- Oxygen Sensors
- Looking at buying a 2017 Platinum (CVT questions)
- I want more! power!
- 90k Miles, Drive Belt Question
- is this a 4g rollout issue?
- 2016 Maxima SR stops accelerating
- Nissan Maxima SR Gurney Add on
- ATT 3G shuts down today
- Resonance at 1500
- Next Gen Electric Maxima??
- Does Nissan always give out your info to sirusXM?
- Recommendations for roof rack?
- Maxima 16 CarPlay Installing правильно
- Headunit Swap
- 8th Generation Fender Rolling
- Extended Warranty - living in Florida
- Maxima 16 SL - Switch Mirror Control / power mirrors not working
- Trade In prices?
- Doorlock Actuators
- Cruise control not working
- Does Anyone Know?
- VehicleAid Amazon Nissan Maxima Headlights
- Nissan Maxima Owner Notification letter Suspension Noise
- Rotors and pads recommendation needed?
- Rear seat measurement
- Regarding maxima GPS
- Frozen door handle
- Car making whistling sound while accelerating
- Maxima 16 SL - power mirrors now working
- This Sucks. 16-17 Maximas
- Center Console Controller
- Factory Window Tint Bubbling
- Any software updates for the 2018 Maxima Platinum since its been out?
- Minor door leak
- Higher mileage 8th Max owners out there
- 17’ maxima SR Clunking noise in trunk??
- So what's next?
- Anyone w/ Michelin Pilot Sport A/S 4?
- post some pics.
- CVT questions, and how do I check fluid level?
- 2018 SL - removal of Rocker Panel Guard - not moulding
- How many oxygen sensors in 2016 maxima sr
- 2017 Nissan maxima platinum undercarriage lighting issue.
- Nissan Maxima Eibach Springs Nose Dive Stance * FIXED *
- CVT error on OBD diagnostic
- Transmisión servís
- Opinions needed - Trying to Decide whether to get Bronze wheels or the OEM 20 Spoke
- Hi everyone.
- Volume button
- I'm back.....
- Must see video on CVT maintenance
- Xm Radio Programming
- Power Bar Display - very low reading
- My first Maxima: 2016 Platinum, have a few questions
- Mobile Pairing
- Infotainment Software Version
- 2016 maxima wireless charger ?
- 2019 Maxima Battery Drain
- Satellite radio issue
- Anyone use battery group size 24F instead of 35N?
- fed up with warranty issues not being honored
- 2016 Maxima slowing for no reason
- 2016 Alternator Change, Wheel Removal?
- Auto Zoom function in navigation
- 2017 Maxima dashboard failure issue
- CVT fluid sucked out at 42k miles
- Tune up for 2016 Maxima
- Headlights for platinum 2017
- Saying good bye to Nissan
- Mobile One Deal
- Car cover suggestions
- Infotainment USB/Aux Module Replacement
- Solid Airbag Light is on
- radio info
- Noticeable difference in mpg between 18 sv and 21 platinum
- Rear suspension link 10 year warranty extension
- Forward Emergency Braking Light
- Sunroof Jumps up when closing front doors
- need a fuse box diagram
- Touchscreen has gone blank
- Install speakers
- 2017 - Add vertical adjustment to front passenger seat or replace?
- Winter Alloy Wheels
- Shifting at low RPM
- lane keeping assist
- Body accessories
- i may be leaving the nissan brand
- 2016 SR - things to be aware of?
- X Pipe
- Control buttons don't light up at night.
- 2016 Maxima No front parking lights
- Key FAB replacement Maxima 2017
- Speedometer and Digital Speed Reading are Not the Same
- leak after hard rain
- Normal coolant temp
- Lowering springs GodSpeed
- The 2 USBs aren’t charging so well (2 hardly charges at all, 1 is a bit iffy).
- Coolant leaking
- Phonebook download
- 2021 platinum, forward collision light flashing
- Sun Roof Water Leak
- 2021 Ambient Light not bright
- Daytime Running lights fuse. Help
- Has Nissan Fixed the CVT Problems?(2021)
- a click sound
- Exhaust Question
- 2017 Maxima A/C reset problem
- CVT Transmission Fluid
- Where is key fob sensor?
- Worst Designed Car for Driving in the Rain
- Driver Daytime Running Light Stopped Working
- sd card for maxima 2018
- 2020 Platinum or SR options
- Any benefit to turning off active noise cancelation with the factory bose stereo?
- Swapping SV to SR steering wheels
- Key System Error
- Really loud vibrating from behind sunroof controls panel at 60mph+
- 2021 Maxima 40th anniversary
- Maxima 2009
- popping noise will drive you nuts
- Goodbye
- Sorry for the stupid question (HD radio)
- 2019 Platinum Vibration Issues
- ECU Maybe?
- front and rear sensor
- Just got a 21 platinum, question about the intelligent cruise control
- Drive Computer display appears/disapperas randomly
- questions on '16 maxima purchase
- The End of an Era
- Having trobule turnning off active sound management on maxima 2018?
- Maxima gas pedal
- 20"tires rubbing front liner
- CVT going out at 73K
- Nissan sent me a post card - the end of 3G
- Where to get aftermarket rear spoiler?
- Cruise control
- Help asap!!!!
- 2018 steering wheel removal????
- High pitched sound when accelerating
- CVT generation
- Battery light on 2016 maxima platinum
- Daytime running lights issue. Help needed.
- Painted Brake Calipers for 2017 Max
- Rear camera prediction lines gone
- AC question: 60 deg F? I want 50!
- '16 Platinum front sensor question
- Vibration in front end (‘17 Maxima SL)
- Powder coat stock rims??
- 2018 Maxima moonroof shade "knocks"
- Grinding noise from front
- Speaker System Install
- Passenger headlights fuse
- Android auto wireless, finally
- 16 Maxima Platinum
- Anyone tint their pano sunroof?
- Parking aid sensor
- 2018 Platinum wheel upgrade
- Do I have ambient lighting?
- Ambient air temp
- Clueless on what info means on my maintenance screen
- Drivers side Door locks
- WTB Interior A pillar trim panels 2018-2020
- Transmission fluid
- AC not turning on
- Cold Air Intake, Worth It?
- Car constantly having misfires
- What exactly does a art y pipe go?
- External ground lighting
- Question about headlight bulb type
- Start/Stop Engine
- Windows rolling down automatically after car is turned off
- Cvt transmissions and Amsoil
- BBK with 2016 SR Wheels
- Fob issue
- 2018 Max SV Looking for a few recommendations
- Front Adjustable Seay Bar links
- Tuning/tuner
- 2016 Nissan Maxima Nearly Stalls/Dies when starting
- Rear of 19 Maxima SL 'fishtails' over bumps?
- P17f1 code
- Track Times
- 2017 SL Steam Pump
- My 2017 max needs more power
- Eibach Springs 63115.140 KIT
- Legit or dealer non sense?
- Please do not let people tel you that you cannot tune 8th gen maxima
- 2017 headlight swap to 2020 headlights
- Rear pads and rotors with only 25k miles?
- A 2016 maxima does not run on water
- 2017 Bose bass sub cracking
- Nissan Future
- HKS Hi power Axle back
- Cruise control issue
- Best aftermarket rotors and brakes
- Usb 1/ Apple car play not working 2017 Nissan Maxima
- Possible rotor swap?
- Autoblog Review of Maxima 40th
- 2018 SL - can't remove Pre-Set radio stations
- Key fob battery low warning
- Trunk space with seats folded
- Motortrend Comparison Article: 2021 Altima vs Maxima
- Eibach Springs
- What is this button?
- Fog light bypass mod
- Do you ever miss your 7th gen?
- P1058 Code
- Are 7th gen and 8th gen aftermarket intakes interchangeable?
- Snow set up - Using 7th Gen wheels on an 8th Gen
- Add Heated Steering Wheel to 2016 possible?
- High erratic idle. Help please!
- Reliability and Repair Costs
- SOS Runaround?
- 2017 sv sub installation
- Halogen headlights
- 19 factory repair manual
- someone run out to your car and check something please
- Damaged rockers... again
- 21 Maxima Vs Charger- Good Article
- Help! Turn off notifications
- Headlight fuse number??
- SL stock wheels 18in
- New 20in Wheels
- Considering purchasing a 2020 Maxima SL. Concerns?
- 20" wheels good or bad 2019 sl maxima
- 8th Gen, 2018 Maxima Rattle over small bumps front Drivers Side, feel in gas pedal
- Driver seat adjustment forward and back word problem max 2016
- '17 Nav Unit -Installed in '16 - Now no Backup Camera
- Stillen Cat back exhaust..
- How many of you use the Car Navigation ???
- How to get Android Auto in a 2017 Maxima?
- Used parts maxima 2016-2020
- Navigation update
- Nissan connect
- Issue with locked door
- Weak heated seats
- IIHA Pedestrian Autobrake Test
- Sammy Says:
- Car doesn't always start. Brake light switch or a fuse?
- Mods and Tuning
- 2016 Maxima Whining Noise and Tapping Sound
- Brake Squeal
- 40th Anniversary in-person
- Replacement key fob in Canada, but don't buy from dealer?
- Premium fuel?
- Acura TLX A Spec
- Detroit Wheel & Tire Black Wheels
- Let the Fun BEGIN!
- Software updates
- New Wheels... thoughts?
- Headlights on S trim
