View Full Version : All Motor
Pages :
4]
- Camshaft Confusion.
- Anyone running a SMT6 on an 04 maxima?
- GUTTING CAT
- ??00VI on a VQ35??
- stright forward cam info
- Noob when it comes to this topic...but here to learn more!
- Acid Washes and Chemical Baths for Internals
- Pathy TB Questions
- DR Mod w/ VB Mod?
- acl bearings for vq30dek
- Technosquare or UTEC?
- Do you guys knew about Cosmoracing parts??
- Unorthodox Crank pulley Question?
- Valve spring installation, my pickle.
- Death of a VQ35DE....(semi winded)
- 09 Maxima Upper Plenum
- VQ35 problem(s) 5.5
- VQ35 intake manifold on a VQ30DE, ever done??
- VQ30 Patch Harness
- Has Anyone On The ORG Successfully Installed VG33E Heads on VG30E Block?
- JET VFORCE Plus? thoughts?
- Building 4th Gen motor for 7k+ RPM?
- Tuning Noob here... help
- 80mm throttle body on eBay
- Meth/Water Injection Install N/A
- Anyone ever use Q45 pistons rings 93mm or Any aftermarket rings on a dek
- 00VI Masters Step In
- VQ30DET Crankshaft.
- DE-K done now thinking z32 MAF...
- need help 3.5 findanza flywheel + 3.0 timing ring
- Any one know what a Built 3.5 compression psi would be per cylinder?
- HR Valvesprings, Retainers, and Seats Compatibility
- Questions about tuning for DE-K injectors
- question?
- 00vi not opening
- 4th Gen Fidanza Flywheel not fitting on Crank Shaft
- 99SE auto-to-manual swap, any difference from 95-98??
- BB MAF setting for DE-K on Greddy EU. Cat recommendations
- EU Data logs needed
- my 00vi swap issues. lots of smoke
- 3.5 with 3.0 heads compression ratio?
- VQ35 VAFC settings?
- shadyonedeath's 00vi swap - 1999 SE-L
- Rb26 maxima
- E-manage Ultimate Reliability...
- Problems with Primary O2 sensors after header install
- 3.5 heads on a 3.0 block?
- Urgent E-manage Ultimate HELP!
- 5.5 gen 6 speed swap electrical questions
- WOT question
- Weird Issue with the Cranksensor
- finishing up my 5.5gen into 240sx swap.. need little help on things
- Finishing up DEK swap.
- VQ35 swap, cold start issue, P0300
- Am I understanding the operation of the 3.5IM VIAS correctly?
- I bought some Headers w/pics - have you guys seen these?
- Dual CAI
- Preparing for Dyno day--AFR
- Completed 3.5IM install with pics of custom IACV/TB mounting plates on intake pipe
- Where the hell is that thread that shows what you have to do to the 3.5 throttle body
- Will 3.5IM work with VQ30 rear coil packs and VQ30 rear valve cover?
- Two I/J Maps Open at Same time= problems?
- Does anybody need VQ35 swap parts? ECU, NATS, Ignition, Key, Cluster, eGas Pedal
- JWT ECU - is it worth it?
- SAFC Wiring on 4th gen
- 00vi randomly stopped working
- Injector Question
- Wideband question
- Ipod/Iphone OBDII interface
- 00VI not activating
- Timing advance in 4th gen
- 6.5 gen motor in 5.5gen having issues
- Please check my timing installation
- PPL who did a DEK engine swap, I need feedback~
- 4.5gen dyno Numbers (3.5 swap)
- Stange problem
- 3.5 Swap from a 2009!!
- complete motor and transmmition convertion help?
- When in park and rev, car wants to cut out
- Building a new car
- Curious: Has the VQ been used in any marine applications?
- Innovate-LC-1-Wideband-o2-With-Db-Red-Gauge-UEGO opinions? help?
- Future swap
- UpRev Cipher question
- 3.5" Intake Tubing
- Return style set-up on 3.5 questions
- Please read....Want to change engine harness to run upgrade ecu....
- 3.5 swap fuel line routing
- I need your 00VI setup pictures!
- Breakout Box (BOB Box) for 88' Maxima
- Stalling/idling rough/reduced driveability w/ broken ECTS (Coolant Temp Sensor) wire?
- 3.5 WITH working EGR
- VAFC to VAFC II?
- 00VI Swap
- a few timing questions on the 3.5 swap
- Kevin's VQ35 Cam Build
- Car died. Need assistance
- 00vi question
- AFR Tuning on Stock Catback?
- Any good DIY SSIM writeups?
- Kelford cams for the VQ35
- Cams
- Using Suprastick as standalone unit
- DE-K big maf/PF TB vs DEK TB
- EU tuning pass stock DE-K ECU cut off
- Best tuning gear for Auto
- emanage
- soooo am i reading this correctly?
- compression test on 3.5
- Greddy Touch
- DE v DE-K
- VQ35 Swapp Help needed:IAC / EGR / CEL ??
- Wanting to catch up on regular maintenance.
- vq35de in a 02 nissan sentra
- Individual Throttle bodies??
- 4th gen full 3.5 swap engine/trans question
- When will the 3.5swap give me a break :(
- 3.0 swap - no start
- Requesting GURU help from Jime Jclaw Nismology
- no start 3.5
- Add-to-sticky Request
- 3inch MAF ridiculously lean!!
- fpr problems with 3.5
- 00VI owners using the A32 lower IM!
- Swapping a 6spd in 5.5 gen (?'s)
- Whats the best way to Build a FWD VQ35 Block
- 00vi swap
- So the build begins...
- no replacement for displacement(sextima)
- vq35 with a mevi??
- UTEC install finished. Pics
- DEK w/ DE components.
- Weight reduction: ABS delete
- Ebay "supercharger"
- Quick Emanage Ultimate Question
- cant get rear timing cover off
- 3.5 coolent line plug?
- MEVI - Stock ECU
- 3.5 swappers come on in
- vq30 5th gen 3.5 swap differences etc
- NEED HELP: Would 2006 G35 rev up pistons and rods work for 3.5 build?
- Scored a 08 Altima VQ.. :)
- DE-K with usim
- thoughts on FPR
- VQ35DE oil pump limit and Rods vs Rod bolts
- fuel feed line and fuel return line
- grey99max building another 3.5
- DEK injectors and rail on 3.5 swap
- Fuel Return to Returnless setup
- MAF/ Intake question/advice
- 3.5 swap hesitating going over 100mph.
- Another Completed Swap
- 3.5 swap.hesitating/misfiring
- QUICK HELP! '08 3.5L
- cant get front timing cover off 3.0
- Replacing Rod Bearings. Easy?
- 3.5 Throttlebody Setups + a few issues
- Full race cams
- 3.5 swap jumped time during water pump repair
- NEED HELP WITH VLSD SWAP IN 99. STICKY CONFUSED ME
- Tune Jumping?
- Emanage Ultimate Help
- 4th gens with 5th gen airboxes, please step in
- Cam Gears
- Potential 3.5 build
- 3.5 swap/DEK swap with NO codes?
- Confused: IM ssim, kinetix, Pelnum?
- 3.5 question for the guru's
- 2000 IACV with dek swap on 97?
- Guy claims 286whp, with intake, headers + exhaust..
- 6-speed swap question
- vq35 in a 99
- VQ35DE OIL BURNER???
- Noob Question: VQ30 JWT Cams
- Another 3.5 swap!
- TS Flash gas mileage
- pathy and 5.5 gen iacv setup
- Trying to pass emissions on a 3.5 swap.
- Timing Case Issues...
- List of things you will need for HR pistons in a VQ35DE
- Debuloz Cams
- 2000 max and want to swap for a vq35
- Vq30 heads on vq35 block
- CMPS problem. HELP!
- 4th Gen DE-K and Tranny swap Q's
- NEW CAMS ?????
- S1 Knock off cams?
- TS L-spec+AFC vs UTEC (5.5 gen)
- Cause of broken buckets on exhaust valves
- VQ30DE-K OEM Piston Ring Material
- 04Motor Swap- Old Motor 100K, New motor 17K!
- suprastick owners step in. TC lockup question
- Ignition Timing Problem
- A-Pillar dual pod 5th Gen
- automatic engine/ manual car
- AFR Help
- 07 altima engine
- Re-strating issues when travelling short distance
- SG Motorsport RWD VQ35 headers
- Opinions on 2 1/4 y pipe
- New OBX design
- NA 4.5 Gen Ignition Timing Advance
- 2 quick vq35 swap questions
- has anyone fixed cold start issue on the de-k motor?
- Question on 3.5 Pistons.
- N/A VQ37HR FTMFW
- My VQ30DE Build
- MEVI ?
- VQ30DET Intake Manifold
- 3.5 swap in a 99 SEL cali-spec
- My winter project -maybe. What year is this engine?
- WTF!!!!! SES flashing in idle
- Oil catch can questions
- Motor swap from 5th gen to 5.5gen...even worth looking at?
- VI Activation
- what exhaust size
- Suprastick Vehicle Speed Help
- VQ35DE in a 4th Gen
- help with 3.5 swap finishing touches
- Our Spec V HR/DE project runs 12.20's @ 110+mph!!
- My 3.5 cammed DEK swap...long
- The differences between the non-revup and revup oil pumps
- High compression/cammed VQ35- Spec V swap..
- HR pistons in VQ35DE block.. no go without mods..
- HR pistons?
- tuning questions.
- Injector Lag Time
- Ruh-Oh, hesitation and jumpy Fuel Pressure at low rpms!
- Wideband Problems
- Feedback on JAW: Just Another Wideband
- 350z intake manifold on 5.5gen, pics inside...
- Stock 3.5 IM vs. VIAS delete vs. SSIM dyno comparo
- vq swap questions
- Auto to Manuel (99 SE) (Noob Status)
- Install a tranny and now no start
- 00VI low idling issues!
- camming my dek. cant decide which
- Is my wideband not working?
- No start issue after motor swap
- Miami's Turn for a Build
- Quick, Important Question
- No spark 4th gen
- Highest i can safely rev a mostly stock 3.5?
- 3rd gen VQ35DE Full ECU Swap Progress Thread
- PISTON SIZE AND COMPRESSION?
- So what ever happened to this folks???
- any NA vq30 hitting the 300hp mark
- '00VI Swap Information
- 5-Speed swap in 5.0 gen
- Car won't crank
