- turbo
- Question about lowering base Fuel pressure & 370CCs injectors
- programming scaf2 to work with a turbo I30
- BOV Question
- Car won't start.. need help again
- Turbo Exhaust Questions
- Where did you tap into for the Boost Gauge?
- Steering Column Mounted Gauges
- So, the 4th and 5th gen kits aren't exactly the same
- i think i found my missing boost...
- I was told not to use my fmu
- Bad gas!
- S-AFCII or E-Manage?
- Did I tap into the wrong Fuel Line for the Fp gauge??-->>
- Needed.. pics of the bronze vaccum lines and hoses
- Vaccum @ 8 hg and EGT is 400 C @ 2500 RPM..thoughts?
- Wooooo Hoooooo!!
- Shopping for A TURBO...
- cartech fmu questions
- radiator question
- oil lines ?
- Engine swap is completed, I am done! car fired up very fast :)
- Contemplating boost....
- Fuel pressure Reguator/ riser?!?
- shreaded belt worries
- Where can I learn about boost?
- Nearly Free +10HP Gain!!
- JWT SC ECU, 370cc Injectors, and Cartech FMU.
- T28?
- got the 300Z injectors whats the Base FP set at? 30PSI, 29, 20PSI
- Which is better? Vortech Super FMU or Cartech FMU?
- need your help guys..look inside
- turbo or s/c
- Thar she blows
- It's got a HEARTBEAT!!!!
- 3 dolla intercooler sprayer in January SCC Mag
- Just bought the Greddy E-manage
- how many have blown-up???
- Supercharger vs. Turbo
- Engine Knock
- Need some help! Vortech Super FMU owners? I know how to adj base fuel pressure, how?
- umm, look what I found!
- FS: Apexi S-AFC II
- Who has blown a 5th gen maf by putting it on the charged side?
- Yes a 5th gen Supercharger will fit a 4th gen maxima except one pipe
- Made leaps of progress today
- Disappointing Dyno Numbers
- have a chance to buy VQ30DET engine or parts!!!
- BOV question...
- stainless oil line question?
- If today were a measure of forward movement... I would still be in bed
- Engine Volumetric Efficiency and Boost Controllers
- a new turbo kit
- bracket snapped and alternator bolt ?
- For all those who have EGT & BOOST!
- Engine install day 1, 1.5 hours
- what happend to...
- Inexspensive Turbo/Supercharger???
- For those looking for a Stillen Supercharger for 5th Gen
- Fuel pressure equation for FMU w/stock FPR?
- videos
- Just my thoughts....
- Video: 9.5 PSI turbo max vs my Supercharged 10PSI max
- boost to 7.2k is delicious :)
- e-mailed some companies about manifold
- i think you guys need a new FAQ in here...
- Is there such a thing as an engine scope?
- How often should you replace copper spark plugs?
- is 1700 too much for sc
- Pics from today.. Thanks dixit
- Question about bolts on the flywheel.. do you need all of them?? :wall:
- How to do a compression test?
- Video: after the meet video, SCed max, stock and boosted GS400 500HP Supra
- Almoost!
- Will antilag crack our manifolds?
- turbo?
- EGT temp problem. NEED HELP.
- thinking about tc/sc
- Less power with underdrive pully?
- those with a vortech charger
- dyno'd the SC setup...
- Dyno'd at 285 hp/240 tq
- Hypothetical question for e manage users
- new VID: Turbo Compilation III
- SC launch tips
- nominal egt?
- BOV Leaking Air...
- BTW... BHP.. Stands for Brake Horse power.
- What things to expect about the PFI Kit
- s-afc 2 detonation feature
- Grrrr Half way done
- thought u guys s/c guys may want a little laugh...
- 350Z injectors
- BOV's
- More Supercharger ???'s
- Is it safe to turbo a 135k Maxima?!
- Boost Controllers
- z32 maf
- supercharge my max? or no?
- Bags' progress - it's gettin there!
- Who will make this work on a 2k2+ Max?
- my personal turbo kit - for sale
- supercharger or turbo??
- LS1 kill post, from him on another forum (+vid)
- Turbo Maintenance
- driving a turbo car
- Video PFI kit T4/T4 turbo kit vs supercharged Z28 part II, and trans am WS6
- got three engine codes need help
- Need opinion on 1st gen DSM Eclipse BOV
- Fuel pump wiring - Tell me if this is wrong......
- is 262hp and 239tq normal for 9psi???
- look what I got!!!! :)
- Injector / FPR / Fuel Pump Guidance Please
- air/fuel gauge
- what were Jay25s Turbo Dyno numbers?
- running turbo off front bank only
- The Injector Thread
- Supercharger and Fuel Injector questions
- where to get vacuum switch for aux fuel pmp?
- Help, problem with wiring fuel pump!!
- What Injectors are these?
- 5th gen turbo
- Fuel Pressure Help please.
- HELP! I want to build a engine that can hold 15PSI, where do I start???
- 5th gen turbo A/T question
- supercharger question
- What wheel/tire size combos are you guys using?
- Day 2 and 3
- turbo size question
- AWIC project (Part I)
- Anyone have a SC they are trying to sell?
- 10 psi+ SC ?
- 4th Gen. Turbo kits
- Clutch Dilemma: Need Opinions....
- aux. fuel pump help.
- size of DOWNPIPE
- IAVC line placement with boost.......
- Injector O-Ring Part Number
- Holley adjustable FPR w/1:1 boost ratio compensation
- Turbo finally here...
- Dyno Tuning??
- More bagy pics!
- SC Concerns and ????'s
- Want my car to be fast...Turbo or Supercharger???
- Ceramic Coating of Intake Piping.
- Raxles
- Guestnx/hal's thread was very similar to my problem... thoguhts...
- Where do I tap my Boost line
- Need an intercooler??
- GReddy eManage USERS
- Shaving Walbro fuel pump for 2000 max
- Roots System is COMPLETE, but w/ a few ungodly kinks. (need HELP)
- Turbo max, and sh!tty idle... HELP!
- Need Opinions on Poly-filled Motor Mounts
- slicks and lightweight wheels for sale
- Advantages/Disadvantages to Running 3" Intercooler Piping
- 3" intake piping from blower to TB
- Day 1
- Lookin for fittings to tap My Pan
- 370cc Injectors installed
- What are pintle caps...
- Nismo 555cc Injectors + e-Manage
- Lots of Sound and Video clips for BOV's
- 3.125" pully. Impression and problems
- I'm about to install my AEM FPR
- Moved: Anyone With Wilwoods Also Have Speedbleeders?
- How many of you have another daily driver
- 2k2 - 2k3 SC Available ?? Yes / No
- What are the differences between oil injection and water injection?
- Best place to buy Nismo injectors
- Haltech EMS E11 - Works for the RB. How about the VQ?
- Turbo my Maxima?
- Saving grace...
- What motor mounts are you using?
- Dual exhaust would we loose power?
- ve turbo
- Homemade octane booster
- Injectors by Russ Collins of RC Engineering
- CJWT ECU and trading out.
- Does anyone use this tuner?
- EGT Probe Location
- How do I run FI with my DPI nitrous kit?
- which clutch did you guys use?
- Sadler's dyno
- Anyone ever heard of these DYNOTUNE digital gauges?
- SAFC Questions
- Overspinning the SC
- Bliiiiing!!!!
- my recenty fuel pressure observation:
- 60 gph, 110psi rated, Airtex inline pump - will this....
- Need Help on this One?
- Where can I find a 9/16"-18 thread plug?
- SC oil return line is a nissan part.
- Flanges
- 30 Psi ?
- Still selling my custom pistons and rods, but now with a FREE engine with 14k miles!!
- Intercooling a SC... Help from turbo guys would help to
- Should I install my V1 or wait a while for a V2 trade
- My last plea for help before I rip out the SC...
- Things not well in baggy land
- And another try at a post!
- How Many Miles With Supercharger?
- BOV Mating Call ....
- 4th Gen injector pics (90-94 Z32, 95-96 Z23 and A32)
- Turbo
- Hesitating in 1st and 2nd
- Air or fuel problem?!?!
- finally found my turbo flange..with pics
- Just got a call from Vortech
- Pathfinder throttle body install
- Turbo97 or perhaps turbo95max Clutch???
- Washer Resiviour location and K&N P/N
- Best Gas Mileage?
- turbo
- ReRouting Power Steering Lines
- Can I go to the track without tuning?
- Gapping my new BKR6E-11 Spark Plugs
- going boost soon but some ?'s
- Noticed small amount of gray smoke
- 6th Gen Turbo Kits?
- What trim is the V2 Supercharger?
- How do I see if my Fuel Pump is dead?
- Video right clik and save as, me getting owned by a turbo max, WRX Vs 10PSI SCed max
- S/C 5 way T or 4 way T Q?
- And the saga continues...Need Help =)
- Help! Little Plastic T (Pic Inside)
- Turbo Pics Finally !!!
- Ony One using DEFI Gauges
- How many of you are running 300+whp with stock injectors?
- Injector questions
- Help Setting up Vortech SFMU
- ? about going Turbo
- Part # for ASP pulley bearings?
- V2 peeps....rpm dropped at dead stop?
- New to the turbo game... point me to good prices on wastegates, intercoolers, guages
- SAFC deceleration setting
- More Pics of SeximaGTR's motor. Ouch!
- pros and cons of a SC
- anyone using the sard fpr???
- Advise on SC or Turbo set up for Road course application
- 3" mufflers, what do you have? what do you like?
- My Roots dream is becoming a reality!!!!!!!!!!!!!!!!!!!
- I want SC NOW!!NEWBIE
- Part Numbers for 370CC injectors?
- Is injector cleaning/blueprinting worth it?
- supercharged max...
- My Custom Turbo-Kit Finally Running
- Who did not re-route power steering lines for SC?
- Did I get the wrong 300zx injectors (PICS)
- What turbo kit is better for a auto ???
