PDA
View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26
  1. What the **** is up with my boost controller?????
  2. Your Opinion Wanted On These Components
  3. For those of you who need the Stillen v2 K&N Filter Replacement
  4. Throwing 3 new cel codes.. please help (slightly long)
  5. Where can I get an FMU?
  6. SuperCharger+NOS #5124 Kit
  7. HOpefully getting my problem solved....
  8. Fuel pressure gauge reads 7psi?
  9. Question regarding vacuum fitting on intake pipe
  10. melted pulley
  11. Piping for the VE30DE
  12. 5th gen saafc instructions?
  13. changing pulley, have questions
  14. help guys, my belt shredded!
  15. Stillen Supercharger Parts
  16. Supercharge OR Turbo??
  17. A cheap way to lower my fuel pressure?
  18. questions about the cartech FMU
  19. Where is your afc mounted
  20. supercharger belts
  21. Cutting bumper?
  22. apexi s-afc and engine codes
  23. Exhaust Question
  24. Dyno Sheet w/ Supercharger
  25. Time for new injectors...
  26. Trust 300zx maf plug - HELP from jdm parts people
  27. Where did most of you get Your SC for the 2k???
  28. belt size?
  29. Lower Compression Engine
  30. Suggestions for wiring boost controller, turbo timer, SAFC
  31. MY Vacumn line question
  32. Turbo Preparations
  33. Which Turbo kit is better Hals kit or PFI's Kit?
  34. Vacuum Line Routing with Wastegate/Turbo/Electronic Boost Controller?
  35. Anyone heard anything about PWR barrel awics?
  36. exhaust problem when boosting?
  37. Rotten Egg Smell...
  38. volumetric efficiency estimate
  39. A Semi-Unpractical Question...
  40. Ok, Guys I am gonna sound stupid but VE30DET
  41. How do you run the lines for the Vortech FMU WITH a SARD FPR?
  42. Maf's and other car
  43. How many of you guys run the stock fpr with Walbro?
  44. turbo 3rd gen
  45. To Charge or not????/
  46. To clear up the MAFS placement issue..
  47. Redmax Engine Blown!!!!
  48. Turbo installation
  49. What adaptor do I need to hook my AEM FPR to my fuel rail?
  50. Questions about Supercharging
  51. Which turbo kit?
  52. Who is using an oil restrictor?
  53. My EGT gauge bobs with my music!! Help...
  54. update on my project
  55. Tial Wastegate
  56. i swear im dumb---need help with turbo kit info
  57. injectors
  58. Supercharger N00b Question
  59. How can I lower my FP with the Walbro and Cartech?
  60. Air/fuel curve..
  61. Q for high torque boosted ppl
  62. HEADS UP: UR SC Pulley is now available!
  63. intercooler goes woo woo...
  64. Oil Return Lines for Turbos
  65. I'm thinking about getting a later model 4th gen and transfering what I can...
  66. Anyone with a Z-32 MAFS?
  67. BOV discovery (a tad long)
  68. Fitting turbo kit into early 5th gen
  69. supercharger V2 for sale
  70. where is the instructions on how to install the walbro pump???
  71. Pating Out SC Parts.. Here's some deals for you boost whores :)
  72. is a Apex-i AFC II worth it
  73. New custom turbo design.
  74. supercharger intercooler?
  75. what electronics are needed for turbo? :)
  76. Exhaust size questions
  77. Where to get a used SC for a 2k???
  78. Anyone regret getting boosted?
  79. Can someone explain how our "stock" bosch bypass valves work?
  80. day & night boosting diffrents?
  81. Where o where to mount the MAF on a boosted car??
  82. Oil coming from crankcase vent?!!!?
  83. New mod/ replacement
  84. *I THINK* I found the cause of my high EGT at partial throttle
  85. What is safc telling me in regards to air flow?
  86. is it possible to s/c a 2k2?
  87. oh my god!!!!!
  88. aux. fuel pump question?
  89. Stillen Exhaust vs 5th Gen
  90. At what boost pressure do you have to start worrying about the head gasket?
  91. upgrade time....
  92. FMU Question
  93. Insurance Rates
  94. Turning up the boost!! need help.
  95. Fuel Worries
  96. standalone fuel management
  97. Taking out S/C
  98. Turbocharger Question
  99. stock pulley!
  100. Oil Qs
  101. My changing role
  102. fuel setup
  103. sc guys plz help!!!
  104. engine still stalling!?
  105. BOV - it did not fire @ 10psi?
  106. Vortech FMU disk change
  107. Installing Electronic Boost Controller WITH Wastegate Questions
  108. Manual Boost Controller question
  109. engine stalling problem w/sc?
  110. Question about boosting turbo and SC
  111. SC CAI question
  112. Turbo being installed
  113. just got my newest mod, actually 22 of them
  114. a/f guage how accurate is yours?
  115. Poll..... Upgraded ECU or SAFC??
  116. What's the "Stock" SC FMU disc?
  117. Do I need to grind the plate for a 3.33" pully?
  118. Compressor Maps
  119. Turbo Help and questions
  120. smaller pulley or 7000 rpm redline
  121. Supercharger + Engine swap question
  122. Supercharger Pully Bolt part number
  123. V2 s/c air filter replacement?
  124. what does ur boost gauge read when cruising?
  125. Anyone boosted with a high knock count?
  126. Which Piggy back???
  127. Anybody have experience with the Vortech Super FMU
  128. sx7r Need your opinion on these
  129. 300z TT Injectors
  130. Compression Test
  131. passenger window..and blinking airbag light
  132. Turbo and UDP
  133. Thinking about fuel delivery.. opinons wanted
  134. Stock internals how much boost?
  135. where to install superchargers in San Antonio/Austin area?
  136. Crap, It's time for smog!
  137. Gutted Random CAT
  138. Dyno/FMU Problems PLEASE HELP
  139. SAFC Settings / Functions
  140. buying parts from Stillen for a 2nd hand S/C, any problems from stillen?
  141. Tuning/timing retard stuff..
  142. Do you think that boosting an 100K car is good?
  143. 80 psi fuel pressure...at idle!
  144. Lower compression pistions
  145. when do you see peak boost?
  146. Oxygen Sensor Voltage Readings
  147. Freaking Oil Leak!
  148. Who sells turbo kits for our cars?
  149. Simple Turbo Question
  150. auto S/C question
  151. DSM T25 Turbo
  152. sc cai piping?
  153. Starting my own turbo project
  154. bigger injectors
  155. Blown Engines
  156. Installed the Dayco Poly Cog Belt
  157. Surface Fatigue on Idler Pulley
  158. Don't you hate screwing in Bolts #14 & 15?
  159. Turbo Maximas: have ANY of you gone to the track yet?
  160. auto or manual conversion?
  161. Ok.. I am going to an 8:1 fmu
  162. DYnoed today - interesting results.
  163. is there a fi 02 or 03 car out there?
  164. OK - I need ideas
  165. Backfire at mid RPM
  166. new supercharger
  167. ok guys... what's next? (SC question)
  168. WTB- 3.125" Pulley!!!
  169. Anybody have a 3" pulley they want to sell?
  170. Abslote Pressure Sensor?
  171. Turbo question
  172. Question for turbomax's
  173. FMU Disc with 3.33" pully
  174. need help with supercharger
  175. Can I SuperCharge a 1999 Maxima
  176. If you want a cheap manual boost controller .. here you go
  177. My Blow Off Valve Stopped Functioning
  178. 3 Questions
  179. Turbo boost bleds down the closer I get to redline
  180. True or false: 370cc injectors can be used with unmodified ECU
  181. Turbo Maxima on LI NY?
  182. sc guys need your help!!!asap
  183. questions about S/C kit
  184. for does who have put a turbo in their max
  185. Take me off the SC list
  186. A question about SC and auto tranny's
  187. Shop to install SC in CT/NY area?
  188. Questions for SC Masters????
  189. Made a change to car...seems safe enuff
  190. &$%&# Clutch!!!
  191. need help. still stumbling.
  192. how fast should i be?
  193. Manual Boost controller or New wastegate spring?
  194. Turbo question
  195. Can I get some help? (ATTN: turbo97se)
  196. My newest addition
  197. Diff between 97-98 and 99 supercharger kits?
  198. used SCs
  199. For those that have not seen my turbo kit!!!!
  200. I need help with alo tof vacuum lines.
  201. FPR question
  202. wtb used supercharger
  203. Couple Turbo questions...
  204. Wtb: Fpr
  205. V1 or V2 supa
  206. turbo
  207. question about fmu
  208. More fuel woes
  209. S/C the max again?
  210. Twin Pipes into turbo.
  211. Power Yields for 60-1
  212. How long a NEW engine before...
  213. Start up problem
  214. Toluene...
  215. RT Cat concern
  216. Code 0803 manifold absolute press sensor...
  217. 0707 Code and it's relation to boost
  218. Need help identifying SC parts
  219. MAF sensor placement when boosted
  220. Another oh ****.
  221. What's the size of the belt and stander pulley for SC?
  222. Just uploaded new pics
  223. VERY rough idle upon start up???
  224. To those with turbo's what rpm do you see the boost start??
  225. for charged and turbo'd max's
  226. Blower Question
  227. Lag under partial throttle
  228. 3'' exhaust
  229. Would you switch from a s/c to a turbo?
  230. Time for me to replace the drive belt again?
  231. coolant lines for turbo
  232. Belt snapped and bolts stuck
  233. SC guys (mainly V1): More power and an Eaton roots sound...belts DO make a difference
  234. Gates or Gatorback - where to buy?
  235. Turbo Reliability
  236. Who is that sells just the MAF
  237. compression test and running lean
  238. Supercharger Or Nitrous?
  239. Question About EGT Reading. It's Too Low!
  240. Need Quick Help!: Belt Size to run with 3.125" pulley??
  241. launch w/ s/c
  242. Another Turbo???
  243. how much power?
  244. I Really Really Want A Turbo!!!now!!!
  245. Autometer Bulb Change ...
  246. Sound Clip of Blizt BOV?
  247. what the hell
  248. I need some faith from the gurus
  249. Results of my compession test :)
  250. Turbo in my Maxima
