PDA
View Full Version : All Motor
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15
  1. stroker???
  2. Can any of these codes be NA power robbing?
  3. DEK Engine in 4th Gen..Anyone Do It !!!
  4. Before & After VI swap dyno
  5. SAFC II, SMT-6, SMT-7 What's the scoop?
  6. Whats Needed for VI Swap ??
  7. 00vi cali or fed spec?
  8. Smt-6
  9. 00vi help!
  10. Guys that have swapped over to the VQ35
  11. Seeking advice during Valve Cover removal
  12. RPM Switch Reliability
  13. Where to buy engine?
  14. Mix and Match coils
  15. Tuning, A/F Ratios, Etc What's the deal??
  16. 00vi swap, how to avoid grinding coil mount towers
  17. 300zx Ecu conversion
  18. vq30 w/ vq35 cam spacers
  19. ?'s on doing a VQ35 swap?
  20. Looking For Someone, Anyone To Make 00vi Adapter Plates!!!
  21. do you agree with jim wolf?
  22. Production Date Mystery
  23. help,lost hp. with headers
  24. How to make 2k2 VIAS work
  25. SMT-6 gains !!!
  26. Need info about running W/O EGR.
  27. VQ35 swap pictures
  28. Need IACV adapter plates, who makes them?
  29. Anyone run a 4th gen w/o the coolant lines on the TB?
  30. True dual straight pipe?
  31. Weird VI swap issues
  32. VQ35DE Stroker kit anyone?
  33. JClaw/Nismo3112
  34. 4th gen 3.5 swap: Stage 2 LTB fitment?
  35. Help: Atlanta Georgia: 3.5 swap on a 4th gen
  36. Pics of DE-K swap into my 96 I30
  37. 2k3 VG33E xterra engine w/ Blower
  38. If you have installed the 00VI on a 4th gen, please answer poll
  39. 300ZX motor
  40. 2k4engineswap
  41. Rough 00 VI How-To
  42. Rev limit...7000RPM or 7200RPM
  43. VQ Engine Specs
  44. SAFC owners: what MAF % r u getting?
  45. SAFCII issues
  46. 4th gen with 5th gen fuel rail - damper or no damper?
  47. Mevi Activation Light (those with one)
  48. Cam Testimonals
  49. 2003 vs 92 se engine
  50. new injectors what kind to get??
  51. 4th gen knock sensor on VQ35!
  52. What kind of work should I be expecting (VI)
  53. OIL Pressure Sensor
  54. my new ecu in 99
  55. So what does the stock MAF max out at on an NA car?
  56. compression ratios
  57. Rebuild
  58. ARP VQ35 rod bolts....$125+$6S&H
  59. Stupid q.... mevi + 3.5?
  60. would hot shot headers for 3.5 will it a 4th gen
  61. Advanced timing through manually adjusting CAS,possible?
  62. good engine books?
  63. will 3.0 headers fit on the 3.5 bottom end?
  64. VQ30 = Interference?
  65. Port And Polish
  66. Next Best Mod?
  67. 00vi
  68. 2K motor swap
  69. Tranny ques
  70. Is It Worth it ??
  71. 3.5 swap
  72. VQ Intake Generations Questions
  73. VQ35 up and running!
  74. Fired up the 3.5 Today, little bit of smoking
  75. swapping ecu's
  76. Old idea, but has it been tried? 2k3 Path IM...
  77. Would a SAFCII help me N/A?
  78. Is there a height difference between DE and DE-K lower IM?
  79. Another 3.5 up and running
  80. Re-use 3.0 oil pan?
  81. Electronic Exhaust Cutout
  82. 2000 VI and 4th gen lower IM for sale
  83. Can you post your hybrid motor config? (Block config and manifold)
  84. VI swap misc question
  85. Alti guys talking to Crawford Z about a plenum ..
  86. Tested: 04 VQ35 IM on 98 VQ30
  87. 3.5 swap w/ ecu & e-gas - no full car re-wire
  88. 3" exhaust piping on n/a engine
  89. Anyone know if a Pathfinder VQ35 Block will work for VQ35 Swap in Gen4?
  90. OBDII -> OBDI conversion
  91. The weights are in (valves)
  92. not sure what the problem could be
  93. mild A.M. set up need advice or opinions
  94. 00-01 engine swap into a 4th gen ???
  95. IM talk years 95-05
  96. Unichip
  97. B Pipe
  98. vq30det intake manifold, anyone got one?
  99. Non LSD 5th gen tranny swap question?
  100. 2000 vi swap pictures
  101. Swapping fuel pumps
  102. Start up problems
  103. can I use 3.5 from 350Z
  104. 00vi
  105. VQ35 cam spacer dimensions
  106. timing advance and VQ35 swaps
  107. Need help
  108. high compression or low compression engine...
  109. Another modified 00VI
  110. motor swapping a 95 with a 97 has it been done ???
  111. Will somebody confirm this? (Related to VQ35 swap)
  112. Where to purchase a VQ35DE?
  113. Timing chain tensioner help
  114. 1995 Fpr
  115. Timing Chain installed Correctly?
  116. Intake Manifold options: 2004-2005 Maxima
  117. 04 IM on 97 VQ, long story short?
  118. wideband comparisson NA 3.0 ?
  119. 2004 Vq35de
  120. Question on installing a 00 tranny in a 96.
  121. VIAS timing
  122. I'm sure this one will get me flamed but here goes...
  123. Factory Fitted Mevi - MEVI Experts please.
  124. Vehicle speed sensor location??
  125. How does this sound.
  126. Front crank pos.sensor necessary?
  127. Need massive cam/VTC info
  128. JWT ECU "the big 8" by-pass?
  129. Deck height adjustment - VQ33 stroker
  130. Guaging interest in manifold flanges
  131. VQ30 Pistons and Rods
  132. wtb vq30 low mileage motor and 5 speed trans
  133. My New (used) VQ
  134. VQ35DE: Question about fuel rail
  135. VQ30 liner thickness?
  136. 00VI Installed Wierd Idle Issues
  137. Building custom intake manifold
  138. calling exhaust gurus.
  139. TB Question
  140. 01 motor in a 98 with 6 speed
  141. All Race NA 4th gen 3.0 update.
  142. Will this work? (fuel)
  143. mafs
  144. VQ35 O ring?
  145. What is the difference between Pathy heads and Maxima/350Z heads?
  146. Different Hybrid Setups
  147. has ANYONE DONE THIS
  148. 00VI How To?
  149. Newb ? about 3.5 swap
  150. 4th gen tranny
  151. HELP on headers installation?
  152. Anyone done any engine TUNING to their max?
  153. how to clean rust from water jackets??
  154. Summit RPM switch
  155. 3.5 5 speed trany in a 4th gen
  156. Would the VQ40 be a worthwhile swap?
  157. Tune-up
  158. Hotshots are on 2000 fed spec WOOOOTTT!!
  159. Will 3.0 lower IM bolt up to 3.5 heads?
  160. What can cause a motor to eject a rod and can this damage a tranny? PICS
  161. engine balancing?
  162. Who wants to control RPM changeover and A/F mixture with one device?
  163. problem with eagle rods
  164. what needs to be fabricated for 00vi?
  165. Lets talk Fuel Pressure Regulators
  166. Car won't start after installing 00VI
  167. Vq35 Tranmission
  168. 00VI question...what to do with these?
  169. Big headache here (3.5 swap). Anybody's help appreciated (Tilley, SR20DEN.
  170. E-GAS to cable TB in less than 20 minutes!!
  171. Help with instilling a 00VI
  172. Help, some problems w/01 vi swap
  173. 00vi
  174. 01 motor in an 98 with 98 mevi
  175. Newbie question about the 3.0 to 3.5 swap.
  176. 02 VQ35DE Engine wiring harness Available.
  177. another job
  178. engine work
  179. 00vi writeup anywhere?!
  180. Another 00vi installed
  181. 2001 setup???
  182. Why do 3.5 intake cams have to be modded to work in VQ35DE going into 4th gen?
  183. Tuned my SAFC2, found a few more hp
  184. Making NA history March 11th
  185. need help on some diagnosis
  186. Two ECU's
  187. VQ30 w/VQ35 sleeves/liners possible?
  188. quick ? vq35 pistons and rods in vq30
  189. 95 Steering column (for swap)
  190. OEM VQ30 cam needed
  191. Important question about RPM sensor
  192. Vq35
  193. Need help with my 00VI!
  194. 2000 engine in a 98
  195. Want a VQ35 in my '98
  196. How to make '00 VI work with 3.5?
  197. 2k1 motor in my 99, what else do i need
  198. Fuel going to be ok?
  199. Fuel pump worth it?
  200. Getting the 00VI on my 97
  201. Advice on headers install
  202. Crank shaft Knifed Edged?
  203. Yet another, 00VI question
  204. New and "improved" 2005 VQ35 Rod Bolts <$30
  205. TS ECU with upgraded limiter is complete :)
  206. new at NA forums...
  207. Darton mid sleeve kit
  208. JWT cams for VQ35
  209. Nissan Consult
  210. Somebody throw this in a 4th gen
  211. EVO II (Wanna be) Didn't fit so well
  212. which new parts for cam install?
  213. ARP rod bolts "NEED INFO"
  214. FrankenVQ
  215. Head talk
  216. Sizes of Various Throttle Bodies
  217. NA 2002 Maxima goes 12.859 @ 108.00
  218. Car is going under the knife need advise
  219. auto to manual swap questions
  220. Pathfinder TB for sale
  221. ecu question
  222. Extrude Honing
  223. Frontier
  224. Removing pre cats on 02 3.5
  225. Difference between the 00vi and mevi
  226. what can i do...?
  227. Whats the best NA IM design??
  228. Exhaust gas velocity ?
  229. MAF opinions?
  230. VE on our VQ?
  231. 4th gen MAF?
  232. 2000 Maxima motor, Will it bolt up to 95' 5speed Tranny?
  233. 00 VI question
  234. Basic VI checklist with some questions
  235. Is there a writeup for '00 vi on 4th gen?
  236. 2k1 5spd Fuel Cut Increase?
  237. AFC wiring
  238. VG30DE vs VQ30DE? 300ZX motor top-end swap..
  239. VG30DE vs VQ30DE? 300ZX motor top-end swap..
  240. Compression testing
  241. VQ35 Piston/Piston Ring Options
  242. NA fuel upgrades.
  243. New To This...need help.
  244. all motor with greddy emanage
  245. Question on 97-2003 custom max. straight pipe?
  246. Throttle Body
  247. VQ35 in 2k max?
  248. 01 cams
  249. 3.5 down!!!!
  250. Speculation at gains on a VQ30 just from stock VQ35 cams?
