- FS: Vortech V2 kit + extras
- Best way to adjust a BOV?
- http://turbokits.com/maxima_turbo_kits.html
- fmu ?
- Cefiro Injectors
- Turbonetics T3/T4 .63 A/R
- Evo 8 turbo...
- FMU, FPR, what are you using?
- Cartech FMU and Mondo BOV for sale!
- direct exhaust injection!
- Help! My T3 exhaust flange fitment
- Blow Through Setup
- vaccum 4 dek?
- sc'ed questions: idle psi, mpg, exhaust, begi/cartech fmu
- 00 Turbo Se maxima???
- RMT on my 5.5gen
- EBAY Turbo kit for 780? nearly complete? hmmm....
- Wrapped my Turbo hot side.
- Changing from FMU/SAFCII to JWT ecu?
- What wb02 is everyone running?
- People with valve body mods on their tranny where do u get the parts from?
- So...I think I have a boost leak
- Benefits of 3 inch charge piping?
- How much boost? Looking for 300hp.....
- Wiring up my SAFC II on vg?
- engine trouble
- DIY rebuild of the Vortech V2
- Okay need your ideas... Time for stage 2
- Z32 MAF question
- Turbocharger Technical Facts and Anatomy
- What do I need to go s/c since the kit's been discontinued?
- SC help!
- anyone running mega squirt?
- A few questions- possible V2 rebuild
- Attempting to install v2 myself..
- Fuel Pressure Help-- Boosted 3.5
- RMT turbo idea diagram
- Project Phase I, need some direction
- Holset Build
- Help please!!
- pulse set up on the vq
- 00VI and 290ccs at 10.5 PSI
- Turbo project part out....
- few questions: built n/a 3.5 and use later for sc
- Why is my belt squealing?
- V2 NOISE IS THIS NORMAL?
- ok spool problem! comes on at 2500rpms
- Lexus idler pulley
- A question about turbo manifold design...
- Compression on a Bored engine: VG30ET
- FWD vs. RWD: VQ35 SC Dyno Comparo at 13psi
- Injector info needed
- weird smoking problem
- Garrett T25 non-intercooled on VQ35
- 3.5 build up time
- Can anybody post pics of where they mounted their gauges at?
- I need emanage ultimate software cd
- What clutch
- STS turbo size question for a 3.5
- V2 supercharger finally installed and running!
- MAF position in a boosted application
- Methanol injection- need a how to posted
- does eu cover it all?
- quick turbo questions
- swaying under boost!
- My boosting crossroads... please weigh-in
- Turbo ?
- SAFCII safe tune?
- SFR Turbo re: 02 VQ35 Alti.
- Stillen SC and PCV
- Stillen S/C ---> Vortech S/C
- Plugs and Gap Recommendations for Turbo setup
- FS: Vortech T-rex fuel pump and FMU
- Adeiu, Fellow Boosted Maximas!
- Need help with installing belt on blower, crank pulley, etc..
- manifolds
- Need parts to rebuild VQDEK (2k1)...
- WOW! Just got off the phone w/ Corky Bell
- Things i need to know before droppin in SC
- SARD FPR Leaking
- going from s/c to turbo whats the best turbo around ?
- Clutch Master Cylinders
- Anyone has pictures of the SC parts?
- Can I use msd 8735 for launch control and.....
- Turbo Checklist
- Turbo experts step in
- VLSD Not working?
- FS: Performance Transmission
- Oil cooler on an SCed Maxima.... can we use our existing oil feed line?
- Little black box connected to Auxiliary Fuel Pump Switch?
- Feedback on Innovate Motorsports XD-16
- s/c blower question
- E-manage ultimate, wideband for sale
- Apexi NEO
- Looking for a oil drain back hose for V2 kit!
- Upgrades: T-Trim, FMIC, Mondo, Projectors
- looking for greddy blue wiring diagram
- Should I be concerned about Walbro noise?
- FS Stillen vortech fmu, aux fuel pump and hob
- Dip Stick blowing out.....suggestions!?
- Poor oil circulation due to Oil Cooler?
- F/S vq30det manifold/ and tial 40mm wastegate flange
- Replace Autometer Fuel Pressure gauge?
- F.S. 410cc injectors off BAGS old max
- My fuel rail adapter is leaking again :(
- Cheap turbo....why?
- What kind of power would I make going with 9psi pulley instead of 7psi one?
- How do I differentiate between blower trims?
- Rich or Lean Condition ??
- Temporarily going unboosted, fuel pressure help
- Is there a turbo writeup
- FS: V2 blower/ plate
- Tunning with EU
- anyone using the Greddy Type RS ??
- new turbo set up Tell me what you think of it.
- V2 officially on board. chalk another one up for CA
- sc odd idle
- Fuel pump/injectors?
- Independant oil reservoir
- Intercooler Cooling Kit, Worth it?
- Nitrous + Turbo, will the nitrous caue spike in boost?
- Maxima "Engine Kit" with Forged Pistons
- Broken Pintles :(
- Total Cost for a turbo for my 03
- Is HKS the only maker of AN fuel rail adapter?
- Rear Mounted Oil Cooler
- noises during boost...
- FS: New turbo parts
- Turbo Question
- Is this the right oil filter stud?
- Exhaust/Muffler Setup
- manage
- How difficult?
- I want to charge my max by next summer will I get about 270HP/230WHP?
- How much boost???
- oil filter relocating?
- Part number for z32 Maf
- 5.5 gen turbo help...
- EU install & now have a question
- Feedpipe gasket? where?
- Leak at Oil Feed Tee
- How to calculate Maximum Air used by engine
- S/C intercooler
- Anyone have a pic of where you're T-ing the BOV?
- Need help with vacuum lines on 3rd gen turbo
- VIAS is stuck, can boost cause this?
- Pressure drop after VI opens
- Parts list
- Any 5gen with V2 kit have pics of how air filter is setup?
- crankcase breather clarification
- pathy throttle body Q
- Stock Injectors w/ 3.12 in pulley and a V1?
- Orgers who relocated their windshield washer reservoirs: Step on in!
- new turbo desing idea, what size pipes?
- Reliable boost with T-trim
- What's the mileage on org members with turbo or supercharger?
- TIAL 50mm BOV question
- How to writeup - Reclocking the blower
- Where's the videos at?
- Where can I find these bolts?
- another boosted 4th gen PICs AND VIDEO
- v1 plate install in progress need help quick
- Clutchnet Fiber Carbon clutch pics 56k no no
- Found some alternate 5 speed gear ratios for our transmission
- what if no dump pipe on the wastegate
- can Engine Restore damage turbo seals?
- F/S: Idler pulley
- greddy profec a setup help?
- how about these gauges???
- Pretty Interesting..V1 + V2 Plates
- Noticed something odd on my pulley
- finally I took some pics of my setup
- People with V2 kit and V1 plate please step in!
- Lexus Metal Tensioner Pulley Part Number & Pic
- Vortech Bolts - Timing Cover Leak?
- joined the SC club
- 6th gen S/C?
- FS: foward feed pipe
- Intake manifold for Supercharger??
- anybody need a pancake filter?
- Some More Questions for ClutchNet Owners
- T trim Vortech superchargers
- 3 Bar MAP volt ---> boost conversion, anyone?
- Compressor wheel needs balancing??
- WTB: Modified tensioner belt bracket for V2!
- FS: PLX R-500 wideband AFR datalogging computer kit
- Just ordered my twins (need opinions on spool up)
- breaking up after 6speed swap
- Electronic Boost Controller for 20 bucks.
- SC: 5th gen vacuum line placement & fuel line final questions
- F/s z32 Maf with pig tail
- turbo rebuild kit for T3/T4
- Boost, 370 injectors, 300z MAF, and no JWT? Come in!
- supercharger with fuel problem hellp!!!
- wtb vq30det exhaust manifolds
- What kind brand and weight are you turbo maxima using?
- Oil feed Line Help
- Does anyone have a Greddy oil catch tank
- 4th Gen Turbo Kit?
- Cheap WBo2 setup
- Home made Oil Cooler !!!!!!!!!!!
- Looking for VQ35 Harness
- F/s: Fmu 12:1 & 8:1
- Emanage Blue pressure sensor (do i HAVE to use greddy?)
- more troubles after the 555 install and z32
- Vortech FMU Question
- soon to be SC have some fuel and gauge questions
- What causes psi to drop when removing air filter?
- 5th Gen Turbo kit quest
- VG Turbo Lag?
- Something for the VQ30DE
- WTB Stillen Supercharger Kit for 01 Maxima
- SMt-6 or 7 Base Map Needed ASAP
- FS: V2 Stillen Supercharger Kit
- max not doing so good
- FS: Build auto transmission
- Found my leak: its the MAF
- any 370cc injectors drop in my 91 max?
- grey smoke while trying 555cc
- Getting a quote for the Emanage Ultimate
- The ORG's opinion counts......
- Need flanges
- Looking for a BOV
- Intercooler/aftercooler selection
- Stillen Supercharger BOV Confusion
- Brown 370cc Injectors?
- Swapping to V1 plate, tensioner clearance
- 3.5 swap progress...
- s/c pulley calculations re: boost @ redline
- apexi auto timer
- s/c intercooler question
- Brand new Snow Performance water/alcohol injection kit FOR SALE
- Performance shops who install sc in south jersey/philly area?
- V2 Plate Question
- Upgrading V2 Pulleys?
- is my 520whp a reality ? hope so we'll see with these upgrades
- Disappointed with my SC
- New intercooler setup
- Emanage Ultimate Help!!!
- Intake Air Temperature (turbo)?
- Question: Auto with supercharger / Turbo?
- F/S: Two FMU's 12:1 & 8:1
- Guys with WB02, hows your car on start up ??
- Wtb 3rd Gen 1992 Ve5 Custom Turbo Set Up
- more clutch/tranny problems
- What piping to use on 00VI swap?
- Help me identify what im missing from my V2
- Supercharger Part Oil Tee adapter assembly
- sandwich plate on VG
- SuperCharger to replace PS pump?
