- wtb turbo reverse y pipe
- My Emanage Ultimate is here! -Part 2- *MAJOR UPDATE*
- Emanage map uploads!!!
- Spark Plug Problem
- Pistons!
- Key Replacement suggestionsfor the pulley?
- what do you guys think about this turbo
- VR4 injectors
- Stupid Ugly Supercharger Sound
- SAFC Adjustments
- is this anything new?
- vortech sfmu good?
- ebay pipes and fmic (your opinion)
- Need Help to find Z32 MAF...
- Emanage Ultimate Revlimit Works, but need help
- Belt shredding fixed FINALLY!!!!!!
- wow Stock ECU outperforms JWT ECU...AGAIN
- my 1200 bucks turbonetics shaft snapped
- New Meats for the Streets
- Vq30/35 and Garrett GT40 Series Turbos ?
- 1st Time at the track tonihgt
- Will These Fit?
- For those people who wants to Supercharger...
- SSQV on My Supercharger
- Stripped Timing Chain cover bolts / Shredded belts.....
- building a 3.5, or not... pro's and cons...???
- battery box pics please
- pic of the wideband
- Where can I get this? What is this called? Cost?
- How much oil with the SCer?
- Got my Zt-2 wideband and timming belt pops!
- Turbonator?
- walbro fuel pump, fmu, sparkplug question
- Dyno day dum dum dummmmm.
- Starting problem
- Wideband O2 sensor time
- 97max internals/tranny ques.?
- selling blower...
- 3.5L supercharger
- Need a new y-pipe
- SC Install help. Using Ptatoheds Write Up! Almost done, need help/advice
- compression high...
- Wideband or J&S?
- ok what to do with my wideband
- what else do i need?
- Roots Style S/c For A Vq30de?
- ptatohed's just-for-the-heck-of-it Cold Air Intake...
- Lame ET @ 119mph today at the track
- Replacing Belt need help
- how about this wide band
- Need Help Quick
- Fuel Pressure sender placement ?
- V2 idler tensioner pulley
- Curved discharge blowers
- Clutch Talk !!
- Should i get turbo or SC for my 5th gen auto?
- FINALLY...a 1:1-12:1 adjustable FPR
- u wanna stillen SC pipe??
- Does anyone want 00 Intake manifold??
- 2.62 pulley for sale
- 2nd Dynomax 3" Bad Again !!!
- new to the turbo world...how does everyone feel about this ??
- cam options Need to decide quick.
- what do you think of AEM UEGO Wideband
- Clutch question
- $hit, what pulley to use!!!!!
- Dyno Results 03/05/2006
- Would a wet nitrous shot max out a maf?
- wtb a 3.25 or a 3.33 pulley
- Manifold options
- Timing!!! 451/447
- Emergency Help Needed
- Stock ECU, Z32 MAF, 550's...explained
- In need of a suspension setup (boosted)
- Whose Max is this for sale? (turboed)
- Encountered one of these last night....
- Dynoing this friday again
- upgrade supercharger
- Dynoing Car This Sunday
- Cold Weather Start
- What fuel pressure regulator do you use?
- Do you guys feel ASP pulleys are just as good as Vortech pulleys?
- First dyno for the Max
- Nitrous/blower, fuel delivery Q
- G35 Turbo or SC fititng the 6th gen IMPOSSIBLE?
- Dyno'd today (pics)
- 2000 Max ECU cylinder map?
- Timing and SAFC corrections (data logs)
- Vids of my car...
- M90 Gtp Sc
- Injectors
- Fuel pressure regulator.
- gauge pod colors?
- AEM Wideband Controller
- 3.5L w/ SC is now underway
- post pic of your Js safegaurd
- How-to install...
- Stillen SC Charge pipe for 4 gens!!!!
- Please Help! Erratic ticking noise near my S/C!
- F.s. Walbro 255 Fuel Pump
- Advice wanted
- 3.5 turbo dyno
- Need help using greddy EBC...confused.
- 2.62 Advice
- Launnching with a boosted car. Techniques?
- Why a CCW Straight Discharge Blower?
- FS: Blitz Super Sound BOV - Vid Clip
- 2.62 pulley 4 sale!!
- Zeitronix and Serial to USB
- Amisoil hookup?
- alarm turbo timer vs stand alone turbo timer
- 3.5 swap worth it?
- FS: 3rd Gen Turbo ECU, JWT: 370cc inj.
- Blew the motor on the dyno!!
- Ultimate problems with emanage.
- exhaust question
- when do you usually start to pull timing...?
- Need help with gauge mounting
- Quick Supercharger Querstion?
- part number for 2000se 5 speed 17" ecu federal
- price Q on J&S
- since the tracks are closed....
- FS: Turbo Feed and Downpipe
- Advice needed!!! 2.62 pulley may be going on soon!!
- **Matty's SuperCharger Parts List**
- exhaust cut-out clip?
- Not shure what Clutch or Flywheel to get?
- wiring
- call it a ricer question if you want. bov?
- Please Help me Figure out this BOV problem ?
- HKS SSVQ BOV with Stillen Supercharger
- Emange Ultimate can advance timing...
- Code for Fuel Pump control module?
- Supercharger Question?
- Emanage Ultimate this weekend,woohoo!!!!!
- going to the dyno Saturday!!
- Anyone have HLH's compilation video?
- Cheaper price?
- Squeeling at startup with loss of power steering?
- Quick exhaust question
- The Wizard's and ptatohed's Water to Air Aftercooler project complete (pics)
- yup turbo vs s/c again!
- DIY supercharger rebuild
- Model # of V-2 Superchargers
- Highest HP daily drivers
- Possible SC upgrade questions
- What does this plug go to?
- Does anyone have a scavenge pump for sale?
- weird problem with the greddy EU
- 370 Injectors, Z32 MAF, some issues
- walbro fuel pump
- Got timing?
- Stock clutch on SC'd Maxima at 60k miles
- Compression check
- What do I need for emanage ultimate?????
- FS: Greddy Profec EBC
- Has anyone used Det cans for tuning?
- Fuel Hose Size ?
- Z32 MAF Needed
- Bought turbo for a VQ35de; need your opinions pls.
- WTB:Motor Mounts
- any one have a t62-1 turbonetics for sale?
- Any reason not to do a DEK in my turbo car?
- Stillen charger pipes on EBAY!
- Question on types of exhaust piping.....
- FS: Level 10 auto transmission 1995-1999
- Motor build????
- ATP VES installed and wooweee!!!!
- For sale 370cc Z32 TT injectors
- Question on 3" charge pipe for 5th gen
- Need A New Flywheel (suggestions?)
- Observation: Boost accuracy.
- Isolators
- Forced Induction Questions?
- Header Install
- what do 5th gen's do for injectors?
- Turbo or swap
- All You Supercharged WannaBees
- Next steps for the SC setup
- Before I get a Headache - WTB: Smaller SC Pulley
- About to start the project finally
- sr20 turbo on 97 vg30
- First Drive..
- Rebuild Vortex SC
- Digital Boost Gauge ?
- Boosted w/cams
- New Live Edit
- Weird CEL code...
- cartech fmu
- Got my Wideband In
- Top 10 ways you know you own a turbo maxima
- bit the dust....
- Fuel injectors, flow rates, fuel system
- making cai for s/c v2, but bypass valve?
- Greddy B-Spec II EBC questions.
- Help gas canister leak fuel!!!
- Obx HLSD differentials
- walbro fule pump?
- It's 4 sale
- NEW: Garrett BB center sections for T-series
- Going Turbo
- Excellent article on Detonation and Pre-Ignition from an expert
- VQ35 Eagle 4340 H-beam rods $600
- Now what Muffler ?
- Another one
- ACT Clutch questions!!!!!!!!!!!!!!!!!!
- turbo XS UTEC fuel managment system...
- Installation of a recirculating BOV???
- Where to buy piping for 3" Charge pipe??
- 1 step or 2 steps colder?
- EU Rev-Limiter works! Timing seems too....
- CS problem
- Any of you boosted guys need some Place Racing poly motor mounts?
- apexi power FC
- Injector ?'s
- VQ30 rods/pistons are SCRAWNY!
- will the dek with-stand boost
- Stock VQ30 internals pics?
- roll bar
- 5 Gen owners........
- Cold Weather & Turbo Maxima ?
- Finally got my car back today...
- Weird Fuel Pressure Readings
- anyone know the part# for the vortech blower for 99max?
- What to do for tuning
- ok houston we have a problem!!!
- Helical or straight cut gears?
- 4th gen 5speed trannies
- 5speed gone?
- New turbo Y pipe setup with pics
- acc video of the turbo vg check it out
- a little shot of my boost gauge
- On a SC'ed setup...which would be more efficient?
- help..sometimes car wont start...
- quick help please with white smoke comin' out of the exhaust
- Ouch...info@greddy.com response to my IDC issue
- FS: Z32 MAF and pig tail
- hoses - lines - fitings?
- Bosch Bypass Valve adapter?
- hoses - lines - fittings?
- VQ30 HP record?
- FS: *NEW* V1 S/C Plate Kits...
- 3.5 supercharger?
- Weird Buzzing...3" with DynoMax Super Turbo
- Dummy question(s) regarding FMU and Fuel Pump
- FPR/Walbro fuel pump question
- wideband o2 question
- Greddy E-manage install write up???
- Interesting Tuning Info
- Turbo Sing in
