- hesitation from a stop.
- denso 550cc injectors would these work?
- Help car wont start.
- what exactly does the z32 maf do?
- z32 MAF and vafc2 sensor type settings?
- 370cc injectors on ebay
- turbo max runnin 11s
- walbro fuel pump
- Watercooling lines
- Smallest V-banded Turbine?
- DEk fuel on a 3.5?
- turboxs rfl with s/c
- what cc are 5th gen 3.0 injectors?
- Z32 MAF problems. Anyway to check if its blown?
- vortech sound explanation?
- injectors for vg30e
- My new toy
- Boost for sale........
- i emailed vortech
- Vortech Question - does pulley need to be mod'd
- how hard is it to change c2 bearings?
- Anyone have a Z31 T3 Turbo?
- Need help quick!!!
- Looking for a turbo feed pipe
- v1 and v2 comparison
- bixenon HID's with supercharger
- Clutch/Flywheel Combo
- Oil restrictor
- 3" test pipe
- Oil fittings, lines, etc questions
- What did you guys use...
- What Luck???????
- Boosted Block Tear Down.
- does anyone sell a silicon supercharger elbow?
- part no/ acquisition/replacement- Stillen inlet "sleeve"?
- Vortech FMU size
- What did you guys use to seal MAF->charge pipe?
- this is just a heads up!!!
- throttle response.
- whats th best blowoff valve to use with a s/c
- Fuel Pressure issues??? Any Ideas?
- Engine start problems- a mystery....
- how to read turbocharger housing code
- Needed: DeatschWerks Customers
- Transmission Woes
- exhaust question
- power steering leak after install..
- et street size 255/50/16
- belt shredded =(
- choices other than the Cartech/Vortech for FMU?
- whats the belt size for v2 with 3.125 pulley
- anyone have problems with supercharger belts?
- Newbie?/turbo management
- belt sizes mixed up or wrong?? help plz asap
- Does anyone have a blown VQ30 lying around?
- Definitive answer SAFC2+370cc+AEM FPR+walbro- optimal fuel for 2.87"?
- Help me resurrect the max :(
- Tuning A/F with boost
- Can not get eu to connect to pc
- VQ35 + V2 S/C + 2.62 pulley + Z33 IM = : )
- brake booster check valve question
- "cad" pipe route picture request?
- eu install metled all my coils
- Dyno question
- SC pulley question
- oil pan pic and what lines to get Q's
- My Dyno "sad"
- treadstone intercoolers
- look what i got today.
- FS. 4th gen stillen charge pipe
- Almost ready to supercharge; just a few fuel system questions
- Z32 MAF question
- Emanage blue ignition harness ?
- exhaust question along with 3.125 pulley
- 00vi with Sc'er question
- anyone know about v2 tensioner pulley?
- Changing alternator on s/c max
- TPS check questions
- Boost gauge questions
- **Gauging Interest: V1 Supercharger Starter Kit for 3.5 Ltr. Motor**
- hope the v2 isnt as loud as the v1
- At what temperature is a lean condition?
- Sound clips for a V1?
- Wow! Belt changing time cut in half!
- mevi and supercharger..
- Car stalling... wtf??!
- theory of cooper plugs
- Gas Smell/Emanage/Deatcshwerks
- S/C + turbo timer...
- Recommended Belt Size for 3.125" on V1?
- V2 idler/tensioner pulley?
- How to tell the difference between V1 and V2 plates?
- what kind of supercharge setups do you have
- does anyone have a boosted 5th gen with a homemade kit
- What injectors to get for a VQ30dek???
- Looking for a used S/C...
- turbo
- Recommended AFPR
- FS: Built Transmission
- Z32 MAF untuned on 370 cc's danger of running lean with 2.87"?
- Z32 370 cc injectors+ Z32 MAFS+SAFC- doable?
- link to my fs thread!
- Anyone used http://superchargerrebuilds.com/l for their rebuild?
- supercharged guys passing smog?
- 4th Gen Turbo Charged
- Question.
- Need supercharger installed in Houston, TX
- rotate the MAF? How??
- Boosted VQ35
- S/C , T/C 5.5 gen???
- Auto Tranny blow outs
- Made a 3" exhaust
- Fuel Pressure Question...555's
- NEED HELP-PLEASE-3.33 BELT PART # at Autozone?
- What Fittings To Install Regulator?
- supercharger installed!!!
- Need help identifying couple Stillen S/C parts
- WTB: supercharger
- Toyota Ct26 Turbo??
- 550s with z32 maf no tune
- Selling my Turbo 5th Gen guys!!!
- FS: NIB Apexi S-AFCII - Black
- New lines to gas tank
- going 2.62" pulley
- Fuel Pressure at 20psi
- V2 to V1 Plate Conversion
- What would be one step colder
- new HKS head gaskets and forged internals
- Switching V2 to V1 not as easy as I thought
- New Apexi SAFC-II Being Sold
- no more 3rd gear :(
- Supercharging AE with 150K miles
- Zeitronix now has linear output WB O2
- Wtb: Afpr
- turboxs rfl bov
- who here changed from v2 to matty's v1 plate?
- GT3076R or GT3582R
- Light Harness Keeps melting.
- Atco track results 10/3
- Where to get pipping for S/C...
- Favorite Guages with Pics!
- At my wits' end- S/C and oil leak...
- Griffen Radiator is In !!
- S/C need some advice.
- Boost/Vacuum, boost driven cutout installed, possible leak?
- Please help me identify this fuel pump..
- Poll: Ebay knockoff or REVUP???
- Turboing a 4th gen VQ35
- Intesting Exhaust Read Turbo and NA
- Excellent book on turbocharging "Street Turbocharging"
- New Gates racing micro-v-belt arrived
- e-Manage Utimate install
- Cheap 1 1/2" mechanical fuel pressure gauges
- FS: GM 3 bar map sensor
- turbo, clutch, flywheel decisions
- drainback plate- install steps
- Clutchnet Chatter
- "interesting" turbo...
- Lost 30Hp from previous dyno
- Diameter of hose that connects Air Filter to blower
- Oil pressure sensor/sender questions...
- Belts- on too tight?
- First rib shredded after 2 years and 20k....
- Supercharger install (almost) complete... question
- pics of my v2s kit...am i missing any major components?
- Emanage problems
- M112 on a 3.0L
- ? about 'sensor' mounted in intake piping...
- Supercharger install- Alternator rotation
- Any Videos Of Turboed 5th Gens (3.5)??
- Injector failure?
- Question about charge piping
- Part number 407000-17- spacers- what size? where to find?
- need spare vq30de-k heads for P&P project anyone?
- Turbo Max in Orlando?
- S/C install... oil feed T fitting won't clear to install!
- WTB:1 stock A32 injector.Help!!!!!!!!!
- Thought I would make more
- Pretty pizzed off, Unorthodox Racing Ultra SC crank pulley robbed 2 PSI...
- No more PFI kit?
- turbo 3.5 4th gen?
- Z32 Mafs
- AFPR Hookup - Accufab
- Thermostat Housing
- Where are you getting your turbo manifold exhaust flanges?
- New Gates Racing Performance micro V belts
- Browsing Ebay; is this FMU a good idea?
- Interesting dyno comparison - I30tMikeD MEVI turbo vs Nealoc187 USIM turbo
- Mevi tick tick tick?????
- Turboing Your Max
- HELP! Mods... Help
- 5th Gen s/c maf location?
- E-manage- Blue vs Ultimate- differences?
- How to calculate how much power my turbo is capable of producing?
- turbo problems
- Greddy Type-s Installation...
- Got my car on a dyno today finally
- Inline Pump Removal? Links in FAQ don't work!
- FMU location on V1 setup???
- Best way to find vacuum leaks?
- F/S Turbo, piggyback and BOV
- Where to buy specialized oil sandwiches?
- How many here are using MegaSquirt?
- Did I miss these topics in the FAQ?
- I need help with comp. maps and turbo selection
- Need help deciding what to do
- SCing soon, have a few questions
- vortech SUPER FMU
- Turbo'd 3rd gen **VIDS**
- Help me understand something.. Z32 MAF+piggy-back/standalone+370cc
- What EGTs do you see during CRUISING/NORMAL DRIVING, and where is the probe placed?
- My Baby Is For Sale
- 4th Gen V1 belt replace how hard
- WTB: one 370cc VG style injector
- Changing SC pulley??
- What size flange...
- CAI caused stalling/driveability issues
- Most reliable means of monitoring A/F ratio for lean/rich condition...
- Z32 370 cc injectors+ Stock MAF
- Experiences With External Fuel Pumps?
- supercharger newbie - can a 5th gen kit work on a 4th gen?
- install question........again!!!
- V2 Blower Knock ???
- power steering/fuel line questions
- manifold vacuum?
- VQ3.5 owners...come in please.
- Turbo parst for sale
- eManage question?
- installing blower tonight I need help!!!!!!!!!
- Bad Greddy EBC solenoid?
- Where in hell....
- Fmu?
- WTB: 5th gen s/c intake pipe
- Supercharger Kit For The 3.5 Kits Soon To Come!!!!!!
- Why does my car stumble, buck, hesitate and then die??
- MEVI activation with S/Cer
- DEK Swap is Done !!!
- Alternative to Griffin Aluminum Radiator???
- Experimenting this weekend with Z32MAF/Injectors + A32 (Stock) ECU
- Stillen S/c V2
- So I bought a blower "kit". need opinions
- Electric Turbo idea?
- FS:1998 Engine 42,000
- Would anyone be interested in a supercharger from RippMods?
- Belt Size..Im stumped !! 2.87
- New Clutch INNNNNN!!!!
- UPDATE: Turbo Now on Road!
- so ive got a 99 and i wanna boost
- Need Ecu layout For safc neo hook up.
- Help with Fuel Management
