View Full Version : All Motor
Pages :
1]
- 75mm throttle body adapter
- 1995 Maxima Engine
- 2005 altima to 2022 maxima engine swap
- 2nd gen vq35 swap question
- 11 maxima engine swap
- How to: Install a 6 speed in a 4th gen, 2023 edition
- 80mm tb
- 99 max with 2020 engine swap
- Questions about vq35hr swap in my 2000 Maxima
- Quick FWD VQ35DE generation guide.
- Thrust washers in the oil pan...
- Vq35 hr vq30 timing
- VQ20DE to VQ30DE swap
- VVT Question
- Maxima/Altima Extended O2 Sensor Guide
- Vq35 pistons
- Vq35de swap problems
- HR Heads on a VQ35DE
- How To - VQ35DE RWD Flywheel in a FWD
- Jdm VQ35 swap with 6 speed in A32?
- Spec V 6 speed swap
- 1988 Maxima Sell or fix? Engine VG30E V6 SOHC
- Raising the stock red line. Yayy!!!
- Advice for the next step on my car?
- HELP quick Please! Part ID for 6.5 gen engine rebuild
- What year pathfinder throttle body fit my 5th gen maxima?
- Is there any throttle body upgrades for the maxima 2000?
- 02 6SPD RMS replacement
- 2000 maxima test pipe?
- Full 3.5 Wiring Spreadsheet Anyone?
- 3.0 Timing to 3.5 VCT
- 2005 SE-r
- MegaSquirt on VQ35..
- Flywheel alignment
- Oil in intake/ smokes on right turns
- 3.5 swap harness confusion
- dek swap 280 hp build validation
- 3.5 Swap and Mods Need Tuned?
- 97 nissan maxima engine swap.
- 5mt transmission swap for Teana
- Do VQ35 stroker cranks respect the deck height
- no fuel pump power
- 5.7 gen datalogging wideband
- vq30 and vq35 headers are the same size?
- Q45tb on a hybrid hr
- JWT flywheel or Fidanza?
- Spun rod bearing in my VQ35. Can we use the crank in rebuild?
- 99 Max Swap Advice
- Stand alone help
- Nissan Master Trans Spreadsheet
- Work to mate RWD VQ with FWD drivetrain
- 03 max running to rich
- Horsepower for my anniversary max
- Help me customize my gearbox swap
- 07 Maxima ATF
- Rebuild or buy used VQ35DE for 02' maxima or Swap in 4.0 VQ40DE?
- 3.0 swap into a 5.5 gen
- HR head gaskets on vq35de? Upgrade?
- Plenum drilling
- 2010 Maxima performance upgrades. Where do I start?
- in distress! help with 5G engine swap in my 99 max
- can my stock 2000 maxima automatic use e85 flex fuel?
- Need new motor
- Light Weight Flywheel & Underdrive Pulley Info & install (2k2) (Picture heavy)
- 2k2 6 Speed Transmission Fix/Upgrade (picture heavy)
- might have found the rods.....
- 2nd gen vq35 swap in a 4th gen with 3.0timing
- Tuning a "stockish" engine....any point?
- JWT C8 cams
- IAT Sensor
- 1.5 inch Intake manifold spacer for more torque.
- Cost Effective Solution Please
- Lean and loss of fuel pressure
- Hr Swap Timing
- 7th gen swap
- 3.5 swap
- random info, could be pointless
- VG30DE- VQ30DE-K pistons
- N00B Questions on Building VQ30
- VQ35 Crankshaft In VQ30
- Can't get A/F ratio Stoich
- Cams, Pistons, and Rods
- 6mt swap question
- List of VQ30 All Motor!
- Vern's random questions about odd stuff
- 3.5 cell codes need help to pass inspection
- Vq35 CP piston in 30 block
- 3.0 freshen up
- Project Help
- 2013 maxima reflash no mods
- Six speed swap
- Purchasing Motor ?
- Cable Driven 75mm TB Installed
- Shoot me!! 3.5 swap help!!
- 7500 rpm valve train set up
- Will Greddy EU 5.0 gen PnP harness work on a 5.5?
- 4" Intake + 440CC
- Apexi Neo Steps
- EMU 2-Step Help
- Engine swap flywheel stuck. Help
- Fuel map and ignition map to my VQ35DE
- MS3 Pro..
- 7th gen engine/tranny into 6th gen help?
- Schmelly's 6MT swap
- At what rpm should I set a high stall converter?
- Stillen z350 high cap oil pan
- 3.5 injector wiring
- custom headers installed on 01 max
- 2.5 Liter Racing engine
- Block plate
- Paging Stephen Max or Tillys99!!
- 3.5 into 4th gen swap help!
- Help me!!! Try to set this timing
- Availability of Justt a Differential
- 5-Speed VLSD rebuild with part numbers
- Any people knowledgable with exhaust piping?
- vq35 internals. cams-less mild buildup. gurus please?
- Help locating Surratt's 2002 5.7 swap thread
- 4" Intake on a 4.7 Gen
- 00vi swap, maf sensor code
- 2J-Racing Side Exit Exhaust Installed
- so i wanna try to throw a 02 maf on a 4th gen
- 2000 Maxima 3.5 Swap Thread
- R35 oem fuel injectors dead times
- VQ35DE dimensions needed (flywheel/crank to block surface)
- hOPE FOR SOME HELP
- dek swap problem
- 6 SPEED swap question
- Is there a way to add an external trans cooler to the aw55-51?
- Drive by Wire Adjustment
- Dek swap no start
- belt size ?
- Trans 6 speed issues
- Quick, dirty, and somewhat cheap "HR" swap into 2002
- REV-UP/HR camshaft bolt drill?
- Need help!
- Jwt ecu
- EMU question
- Park and Neutral not showing on Dash
- VQ35DE - Replacing rings and stem seals.
- Vq35de issues
- "Improved" 6 speed in 4th gen swap procedure
- Vq30/35 destroked/hybrid, vq35, or 09+ swap?
- All Motor Upgrade
- deloa84's build??
- rebuild kit for 5 speed non vlsd
- ARP Headstuds Torque Specs
- megaphone ypipe
- VQ Injector Comparison
- VAFC tuning question
- e85?
- Next step
- advice on 3.5 swap cam setting
- dek swap
- 4th gen 95 ecu/harness tps with pathfinder throttle body
- 4th gen lim use on 00vi question/confirmation
- weak sauce manifold
- Forgive me but can someone match what 00vi setup I have pics...
- What is this noise?
- VQ35 cams in a VQ30
- 3.5 upper oil pan on a 3.5 swap
- can i use vq35 cam bolts on the swap??
- vq30 kelford regrind cams in vq35
- delete this one
- Double Shimming a VQ35?
- 3.5 swap problems- No fuel, no spark
- Sooo...5.7...and 6 Speed Swapped the car...
- Which Intake 00 Max 3.5swap
- Active test results
- 5.5 Gen Timing Curve - NO KS
- Do I need fpr on all motor build?
- coolant pipes
- hope for about 30/ 35 more
- performance chips
- Are RWD and FWD valve covers the same?
- What compression pistons for vq30 block and vq35 head?
- Engine Swap Advice
- 5.7gen: No start, P0340, P0345
- lowering base timing effect timing curve?
- 5.7 gen swap with head work
- weird AFR spike
- header wrap
- new project Maxima
- 110octane
- 00vi vias delete
- making. 62mmt/b. for the 4thgens.
- all motor upgrading, on a budget ?'s
- Not another teen 00vi! Pics inside!
- 3.5 swap starting problem. Need Help!
- 5th gens With VQ35 Swap
- VQ35 swap with 4th gen ecu - a discovery?
- which wire for vias activation
- What went wrong?
- Raising stock rev limiter 00max?
- Help! Stuck with: P0335 P0340 P0345
- advance flywheel question
- VQ30DE - need help with identification and parts
- Vq30de race boat performance upgrade ideas
- emanage ultimate usb driver?
- 2000 3.0 5 speed going to replace motor, what all do I need?
- Starting my VQ35 swap - question thread
- Using universal tractor fluid in auto transmission?
- What route should I go?
- Questions about 2007 altima engine in 6th gen/6spd
- can't make heads or tails of these numbers(stft and ltft)
- OEM airbox volume difference from '95-13?
- Need Performance HELP
- VQ35DE/HR hybrid part2
- so i got an emanage ultimate
- Need to run mid to low 14's
- wide band air fuel question 3.5 swap
- A33 valve springs and A33 camshaft on a A32
- Help Guide: Help! I need a VQ35! Which Ones Will Fit My Car?
- New Car with EGR Valve Problem
- Rebuilt 00 5spd vs. used 01 vlsd
- vq35 manifold on a vq30
- Stripped bolt from clutch to flywheel - Help?
- HR heads VS Ported DE heads
- Who has a 4" intake on an 02-08 VQ35?
- installed safc2 now car wont start
- Sharing my build...
- pftb issue... any advice?
- E-Manage Ultimate Help
- Boredom post... cleaning LIM
- 3.5 swap and keep 4at?
- vq35de cam drilling question
- Coolant flow question
- good 3.5 transplant for 5.5 gen 03 maxima
- wiseco 11.1
- 7th gen tb idle surge question..
- Android Torque: $75 Bluetooth Consult Adapter
- Emanage Blue Capabilities????
- piston head quench?
- Metal in engine oil!!
- DEK + 6MT Swap
- walbro gss question
- 2007 Altima engine, 4th gen, 3.0 timing
- DEK Swap Questions
- Motors + Transmissions That I've Shipped
- 00vi Tachometer Voltage: VIAS control solenoid valve
- Sentra Bell Housing Swap Difficulty
- Weight Reduction
- Kinetix Intake Manifolds
- 3.5 swap backfire, hesitation, wont rev pass 4,000 rpm
- Ebay Clutches (XTD to be specific)
- New Custom Intake Manifold + 4" Intake + 2009 TB + LOTS OF NAWZ
- Which engine
- Idea for a custom intake manifold - looking for feedback
- 5.7th Gen#2?
- Oil pump flow rate??
