PDA
View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26
  1. Oil level for a turbo?
  2. My Fuel Pressure is crazy high.. WTB Sard FPR??
  3. I bought a bov, now what about the flange??
  4. Interesting RPM stuff with the SC
  5. FI/ECU question
  6. PolyTreck 450hp turbo kit
  7. I'm gonna need some part numbers and what not
  8. SC question
  9. What should i do for exhaust??
  10. where to find bov, what belt do i need?
  11. Recirculating Valve....
  12. urgent!!! need to know where to connect the air fuel ratio gauge...
  13. 99 SC bracket
  14. Does anyone know what this is ???
  15. Hose size needed
  16. Deal with a Rebuilt Turbo?
  17. code: 0210 Fuel INJ sys left bank:lean
  18. blown MAF has been replaced, But..
  19. Where do I buy a boost Guage?
  20. SC Installed!!!
  21. FMIC core size
  22. problem with supercharger install, need advice....
  23. Do you need a bigger battery/more cranking amps when you have an SC?
  24. Belt Alignment tips
  25. SC Install...day 1
  26. got a problem...
  27. Venom-400
  28. spark plugs?
  29. Urgent help!!!!!
  30. My BOV sounds funny
  31. Stripped the threading into the SC....am I screwed?
  32. Post part numbers to the supercharger want to post a sticky etc..
  33. Lightweight Fly vs Lighweight Pully
  34. Is there any special tools i need for the install
  35. sneek peak
  36. Problems with AFC1
  37. I am buying the stillen kit what else do I need?
  38. Correct Hex bits for SC
  39. Car not boosting at all???
  40. T03/04 spool?
  41. Is There Such Thing As...
  42. Anyone using a Vortech S-FMU?
  43. all boosted max's... question for ya....
  44. Gaping of spark plugs
  45. What is the best Sounding Blow off Valve?
  46. 99 VS 95-98 SC mounting bracket differences...
  47. PS line install (for SC)
  48. Max boost for stock injectors of a 4th gen???
  49. Car is not running...HELP!
  50. anyone interested in a sard bov??? i am looking for an hks ssq
  51. custom turbo
  52. How essential is dyno tuning?
  53. Should I change FMU Disc from 8:1 to 6:1 I'm Running Rich??
  54. changing fuel pump
  55. Did Stillen crush bend this?
  56. A few pics
  57. Just installed Fuel Pressure Gauge. Kinda off?
  58. Why an SC and not a turbo
  59. pricing on fmu disc...
  60. Is there an upgrade for the Oil pump or Water pump??
  61. How much HP does 1 PSI Equal???
  62. Shaving S/C mounting plate
  63. If you could reprogram the ECU on your blown VQ30....
  64. I wanna go boost? advice needed.
  65. T3/t04 Vs T04
  66. tax time
  67. What's the difference between these..
  68. I dynoed yesterday
  69. SC Pre-Install Install questions
  70. finally got around to mounting the guages
  71. Adjustable fpr question
  72. Experience with Kev's car :eek:
  73. Looking for SC piping "elbow"
  74. Question about SC'ing (I know nothing)
  75. I am in the boosted crowd
  76. what parts of the engine differ the vq30de-d and the vq30de-t????
  77. Car dynoed/tuned at 5psi with t3/t4b Turbo
  78. does anyone know the compression ratio of the vq30de-t from japan???
  79. SC efficiency advice...
  80. bov question
  81. 3.125 pulley questions
  82. Is this safe? I need to cut some costs :(
  83. Turbo owners, need help, increased boost to 10psi now having problems....
  84. OK, stupid question...
  85. First shredded belt, Not even 3 months of use!!!!
  86. What If your AFC isn't set at 40 and 39 percent?
  87. ACT Clutch ???
  88. Installed CAI last night
  89. I have been running super LEAN all the time. Need advice~
  90. Who else has killed their tranny
  91. New Brand SuperC ?
  92. How Can A Turbo Shatter?
  93. boost guage fs
  94. stock or aftermarket cams...help me decide
  95. New SuperC Kit??
  96. Do I really need big brakes?
  97. How many dyno runs does it take
  98. ecu upgrade?
  99. Turbo Creep?
  100. Part number of K&N
  101. quick question 'bout fuel pump...
  102. do i need a y-pipe?
  103. Free turbo?
  104. Question about SC
  105. turbo auto, SC auto, convert
  106. Dyno result = very lean mixture....Help!
  107. SUPERCHARGER price reduced. (click)
  108. Boost guage?
  109. Exedy clutch
  110. 103k on original motor and i have s/c recomendations.
  111. What are the pre-dyno settings for the S-AFC2?
  112. new gauges are here <pic>
  113. Turbo when is he takin orders
  114. FMU Disc question
  115. Finally got my new toy!
  116. Can air temp sensor affect your boost?
  117. SC auto vs. TC auto....which pulls harder?
  118. Where can I mount my S-AFC II?
  119. Turbo installation questions
  120. Who was the first org member to supercharge their Maxima?
  121. List of boosted with VIAS (MEVI)
  122. Aquick injector question.....
  123. Garret ball bearing T30 turbo??
  124. intercooler core design question
  125. 9psi, 3rd gear, but didnt feel like she was pulling???
  126. Correct NGK copper plug?
  127. question before getting a V2
  128. List of all boosted Maximas, did I miss anybody?
  129. SC people, will you do me a small favor?
  130. VG-T custom pipes are back finally....
  131. Other Hish Flow Injectors Besides 300ZX
  132. RECOMMENDED BOV, turbo gauges, boost controllers...
  133. Exhaust wrap, how does it continue to smell?
  134. For those planning to go FI, i've got some gauges
  135. T40E, T40B, 60-1, or some hybrid
  136. turbo size???
  137. SC sounds like a can full of nuts & bolts
  138. EGT probe, where
  139. 500 hp = blown block
  140. Important Question
  141. custom turbo
  142. oil return line
  143. Say your belt shredded in the middle of a desert
  144. SC: Cold Air Intake, or Functional Hood?
  145. Fuel Injector - facts thread
  146. the almighty tiny 2.87 is back to her daddy!
  147. Am I running lean?
  148. Boost pressure, why only when in gear? Wht not in Neutral?
  149. 2.87"/2.62" pulley checklist
  150. How long have you been boosted?
  151. Belt jumped!
  152. Mmmm just touched my S-AFC2!
  153. Turbo Kits and ATB Diffs
  154. Variable intake and Turbo/Supercharger
  155. More boost news with leak fixed
  156. turbo manifold/s
  157. Yearbook for boosted Maximas??
  158. in need of a Turbo mentor
  159. Keving & Lag... go hand in hand ... ?
  160. 2k-2k1 5spd complete Turbo Bolt on system vendors?
  161. custom turbo?
  162. Intercooler vs No Intercooler
  163. Group Deal for 300 ZX injectors anyone??
  164. NEW VIDEO: HLH0501 Turbo Compilation II
  165. Turbo Maxima -vs- Active Turbo BMW
  166. Apexi S-AFC setup
  167. Where to put the MAF sensor on boosted car?
  168. PFI Automatic KIT is Finished
  169. Valve cover vent?
  170. Hideous phum syndrome
  171. prep for turbo
  172. What are the options for fine tuning the AFR?
  173. Greddy Engine management system???
  174. 2k Max (Auto) and Turbo
  175. I'm finally boosted
  176. oh dear cf hood / SC found a slight problem....
  177. DOH! I am a retard
  178. How do I adjust my HKS SSQV??
  179. (Autometer) Boost Guage Mounting Location
  180. Ordering ASP pullies...
  181. Maps / Cfm
  182. Ordering a new V2 on Monday (BOV or not)
  183. VG30E, is it possible to turbo?
  184. V2 In - Stock Y-pipe Sux
  185. Fuel cut on 4th gear?
  186. How to swap pulley?
  187. 6 ribs to 5 ribs....plan to go down to 2.87
  188. would anyone be interested in...
  189. Why do turbos make more hp than sc?
  190. Turbo kit question
  191. Which Turbo is best for our Maximas?
  192. Stillen Supercharger Kit-V2
  193. SE-L Special Mounting bracket?
  194. Sc + Mevi + Ecu?
  195. Intercooler or Water Injection kit?
  196. Will pressure be too high if FMU is here?
  197. I wanna buy a turbo
  198. New clutch when installing SC
  199. Installing Stillen SuperCharger on 1995 Max
  200. Installing Stillen SuperCharger on 1995 Max
  201. Blow off valve install question
  202. What's the optimal AFR?
  203. Let's talk V1 SC Torque Fellas
  204. Does anyone have a write-up for the Apexi S-AFC II Install?
  205. V2 SC install issues
  206. CAI on a SC
  207. I've decided [Supercharger Questions]
  208. BOV inquiry - Blitz Dual Drive
  209. ok I am boosting an experienced engine.
  210. Autometer boost gauge
  211. Engine life with turbocharging?
  212. What weight oil are you guys using?
  213. Interesting find on blower...
  214. Question for the Turbo guys....
  215. turbo for auto 2k2
  216. What is boost bleeder valve?
  217. healp please listen......my SC need advice
  218. What I did during the Super Bowl
  219. turbo, supercharger??
  220. Dyno (finally!)
  221. Compression test results :)
  222. So how long did your auto last?
  223. Just changed spark plugs, now I keep getting the 0115 code...
  224. There's gotta be a way to boost sooner w/o changing to a smaller pulley...Rods?
  225. Rebuild Decision Criteria
  226. Running Max during rebuild
  227. How can you tell if you were running rich or lean from looking at used spark plugs?
  228. Why does my BOV sound better facing passenger side than driverside?
  229. Walbro FP installed, have a few ?'s(long)
  230. 2000 Maxima Turbo or Supercharger
  231. Turbo piping
  232. Need Help converting my boost gague reading.
  233. Just got my intercooler in-what you think?
  234. 15psi I could not believe my eyes.
  235. My car completely died on the highway today
  236. Progress report and alternator question
  237. To NOS or not to NOS that is the question!
  238. Intercooler
  239. How to adjust alternator belt with the dam Blower in the way?
  240. Check this out
  241. ok car is broken...LONG but need HELP !?!?!?!?!?
  242. 3 options of Motors....help decide
  243. Completely lost on this fuel pressure stuff....
  244. Warning: Low Fuel Light started fading in and out, but my fuel is not low?
  245. Who has a walbro fuel pump on a 5thgen?
  246. Hobbs switch mod help
  247. Need part no. on for these two parts of SC
  248. what is everyones fuel pressure at idle
  249. Does anything else need to accompany a smaller pulley??
  250. Fuel pressure equation
