- Cartech FMU and SAFC2?
- Got a few new toys!
- compression on my motor
- Supercharging Guys PLEASE LOOK
- What gauge is more important ?
- Who's got an Oil Catch Can?
- Atmospheric BOV vs recirc
- boosted guys with battery relocated
- Z32 MAF messing with your timing?
- Boost activated "Virtual Exhaust System"
- Lets send some "car" magazines to JAY25
- The cost of FI
- NA vs FI
- Fuel Pressure Problem Part 2 ??
- How much do pfi kits go for these days??
- JWT ECU Data Logged AFR!
- master power t4 gt45 1.05 a/r
- Turning up the boost
- Round #2
- Wastegate/ PFI kit question
- 5 Speed Tranny For Sale
- Where to mount the EGT sensor
- SC/Turbo Max Poll
- HELP! have 3.125 pulley on s/c but only running 5psi, why???
- Thinking about running a 2.87 pully on my charger WHAT DO I NEED?
- Boost gauge options?
- Exhaust cut-out questions?
- Fuel management with the Stillen Supercharger kit and Turbo's
- safc 2???
- Apexi Gauges & Blow Off Valve
- sc price question
- What do you guys think about this wbo2?
- Autometer Cobalt Series Gauges
- Blow off valve for Stillen SC
- 3" exaust from warpspeed
- Turbo Prep?
- adj fuel press ?
- She's back!
- Several questions on going turbo!!
- exedy stage 1 clutch enough for my needs?
- Gauges are in...Problems !!
- turbo question
- Have emmissions this month.
- Gas Smell ??
- is this kit any good????
- She's alive!
- Max stock VQ30DE HP?
- Why my car didn't pass emissions...HELP...
- Looking at a SC this weekend HELP!
- Supercharger??Intercooler??
- opinions on wideband o2 sensor
- Low HP # for Supercharger??
- Anybody here using walbro 190 low pressure
- electronic Boost gauge problem
- Help Wiring Gauges ??
- Turbo or SC out for 02' Max???
- Finally Boosted !!!
- J&S with emanage?
- V-band clamps for BOV, WG, turbine? Good/bad?
- Hows everyone doing? I have not been on.
- Which year max is best for turbo?
- oil return line ?
- Wanted Test subject 2002+ Maxima CO area
- which gauge should I get?
- That new turbo kit w/ the small turbo...
- Since the other stand alone thread is closed...
- 02 sensor location on turbo maxima
- Mechanical Fuel Pressure Gauge, Okay?
- anyone using stand alone ecu???
- what headers to get....
- Oil Feed Line ??
- Could be BOOST time, HELP!
- Buying PFI Turbo Kit w/ intercooler and turbonics 60-1 what do i need to know?
- Selling my 9:1 forged pistons
- Hi boosted crew!!!
- More question about Stillen FMU
- MAF location on Vortech'd Max. in relation to AWIC
- Thread about 3rd Gen guy running 21-25psi w/a 11.9 1/4 mile
- I am Going Turbo, How should i upgrade my Fuel system??
- my boys 3gen turbo max doing 11.9 omg...stock motor/trans what do i need........
- Question about Stillen/Vortech FMU
- Oil Cooler ??
- Supercharger: A Few Questions
- Supercharger guru's inside please....'98 Maxima with Stillen V2 kit needs help...
- Anyone know the OD of the input shaft for a V2?
- HKS 6AN fuel rail off fitting does work on VQ30DE
- What size Intercooler?
- why a turbo is better than a s/c
- Bar & Plate vs Tube & Fin Intercoolers
- Which Oil Cooler?
- Turbo or not?
- Gatorback size
- Vortech FMU still ran after engine turned off
- cant get belt on
- does anyone know the specs on this turboed automatic??
- Upgrades?
- Trick in Tightening Belt
- Is anyone intersted in a new ASP idlery pullye for s/c?
- ?'s about 3'' Exhaust
- My car is spuddering @ 3,000 rpm
- Turbo Experts Please help me out (Read Inside)
- maf location with turbo
- Electric Supercharger
- Preparation advice... Supercharger install.
- thinking about sc'ing
- Vq30de
- Got My Bolts
- roots type s/c ??
- which JWT prog to get???
- Any 5th gens w/ a Turbo??
- More chip tunning info....
- PFI Automatic Non-Intercooled
- You Have a 2nd Vehicle ??
- Maximas came turbocharged from the factory??
- swirl valve control line??????
- 6 an fuel filter.
- Fabrication Resources
- Standalone for PFI customers
- Is it Worth spending money On SC?
- i'm new, be nice, i need to see if my setup will work
- wastgate on 84 z
- Basic Preignition/detonation stuff
- Homade race gas..
- high valume oil and water pump?????
- Help with severe Bogging Down
- Vortech V1 Kit for sale
- Car went under the knife this weekend - new intake path
- starting issue/stalling issue
- questions about i30krab's vortech powercooler
- Cam Sensor Retainer
- Help!!!! Need Pistons And Rods For A Ve Turbo!!!!
- Ported And Polished Heads
- Important Thread Links!!!!!!!!!!!!!
- quick question about AFR tuning....
- The ONLY thread about Twin Turboing a Maxima.
- Pics of 3" exhaust wanted
- help me analyze my plugs...
- 02 maxima twin turbo kit
- 370cc isn't enough!!
- pfi kit is installed but a few problems
- about to get S/C V1 kit...how to get every last drop of power?
- Long term impressions of JWT ecu (long)
- 550cc injectors
- BOV....which one to get?
- Question for all those Pros
- questions about J&S safeguard
- Oil Connection
- Running Cartech+AEM FPR
- Running V2 without a FMU?
- Boost Leak?
- What is the best compresion ratio for a turbo on a 4th gen
- turbo n00bie questions..
- Need SAFC settings PLEASE HELP
- who was the guy making the "U" piping for the intercoolers for a S/C setup?
- I need the 5th gen Supercharger instructions!!!
- Custom S/C Pulleys for sale!
- Vortech super FMU
- Where to find Aluminum Idle Pulley for V2??
- do our MAF's really max out? per say?
- Fuel rail adaptor fitting.
- Summit RPM switch
- when I go S/C, should I keep 7200rpm redline?
- what plugs to run?
- The 4 post plastic end caps on injectors...
- hesitation under boost?
- Greddy E-Manage Install Aid Please......
- Cattman Headers or WSP 3 inch exhaust system?
- Cant get Bolts off
- A little help with turbi piping.
- Group Deal for KAAZ LSD's
- intercooler question
- E-Manage Questions (and a Cam question)
- Anyone have leads on.....
- car acts weird when boosting 5-6psi...
- Project Makin My Max Trubo
- Fuel pump question
- Shaving Post for 3.125" Pulley?
- Emergency Belt (Quick replacement)
- Turbo question
- pulley problem and questions
- Thought you guys would know best..spark plugs
- cheap turbo or supercharger 2001
- How to Weld Damn near Anything: Monster Garage
- supercharger or nitrous..??
- TurboXS RFL BOV
- turbo questions
- 2003 Path Injector size?
- How do u properly take off S/C to replace camshaft position sensor?
- Does anyone know for sure what the difference between 1999 and rest of 4th gen kit?
- PFI customers ... someone missing a turbo?
- 520 hp turbo maxima
- Q45 injector???
- To those who Supercharged (Stillen)
- Stillen Part #...Bolts ??
- simple question.....looky...
- A/F w/Rising Rate Regulator??
- Oil Cooler (SC people)
- Emanage Help ( And Future Faq )
- This may not be the right section for this question but...
- AFR gauge, Dont waste your money on that crap
- oil catch can hook up
- Passing Emmissions with 370cc's
- Fpr
- Settin on Cartech ??
- How to do a SS fuel return line
- Jay25, Shadow & Mishap
- Cams FAQ
- SC and JWT cams anyone??
- What's up with this Cryogenic intake system?
- Ready to start On Internals
- Running lean in upper RPM
- SC/TC forum FAQ - please read before you start a new thread
- RUnning Cartech FMU + JWT ECU?
- Should we have an FAQ for TC/SC forum?
- Injector vs power discussion
- Dyno Results!
- what does the 3.3 pulley look like
- injector question
- **My EGT is acting CRAZY?? HELP**
- contemplating a turbocharger
- Which Is Worse Turbo Or Supercharger?
- super or turbo?
- How To: Depressurize Fuel System
- Tranny for boost...Please Help!
- I need a egt probe
- Jay25's NEW whp numbers
- 14 Psi?
- what fuel pump are you guys running
- Vortech FMU Brass Fitting ?
- anyone need an 8:1 disc?
- turbo/sc 1/4/0-60 times
- CAI on a 2000SC
- how much boost pressure can the stock fuel system support?
- after much reading...VQ30 better for boost than VQ35?
- This is why you MUST flow test injectors...
- Water cooled turbo guys.
- NEEDED... 1 370cc injector and a 4:1 fmu disk...
- question on piping strategy for custom turbo
- How to track down fuel leak?
- Garrett GT3037 (56 trim) ???
- VIDEO: SC'd 400whp 97Cobra vs. Jay25, Cobra vs Z28 & 240w/RB20 Swap:56K friendly
- problem with supercharger
- mevi Installed
- ignition timing
- junkyard turbos
- Time to add Shadow to the 300whp club
- Where do you get your turbo oil from?
- Turbo dreams
- Tranny issue.
