View Full Version : Tires and Wheels
- Tire question....
- 350Z wheel color
- wheel spacers
- for those with staggered offset...
- Need opininons on Continental Contitouring Contact CV95 tires please...
- noob question on wheels
- Experience Using Only One Pair of Snow Tires
- will 16x7.5 5x114.3 offset +42 fit 4th gen ?
- What brand?
- Entering uncharted territory...
- Flat Spotted tires?
- Gislaved Snow Tires
- My thoughts on the Toyo Proxes 4
- tires
- wat do u think of these rim plus i need ur help
- Need tires - any comments on Kumho
- Dunlop, Sp Sport 9000, 245/45/18
- Will 245/45/R18 rims and tires fit on 2000 maxima?
- Input Specific to Snows
- Whats the widest rim you can get without rub? Will 18x8.0Front and 18x8.5Rear Fit?
- will these tires fit?
- Will these fit
- 15"s or 16"s for Winter tires for 2000 GLE?
- Yokohama AVID V4S:Any good?
- How much does weight/size effect MPG, Acceleration
- Anyone recommend tires for stock 96 se 15" rims?
- Wheel painting/finishing advice needed
- 225/45/18: rubbing issue
- questions regarding tire pressures
- Check out the wheels i'm going to purchase
- Help Please - Tires for 2004 Maxima SL
- Can I take the centercap off?
- Why are my tires squeaking so loudly!!??
- WTB: 97-99 Max SE 16" stock wheels
- what kind of tires do you have?
- 235 safe on a 7.5" rim?
- Converting "Backspacing" to "Offset"
- going lower profile on 16"
- Wheel/Tire Size ?? Need some help.
- quick offset question
- new rims with 20mm offset for 6th gen. HELP!!!
- sawblades fit my 03 max?
- ContiExtremeContact - 235/40/18: $125
- these tires fit?
- 9.0 inch wide in front 4th gen
- Any Falken 452 owners out there?
- 300zx BBK guys please help me real quick
- A month past due
- Comparing Deals on Snow Tires
- Any experience with Fuzion ZRi?
- looking to swap 350Z wheels?
- 19x10's on 4th gen
- how to remove tires off a rim yourself?
- WTB: Nissan Altima SE or Maxima 17' Rims
- How low (of tread) do you go?
- 4th gen max w/ SER altima rims
- Spacers
- g35 rims
- 45 to a 50 series tire...'99 SE-L
- Offset question
- How wide can I go?
- 20" rims
- I think I have too many tires and wheels...
- SSR type C
- ContiExtremeContacts... Size question
- Blizzak WS-50
- Differences between the Toyo Proxes 4 and the Pirelli PZero Nero M+S
- 03 Accord wheels on 00 Max??
- Can this work...
- 225/45/17 winters?
- tire height question??
- Strongest wheels ever
- wheel reconditioning / repair
- Is it safe to run 225/50/17 on 17x7.5" rims...Please help!
- Fixing the Speedometer
- RSL 17x7: What other cars do they fit?
- what are pitted rims ? please describe
- Aftermarket tire psi?
- is this a good deal
- steelies to sawblade tire question
- Wheels caps won't fit?
- 6th gens and big-lip rims...question
- Bridgestone Potenza G009 compare with Falken ZE-512?
- narrowest winter tire on stock rim?
- Questions about replacing stock 12x1.25 studs with 12x1.5 studs
- Almost time to buy tires, suggestions? v.allseason
- Wheel Spacers w/18" G35/350z Touring Wheels on a 5th Gen
- painting wheels
- Deciding between General UHP or Kumho 711
- Help me choose tires
- need help with the tire size. please
- Anyone riddin' Michelin XGTZ4 Pilots?
- Falken 512 Vs. Avon 550
- question about rims
- evo enkei wheels fit max?
- Will these 18s work out fine for my maxi?
- Got My Full Tokico Suspension.. Replace What Thats Oem?
- pics of my RSA's
- is it ok to run 225/55W17 instead 225/50/W17
- 5zigen Wheels
- 215/55/17 2003 GLE Choices
- factory rims corroding?!
- 15mm Spacers on rear rubbing with 19" Axis Mods
- What happens if I go from 45mm wheels to 50mm wheels?
- Will 5x100 bolt pattern fit my max?
- Kumho rebate through 12/31/06
- All-season tires year-round, or A/S for winter and summer for spring-fall? Help!
- anyone here manage to repair/refinished polished lips?
- running 235/45/17 on 17x7 rim.. yes or no ?
- Somebody jump on this..
- financing rims in Miami?
- question
- Which do you like better (winter wheels)
- Tire time- choices narrowed to 3...
- Substiture for Mille Miglia evo 5 - Suggestions please
- anyone know the weight of the stock steel wheels?
- do 15' rims fit on 5th gen Maximas?
- 03 TE wheels on a 02 GLE
- racing hart evolutions
- need some quick help
- car verring when sterring straight
- tire question
- Help, might be getting 03 350z rims on my 00 maxima. Need help and opinions!
- What are my options for tires sizes on a stock 17" rim?
- Radical new tire design by Michelin.
- Bronze Wheels... Post Away Ur Pics!!
- Where to pick up stock 5g rims
- Infiniti G 35 Wheels on 5th Gen.
- Higher ryres
- need help with wheels offset and size...
- got free wheels wanna give them a test run...one quick ques b4 i give it a shot
- 225's On Sawblades
- Wheel offset question please help
- Maxima tires on 350z wheels
- mismatched tire questions.
- Just Picked these up
- odometer and speedometer issues with shorter tires?
- Mustang rims on Maxima
- Need pics of 5th gen on 19s
- Powdercoating
- 1mm difference in center bore- Bad?
- Wtb 22 Inch Rims
- recent experience with Exel wheels
- Anyone have pics of a white 6th Gen. with White 18" rims?
- Mille Miglia Evo 5 17" where to GET?
- The GoodYear tires SUCK
- repair/painting rims
- Bent rims- any way to straighten at home?
- Hey guys...how much $ are these wheels worth?
- help on tire selection please
- 17's or 18's
- What size wheel spacers for 17" 350Z tires on 4th gen?
- got spoiled on Pilot Sports...
- I need new tires
- se-r altima wheels
- Are 245-45-18 size tires okay for 2004 maxima SL?
- 5th Gen with 17" aftermarket wheels?
- 350z wheels with TPS on Maxima
- Altima SER wheels on 06 Max SE????
- has anyone switched to falken ZE-512 from dunlop sport A2+?
- Nail in Tire
- repairing/touching up scratches on wheels?
- 225/40/18s on a 5th gen? Anyone have this? Too small?
- Cheapest Falken Ziex 512 245/40/18
- Anyone wants to trade 03 stock rims for 04 stock rims?
- Falken FK-452
- Best Place for Cheap[er] Wheels
- what size is everyone rolling on?
- what is the color of MIlle Miglia Evo 5'S ?
- 1994 300ZX NA Wheels
- Going to get Drifz 505
- Help on Wheel / Tire Fitment
- Hankook Ventus HRii H405? any input would be appreciated!
- 15 inch sawblades
- Kumho SPT and 712
- Would you run H-rated tires on 17"s?
- what doya think?
- will STI Rims fit an 01 max
- which tires do you guys recommend?
- Blown Tire
- help deciding....
- 18x8 rims
- Question on Staggered Fit...
- Opinions on Goodyear Eagle ResponseEdge
- Need some help on choice
- 18" Rim Repair Cost?
- how to get rid of curb rash on chrome lip?
- Rims for "Maxi"
- Question about Tire Rotation
- 350z Rims
- your thoughts on new wheels
- offset problem?
- Bridgestone Potenza RE960A/S Pole Position with UNI-T AQII
- Will a 215/50/17 tire work on stock 5th Gen SE 17" rims?
- BFGoodrich g-Force Sport
- Rim offset question
- People that have or have had Pirelli's
- My rims got JACKED!!!!
- Introducing ICHIBA USA Hubcentric Aluminum Wheel Spacers
- Any lowered 4th Gen running 225/55R16?
- Odometer question= 18's vs 16's
- anyone name these rims?
- Scratched lug holes on SE/TE wheels...
- S-03s are on closeout at tirerack.
- 235/40/18 all season stiff sidewall?
- Tire size for 17 x 7" wheels
- 18X8 with 48 offset, what tires?
- :( Stang rim Question
- Simple question
- 205/60-16 OK on 2000 max 16" alloys?
- Kyowa Racing
- kumho victoracer vs. toyo ra-1...experiences, thoughts?
- quick question about 16" se
- hole from underside of the wheel ... can it be welded?
- 225/50/17, help me decide what tire!
- Tire Bubbling
- pirelli pzero nero M&S owners, step in please!
- 18x9 offset question help for TSW Vortex.
- Best DR for price
- Need Tire Recommendation for '04 SL
- z wheels for max
- Speedometer w/ Bigger Rim Question *Searched*
- What are the best wheel locks out there? Paranoia
- Will these fit alright on my 98 max w/ stock suspension?
- OZ Wheels and Tires from IS300 (48 offset with 215/40-18).
- Rim paint
- New Rims in front center cap keep popping out
- 17" G35c Wheel trade?
- 16x8 +30mm offset suggestions...
- Can i get some ORGers inputs on the Potenza G 009?
- Kumho Ecsta SPT vs. Essenza 210 Type Rs
- Ford Explorer rims on a Maxima?
- SSR COMPS.. steven88 chime in!
- 50mm Offset
- Widest tire and rim combo
- Work Emotion CR KAI
- 245 / 45 / 18 infiniti wheels, will they fit?
- Wheel Locks removal
- Enkei RP-02
- Question about stock rims...
- Will KYB's AGX shocks help?
- opinions on FLIK LEX rims.....
- Specs on '06 350Z Wheels
- Couple tire questions
- Anyone have pics of a 95-99 Max with 350Z or 04 Max wheels on it?
- Good PSI for 17's
- How much is TOO much mileage on rims
- Will 20x8.5 Rims Fit 4th Gen?
- Quick Tire Question
- Suggestions on All-Season 225/50/17
