View Full Version : Garage and Workshop
- Spun bearing help
- Crankshaft position sensor- part numbers don't fit crankshaft clip
- Hot wiring a Maxima not a theif
- Crankshaft Pully / Camshaft Position Sensor
- V2200Plus 2 in 1 jump starter and tester
- Automotive technicians rely on thermal imaging tools for efficient vehicle diagnostic
- TopScan: The Ultimate Automotive Diagnostic Tool For Car Enthusiasts And Technicians
- Lift thoughts? Lift Novice needing help.
- Unknown wiring connector
- My new toy- 1/2” Impact Wrench 18v RYOBI
- What is the ID of the tubing to bleed Maxima 2014 brake line
- Harbor Freight jackstand recall !!!
- Single Action Coil Spring Compressor?
- JIS versus Phillips Head Screw Drivers (Japanese Vehicles)
- Recommend a good but inexpensive jack
- Streamlight Stlus Pro Penlight
- Upgraded Air Compressor
- Portable Mid-Rise Scissor Lift — 6,000-Lb. Capacity
- No Garage to do my own work..what to do?!?!
- need help with the painting tools
- Installed a new garage door opener
- cleaning k&n air filter
- flexible hose clamp pliers
- Thanks everyone!
- Right angle drill for removing broken water pump bolt
- Need 3.5 to 3.0 Cam addapters
- Homebuilt Specialty Tools
- need help with trans...
- alternator. or something else?
- 06 maxima makes noise when I turn ac on after alternator change
- Garage Makeover
- Auto headlights issues
- Impact wrench
- T5 or T8 shop lights in the garage?
- Would Like Input On Getting More/Better Tools
- any obe ever strip a aluminium. fly wheel. fidanza/stillen??
- missing reverse and 1gear
- Maxima acting weirdo
- 4th gen. compatibility with infiniti
- 2000 maxima no fire
- Whats wrong with my car? Loud sound!
- Vavle cover tightening sequence?
- Is this the sound of a bad transmission?
- I30 idle problem
- abs sensor please help
- Out, damned dipstick!
- Need Advice !
- Exhaust/Cold Air Intake
- Airbag Light
- Upgraded to 60 gallon air compressor
- What is this connected to? and what does it do?
- nj: ypipe installation
- Snapped Swaybar Bracket Bolt
- Should I Change My Plugs?
- small cam gear chain removal
- Fender Finisher
- Front of car
- Dropping sound
- Dropping sound
- Noise. Ideas?
- Interesting noise - Ideas?
- 2002 maxima driverside low beam wont work
- Removing safety belt panel
- Rough idle and mysterious oil leak
- 7th gen maxima brake rotor replacement
- Home Machine Shop Equipment - Smithy, Harbor Freight, Etc.
- Torque wrench
- my investments
- '02 Maxima vq35de starting problems
- Water Jet
- Double your torque wrench capacity
- 04 3.5 SE annoying ticking noise
- Maxi shuts off randomly
- Anyone have a lift?
- New Tools
- NEED HELP!!!!!
- spark plug barrel filling with oil!!!!
- Some simple garage door security
- Loss of coolant quickly
- 5th to 6th shift fork
- assistance please
- bad idleing
- need help diagnosing a noise (wheel area)
- Hi, new guy here 1996 GLE noise
- custom fiberglass installations
- car sticks in gears someone help
- how do i jack up the engine?
- Clutch pedal hard to press
- Help with Plastic Fasteners
- Sometimes when you save a few bucks, you lose.
- 2004 Maxima Has Tranny Issues, Anyone In Minnesota Have a Good Mechanic?
- Replace Air Conditioning Suction Hose
- injen cold air intake
- Nissans concept luxury car Ellure..possible future of the Maxima?
- Creating your own carbon fiber?
- Free On-Line Vehicle/Equipment Maintenance Tracker
- Machining/Metal Fabs Service
- Air compressor CFM vs impact gun required CFM
- Does this fitting require Teflon tape?
- How do I fix this?
- ProScan OBD software
- Transmission Jack???
- Torque Wrench
- NJ local mechanic needed
- Air ratchet?
- 6 Tons
- cordless impact driver
- Can you beat me in the Grassroots Motorsports garage challenge lol?
- Any Maxima Mechanics or DIYers in Portland/Vancouver Area?
- ELMScan OBD II Scan Tool? Anyone used it before?
- Must have tools for lots of DIY car project
- some recent garage shots with some new features/arrangements/cleaning...
- What kind of electrical plug is this?
- My tools are ****. Need advice on buying a good kit.
- Anyone has a Tig/Arc/Plasma cutter station...
- My newest tool...
- primer off of moldings
- Cordless tools - What brand???
- Looking to buy a scan tool, recomendations?
- Floor Jack????
- Washing Undercarriage
- Check out my new tool box
- Torque setting
- Removing resonator?
- Jackshaft garage door opener
- floor jack question..
- Blow torch
- Stupid tool question.
- How to insulate my garage?
- Risk Analysis - Transmission Leak
- This user does not have a garage.....
- Bought my first infomerical item - The Jawhorse
- Insane garages pictures
- Total Garage Overhaul !!!
- Black Friday Shopping
- Where to paint my car
- If you have a fire extinguisher...
- Rubber notched lifting blocks
- Lighting Options
- I'll have a 3 car garage soon ... What to do?
- Head gasket removal / prep
- FYI - Craftsman Club Rewards points
- New toy!
- ac compressor removal y2k max
- Torque wrench calibratng
- My garage featured in "Classic Motorsports" magazine
- Is Laquer Thinner & Varsol Dangerous to Breath In?
- what jack stand you use?
- Removing RTV?
- Cheap impact wrench for rare usage?
- Casters for New 2 Ton Engine Hoist not Same Size
- Engine hoist leveler
- Doing some work in the garage
- Garbage Torin 2 Ton Engine Hoist
- Contemplating geting a car lift
- The new dual 80 technology looks sweet
- Hard enamel for plastic?
- My Garage
- scary story about my dad jack failing.
- Paint - enamel or urethane?
- rotor pros website
- Is a 1/2" Drive Ratchet THAT Useful?
- Tools were stolen this weekend...help me rebuild
- EBAY Torque Wrench
- Left Turn Drill Bits
- New Garage Toys
- Fastest Small Cut Off Wheel For Die Grinder
- Looking for a good floor jack...
- Got some tool storage
- Can someone tell me how to basically do the Leakdown Test
- How to clean your headlights?
- 2007 Nissan Maxima COMPLETE Service MANUAL (Downloadable)
- looking for a kink-free garden hose...any recommendations?
- Cheap OBD II scanner
- Funny Story To Share
- Which battery charger do you use?
- Air Compressor for Impact Gun
- Is it Safe to Run a Oil Lubed Electric Air Compressor in Winter Conditions?
- Suggestions for Inexpensive Impact sockets
- Pre Engine Rebuild Question.
- Anyone make their own car ramps?
- Need To Cut Into Firewall...
- So what did your garage get for Christmas?
- Thoughts on possible gun purchase, (impact).
- Nissan FAST Software - Supplement to FSM
- Bought a new toy...
- Best Screwdriver haha?
- sand/media blasting?
- Angle Wrench - For Angular Tightening Method
- What do you use to seal your pneumatic fittings?
- Some garage modification...
- Alright, what about garage heating?
- hand cleaners?
- Exhaust Manifold Studs
- Leak Down Test vs Compression Test
- ALLDATA- I need some help
- Transmission Jack - How to Operate
- Speed Sensor
- bolts that need to be torqued more than 140 lbs
- Do I need to prime a metal frame?
- Powder coater...
- "air filter" for compressors?
- What Valvespring Compressor do you have/use?
- Folks Living in Apartments
- What Heavy Equipment Will I Need to Do an Engine Swap?
- concrete sealer / topcoat
- Can we post FS threads or have a classified sticky?
- Craftsman 145 pc Mechanics Tool Set $100, usually 199.
- What does your garage look like right now?
- to get an air compressor or not.
- Oil Lubricated VS Oil-less Air Compressor
- removing screws with stripped heads
- heli-coils...flywheel bolts.
- Need a shopvac? Craftsman 6hp $17.99
- Breaker Bars
- Fixing Rust aka Car Cancer
- doing custom lighting in garage
- Socket Organizers?
- Want to buy a tool box
- Flex Wrenches or regular ratchet wrenches?
- Removing Broken Bolts.
- Motive Pressure Brake Bleeder- novice review
- Evap Canister large leak
- helicoil kit for lower crossmember? thread pitch?
- I'm running out of storage ideas.....
- Walk-Behind Lawn Mowers
- A Question For The Seasoned Mechanic Types
- Chicago Pneumatic
- Maintenance on Floor Jacks?
- Is Liquid Gasket Sealant Required for New Hose Connections?
- Question about COIL packs
- Looking at buy a reliable floor jack. What do you recommend?
- My Before and After (little tiny garage) .. oh well. work with what you have!
- mwahahahaha....
- Areas to Avoid Spraying with Ashphalt Rubber Underbody Rust Proofing
- Welder, cut off wheel...
- Heat Gun Selection
- Multimeter
- how to fix scratches in plastic gauge cover?
- thought some of you might like this garage...
- Which tool set?
- Damn plastic screw things...
- Rear wheel drive vs. Front wheel drive, which is better for maintenae?
- Coolant Flush: Where to dispose of the fluids?
- Recommend me a good sub $200 drill
- Snap-On CT4850HO or Ingersoll-Rand W360
- Lets talk about Die Grinders
- Transmission rebuid shop in Northern Virginia Washington DC Area
- My New Toy - media blasting / shot-peening cabinet
