- s/c fmic help
- Guys with Intercoolers...
- Max boost on VQ35 with stock injectors, fpr, and walbro fuel pump
- Any Experience with Flowmasters ?
- Emanage Ultimate Help
- Intake related question
- Emanage Blue Question
- .........FOR SALE SECTION FOR F/I PARTS.........
- Fuel Setup
- Timing and Boost Pressure related?
- Why cant i put 6 turbos in my V6
- vg30dett power
- THE FIRST??
- 440cc injectors on stock ecu????
- turbo did underdrive pulley help increase spool up
- 3.5 swap + EU > S/C + JWT
- 369.4 to the wheels
- Another turbo 4th gen setup.
- Oil return line
- Piping Problem
- my attempt at a build thread
- Fuel Economy questions and ideas
- Looking for better tune than just a SAFC
- Oil Drain questions
- Tuning Help
- 350z exhaust manifolds
- CAI and fuel injector help
- Choosing a RMT?
- Emanage Software Install Password
- NEW MAXIMA "PAR ENGINEERED" GEAR SET now available Pics of stock vs par gears...
- Twin RMT?
- Vortech 2.87 and Fields SFC for sale
- How to mount turbo
- time to sell S/C stuff
- Emanage maps
- Garrett T3/T04E turbo, Oil Drain and Feed Lines, and Turbonetics Evolution Wategate
- Just curious, Is anyone running a water/meth kit?
- 3" Y where art thou?
- 3.125" pulley + V1 plate = belt rubbing?
- Greddy emanage A/F harness pinouts
- Emanage Ultimate help
- New member of the supercharged club.
- another rmt up and running!
- A few Turbo Questions
- Im Still Having Clutch Problems....
- Does anyone have a red tial 38mm 5lb spring
- Nismo afpr, is it rising rate?
- Is the 99 Cali lower intake manifold restrictive?
- Turbocharger question
- Won't Idle: 370cc, T-Rex Pump, Z32 MAF, JWT SC Program
- VG30ET: Oil Feed Question
- 2.87 pulley, 440cc injectors, Vortech Bypass Valve and FMIC
- Finally turbo for 5th gen.
- TD04 Turbo on a VQ30DE?
- Walbro install NOT as expected....
- Bye Bye turbo maxima...
- 5.5Gen Turbo
- Custom Auto NRH tranny
- Datalogger question. LC-1 or LM-1
- Oil leak - Camshaft position sensor retainer
- My RMT idea and plans
- AEM Universal FPR
- FS: RMT Turbo kit - SAFC NEO - NGK AFX Wideband - Walbro ect
- e85 Max
- FS: Blitz SBC ID boost controller and Blitz Powermeter
- automatic turbo
- FS: Matty's V1 Supercharger Plate $375 OBO
- Fuel Delivery with S/c
- Yay! I've fried my tranny :(
- vq35 Forged Rods
- FS: GT35R/T4 Turbo kit, 3in exhaust and extras...
- Okay I messed up and I know it!!
- ok don't roast me but. 02-03 turbo ?
- Front Mount fitment question
- FS: Autometer boost and a/f gauges!
- Oil leak from bolt above thermostat housing?
- EGT and AFR on stock motor
- Emanage Patch Harness
- I'd like to email my EU tune and have someone look at it.
- whats my option for 5spd trans on a turbo max
- First Sc Max..Questions on Setup
- EU timing setting on supercharged and turbo cars
- Walbro fuel pump problem
- General Emanage question
- 3" ypipe
- Diesel turbos on the max?
- Stand Alone
- ? on tapping upper oil pan.
- Anyone have trouble with an axle popping out?
- 3.125" pulley and pinging
- My RMT dreams
- How to: Build you own Poly Motor Mounts
- My RMT plan....yep another one to the dark side
- Parting out turbocharged maxima
- FMU question.
- F/S: Stillen SC Kit 90-deg Bend $115 shipped OBO
- New vortech V-3 head units are self-lubricated
- Pics of I-MFD wideband and SM-FluidTemp installed in gauge cluster
- my 5th gen SC piping
- electronic boost controllers
- About to do fidanza, ACT nm1-xtss and 3rd-4th par(gears) upgrade on my turbomax00
- Greddy Td06-20g
- FS: 3" Cromex Charge Pipe
- MEVI vs Stock in boost app?
- Help me finish this SC kit
- Boost gauge goes to 0 and stops also BOV not working.
- turbos and Muffler Restriction
- Car studders bad
- SC'd Aussie Maxima
- Bad knock sensor reading 86 at 1300rpms!
- Considering the purchase of a SC setup and..
- 5th gen intake piping and fuel?
- Boost a pump
- Is this one of Matty's plates?
- forward feed turbo setup
- WTB: 3.6" Vortech SC Pulley
- My Turbo Kit For Sale
- Boost gauge issues
- Car running rich on startup
- Boost through Gears
- Adieu friends!
- safc II
- Some parts
- UTEC vs EU for EM on boosted 5.5 gen
- My SAFCII is it fried?
- Actual 2000/2001 Stillen Supercharger instructions
- turbo idea
- weird issue, any suggestions?
- Settings on SAFCII on VG30E Lost my book!
- FS: 2.87" Vortech puley and Gatorback belt
- V2 belt shredding straight after install
- Good Wideband controller datalogger
- Preliminary S/C Prep
- I’m proud to be part of the 300 horsepower club! :oD
- Is $650 for an S/C install Reasonable?
- 5th Gen Stillen S/C Instructions
- Car won't rev over 2000rpms
- vortec fmu for sale
- Finally all the little problems fixed and Turbo up and running!
- I need help with my S/C setup
- Mega Squirt help?
- Bosch BOV
- Back in the land of the boosted
- 3.5 supercharger
- dsm metal bov with atp flange $30 shipped
- new pulley on the S/C...now fuel problems...need some help
- Will heat from a turbo kill my battery
- How much boost can the JWT SC program + 370s handle w/o an fmu?
- Catch can with a s/c
- Walbro or No?
- Fs: Vortech FMU with recalibration kit
- FS: Stillen Charge Pipe
- Decided on a Water/Meth kit, opinions welcomed
- Budget of $ 5 to 6 K
- How does the exhaust wrap do when wash the engine?
- Fuel delivery question(s)
- General Supercharger Question
- Question about belt sizes
- What PSI is the Blitz BOV good for?
- 300zx maf and maf adapter for sale
- #6 Injector dumping fuel when acc turned on
- Fuel Managment Question for 10psi of boost
- Boosting and FMU
- What kind of boost from Garrett T3 60/63?
- Fuel Dumping out of manifold before crossoverpipe?
- VQ30DE Turbo Kit from Nissan Cima
- New S/C max on the road
- 5th Gen Charging from 4th Gen Setup
- VQ30DET Manifolds on a 5th gen
- Turbo Still no start after months!!
- FS : Killer turbo + injectors
- Low compression motor with V2 T Trim...
- question about 300zx maf
- VQ35 Midmount Turbo...
- Who makes vq30 Rods and Pistons?
- Turbo Oil feed/drain alignment
- 'Boost with no Tune' Questions
- FS: BNIB Turbo and intercooler
- FS: Built auto transmission
- Stillen S/C stuff
- Turbo 3rd gen still wont stay running.
- Not really sure if you guys have seen this yet -- Wideband o2 shootout
- Fs hks blow off
- need help trying to read turbo model numbers
- FS: Vortech FMU and T-Rex Inline Fuel pump
- Need some advice on doin FMIC with SC
- Sqeaky sound from bottom of car with V2 kit any suggestion?
- Show me those FRONT MOUNTS!!
- Gizzmo Launch Interface
- question about location of wastegate
- turbo on a ve
- MAF Issues... please read
- Anyone with a boosted 5.5 gen?
- brand new rc 440cc injectors for sale
- quick turbo question
- So I heard that these VQs hold boost well but how do other parts?
- Anyone checked out the new AEM Fuel/Ignition controller yet?
- Turbo spitting out oil. Bad seals, high oil pressure?
- quick supercharger question?
- manifold piping
- Anyone want to help sized a proper intercooler
- recommendations...
- Turbo + DE-K + Vaccum lines
- New Meximax: Built VQ35 with a 6-spd HLSD
- Where to get blow-off valve adapters?
- FS: Apexi Turbo Timer (Brand New)
- eBay Fuel Rail Adapter
- reliability question
- Exhaust diameter formula needed
- Quick ? on Split T3 Turbines
- S/C Fuel delivery issues at idle... kinda long...
- turbochargers/superchargers and water
- F/S Mattys V1 plate and Vortech Race BOV
- Need help getting 3rd gen turbo started
- fuel pressure regulator help
- when do you go into full boost?
- NEW PLX R-800
- Turbo Maxima back from the Grave
- What are the exact benefits of the T-Trim?
- oil restictor for turbo
- Talked to PFI today
- FS: Cosworth Headgasket - VQ35
- New PLX Promotion: Those looking to buy.
- .63A/R or .70A/R
- FMU Disk question + few other fuel questions
- Cooling system upgrade on FI guys.
- EU questions
- Clearance question- new pulley bolt from Vortech
- pictures of my turbo build
- Question about taking a blower off
- VAFC-2 / Z32 MAF
- Fuel Consumption on turbo/sc
- Low idle with V2 SC any suggestion/fix as to why?
- how much horse power?
- F/S 2.87 vortech pulley!!!
- f/s rb25det maf with pigtail for sale
- In-Dash Gauge pods??
- RMT Intercooler Installed (Pics inside)
- BOV, whats good for SC?
- looking to get boost
- 01 i30 supercharcher
- INTERESTED IN SCer But how?
- Which gatorback belt fits V2, 3.125?
- Turbo and Supercharger
- Turbo 3rd gen is ALIVE.....
- Anyone need a J&S?
- question about forward feed turbo setup
- Stock engine 3rd Gen Dyno chart and Video.... 400whp
- V2 Rebuild- part2
