View Full Version : All Motor
Pages :
12]
- timing graph
- 3.5 Cams or Aftermarket cams?
- Knock sensor??
- Headers question
- 5speed vs. VQ35 swap
- emanage..... map
- vq35 and 4th gen auto tranny?
- AFR changes according to temperature?
- VAFC-II setup template
- North-south Vq30de?
- Are high 13's possible with a finely tuned 3.5 swap and vb mod for my auto?
- Fs: New Stillen V2 Supercharger Starter Kit
- '00 VI Swap : Rough Idle
- 350Z TB on 03 maxima?
- big time idle problem after NEW TPS and cleaning IACV
- Does a VQ35 Cylinder Head Directly Bolt on to a VQ30 Block
- Engine harness removal question
- Piggyback systems
- water injection
- Timing chain kit for sale
- Naturally Aspirated Tuning Discussion
- 3.5 swap needs fine tuning plz help!!
- about to put de-k in.... Want to get headers
- Apexi V-AFC II & S-AFC II
- MEVI vs. 00VI HELP!!!
- 3.5 swap... 5th gen ('00-'01) clutch?
- Coil Question
- Fuel Injector issue
- Clutch Question
- evap equipment with 3.5 swap?
- 350z IM on fwd maxima
- RPM switch
- Anyone used a jet vforce control module?
- removing swirl control valve on 01 de-k ?
- Want to get E-manage(old one, blue box) for NA
- Emergency Help Needed
- port / polish stock 4th gen intake/tb ?
- 2k2 VI control options
- Need VI assistance stat please..
- where to buy iacv adapter plate for 01 dek engine?
- Is it possible cruise control with VQ35 TB
- nismo adjustable fuel pressure regulator
- 3.5 swap, motor build...
- Apexi AFC information needed
- Any interest in my JWT HD Valve Springs
- 3.5 swap and emissions
- 01 maxima 300zx twin turbo swap
- 1 more Breathing NA TorqueMonster
- cheap motor
- VQ35 swapped
- G35 Manifold fitment issues
- ultimate exhaust for drag car
- Need more 3.5 cam drilling info *pictures*
- MEVI installation
- VQ Powered S13 Video Compilation
- SAFC-2 Configuration
- Dropped the VE off at the machine shop today....
- FS: 00VI kit
- got a great deal on vq35 + tranny...should i swap??
- how does your car run after the de-k Engine swap ?
- VQ35 300hp RevUp cams for <$600!!!!
- another 3.5 swap question
- 6spd swap in 2002
- Installing VAFC2 on 4th gen
- JWT valve springs necessary
- 5.5 vs 4th gen stock ignition timing
- Write up on DEK engine Swap in 4th gen ?
- will my tranny hold in a dek swap...
- O2 sensor questions..
- best way to remove engine and tranny together?
- question on removing a/c
- 5A valvebody
- Emanage Ultimate, or SMT 6
- Using hotter plugs in hopes to gain extra power...
- chassis dyno vs dynojet?
- Summit RPM Switch
- Which Piggy does it all?
- Exhaust cutout N/A
- VQ35DE 4th Gen: Shift Points and Dyno Shootout
- drilling cams
- fuel rail question
- VQ35 Oil cooler
- 3.5 swap question, very urgent
- Advancing Timing on a 4.5 Gen.
- Can vq35 maxima use Utec?
- Tach Going Crazy
- Requesting: Available N/A Mods for VQ35, please
- need 00-01 max injector clips asap
- E-gas TB
- Vacuum leak
- Servicing camshaft and exhaust camshaft sprockets?
- out of my knownledge problem
- 4th Gen MAF mod
- New VQ35DE 4th Gen: Dyno Included
- Any opinions on this ebay FPR?
- EGR valve with 3.5??
- tranny fittment?
- De-K swap
- 95 pathfinder parts?
- needs some 3.5 internal
- what kind of power would I be looking at?
- Any dyno comparisons of 00vi with it tied open or power valve removed?
- Looking for the pros and cons of different cam setups.
- safc II question
- ignition coils Q for swapped 3.5
- 2k max w/ full bolt ons Q
- 2k-2k1 maxima 5spd full swap car doesnt run?
- Need some info
- PF throttle body
- knocking??
- Difference in blocks
- 5thGen Tunning/ECU
- 2004 vq35de 6 speed in 4th gen
- 5th on 4th gen clutch set up
- 2004 maxima 3.5 engine and 6spd on ebay
- Tear this idea apart
- 3.5 Clutch setup in 4th gen
- VQ35DE stock injector CC's?
- What's the most beneficial A/F ratio?
- Bypass switch for ECU's?
- Could I Get Pictures Of 00vi Please...
- Motor Prep
- Yea right, RWD maxima...but what IF?
- Ideal All motor screamer?
- Customized MEVI?
- Building a custom VQ35DE intake manifold
- 5 speed auto for 98 maxima?!?!
- DE-K or 3.5???
- Apex-i S-AFCII/V-AFCII settings for vq35! Post #s!!
- What's the VQ35 cam wheel look like?
- O2 Simulators or O2 Sensor Extension?
- Some engine build pics
- vq35 heads on a vq30?
- VIAS Stuck but NOT actuator cup? wtf?
- Dyno tune Q's?
- turbo XS UTEC fuel managment system...
- mevi Questions
- need help...fuel problem
- MAF code after vafc install
- What numbers are we looking at with Hybrid Engines?
- apexi power FC
- Consequences of running 3.5 injectors/3.0 ecu
- Poll- Send ECU back to JWT for reprogram of 290cc injectors or tune via VAFC/SMT6?
- I want to make my motor stronger
- MEVI parts that are needed to install
- since ppl in 3gen don't believe me how about u guyz
- How Does 1999 Emission vs 1995 Emissions affect Performance
- 00vi
- Engine Simulation Software
- Where to Find Cylinder Head Bolt Tool
- A32 5spd in a A33
- '00VI problem... please help
- ahhh!! transmission wont shift after engine rebuild!
- VAFCII/SAFCII owners, plz step in!
- DEK Swap Complete - Rpms keep bouncing between 1600 & 2400
- wut year 3.5's can i use
- 8600RPM I would have known by now right?
- Thread to consolidate info about SAFC/VAFC, SMT-6/7 and EU
- 00 VI injector problem
- Pathfinder TB for sale
- What's the deal here?
- emanage ultimate
- VQ30DE fuel rail in VQ35 engine
- who has a JWT ECU in their 97-98?
- Port and polish pics
- Pin location for VI on 2k2 ECU?
- will a z32 maf work on the 3.5?
- MSD RPM switch??
- 3.5 Engine in 4th Gen.
- 3.5 swap pics?
- Cheapest place for ENGINE GASKET SET
- A few 00VI questions....
- Loosing oil fast!!!! WTF!!!
- Compression Results
- Weighed a bare VQ30 the other day
- Yet another 00 vi question...
- New SFR 350z Intake Manifold
- What is the fastest 4th gen auto? Check out my Dyno
- Fuel damper?
- megasquirt?
- Old Project of mine might not be dead...
- Can the SAFC II be used to increase fuel economy??
- how much timing is added with SAFC?
- Will the car run without these?
- 00VI VIAS Question
- V-AFC VIAS Engagement?
- How to Tune Max w/ S-AFC II
- For all those who swapped engines...
- Engine Difference?
- OOVI SWAP: Need Grocery List to get everything I need.
- Need work done in OHIO
- ITB's?
- injector CC sizes.........
- anyone take out tb/manifrold spacer in 5th gen?
- Please Read....
- Vq35
- internals
- what are the vq30 and vq35 head CC's
- 2000 engine in 99 max: engine swap
- Motor Rebuild
- ve/vg hybrid
- 6 spd onto a 3 liter?
- 2k1 DE-L Motor in 97 - Now car wont start :(
- 3.5 problems
- anyone done an all out VQ35 swap?
- Helpful Info
- computer upgrades for 00 vq30
- rpm switch connection quick please
- VQ35 and strut bar?
- Sleeper cam suggestion
- Tilton 350Z Clutch/Flywheel installed
- Pic of my new engine (slapped a little paint on)
- Need help, inital setup for V-AFC-II
- 99.5 Se-l 00vi?? (ca/nlev)
- getting a 01 motor what should i do.......
- 2k Lower IM swirl valves
- Searching for 00VI in New Zealand, photo included, does everything look the same ?
- Ordered my 00VI DEK Manifold..Look what I got...
- Why no 00VI writeup?
- 00VI Kick-in Point
- VQ30DE motor swap/ engine differences?
- Auto to 5spd convert with horrible wheel hop... What to do?
- Better Power/times JWT or TECHNO?
- what else do i need for the 00vi swap?
- I bit off more that I can chew!
- ve mods?
- Good deal on used slicks
- where to find a MEVI gasket?
- VLSD 5-speed swap info
- Safc or Emanage for n/a?
- Voltage for crankshaft position sensor
- 00vi
- Weak spark??????????
- ? on SAFC tuning
- another 00vi question, bear with me..
- questions need some answers
- Skunk2 plenium spacer
- Transmission Shims
- Anyone who wants 3.5 cams installed
- Possible problem?
- VQ35DE in 2k Maxima?
- Cold Start saga continues
- My new all motor vehicle
- No spark on cyl 2&3, tested...coil drivers?
- Custom Internals
- Motor Mount Questions...
- Vi ?
- Signal Plate change for 3.5 Swap
- Vacum problems
- need help making decision, 3.5 swap
