PDA
View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26
  1. vq35 supercharger
  2. Will a company like greddy produce 5thgen turbo kit??
  3. ? about S-AFC2 knocking sensor
  4. Jwt Ecu Sc Program?
  5. True power of a SuperC ?
  6. where do you guys usually put the egt probe???
  7. smaller sc pulley?
  8. Blow Off Valve?
  9. For those of you thinking about being boosted...
  10. Switching to 3.125" Pulley
  11. For thoes of you just getting started....
  12. My dyno graph
  13. Replacement stock V2 intake..
  14. Turbo kit suggestions
  15. Porting headers...
  16. High EGT = no race against a Prosche Boxter
  17. SAFC question
  18. do miles matter (for motor building purposes)?
  19. Used Supercharger
  20. Fuel Issue
  21. FMU and fuel info needed please
  22. Fuel Pressure Gauge
  23. my car pulls stronger @ 3/4 throttle than full throttle at 4th gear.
  24. Stillen Supercharger Help
  25. s/c with 10 psi
  26. Narrowing Down Turbos.......
  27. 15W 50 oil?
  28. Belt numbers
  29. Buying a 2.87 " Pulley
  30. what kind of wear n tear/problems/repairs occur when a SC is on a maxima?
  31. VQ Building Time!
  32. How safe is it driving on a shredded belt??
  33. Backing up engine
  34. 2 oil leaks
  35. Injector duty cycle question
  36. injectors
  37. manifold gasket problem...pics
  38. Seriously folks, how is your reliability with the SC?
  39. My fun tonight
  40. black smoke
  41. Which oil?
  42. Gauge Pod
  43. New turbo feed pipe routng?
  44. dyno day round #2.. a bit better this time
  45. JWT ECU with SC + MEVI + 5spd Conversion question
  46. Turbo probleme?
  47. Haltech ECU anyone?
  48. Q on SC parts
  49. 3" pipe gains
  50. No more boost ... thoughts/help?
  51. What does your pipe feeding your turbo look like?
  52. Mass air flow sensor
  53. where to buy a turbo?
  54. Would I be insane to run my JWT ECU NA program with a 3.6 pullied SC?
  55. boost before boom
  56. What EGT are you seeing at high speed?
  57. Bad idle with new fuel pump
  58. New Toy (pic)
  59. mods after SC
  60. Gauges - oil, EGT, fuel...
  61. Best places to get guages & custom aftermarket pulleys(idler,tensioner)?
  62. F#$k My Car
  63. 4th gen safc install help
  64. Redline oil 10w 30 or 10w40
  65. Supercharger warm up...
  66. SC or new car?
  67. Turbos turbos turbos, which one?????
  68. Things one should do after installing a S/C v1 on an auto?
  69. what are your quarter times and Dyno numbers
  70. Couple of turbo questions
  71. What about a screw type supercharger for the Max?
  72. spark plug info needed
  73. Changing out head gasket, how hard?
  74. FS: J&S Ultrasafeguard
  75. Walbro 190lph High Pressure flow numbers are out
  76. Defi fuel pressure gauge installed! 100+psi @ WOT
  77. New
  78. Any of you guys F@#$ up this badly?
  79. SC CAI installed
  80. Oil in SC inlet
  81. 3" exhaust with a quiet muffler
  82. fmu and fpr
  83. I want to get a cat back exhaust system, what do you guys suggest?
  84. Something interesting for you turbo guys...
  85. Vaccum and idle question
  86. Does anyone know the flow rate of the stock fuel pump?
  87. Looks like im going to be on my 4th belt in one week!!!!!
  88. Synthetic automagics
  89. JWT ECU or SAFCII
  90. whats the deal with the lexus pulley
  91. so has anyone actually gotten vq30det internals???
  92. Cheapest Place for V2 kit?
  93. Should I run 1 Step or 2 Step with 14psi 2.87"
  94. more ignition help needed
  95. Questions about engine oil cooler and installing fuel pressure gauge
  96. Oil Pressure Line
  97. Another problem
  98. Can I tune fuel pressure w/S-AFC?
  99. Project Cutommaxima Turbo Automatic max COMPLETE
  100. Alignment Problems !!!!!!!!!!!!!!!!!!!!!!!
  101. Some things you may want to check out
  102. Dissapointed.
  103. What BOV to buy?
  104. where can i buy walbro fuel pumps for cheap???
  105. Before anyone else starts blasting about their pullies
  106. Install problem -- Belt Size for 3.00" & V1?
  107. Cheap blown MAFS insurance
  108. Near disaster with S/C, now is fixed, but my belt is jumping off!
  109. Raced my friends n/a '99 Max 5spd, VERY unhappy with the results
  110. 3D cad turbo piping pics...
  111. Supercharging an Auto
  112. Wish me luck (project)
  113. Can boosted Maxima kill OEM BMW m3 e36 ?
  114. In your opinion, is that worth to put S/C or just MEVI on Auto Maxima
  115. Aout SC custom Intake.
  116. I'm close to finishing the install, have a few questions Please help!!
  117. oil inlet/oulet question
  118. Dam The Idler PULLEY !!!!!
  119. Where do I tap my guage sensors?
  120. Stillen V1 Supercharger Pulley Bolt .. Part #?
  121. Post the correct belt part numbers along with corresponding pulley sizes
  122. If you have had belt alignment problems, which kit?
  123. Building motor for turbo... question...
  124. Car gets slower after repeated downshifts?
  125. Input on where to mount oil cooler
  126. turbo question ???
  127. Anyone need a 6:1 FMU Recalibration Kit??
  128. My stalling problem seems like it's getting worse
  129. Turbo Manifold
  130. What if someone HYPOTHETICALLY got an SC kit with a 7200rpm rev limiter?
  131. Quick question?
  132. Supercharger install day one
  133. questions, and more questions.
  134. TURBO from CUSTOMMAXIMA!
  135. yet another lean code...
  136. question about the PFI pricing
  137. arrrrrrrgggg!?!?! stupid #@$# belt
  138. My Car Freaking Stalled This Morning!!
  139. wastegate queston
  140. Anyone reccomend a central IL shop to install?
  141. Aluminum pullies and FMU disk anybody ..need?
  142. my cousins GSX
  143. Anyone need a HKS Steel Flange Or Blitz SS DD BOV?
  144. Performance parts for less anyone?
  145. Who makes
  146. S/C - PowerWise-Battery?
  147. Engine Basics: Detonation and Pre-Ignition
  148. What is the belt size of the Stillen SC
  149. did I find the right Turbo...
  150. I'm Jumping To 2.87" Pulley.. What Should I Upgrade? More Boost!!!
  151. Humidity & Forced Induction
  152. copper, or platinum plugs? Part#?
  153. Turbos
  154. So bypassing the blower is possible, cool.
  155. SC off the car in 1.5 hour, not the belt this time.
  156. how much power can the 4th gen transmission handle?
  157. Noticed warping on ASP idler
  158. Atten SC'd folks
  159. Turbo selection
  160. Racing fuel
  161. (Kevin's) SS Line Instructions
  162. Keep blowing O2 sensors, why??
  163. NPR intercoolers
  164. ER... Fmax Turbo Kits for Maximas?
  165. Auto is biting the dust
  166. Tuning wtf please teach me
  167. Please Read** Need Everyones Help
  168. just got my s/c kit, bov question
  169. My car just shuts off......
  170. In case you missed it
  171. Ok ceramic coating
  172. question about sc install ?
  173. Question about FP Guage
  174. In car dyno?!
  175. Oil on spark plugs
  176. Tuning with the stock pully, worth it?
  177. How many miles do you have on your V1/V2 blower?
  178. torque steer - how come I dont get some?
  179. Some random pictures....
  180. Oil feed line
  181. VQ30 Questions
  182. Bend spark plug.....
  183. VQ30DET back up and running
  184. What is SAFC?
  185. Looking for as much info on built motors as possible
  186. 350Z with Skyline Swap: Kinda OT
  187. Oil pressure or temp?
  188. VQ35 Turbo Questions
  189. Guage Questions
  190. Saw my first turbo kit in person today!
  191. couple of questions
  192. anyone bought turbo parts from this company?
  193. New turbo Kit!
  194. Snapped another belt
  195. Question about Turbo-ing
  196. boost tuned S-AFC minus the boost...gonna cause problems?
  197. BOV without turbo and supercharger?
  198. PFI turbo kit
  199. External Wastegate
  200. power steering lines ?
  201. stillen Super charger part numbers
  202. hals turbo kit.
  203. What size of pulley for Newbie SC
  204. Idle problems
  205. Super or Turbo?
  206. Interesting Group Deal???
  207. Another (Different) FMU disc question..
  208. What size T4/TO4E Turbo comes with Nigels kit?
  209. Oil started to leak out from Oil Pressure gauge.....HELP!!!
  210. I saw Hal's kit in action today...
  211. Guaging interest on a possible sc sale
  212. problem with idler pulley.....
  213. V2 INTERCOOLER, who would want one???
  214. Anybody got the long winded instrutions for
  215. I think I shavedthe bracket wrong for the 3.125 pulley
  216. Temporary crazy setup:
  217. 3" Exhaust systems...
  218. Warped aluminum pulleys cause of belt shredding
  219. anyone w/ experience of getting blower serviced at vortech?
  220. Defi fuel pressure gauge, any comment?
  221. Belt shredded on V2
  222. LONG trips w/ boost, safe or not???
  223. Which turbo "kit" is better?
  224. Which turbo "kit" is better?
  225. Does anyone know the p/n for K&N filter on V2 Kit?
  226. Went to New Orleans and got pretty good gas mileage
  227. f/s 3'' stainless test pipe w/ resonator
  228. My Turbo problems, defintely a fuel delivery issue.
  229. Afc
  230. any 02 or 03 blown or s/c maxes?
  231. Who has the highest 'mileaged' boosted Maxima?
  232. How much turbo play is acceptable?
  233. what is a reasonable price for the cartech fmu
  234. New turbo, Pistons and rods are in!
  235. any pics for supercharger on a 3rd gen
  236. For those as ignorant as me :D
  237. A new S/C kit for the 4th Gens!!!
  238. bypassing blower (belt size)
  239. Those who offer turbo kits
  240. Anyone want a Greddy Type S?
  241. Turbo Manifold Routing
  242. S/C operation ...big ???
  243. Turbo Differences 101
  244. BOV Install
  245. Stock Z turbo enough to handle the VQ30?
  246. Are most running a turbo kit, or custom setups?
  247. I am going to run a 3.12 pulley do i need to get anything extra?
  248. Coolant/Radiator Problem
  249. Turbos On A Maxima??
  250. Belt jumped a rib...
