- Newb to max turboing
- A/F gauge ?
- Y dont more people use a 2.87 pulley?
- LFR6AP-9 : What are they? What is compatible?
- help with OEM Part #
- Ian's repetitive quesiton of the week (K&N PN)
- V1 vs. V2 on a 2000
- Split Second the non-JWT answer to our Maxima prayers
- Power steering lines ??
- afc ?
- my fun turbo troubles....
- Venom Injectors
- 300 N/A vs TT MAF
- Anyone running Aquamist...
- V1 vs. V2 Install ??
- NGK Iridiums IX
- Difference between the stillen 95-98 and 99 kit?
- SFMU Mounting Location
- What Size Turbo For VQ35????
- How to remove tensioner pulley??
- Fuel Pressure Problem (perhaps a bad pump?)
- Wanna make my max turbo....
- Stillen V2 SC kit, Plastic Pulley replacement
- Rod length (anyone know????)
- Intercooler as a intake question
- Anyone use PTR clean/flow service for injectors?
- Turbo timer install
- Who is using the z32 MAF?
- Anyone have BLUE S/C Caps ??
- fuel pressure regulator
- new turbo kit( maybe repost)
- Went lean at high rpm
- Finally!
- Will Stillen sell us S/C misc...
- Can you Clear it up???
- cylinder heads
- Ordered my pistons yesterday!
- Clutch sticks
- Upgrade fuel injectors?
- supercharge automatic Maxima?
- Got a Link?
- VQ35DE Twin Turbo Kit *Videos*
- Where to buy 370's, MAF ??
- Linuxr Bad Clutch vrs a Subaru WRX
- Which model Cartech FMU?
- Issue with Fuel Pressure, keeps changing at idle....
- advice needed: Lowest boost S/C on stock auto; is it safe?
- coolant question for Garret GT series turbos
- Video: Jay vs. NSX and bags part II
- ? on SARD FPR
- Video: Bags turbo @ 8PSI vs SCed Sleepy @ 8PSI
- Help, Gas attedant put 87 octane in my supercharged max!!!
- Best Exhaust for S/C ??
- FMU Question
- my new throttle body
- Air to Air-We'll see Soon!
- Turbo Auto
- T25 turbo too small??
- Turbo question...
- New to Boost!
- need help in gapping plugs
- S/C Fuel Delivery
- SAFC2 KS monitor
- Nismo FPR
- I need everyone's advice! Turboing this Mofo
- Need T adaptor for S/c
- Greddy E-manage, boost controller and more!
- S/C sound
- jet vforce power control module good/bad?
- Does anyone have a dyno plot I can look at for turbo with 7000rpm limit and MEVI
- If you had an N/A JWT ECU would you keep it to modify to FI specs later or just sell
- Help me figure this out...
- Red top injectors
- question about changing pulley for more boost
- Want to put intercooler on supercharged 01'
- 370cc or??????
- SC + dry N20 setup questions
- fpr, fmu and walbro
- welding tips
- Speed Shop/s in Las Vegas
- I would like to give props to all turbo/sc max's
- Price for VERY slight used T3/T04E PFI kit?
- Just ordered my new turbo T04R
- 14.7psi 96%DC 4.67v@MAF 7krpm and third gear has enough!
- How many miles is too many?
- Can you SC with stock exhaust?
- How do you define knock count?
- Wideband O2 or EGT
- 12.9psi, 4.62v@MAF, 82%DC, 7100rpm
- Sx7r Fuel rail off-fitting
- Can I still get decent gas mileage?
- Redmax Destroyed
- New Turbo for vq35de
- Vortech MaxFlow Power Cooler
- vq30de specs
- Looking for 4th Gen Turbo Project
- Start / Idle Problem
- To turbo or not to turbo?
- Opinions on turbine/compressor
- Project update
- Quality Turbo Kit Interest?
- Which exh. is better?
- Selling V2 w/ 3.125 blower only, must go
- Anyone looking for a set of 370cc Injectors?
- 8 VIDEOS 9.7PSI turbo max vs 10 sec 03 cobra, SC IS300,15PSI 300TT, Bags vs SC IS300
- Installed WSP's 3" exhaust
- turbo install in los angeles area?
- Any 01 Turbos out there?
- Possible Problem with New Engine......
- Got the new bracket, the drama continues
- oil return for turbos
- lookin for a BOV
- Cartech FMU or Walbro?
- T4/TO4R for 3.3L ...
- What ever happened to...
- Is This Possible?
- See anything worng with this turbo?
- Out with the OLD... IN with with NEW
- Turbo Kit for $3,400
- Does anyone know this guy?
- More FAQ type stuff...
- Please Explain This One??
- External wastegate w/o the nipple on turbo?
- Daily Driver, or not?
- need help bad! loooong
- Turbo sizing for automatic trannies..any different?
- GSS342 Installed!
- Smell Fuel on Start up
- ??? for turbocharged
- Bags VS Modded EVO.....
- E-manage help...
- Help! AEM Adj FPR install
- Cost > value ??
- Looking for another turbo, have question
- Anyone had low vacum readings?
- T4/T04B Turbo Shopping.....
- Is there a MAX meet on 03/07 in Maryland??
- What trim turbo is everyone running?
- What is the difference in a Turbine A/R .83 and .63?
- Want to supercharge my 93
- Aquamist Power Gain
- Think I found my leak
- problems with turbo kit
- Supercharger facts. directions, part numbers, belts etcc
- Lets start a Turbo FACTS ONLY right now! POST AWAY
- Thinkin about turbo.. need some insight
- 1 step or 2?
- Aquamist before or after the SC??
- Boost with lightened Flywheel ??
- what sparkplug is the best for turbo max
- VQ35 for $500
- Blitz BOV owners, I have the filter on my BOV, would you sell your little metal horn
- Possibly Buying a V1...
- LeBaron turbo on a Maxima??
- How many miles when Boost Began ??
- OBD 2 Scanners
- Sound clip of V2 ??
- New for 4th gen?
- Belt Shredded! FCUK!
- Look what arrived at my house for my project....
- Clutch...ACT ??
- 2nd Gen Turbo
- AWAC ?'s
- VI with S/C
- turbo questions
- Comprehensive dyno comparisons
- Anybody have an extra Manual boost controller laying around?
- what kind of clutch is FI people running??
- How to hook up the turbo timer. The two main ignition wires to look for, read inside
- turbo question
- to the supercharged: i need your help
- Zemulator
- Is it fair to say each drop in pulley size = 10HP?
- Timing retard?
- Extreme Kit for maxima?
- 3 inch SS Resonators
- intercooling help?
- Anybody boosted on State Farm Insurance?
- R32 Intercooler?
- how much can a stock motor put up with?????
- Emanage ignition tuning...any input is appreciated
- Turbo Setup Questions
- Useful links
- Are JWT cams ok for forced induction?
- OIL return problem.
- Useful web calculators for FI guys
- 89 air flow meter cfm rating???
- Fuel pressure: OEM FPR vs OEM FPR + 4:1/6:1/8:1 FMU ratio
- New Turbo Kit
- I just had an intersting discussion...
- SAFC settings for A32 ecu, Z32 maf, 370 cc/min injectors
- The Uncorrected DYNO numbers ARE HIGHER!!!!
- Differences between V1 and V2 mounting plate.
- ?s about uping boost and hp on v1
- Tomei Z32 plug/pigtail?
- Boost or not to boost that is the question
- PICs of Auto anyone
- Misc Turbo parts. Where do you guys buy?
- vortechs phone number
- anybody have an auto with a 3 " downpipe?
- 30.5x8x3 SPEARCO intercooler -CORRECT SIZE??
- Blitz Super Sound BOV : Any Good
- Congrats to Bags and Ramius on very impressive numbers
- V1 or V2?
- supercharger question
- 3" Exhaust installed.
- ????big brakes guys??
- Greddy ignition Harness, Code 0201 Quick help please
- Turbo timer Turbo Boost and blow offvalve?? take a loook thanks
- Thinking of SC'ing, or geting a turbo for my Maxima
- slicks and rims
- build kit?
- safc sensor type setting???
- Fuel Hose Help
- 5psi never felt so good
- problems with my max
- Turbo intercooler Size??
- GSS342 Walbro in-tank fuel pump works for VQ35s?
- Does anyone have a recommendation for a replacement idler pulley ?
- Fuel system, ECU, ignition timing, what is everyone running?
- turbo question
- Which spark plugs to use?
- HomeMade Turbo ....an option
- I've sprouted another gauge
- Is buying a used SC worth it?
- gator Belt 2.87
- Fuel Pump Walbro
- 7th Injector?
- Maximum Tuning Valvebody
- aerobearing turbos
- what do these symbols mean
- for all turbo guys help choosing thr right one
- bov and wastegates
- Sorry common newbie question
- SH*T, I think there is water in my motor oil...
- You guys see any problem with...
- turbo prep question
- is this a good turbo???
- Turbokits.com?
- Insurance Covering car with a Turbo?
- can you use a udp with a s/c?
- 5th gen injector options including VQ35s
- Need your help guys
- Greddy eManage installed, finally works! Pics
- water injection, lowered compression, bore
- Hey guys! Just dropping in.
- 555 injectors
- Any1 selling there supercharger?
- Supercharger worth the money?
- Compression Tested!
