- How reliable is a S/C Max?
- What are the chances of blowing my motor with the 3.33"?
- ASP Pulley puller?
- S-AFC Setting after a 5SPD conversion. Will is the be the same as when Auto?
- OK.. I'm lost again..
- turbo kit
- Boosting and OBD II
- belt size for a 3.125 SC pulley
- What is wrong with my SC max?...poor dyno results
- SC setup guage ?
- Final Chapter - Belt replaced, but not aligned
- Adjusting the idle speed
- Turbo Dyno......
- More fuel pressure than expected
- I Need Honest Advice On Pulley Size For V2
- 3.33 Pulley size "6- Rib"?
- Changed the nylon hose and I'm still getting 10Hgmm
- HELP~ the blet is running off the idler pulley~ HELP
- 12:1 FMU disk diameter
- VG30ET v. VQ30DET - compare/contrast
- I just sold my boost to GoldenGlory
- Oil return line hose?
- Sard FPR install
- Hooked up my EGT and FP..
- Boost exhaust question
- A new toy for cars with air induction :)
- MPG or per tank for turbo and supercharger people
- turbo question?
- bigger injectors. What kind of fuel computer/management?
- Is this Flywheel worth it?
- Last minute questions before SC fully reinstalled. please help.
- Does the UDP effect SC
- To all the recently blown maximas
- Boost gauge readings (Poll)
- HELP: Stillen part number question for 95-96 SC'd
- What readings to expect from Fuel Pressure and Boost gauges?
- Walbro FP
- Help...fuel pump question
- I thought that stillen s/c was suppose to make the car run rich
- Is this normal?
- Pics of my ghey gauges...
- SC troubleshooting scenario
- Benefits of Water Spray Kits
- I just changed boost gauges and..
- Auto Gone
- turbo question.
- I am officially SUPERCHARGED!!! But my Setup is VERY odd!! Check it out...
- passing emissions
- SC uninstall AND reinstall - Chapter 2
- Turboing an Automatic 5th Gen Maxima
- Should i get a different y pipe
- When changing boost settings on the turbo Maxs, how does one regulate fuel flow?
- Parts List?
- Where can I get the HKS SSQV inserts?
- Place Racing on s/c!!!
- SC uninstall - Chapter 1
- Supercharged Autos - Hitting the rev limiter?
- Why is my car boosting low?
- What clutch are you using?
- Valve cover filter?
- Any one have BOV for sale
- Info question: Goodyear Gatorback belt sizes?
- my ve turbo
- VI with boost - - always have it open?
- VQ30DET powered maxima will be running again soon!
- Anyone install their own Fuel Pressure gauge?
- does anyone have the HKS SSQV on their SC?
- Crnk Pulley woes
- Any kits to turbo or SC a Ve motor???
- Belts seem to squeek during cold starts..
- Im thinking of supercharging, many questions
- V2 Supercharger kit for sale w/ extra's
- Can a BOV hurt performance?
- Iridium plugs better than copper for boosting?
- Good Idea!!
- '95 SE tweeter + dual autometer gauge pod =
- Jumpin ribs.
- EGT probe location
- First kill.....
- S-AFC Dyno Results needed
- say goodbye to my gates belt
- Is 11 in HG for a 3.33" low?
- Supercharger is weaksauce w/stock pulley?
- Need help w/ supercharger belt size info??
- How significant is a free flow cat-back system to a SC’ed Maxima?
- Gauges in DIN???
- fact or fiction?...
- buying supercharger, have a couple questions
- How long is the vortech warranty?
- 5th gen exhaust w/ boost?
- What kind of T-fitting did you use for the Boost Gauge?
- Can you weld brass to steel?
- Car problems.
- anyone need/want a built engine?
- Should I get the Apexi S-AFC?
- aftermarket knock sensor?
- Quoted: $400-600 and 1 WEEK to install V1 S/C
- SAFC questions with test pipe
- V2 Dyno results (auto)
- Anybody have problems with their radiator hose blowing off?
- Anyone with Turbo & MEVI ?
- Painting Gauge Pod to match Gray interior?
- supercharger problem
- Turbo or Supercharge that the question????
- Optimal exhaust setup for turbo max?
- Are SAFC modules removable?
- Painting the autometer 2 pod pillar
- supercharger thermostat housing install question
- What should I expect to run the 1/4 in after SC?
- Is my belt too tight? See pic
- Hobbs switch
- ****en Check Engine light is on!!
- Good idea to replace all fuel hoses?
- SC pics... a little confused
- I just noticed something odd about my VI!!!!!
- 9 psi with what pulley and at what rpm?
- Successful S/C install, thanks to Jaime
- How does fuel cutoff work in our cars, esp. under boost?
- Who is running the stock FPR with their Supercharger and are you running rich?
- 2002+ Fuel systems, my knowlege and yours
- V2 tensioner assembaly HELP
- Weird squeeky sound coming from S/C..
- Where to get missing parts for autometer gauges??
- How do I depressurize the fuel??
- where are u guys geting your sc
- Who was the person complaining that their car was stalling after installing your BOV?
- Narrowed it down to EGT/Boost/FP via Autometer Phantom.....help an idiot out.
- Need a good source for SSQV flanges??
- Let's talk about EGT gauges and disscuss what means what.
- does hks make a univeral blow off valve?
- HKS has them, but are there any inserts for Greddy BOV's?
- Shopping for Boost and EGT gauges
- Reinstalled the V2 for the second time
- Why not more SC+MEVI people?
- Is there such a thing as an Allen key ratchet?
- What a VQ35 w/ 13lbs of SC boost dyno might look like
- SC CAI install results in blown MAF
- BOV, do I need an aftermarket one or Bosch will do?
- Anyone tries a Turbo XS H BOV?
- Measuring the tightness on the belt
- Opinions on setup
- Follow-up - cold start rattling noise fixed!
- Belt jumping the pulley!
- Sh*T! I still have to grind with a 3.33" Pulley
- A nice SC info write up...
- stronger head gaskets?
- Which way should the pulley on the blower face?
- FMF disk price......I got ripped I think
- Tuning my SC further (long)
- what does a turbo maxima exhaust sound like?
- Supercharger deepens exhaust note?
- S-AFC or something else??
- What does a bad V2 SC sound like?
- Boost gremlins
- can a supercharger exist with turbo?
- Ive decided to go back NA
- Placing a turbo kit on an atuo....
- You won't believe this!
- Boost controller question.
- Finished Install, But Car Won't Start
- Hey Did You See This?
- V2 belt shreds.....
- What pulley do you guys recommend for me? 3.125, 3.33, custom 3.25, ect. Need SC help
- Supercharger CELs.
- oil cooler sandwich adapter fits okay?
- Goodyear Gatorback Belt Part #?
- What RPM does your BOV open?
- is a maxima capable of being a 10 second car?
- Which form of boost would be best for me...
- Congrats to Turbo95max another Moderator:)
- Congrats to Mardigrasmax..our new Moderator
- Need Help, SC Stand-off bolts won't fit :(
- 5speed vs. turbo
- What part of the supercharger plate needs to be shaved, im lost
- Why did I get a 8:1 with my FMU?
- Belt sqeaking...
- I am a nut!
- Rattling noise after SC install
- V2 Stillen supercharger instructions
- supercharging a 4th gen with an auto tranny....
- Colder plugs?
- 5thgen owners.. Where did you get your gauge pods?
- Which 99s need the special SC Kit?
- Those Melting Pullies!
- Finally can ask questions on s/c
- V1 kit with 3.25" pulley - 1 step or 2 step colder plugs?
- How long did Vortech get back to you after they received your SC Blower?
- nitrous and stillen supercharger
- Blitz Blow-Off-Valve Install on 5thGen V2 Setup????
- Which pulley remover do YOU use?
- Congrats delio...... another moderator
- Congrats to JAY25..... a new moderator
- why is turbo knocked for auto's
- Turbo Timer?
- Hopefully someone can adapt Kevings future 3.0L turbo to 3.5L turbo
- BOV installed, car stalls
- turbo?
