manifold actuator not activating (long)
- Help with VAFC2
- pathfinder intake manifold...will it fit?
- Who drills 3.5 cams now?
- 2002-2003 intake manifold power valve
- 00VI concerns: IACV and PCV valve setups
- To all Emanage ultimite users
- DEK swap...coming soon
- I need help! NATS system malfunction..
- Auto transmission questions - Aaron92 and others come in
- It's almost race day....*veterans chime in*
- slick Q's
- ECU Compatablitity HELP!!
- fuel pressure problem.. and running lean!
- Coil Packs Causing Misfire?
- choices other than the Cartech/Vortech for FMU?
- Blown Tranny, Now what?
- Head work VQ30 heads vs VQ35 heads
- Another Pathfinder TB Related Question
- I have a question
- Calling all those using a Walbro 255LPH fuel pump!
- ECU differences...
- 3.0/3.5
- Im EXCITED!!! ...to say the least
- Please link me to 4th gen TPS/idle adjustment procedure!
- Safc2 wiring question
- To those with trouble maintaining 51psi on a 3.5 swap!
- MEVI question?
- VQ35 in formula 3
- TPS Question
- Pathfinder TB Cold Start Issue
- Alternate throttle signal pin & ECTS experiment.
- coil firing Qs
- 3.5 swap: car running rough
- Air/Fuel Tuning Question
- Greddy has a system to tune CVTC!!!
- emanage blue questions
- UDP Belt's
- Starting Problem: no spark
- IACV on a 3.5 swap General Question.
- 5th Gen TB or 4th Gen TB on 00VI swap?
- Need an engine for a 95 max on the west coast
- 3.5 swap: fuel pump not priming
- after dek swap im getting knock sensor code
- bigger injectors?
- 3.5 swap: Modifying fuel line
- what to do w/ EVAP & iacv hoses if i'm not using them
- Been out of the loop for a while... lil help would be GREAT!
- Headers design
- ? about shift-fast mod
- Have a question on converting 3.5 TB to wire driven.
- Emanage Blue and tach issue...
- 3.5 SWAPPED motors and their Tranny's
- motor ????
- Msd Rpm Switch 8969
- A good read about spark plugs for the n00bs
- EB not letting me activate VI...
- **MEVI-need help wiring the relay**
- car runs richer after cai install
- 00VI Starting Problem
- Another Complete 00VI Swap!!
- Unorthodox Flywheel on a 3.5 swap??
- Cosworth Plenum
- 3.5 swap in progress, need double check on timing chain install
- High/Odd Idle +Vacuum lines
- cam adapters problems
- Cooling System Went Caca after 3.5 Swap
- trouble with plugs
- Did the Z IM make power over the stocker?
- 3rd gear pull n stock 95with a dek (data log) air fuel
- 3.5 swap in a 5th gen?
- Vafc Ii
- Need serious help guys
- huge misfire..no codes
- A few questions about AFC and such..
- What do you think??
- shimming 350z thermostat
- SMT6 installed and need help
- rebuilding 3.5L
- got vq30de-k 2day, where do i start on removing 00vi parts?
- Pathfinder TB Question/with 00VI ??
- SS Autochrome Headers
- An Unsolved mystery-- (for me at least)
- Wb o2 time..
- noob questions about greddy emanage
- VQ35 VIAS question
- Help with MSD 8950
- Engine break In.
- HELP GUYS! VERY odd mechanical 3.5 swap problem!
- Mfa60
- Switches
- Engine Controls
- How often do you break brand new axels?
- 3.5 swap question
- EU version 2 has been officially released
- Use Innovate LC1 to replace stock front o2 sensor?
- 00VI Idle Issues.. Possible Vacuum Leak.. Help
- Tuning with fuel pressure regulator.
- What is the best rpm for the 00vi to open?
- best rpm switch to use for the 00vi
- Problem 2nd gen
- I want to modify my PCV setup...
- Scan Tools, whats everyone using?
- Idea on what air fuel for the rpms
- Weird Limiter Problem: EU
- Zeitronix Questions
- Vq40/vq35
- Pics of modified 3.5 IM
- VQ30 Pathfinder Manifold install?
- Anything else needed fo a direct swap?! : )
- Wideband O2 Question
- water pump in VQ20DE vs VQ30DE
- weird fuel problem now (dek swap)
- I HATE my engine!!
- Dek Swap Help asap please
- Re: Throttle Body For 3.5 Swap
- Rear o2 sensors necessary on 02 vq35?
- dek idel problem thread
- 3.5 head swap
- 3.5 swap having loud noise
- Installing a Catch Can
- 04 350z head fitment....
- Cleaning Up Fuel
- Wideband O2 Zeitronix Zt-2 install
- New Apexi SAFC-II Being Sold
- 5 speed convertion
- A/F problem for you Guru's...
- Prepped VQ35 from 95 to 00-01?
- Best clutch for 3.5 4th gen swap
- Lapping valves and clearances
- QR25DE, VQ35DE and VK56DE = Same ECU!
- Engine harness removal question...pretty urgent.
- Zeitronix now has linear output WB O2!!
- dek fuel rail things where to get them
- clutch stage = clutch stiffness?
- 5-speed swap...Questions???
- Dangers of over-revving?
- Did the Dyno on the DMC.
- Question about VAFC
- Wtb: Afpr
- Motor contemplation time.
- witch wire for neo to run the VI
- VK45DE and Pathfinder VQ35DE heads what can I use? *pics*
- Emanage ultimate setup questions
- Injector Mystery
- 3.5 complete . . . running rough
- 3.5 + Spec Stage 2 = frisbee!
- doing a DEK swap vs VQ35 swap
- Random New 00VI Information
- Greddy E-manage Ultimate Installation Write-Up
- Plug coolant line or T it?
- A34 Owner : 350Z I/M ?
- Installed JWT ECU: now motor lagging
- FPR help
- Variable Compression Engine
- 00VI Cutaway
- For those with 3.5s in 4th gen,please explain ur fuel setup/fuel pump regulator setup
- Oil Pressure
- 3.5 swap- can I use x, x, and x from 3.0?
- Should I keep wet kit or go with MEVI?
- Nismo 350z 262's in my 04 max
- Weird Emanage Problem
- What's your max advance on your 3.5L?
- 350z Cams
- VQ35 in Sentra.. off to the dyno..
- Clutch recommendations please
- VQ2.0 to VQ3.5 Swap
- Interesting Exhaust Read Turbo and NA
- How do you guys think this exhaust will sound..
- Which VQ is this??
- 3.5 Oil pump the same?
- It's time to play NAME THAT VQ35 sound!!!
- WHY is this not a sticky!?!
- 3.5 swap: update on "whining" sound...whaddya' guys think?
- Why do the 3.5s sound different from the 3.0s?
- 350z & Max ECU
- 4.5 gen wha clutch u using?
- anyone in the nyc area do 3.5 swaps?
- how the heck. 4th gen tb on 00vi
- car wont rev above 2000 rpms
- 3.5 starts runs bad no fuel
- SE-R Engine
- 00VI swap, PCV question
- question about dek swap
- 3.5 swap: what the he!l is this noise???
- Quick CPS question
- Main Cat output dia.?
- What 3.5L ECU would you use for a custom install?
- MEVI install help- which ECU wire to tap for RPM? (96)
- Mystery Misfire - Help Diagnose(Bare with me. Long)
- Another DEK Swap Completed
- Consolidated N/A links and reading
- Opinions on NA/Auto Mods (2000 max)
- ECU Compatibility
- Suggestions for intake tubing for 3.5
- MEVI not activating..
- 3.5 swap problems, hesitation + codes
- VAFC-II tuning vs. JWT ECU
- VQ35 Swap using 6th gen alternator
- 3.5Cams install help.
- CEL problem
- Vehicle speed sensor question..
- VQ35HR Block
- thinkin of doin 3.5 swap...
- 3.5 swap using de-k timing equipment in 4th gen?
- Help with A/F tuning & Datalogging
- 200whp MEVI vs. 200whp 00VI dyno comparison.
