PDA
View Full Version : Supercharged/Turbocharged
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Successful MAF removal for MAP on the EU..... ANYONE?
  2. has anyone sc a 02 max
  3. MAXUS 2010: Attending?
  4. More boost at lower revs (supercharged)
  5. Odd results from AFPR install
  6. 4th Gen Charge Piping Question
  7. Exhuast Question
  8. Blower installed, looking for advice on related stuff
  9. Blitz BOV wont vent at idle
  10. 382whp/380wtq
  11. e-manage blue to gold ????
  12. Driving around Video clip
  13. Supercharging a 5th gen
  14. Turbo automatic solution for prolong life...
  15. v1 supercharger.
  16. Poll: Your favorite clutch
  17. eaton M62
  18. Raised rev limiter with EU?
  19. Supercharger BOV question
  20. Stillen Max's Scd: Upgraded Front mount
  21. Problems with a Lean Idle
  22. Very very Low Compression (mind boggling)
  23. Turbo Help...
  24. Lets talk exhaust
  25. supercharger charge pipe
  26. Wideband O2 Installation
  27. SAFC 2 Help Needed!!!weid issue with loss of RPM signal
  28. 4.5gen backyard turbo build
  29. Mid Mount Turbo
  30. 2000 maxima build from dek 5 speed turbo to 3.5 6 speed turbo
  31. Turbo Setup Pictures
  32. dynod the frontyard boostkit
  33. Surging/Hesitation at WOT
  34. Super charger pulley question.....
  35. increasing spark
  36. Need help...turbo kit installed
  37. Vortech FMU help
  38. Need a little guidance.
  39. Question regarding 370cc Injectors with only a cartech FMU for fuel management
  40. 3.0 no more........3.5 soon come
  41. Turbo drain gasket - options
  42. 3rd Gen Walbro Fuel Pump In 4th Gen
  43. SC setup Blitz BOV -how tight is yours set?
  44. What Plugs do you use?
  45. Z32 or A33 or A32 MAF?!?!
  46. Vq30 Boosted looking to spray
  47. turbo manifolds for 4th gen
  48. Rich out-of-boost after muffler delete
  49. Ignition timing
  50. What next....
  51. Injectors
  52. best and cheapes place for manual bent piping?
  53. turbo question
  54. Link to J&S info...
  55. supercharger
  56. New and Bigger intercooler (pics inside)
  57. Un-Built VQ35??? Boost??calling out those who have blown them
  58. SSIM vs. stock IM(no vias), 15+psi 3.5
  59. Oil drain back plate, and v2 tentioner bracket
  60. Which Swap Should I Do for Boost?
  61. Turbo piping diameter RMT.
  62. difference between Tensioner pulley bracket from stillen and factory
  63. FPR (AEM) + Vortech FMU + DEK Injectors for 11lbs SCing ????
  64. J&S Safeguard and Emanage
  65. SC install before putting motor in car?
  66. Z32 MAF wiring.. WTF
  67. Help me understand Z32 MAF + Larger injector
  68. for the trully experienced with generations of turbo units, I need help.
  69. SC with DEK injectors and no FMU
  70. does everyone upgrade to a 300zx maf?
  71. Vortech FMU
  72. CT26 mrII turbo in a 4th gen?
  73. vq30dek supercharged need help!!!
  74. Built turbo VQ35 in 4th Gen
  75. Fellow SCed Orgers...
  76. Oil lines q's
  77. What spark plug to use?
  78. Emanage Ultimate + knock sensor input
  79. Zinc oil additive with Every oil change?
  80. ? about Kinetix SSV on a turboed 3.5
  81. My knock sensing device!!
  82. Boost flutter, dosnt go away
  83. EMB questions
  84. What Causes Low/Restricted Boost ~4psi ?
  85. Problem running Turbo Maxima in hot weather???
  86. Wiring my Turbo Timer
  87. Boosted 5th Gen guys, Fuel Pump Question
  88. Fuel tank sump
  89. V1 SC questions
  90. Setup for the supercharger ?!?!
  91. The two Nismo FPR's 5th gen fuel rail
  92. What's the ideal turbo stoich?
  93. Boost control and Tial WG
  94. Holset turbo question
  95. 3 Very fast questions !?!??
  96. Put another SCed max out there also full 4th gen piping on a 5th gen
  97. SecondToNone's backyard rebuild ** lots of pics **
  98. Used emanage injector harness to open the MEVI, read on
  99. Anyone here ever used a southbend clutch?
  100. n00b question, where to buy this flange?
  101. My Turbo Build
  102. Symptoms of blown turbo
  103. I need help with a belt question.... ASAP
  104. Progress on a V1 install .........
  105. supercharged video
  106. ? about pcv valves and boost
  107. Compressed Air for boost
  108. Post pics of IC setups
  109. How to install oil cooler
  110. Kevlo RMT Turbo build -Works !!
  111. Supercharger pulley, who is selling one? I need a 3.25
  112. Emanage Tuning for Boost, help.... + how do I make GM pressure sensor work?
  113. problem in first gear under boost
  114. call pulls to the right under boost
  115. J30 metal pulley as the idler, plastic fenco on the tensioner
  116. Turbo fuel requirement
  117. S/C Install and Progress - DFOWNZ
  118. Turbo damage? (Pics inside)
  119. Finally boosted!!!!
  120. Mastercater7's 4.5 Gen RMT Build Thread
  121. In-Cabin Photos
  122. SUPERCHARGER HELP
  123. help findin head studs
  124. New Stillen Supercharger Setup
  125. Boosting to 8psi
  126. V2 whine when boosting
  127. Turbo Progress Halted
  128. Will this blower work?
  129. V2 Belt Tensioner Bracket - Help!
  130. fuel system on a 5.5 gen max
  131. ANOTHER 5.5 TURBO
  132. Need some info on this tubo
  133. Need answer asap.
  134. Aftermarket Radiators
  135. PFI Kit
  136. VAFCII Quick Question
  137. If you have Gizzmo boost controller
  138. Trouble with emanage
  139. Will a V1 SC blower work?
  140. Breaking in a Built Engine
  141. 99 cali V2 3.125 tuning
  142. Project A32.5-T
  143. Emanage Blue + Wideband Help
  144. Need Fuel Help - Turbo
  145. nice engine for the price?
  146. Nismo Low Temp Thermostat VQ35 can it work on 4th gen
  147. Quick Injector Q.
  148. SC kit parts help
  149. New Products: MAF Solutions for FI
  150. My Turbo 3rd Gen
  151. Greddy Ultimate cd?
  152. Info about 350zIM on 3.5, fuel rail and return conversion. (5.5gen)
  153. Injectors
  154. My first S/C kit
  155. Upgade on radiator fans for boost
  156. guage Q's
  157. Help installing Ultimate/hks ignition
  158. DO NOT DO BUSINESS WITH SER_ALTIMA until he handles his current transactions
  159. Base Map for Greddy EMU
  160. Streetzlegend goes to the darkside (3.5!)
  161. ??BELT SIZE???
  162. 4th gen turbo parts
  163. VQ30 oil burning?
  164. Boost virgin 5th gen questions
  165. My Cutout idea
  166. Boost Control on a Supercharger
  167. FI noob...many SC questions...help please...
  168. Clutch Decsion
  169. Fuel setup changes - Returnless to Return style on VQ35
  170. knocking
  171. Removing pulley from blower
  172. Sc'er's Vs TC'ers
  173. Walbro 255lph fuel pump competition?
  174. choosing the right cams for turbo
  175. Upgrading to 660cc from 370 what brand to look for?
  176. 3rd Gen VG30E(T) Oil pressure sensor thread size?
  177. Apexi safc or Gerddy e-manage blue
  178. Quaife ATB differentials for 95-01 5MT Maximas
  179. best turbo setup?
  180. Getting A Manifold Fab'd for me :)
  181. VG30ET: Crank pulley Problem.
  182. Superchager bov
  183. electronic boost controller?
  184. Has anyone looked into E85?
  185. knocking at 14psi even with meth injection
  186. Urgent: Need to order kow C/R piston for DEk...
  187. injector info
  188. **The wait is over! Official thread for 95-99 3” Cattman Catbacks**
  189. 5.5gen Turbo'd putting out 447whp is it possible?
  190. placment of MAF
  191. T3 Water cooler Kit
  192. J&S Safeguard Explained
  193. need help on clutch decision
  194. rough idle & black exhaust
  195. Turbo Specs Help!!
  196. What harness to get with Greddy ultimate?
  197. New turbo is on its way.
  198. VG33R Supercharger
  199. Streetzlegend Headgasket Replacement progress..
  200. Vid: Turbo 4th Gen vs. APR Stg 3 GTI
  201. 6th gen superchargeddd
  202. Rough Idle, Really Rough Acceleration and More. HELP!
  203. Crankcase breather filter
  204. bigger injectors or keep fmu??
  205. jdm Vq30det info
  206. fuel line hookup?
  207. Vids of mastercater's S/C VQ35
  208. Walbro 255 HP?
  209. sc pulley question
  210. mild perfromance turbo build. plans and questions.
  211. Shopping for 3" I/C pipping & T bolt clamp
  212. VQ35HR potential
  213. '00 vi or high stall converter?
  214. signs of a s/c going bad??
  215. another supercharged 95 max!!
  216. Important Tuning Questions
  217. some basic sc questions...
  218. Another Supercharged 4.5 Gen
  219. Twin Turbo update....
  220. Some Black Smoke
  221. Opinions on this turbo:
  222. Trying to get started, did alot of reading, need specific answers!
  223. idea for the stillen sc alternative
  224. tuning help
  225. Preparing The 4.5 Gen
  226. About that time of year.
  227. Auxillary fuel pump install
  228. Anyone with water cooled turbo?
  229. DET parts for VQ30DE boost build
  230. Gauge Pods
  231. My turbo build
  232. MAF Harness Pin Removal
  233. DEK build for boost
  234. clutch suggestion for sc maxima
  235. Greddy files for bankruptcy
  236. to buy or not to buy?
  237. FMIC and CAI now installed Pics inside (56k = NO NO)
  238. MEVI's, SC's, and Turbo's...oh my
  239. doing some research
  240. Bah, blower rebuild possibly in the future
  241. Emanage Ultimate assistance - larger injectors and MAF
  242. 3.5 s/c build thread....
  243. Good fuel pressure regulator?
  244. Who owns this turbo 4th gen?
  245. Quiet Blow Off Valve
  246. I need help on the easist way to turbo charge my max
  247. First pics of my setup
  248. diy eprom? 3rd genners?
  249. Need SC to Plate Bolts
  250. 3.5" SS pipes vs 3.5" aluminium pipes heat dissipation
