PDA
View Full Version : General Maxima Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. I use Walmart SuperTech oil and it's absolutely fine.
  2. HD Radio Artwork
  3. The Beginning Of A Much Needed "Revival!"
  4. Revamped 240z?
  5. steering problems after strut assembly replacement
  6. 02 Maxima P0159
  7. 2014 maxima wont reverse
  8. Windshield hit by rock
  9. Exhaust Compabilty
  10. 2010 nissan altima. ALL power windows roll up slow
  11. 01 maxima reading codes P1610 P1611
  12. Nissan set to discontinue the Maxima
  13. LED Headlight kits reviewed and tested
  14. 6th Ram Air
  15. Water leak on passenger side after rain
  16. Speaking Of Photobucket ...
  17. display reboot maxima 2016
  18. Extended Warranties Good or Bad
  19. Brake cleaning
  20. Carlos Ghosn . . .
  21. 2011 Maxima footwell light
  22. Stuck in Park/No Brake Lights
  23. wont start
  24. OEM Car Parts
  25. Any updates/reveal date for 2019 A35 Maxima?
  26. Speaker's
  27. 2002 maxima
  28. Blower Motor
  29. Nisaan Maxima 2002/03 Halo ring
  30. Need brake help
  31. Carfax question
  32. wire gauge, strands, amps, volts, speaker wire,
  33. Which one I like both?
  34. Rebuild door hinges !!
  35. 2016 or 17 Nissan Sentra navigation head unit Nissan part number 259153sg0b I'm havin
  36. Oxygen Sensor =P0134 problem/fix
  37. Dirty engine
  38. Discount Tire
  39. P0110
  40. HPTuners now available for Nissan
  41. Hey everybody! New here
  42. Need help on how to remove overhead console in 2007 Maxima?
  43. BEFORE I SCRAP My 04...
  44. Welding up a low pressure AC line - has that been done?
  45. Toyota vs Nissan CVTs??
  46. Does a 6th gen maxima seat fit a 5th gen
  47. Which Maxima Generation is the Best and the Worst
  48. Transmission Video of My 2003 Maxima it it working right
  49. Headlight help
  50. Need help
  51. Idles crazy... Maxima
  52. Tenneco buys Federal Mogul
  53. Light theme for the forum possible?
  54. Maxima - Slip - Brake - ABS- Traction Lights Stay On
  55. Nissan vs Honda in Reliability....
  56. Consistency in the simulated shifts
  57. Performance, handling, and general enjoyment of 3rd gen vs 4th gen
  58. My 1997 Nissan Maxima with 2701056 miles runs strong
  59. New cars are too computerized/complicated to work on
  60. Fuse having acid around them
  61. Engine swaps on 2000 maxima
  62. ProPILOT in a Maxima--when?
  63. Solenoid Failure (Bad Oil Change?)
  64. Humming/road noise sound that doesn't increase with speed!
  65. Please Help... Good or bad deal
  66. P1335 Error code Nissan Maxima
  67. Nissan maxima 97
  68. How to do 3.5 block with 3.0 head?
  69. Die cast model!!!!
  70. 04 Maxima dilemma. Need help?
  71. RIP Raceway Park, Englishtown NJ
  72. Fast program or parts catalog??
  73. Fuel Pump
  74. Grinding noise after doing clutch... [5th gen]
  75. Maxima MPG 2013
  76. 2001 Maxima 20th Anniversary Radiator Support Advice
  77. Overheating / Cooling System Basics
  78. Black Dust on drivers seat
  79. 2004 nissan maxima acceleration issues
  80. Why you decided to buy the Maxima?
  81. Moonroof question on 87 SE
  82. VQ30 RWD Conversion (not into a maxima....)
  83. What should I do with my car?
  84. B-Pillar Vibration
  85. Whats on your keychain?
  86. Tranny Rebuild Suggestions
  87. Strange noises at idle
  88. tire has no date code? and cracking
  89. 6MT Shift Control shaft seal
  90. New member, would like opinions and thoughts on the 3G Maxima
  91. Motor swap
  92. Where to buy an OE radiator- 2010 Maxima
  93. Mass airflow sensor gasket?
  94. blow by on 4th gen
  95. Rust repair thread
  96. Successfully fixed a fuel lid (transplant) and repair
  97. Initial impressions on installed BS Racing Coilovers.
  98. Body needs work, rust mostly
  99. Nissan
  100. difference between kill(all) and kill(labels)
  101. Access Denied in Windows 8.1 for stringout
  102. Truck eats Maxima, driver fails to notice
  103. The 8th Generation Maxima
  104. New Person Thread/Question
  105. Gps unit on eBay?
  106. A word of caution: Even the newest Nissans/Infiniti ain't bulletproof
  107. Anyone have problems with Remin or B and I wood kits in the long term?
  108. New Max buyer questions?
  109. Hello, it's me.
  110. Parasitic Draw
  111. ma
  112. Toe Out - How much to create Severe Tire Wear?
  113. OBD-II devices and battery drain
  114. Engine noise?
  115. Under Engine Splash Guard
  116. Maxima.org App & Forum Runner Problems?
  117. Can anyone ID these rims from the photo?
  118. Need help on my 5th gen
  119. I need help egr problems
  120. Something is running when car is off
  121. OG's Chime In: What are you driving these days
  122. Suspenion Pros and Cons
  123. front seat wiring help
  124. NZ/Aus Maxima J31 2008
  125. New here ( why maximas get no love )
  126. Odd fender question for ya.
  127. I'm new here
  128. VQ 30 DEK in Ford F250
  129. 1998 Maxima Rear Lights
  130. SUN shade
  131. HID issues: Can I use aftermarket kit in my car with FACTORY HID?
  132. gold star(s)?
  133. 2006 maxima noises at 60 mph
  134. Factory extended warranty pricing
  135. 98 maxima
  136. 2003 New MAF, Shifts smooth, still pings!
  137. Rough start
  138. Transmission problems after engine swap
  139. CPU display gauges
  140. 05 maxima not shifting??
  141. Fog/ low beam headlight bulbs
  142. 2000 maxima
  143. Generation 5 RWD Conversion Kit
  144. Manual transmission shifter bracket?
  145. Service engine soon
  146. First Maxima Ever At Gumball Rally
  147. The future of the Maxima (2018+)
  148. Lost my Maxima Today
  149. ECU tune after exhaust/intake thought
  150. Actual gear indicator for 4AT
  151. neutral safety switch alignment 02 maxima auto
  152. Fuel Injectors
  153. Oops....did that just go down the intake manifold?
  154. How to find E85 ethanol gas stations?
  155. Ignition
  156. Road Trip
  157. Aluminum Wheels -- Please Help!
  158. Car specific tool box
  159. Crank issues
  160. Maxima.org needs a new banner - Can you help?
  161. Power Steering hose leak issue in Maxima/Infiniti
  162. cup holders
  163. What kind of paint should I use to paint an engine bay cover? Also brakes?
  164. Allmaxxedout
  165. 4th Gen Max, 5.5 Gen Max, or Infiniti G35??????
  166. Prospective Buyer - 4th/5th/5.5/6th gen comparison
  167. Interstate MT-25 Vs PF-24F
  168. Help in FL
  169. Air Intake Hose - Lubricate to get back on?
  170. Who has remote starts?
  171. possible fuel pressure regulator fix
  172. Endless Maintenance Manuals!!
  173. Matrix of differential operator
  174. Thinking of selling out...
  175. Nissan MT Notchy
  176. Experiences with Small Tire Shops vs Garages vs Dealers
  177. Lowering your car
  178. Bye Bye Max
  179. How to launch a cvt
  180. 3rd gen GEM on CL
  181. Vq40 throttle body and maf on my vq30
  182. Fuel sending unit
  183. Cam position stumper!!!!!!
  184. 2016 maxima top speed 134 is that it?
  185. octane in gen 8 2016 maxima for top performance
  186. Detonation - What it is, causes, avoidance, etc.
  187. Mode $06 ODB Scan Secret Values
  188. Opinions on CAI during winter weather?
  189. VQ30 Engine Pull
  190. carbon fiber brackets?
  191. site store
  192. vq35de swap
  193. Extended Warranty purchase
  194. Flashing or Pulsing 3rd brake light
  195. Pick 1 out of the 2 cars to keep
  196. Lost my key + key fob - 2003 Maxima
  197. What is your favorite little tree scent or air freshener???
  198. VQ parts swap.
  199. Rpm suddenly drops and car jerks??
  200. Aftermarket specialty air intake
  201. 2005 P0305 code repair
  202. The First Seven Generations of Maxima, Ranked
  203. Body kit Question
  204. Most rear seat room
  205. After market driving light problem
  206. 2011 ac issues
  207. 2001 max se sunroof problem
  208. Bent wheel, repair or replace?
  209. I need rear camber plates.
  210. Which would you buy? 4th, 5th or 5.5 gen
  211. lost key -> locksmith -> now original key dont turn in ignition
  212. Fog Light Wiring Harness Help!
  213. Tilted steering wheel
  214. obx/aftermarket header gaskets
  215. When is Nissan phasing out 6 cylinder engines?
  216. 1997-2003 which do you prefer?
  217. 87 octane fuel 97-03 damage engine?
  218. questions about rpms
  219. Engine power under 4k RPM seems low, need maintenance?
  220. Can anyone recommend a Consult Adapter
  221. rockauto.com discount code
  222. Bleeding Brake by Pumping into the Reservoir
  223. First Gen Rally Domination
  224. 2011 Maxima
  225. I am looking to buy Wheels
  226. Towing my 300zx with Maxima
  227. Looking for rebuilt transmission supplier and/or nissan Infiniti shop in Atlanta
  228. Will 2013 maxima tail lights fit in 2010 maxima?
  229. Intro and Questions. Motor swap time. BUT...On an ALTIMA SE-R
  230. Project Maxima: Best Generation to use?
  231. bad VQ30/VQ30DE videos?
  232. Maxima j32 compatibile with i30
  233. Air Bags
  234. Loud pop.
  235. L24E - Notched Cylinder Bores?
  236. Getting Pre-Cats from Junk Yard- Against the Law?
  237. Raised White Lettering On Tires
  238. Rear floorboard carpet coming apart
  239. 200,000 miles and going
  240. First time with no Max in the garage since 1986!
  241. reaching 300k
  242. Hello everyone!! Haven't been here for long time!!not a maxima but a nissan
  243. Walking Dead Spotting...
  244. Maxima Germany Plates?
  245. 2nd Gen Love with a little 1st thrown in
  246. SS Headers
  247. Maxima love
  248. Ignition coils?
  249. AAA services
  250. I'm back!!
