- Wat is a fair $ for a used V1 kit?
- What F.I. choice are available for 6th gen?
- 4th gen ECU
- Small amounts of water running through SC?
- Z32 maf
- fs: greddy emanage
- what setup to go with...
- E-Manage question - flashing lights
- FS: 370cc Injectors
- problem with turbo timer
- HELP wiring diagram for e mange
- best 5th gen ic
- calling all motor swappers!
- intercooler on a sc
- Help! ECU diagram
- FS: Every MOD off my turbo 98 Maxima
- 550cc injectors FS....
- exhaust manifold flanges,source?
- Car runs like @$$ upon startup
- Boosting the VQ
- Intercooler clearance/mounting issues
- Looking for LSD and other mod advice
- Need pics/specs of 5th Gen Stillen Intake Pipe
- Boosted!?!?!?!?
- Rehashing of Clutch??
- So my hex socket tool broke off...
- block posting?
- Clutch
- f/s 370c injectors
- Where Can I find Used S/c
- Just got a Tial wastegate...question
- sc belt question
- videos or sound clips
- xmas money
- What do I need to take the pulley off the blower?
- stock auto hp limit?
- 3.0 bottomend with 3.5 heads? guinea pig?
- Selling Maxima parts FORCED INDUCTION plz allow to stay!
- Valve springs and boost... Cams?
- why was my thread moved?
- FS: 516/555cc OE fit injectors
- I'm interested in a local V1.
- how do you retard timing
- Which CR for V2/3.12 application
- How much power for the vg30e will it stand
- Walbro fuel pump problems?
- Talked to Turbonetics today
- Vortech recommends not to use V2 if temp < 32 Degrees
- Subs...
- 342whp @16.5psi, mission control have a problem!
- fs: jwt ecu
- EGT readings
- question about collecter pipes for turbo set-up
- Noticed something strange
- Goodyear Gatorback Belt *cheapest place online?*
- turbo size
- Question about installation
- S/c Resizing
- What parameters does the cold start program change?
- Live Edit works...
- dyno results are in: 00vi vs mevi
- SC seized up? Time for rebuild??
- intercooler kit??
- guys..i really got a problem now..car wont start...
- Looking for Blow-up Diagram of V1/V2 Blower
- What else should I do while I have..
- How often do you rebuild your S/C ?
- Can someone tell me what this code means??
- How do I get there??
- Head Gasket/ Manifold ?'s
- Lower Compression
- Bypassing SuperCharger *help*
- Map sensor questions
- JWT Z32 MAF Chip is in - problems? (long)
- Want A Fast MAxi
- Need new Tranny!! Yikes
- thoughts, on junk yard turbokits...
- FS: Greddy Type S BOV
- ZEMulator tuning system works in all 3rd gens! 4th gens are soon to come!
- turbo question.....
- found cheap injectors
- Couple of questions regarding boosting
- pfi kits?
- Which BOV???
- does anybody have link to stillen s/c manual with pics
- cheaper injectors???
- Compression results
- alignment w/ turbo kit
- Report on new GT35R
- Forced Induction Maxima specialty shop in Southeast?
- Am I crazy for thinking this???
- Water/Alcohol Injection GB over @ sr20forum
- Zeitronix bundle for sale in the FS forum
- Weird Idle ??
- Fs Bov
- Since we are talking about pulleys....re: crank pulley
- where to buy an safc?
- Upgraded pulley
- recomendations
- Also Need!!!!!!!!!
- Just installed 370cc injectors(kinda long)..experts needed
- Just got my car...disapointed??
- Read through stickies and some ?'s
- Vibration Noise?
- Some Fuel, MAF, and other questions about FI
- All turbo maximas, please anwser this questionnaire
- standalones.
- New ECU
- Tightening the throttle cable when....
- Car did something quite weird yesterday...
- New sticky - take a look
- List of boosted maxima's and DYNO results
- breaking trannys?
- water injection = more power on pump gas
- installing vg30e into 95-99 maxima???
- 26f!!!!psi
- stillen v2 sc on a 2003 maxima?
- tuning for turbo
- anyone know where i can find just an EGT sensor/wire?
- building a turbo for an 03 max
- wtb stock bov n also the charge pipe from stillen
- Fs: 3.33 Pulley And 6:1 Fmu
- Ignition setup for turbo
- going for broke.
- Safe with Blower ???
- for sale
- Difference between 4th and 5th gen trans for FI duty.
- S/C questions for 00 Maxima
- hp ratings for 2.87 pulley
- Need expert's help about 370cc injectors
- Need some judgements on my upgraded fuel setup
- clearance Qs about V2 SQ and HO alternator
- New Greddy Type RS BOV!!!
- NISMO 740cc injectors
- Built bottom end, max hp/psi?
- newbie
- Need some help on gauges
- 2002 Turbo kit?
- put on 2.87 pulley & now belt rubs
- ported and polished with turbo
- 3" inch exhaust
- Any suggestions on how to "mock up" exhaust pipe routing?
- Effect of lowering compression ratio via larger head CC?
- Qestuon on Turbo Spool up
- Books on Turbocharging
- Allen key bolts for the blitz BOV
- New site for Turbo and Supercharged vehicles in Midwest
- vortech superchargers
- Under hood temps
- supercharger vs. turbocharger
- Broken belt
- Traction problems
- S/C guys: When's the last time you...
- Denso
- Laptop requirements for Greddy Emanage PC Support Tool
- Turbo help
- Turbo Emissions
- supercharged 00 MAX
- SPEC stage 3 Clutch
- Cattman headers + V2
- big driveabilty problems help
- Considering getting SC'd over getting a new car, need some opinions
- Maximum crank HP on stock internals
- What is the most basic turbo set up I can run?
- Greddy Type S BOV Question
- Oil Press and Volt Meter Gauge Wiring
- Few quick Emanage questions
- Oil Filter Question
- 2k2-2k3 turbo
- (((twincharging my supercharger)))
- Final track day of the season
- How to Install Blitz SBC-iD
- pic of the ct26 on the vg
- WTB: 6:1 FMU disc
- Turbo cars esp Cali spec
- 1/4 mile time
- Question about Uberdata
- NO Boost #'s In 1st ??
- cali turbo maximas...a question for you?
- new jwt ecu and cams fs
- Romulator/Live Edit/Jim Wolf?
- new sc problems
- Please!!! Help Needed Asap
- SC Back In
- Best way to turbo an auto?
- SC installed over the weekend, thanks to Tilley!!
- Supercharger for 04-05 6th generation ??
- Turbo size?
- Vortech Bypass valve vs blow off valve
- For Sale: Turbo kit
- Exceeding the MAF with e-Manage and MAP tuning
- another water injection Q
- in need of 370cc injectors..
- PFI Turbo Kit
- Another Mevi Q
- building a F/I VQ
- i guess im going on motor #2
- Pathfinder TB coolant lines on USIM
- 89 Max update:
- More Nissan Ecu info
- What kind of turbo you got
- Dyno after header install - 274 tq/348 hp
- Vortech Super FMU help
- mevi and s/c
- 3:1 or 4:1 FMU question
- Decisions: what turbo
- v2 fit on v1 bracket /4th gen?
- 2.62" pulley and FMU Parts
- compression on vg after boost
- What R 370 Injectors?
- Additions to Sced max?
- Ok.. $50 for the next s/c'ed nut
- fs: new 96 jwt ecu
- wtb z32maf 370cc injectors
- quick question regarding adj fpr's...???
- SAFC is acting a a$$ on me!
- need someone to talk to
- turbo piping
- Reliability
- 300ZXTT Injectors and MAF
- help if u can
- How Many J&S Channels?
- Retard SC question.
- Z32 , 2.87 installed...
- Cattman headers installed
- Z32 MAF question
- bearings and SC...
- sc belt issues
- Too Boost or Not to Boost??
- Got JWT today
- AEM Wideband, Which One?
- Do you think this is a good deal on greddy emanage?...looky...
- Nissans suck... (pics)
- Aquamist hook up
- turbo and exhaust??>>>
- I know, I know!! Its not a FI?
- Delta II wastegate.
- Dimensions For A Front Mount Intercooler Without Losing Fog Lights
- wiring for Z32 MAF
- can I get sc'ed cheap?
- OK stupid question
- Turbo for 2k1 auto...
- Where should I tap for my boost reference?
- Sc video?
- Got the ct26 installed VG30e
- Turbo compressor map java calculator
- 89 Boosted Maxima G-Tech Time.
- MAF location question
