View Full Version : All Motor
Pages :
11]
- Considering the EMU as first performance mod
- shorter belt to run without a/c
- Extrude Hone a VQ35 Intake Manifold?
- Car doesn't go into gear when on - URGENT HELP PLEASE!!
- 00VI, Dosnt start unless I tap the gas.
- JWT cam discussion I'd like yall to join in on please....
- vq30 power!?
- all motor 250 to 300 hp?
- Technos. Ecu or afc? (02' 6-speed)
- new update on 3.5 swap (leak down test results)
- 4rth gen 5 speed in a 2000
- EU in but some problems
- MY 3.5 and 5 speed swap 55% done "I THINK"
- 00VI Swap Photo Gallery
- Manual tranny swap
- 1999 Wiring Harness & 1995 ECU
- How to check for TDC?
- Recommended Online Store to buy Greddy Emanage Ultimate ?
- idle issues - high after driving (PLEASE HELP)
- Who needs a VQ35...?!
- Can we use 350z Pulleys?
- 00vi
- VQ30 on VQ35.. timing cover questions..
- complete pics of DE-K swap
- Emanage ultimate question
- thoughts?
- 5spd Conversion Issues
- VTC Cam Angles vs RPM
- porting vg30e
- Tilley or anyone else near queens, nyc to do 3.5 swap for me
- best year 4th gen for vq35
- Has anyone noticed...
- I need more power
- Spare VQ30
- OOvi help.....
- VQ35DE INTAKE SHOOTOUT: FWD IM vs. Z33 vs. Z33 + MD Spacer
- getting a 3.5
- VQ35 into my Altima??? is it possible
- Set some new N/A 3.0L records today - ET & trap (if I'm not mistaken)
- 00VI w/ stock intake
- Problems with DEK swap...
- HELP!!! 00VI install gone crazy
- Hard start
- 00vi clutch issues?
- VQ all motor Questions.
- VQ35 swap questions - near swap date
- Possible MEVI modification?
- 3.5 Swap no start
- Dek swap questions..
- Technosquare ECU upgrade
- 3.5 motor swap using 3.0 cams
- witch wideband whit Emanage U
- 6 speed swap questions
- De-k Swap Ecu Issue
- Anyone with Pictures of DEK swap..
- Need some VQ30DE guys to do me a favor - coilpack related
- 3.5 swap issues
- DEK swap: Starting issue
- Where's the Sentra VQ35 thread?
- Oil Pressure?
- Valvesprings spec'd. Nismo, revup etc.
- 4th Gen Transmission Woes
- Should I get a VAFC2?
- emanage blue harness question(s)
- 5-speed AUTOMATIC on a VQ30?
- Tilleys cost for 5speed swap?
- SMT6 for cheap
- vq35 cam spacer???
- VQ35 - Which year was best?
- Emanage Ultimate is in !!
- compression test results
- VQ35 RevUp cams in non-Rev heads w/o machining
- 6spd, VQ35 swap on a 4th gen
- Ultimate vs. ECU+SAFCII ??
- Here is a head scratcher!
- 3.5 usable parts on my 3.0?
- Air-Fuel Ratio?
- Tranny gurus, please step in...
- VQ30 - what type of lifters do we have?
- Anybody with VQ35 Airflow Data ????? (NA of course)
- dek timing case
- aftermarket cams and vaccum?
- Q: 00 IACV removal?
- which axles for anniversay VLSD 5speed in a 4th gen?
- So I just weighted my VQ35 on a bathroom scale...
- 3.5 swap VI activation Rpm switch /safc/EU
- 3.5 Swap Water pump
- what version of EU supports timing and rev limit advance?
- 95-99 (DE) Block vs. 00-01 (DE-K) Block
- Altima gears in a 4th gen
- Do we have an injection off feature???
- 5 speed swap clutch pedal question
- Any one know about the VQ33?
- on the dek rpm switch
- need to find a fuel pressure regulator for sale for maxima
- need help with vq35 swap in a 96 max
- De-k Question?
- Leaded vs Unleaded Race Gas In Maxima
- DEK swap: Jumpy idle and knock... need help.
- SC'd 3.5L up and running (well kind of)
- 70mm Throttle Body - Will Nissan Frontier/Xterra Work In Maxima ??
- High-Flow Cat & Y Pipe Questions
- Lets Talk EGR !
- Couple of Motor Swap Questions ?
- NextGear Thermoshiled Intake Manifold Gaskets
- what parts have copper, brass, or bronze??
- How much money are we talking for a 4.0L vq35
- Car shuts down on me... '00VI related
- Cams w/ JWT Valve Springs and Shim Kit
- MAP/Baro vacumm hook up...
- Where to find ARP rod bolts for VQ35???
- TPS question (3.5 swap)
- 4th gen UDP compatible with VQ35??
- Another VQ35 Sentra swap..
- 240 HP plan
- Hardest part of the 3.5 swap?
- Has anybody noticed...
- upgrade injectors?
- 00VI EGR Guide Tube Question
- there should be more 3.5 swaps on 5th gens
- Thinking about buying EU, but I have no clue what the install is like
- First-timer/noob pulls off 00VI install...
- 3.5 VI activation?
- EGR w/ 3.5 swap question
- Question on VTC
- A/F ratio at Idle?
- What do you think of this AFPR for 3.5 swap?
- Port n Polishing 3.5 Heads
- where does this coolant sensor go on the 3.5?
- Pics of TopSecret Race VQ (ITB)
- Advanced Timing
- Problems after header install and vafc II question
- 00vi installed...have a problem...
- mmm 3 grand to spend
- 2000 DE-K: Pre-6/99 vs. post-7/99?
- wiring diagram for VAFC II on a 2000
- Genisys 2.0 Scan Tool-TIMING ADV.
- Question about 4th. Gen IACV
- Will this clear the vq35 swapped cars
- patch harness ?? EU
- 00-01 throttle cable bracket part number
- bare 3.5 motor or direct swap?
- VQ35DE Stroker Kit
- Plastic caps on fuel injector nozzles...?!?!?!?!
- 00vi and starting your car up
- Realistic to run mid 13's ?
- anyone used the msd 8950 rpm switch for the 00vi?
- Is it possible to use the 3.5 IM?
- Anyone need a Pathfinder TB Adapter Plate???
- which gas for technosquare ecu on 95?
- 00VI w/ Stock Intake
- another 3.5 4th gen up and Runnin
- Quick Question on the 3.5 in an 02
- Anybody know the specs on the crank bolt?
- Upper intake manifold
- quick question
- More timing thoughts and questions
- 3.5 swap question
- DE-K 01 in 97
- Quick Question about dowel pins in 3.5 cams
- IAB and PCV for 3.5 Swap
- updat on SC'd 3.5L
- Radiator design question
- Flycut cylinder head to raise compression?
- Tach Signal..
- My 95 isnt getting any spark
- New Generation of Vq35
- SMT for sale for those who dont check the for sale
- Any Write-Ups On The DE-K Swap?
- These are the right injectors right?
- Guys w/insane N/A setups
- Lower plenum butterfly valve removal?+ -
- check out my WB02 results!
- Pathfinder TB question
- VQ Sentra Swap Finished!! :)
- How much timing advance on a 3.0
- compatable MAF's for 3.5
- 3.5 crank pulley removal
- Rescaling the factory Tach?
- Oil in spark plug valve 4
- Fuel pressure/flow.
- Blown coils in a VQ35 swap.
- Successfully running 00 EGR/00 IACV
- New dyno with DE-K- 210 whp and 203 wtq
- 00VI install
- VAFCII Questions + Tuning Advice
- 3.5 Sentra Swap.. HUGE lack of power.. :(
- recycle the block
- Which o2 sensor wire to tap for A/F
- 3.0 is back in... and it wont start
- 3.0L vs 3.5L
- Pathfinder TB Adapter
- cold start issue.. DE-K in my 97
- TB/TPS question
- New Apexi AFC NEO?
- Mass Air Flow Meter from a 300ZX
- VQ40DE has anyone confirmed tranny bolt pattern?
- Anyone know why tilley is not answering e-mails or phone calls?
- DE-K swap in 96
- weird question about the MAF
- Using heads from other VQ35s
- New dyno after 3.5 swap
- igntion upgrade?
- EU can now read the VQ30 crank signal!
- Street Tuning discussions
- Finally done 01-DEK Engine in my 97 (Video)
- I want to learn about EFI tuning
- Emissions removal
- OOvi install!
- vafc questions
- New Toy for my maxima!
- VQ35 cams for sale
- anyone know of a good swap for the vq30de 4th gen
- VQ35/4th gen with 02+ auto tranny?
- Removing A/C this week, question on belt ?
- s-afc help
- Power loss somewhere.
- 3.5 swap help
- 350Z injectors with 350Z ECU?
- auto transmission cooler
- Power gains
- made my own iacv cover plate (Pics) :X
- VAFC-II Problems
- AHHHHH so many vacuum lines on the 00vi which to keep which to remove ?
- IACV Adapter Plate
- Wideband o2 decisions, decisions, decisions
- MAF percentage correlated into power gains?
- Fuel Cell Install
- **DEK Swap**
- 3.5 swap
- altima 3.5 header+y pipe for maxima???
- 00VI swap question
- Valve Train Questions
- VQ35DE piston bore
- 3.5 Downtime Question
- Kinetix IM for FWD VQs
- Would you be interested in an intake manifold?
- Cattman headers for sale
- It's alive!!! 3.5 swap with cams
- Question about plenum
- emange ultimate + fuel upgrades
- 4th gen tranny, weakspot?
- VQ30 auto possible to hit the 14s with boltons?
- 350Z Plenum Installed *Pics*
- 4.3 Stroker in 4th Gen
- *HEADERS POLL* VOTE and please COMMENT on your choice; for a 3.5 in my 4th gen
- a/f tunning from a stop
- To sell or keep :(
- clarify please:what year headers? to go on a 3.5 IN my 4th gen..97-99, 00-01, 02-03?
