- A caution to those adding subs
- Any help to fix my gap promblem with the gxe dash kit
- Power windows problem
- radio won't turn off after JumpStart (aftermarket)
- is anyone running a 3 way component in 02?
- Finally stepped out of the dark ages, 4th gen
- weird volume issue
- Boss Sub Question
- R34 Headlights and Clear Tail lights
- 02 maxima where's a good ground?
- Tuner Not Working
- Black plastidip
- Aftermarket stereo system
- Maxima won't start
- Anyone willing to help me install remote start alarm?
- Remote start advice and a couple other things.
- A/T Switch Light
- 2002 or 2003 oem bose radio harness
- ground wire all metal flat
- HID not working properly when switch is in Auto position
- What's involved when replacing speakers on '99 Maxima (non-Bose)
- Trunk Rattling when I pump the bass
- No sound from speakers
- electrical dissastor
- Need Advice for 2004 Bose System
- 99 se 5 speed maxima I think my ecu is on security mode no pluses on injectors
- LEDs and LED strips
- Advice Needed On Audio Components/Set-Up
- Aux in to CD Changer Input on Non-Bose HU?
- Passenger side HID headlight
- new head unit only has 1 sub output, need help.
- UPDATE: 1998 Maxima SE fog lights wont turn on.
- 1998 Maxima SE fog lights wont turn on.
- Crimestopper SP-402 Car alarm on 4th gen Max
- oem bose cd changer
- A learning experience for a cheap ***
- 2012 gps
- Repairing Bose Amp
- Focal install with custom front speaker spacers/adapters
- remote door locking
- Gas Gauge BackSpun
- 08 AfterMarket Audio Question
- Skar audio 10"vvx d4
- Mounting 10in T1 in Stock Bose 8in hole.
- How to hook up these subs
- What IS a 2002 Maxima Bose system?
- Yet another Bose question from a Noob
- pioneer in dash and boyo camera questions
- fog light replacement
- Phone mount for 7th gen max
- How Do I Disconnect this Plug?
- Python 991 never locks doors when cold.
- Why does my cap say this
- Viper Alarm programming
- 15" cerwin vega
- double din question.
- Aftermarket headunit reception prob question
- Jl 12w6v1
- Subs not hitting that hard.
- Replacing Bose speakers?
- aftermarket keyless entry trunk release
- Amp FQ and Radio FQ for Sub
- Aftermarket setup questions 02 SE
- Dimmer not working
- Rear view camera with Pioneer AVH-P8400BH issue
- Sealed box for 2 subs
- Subwoofer port size.
- Bose = PITA
- Jumper Cables Backwards = Dead Nav/Control Panel
- How to hook this thing up?
- Subwoofer pop, thump & noise fix
- 2003 Bose Treble and Bass Settings
- 09 Max. Sunload Sensor
- Time to upgrade Bose ... What's the latest/gretest in the aftermarket? ?
- Did i blow my amp or speakers
- Amp Power
- Amp Won't Turn on????
- Amp Settings
- sound
- So what alarm wires do I NOT need?
- Trunk wires to alarm r disconnected and I want to fix it
- bose stereo
- Getting Bass from the trunk to the cabin?
- Help from wiring gurus
- i30/i35 Nav Screen DP5W-3860US Wiring Diagram
- no sound from aftermarket stereo
- Replaced BOSE 8in Woofer...mad
- Best Amp for a 12in T2?
- Need Advice On New Sub!
- iPod Integration Not Working...
- how to tell is my 1995 maxima had bose radio
- 2002 maxima audio short no power fuse spark
- 5th Gen Bose system swap
- Fuse for Cigarette Lighter
- Adding subs and sub amp to stock system (no Bose)
- 96 maxima radio stopped working
- Music Box
- After market HU Fitting
- Current good double din nav units
- 5.5 gen Aux input
- Radio code maxima 1995
- What do you guys think about my amp & sub setup?
- 5.5 Gen Bloze torque
- paint dash kit to match
- Car audio setup
- Question about 04 Maxima Electrical Issue
- Helping Wireing 4ohm DVC to 2ohm stable amp
- 02 Maxima. Window and remote unlock after headunit replacement.
- 07 bose unit
- What size is 01 Maxima SE door speakers (front)
- 06 SL Bluetooth Question
- 2 AA Mayhem 18's wall vids
- Car Gauge Pro for Android
- radio swag
- Replacing bose head unit... Help ?
- Upgrading stereo system to 7inch dvd player...help ?
- Anyone installed an iPad Mini in their 04-08 Maxima?
- Amplifier clipping and in protect mode sometimes
- Will a 2k1 clockspring work for a 2k airbag?
- Installing Clarion cx501
- Adding 01 Steering with audio controls to 2k
- 6th Gen sub/amp add
- 02 Nissan Maxima SE Audio replacment help and Subwoofer questionplease
- Headunit turns on but no sound!!
- Installing my alarm by myself *Help please*
- Advice Needed to Upgrade Bose Speakers & Amp
- 97 max headunit
- 2013 Max audio/video questions
- 2009 nissan maxima
- Transistor Horn install
- Help Need Input
- Nissan Maxima 2001 GLE Electrical Problems...PLEASE HELP!
- How do I wire up two headunits?
- ?? 7th gen alternator??
- Strapping Bose amps together?
- what viper unit do I have?
- Wiring High Level input to Bose stock
- Is Blu-ray ever going to get into the car audio/video world?
- Blower and stereo malfunctions
- 4 Channel AMP
- 2003 Nissan Maxima SE Bose No sound
- AIS-NIS2 vs. isimple vs. USA Spec?
- 1995 Bose Radio replacement questions
- Rear Camera in the back?
- 2006 Bose (No Navi) upgrade tech options?
- have searched everywhere and have gotten 17 different answers
- Stock BOSE System Sucks..?
- 98 Maxima GLE Stock Bose won't play new CD R
- Need help finding HO alternator
- Upgrade from stock BOSE head unit?
- A question about my viper 591xv.
- Issues after replacing headunit in 02 I35
- Suggestions or changes to my potential new system
- 02 Max Sub Question
- Is this decent for $400?
- 15.1 Cubic Ft... Whats the dimensions? Also How Much...
- 97 Non Bose wiring harness
- Best Position For Subwoofer Box For Loudest Interior Rumble?
- How does In Dash Navigation work?
- Stock Bose sub cuts off.
- Bose speaker problems.. help?
- Kenwood still a good brand?
- Nissan 07 Maxima Bose Aftermarket Problem
- rca question
- 500-600 watt class D amp suggestions?
- Much Rattle, Even after Dynamat - Please Help?
- Is this type of HU upgrade possible?
- 2002 Maxima...To replace complete sound system???
- recording DVDs
- Adding Subs
- Bose System Draning battery
- Walled '97 I30
- Getting a stuck PIN out of a harness connector
- Keyless Remote working sporadically
- Homemade In-Car Camera Mount
- should I get a TomTom Nav?
- wiring a speaker level to RCA output converter to wires on back of bose sub
- Firewall opening in 7th gen
- Question about annoying remote wires not working with after market head units.
- Best Amp wires?
- GReddy Blue main harness
- volume to low with after market headunit
- Aftermarket Deck Install - Dash Lights & Tilt Steering Fail
- Replace head unit on '02 Maxima with factory NAV
- 2002 Factory CD player
- Need help with speaker n amp choice
- How Do I Check Door Speakers
- Navi System
- Any interest in custom 7th gen sub boxes?
- Kenwood head unit install issues
- Help with sub decisions... (model knowledge preferred)
- GREAT tester song......
- converting power window door harnesses...
- Hardwired Micro USB
- solobarics
- make a audio IN (aux) on bose radio
- Lost sound to my subs
- Alarm not functioning can I buy an OEM remote?
- Stereo randomly switches inputs on its own?
- 1993 Aftermarket HU - by-pass bose
- relays/fuses
- Touch Screen Headunit
- BOOM BOOM (Installing Two 15'" RE Audio Subs) Noise/Rattle Suggestions?
- Definitive opinion on Metra 70-7551 for adding HU to 4th Gen Bose without pops
- WTB: 1997 Bose Stereo Double DIN
- good clean sound suggestions for high and mid staging?
- Stock bose subwoofer help!
- two twelves in the rear deck of my 02 maxima?
- Bose system no sound
- Touch screen head unit, Help!
- 5.5 Gen Bose Replacement Ideas/Suggestions
- factory speakers not playing
- In need of an alarm ASAP!
- Is this all i need to install my new stereo?
- Cell Phone Charger Causing Static on radio
- Quantum Audio 3500D Any Good?
- Cerwin Vega restoration project (Pic Heavy)
- 07 Maxima HU removal
- Please help asap with radio fuse!!!!
- Need help w/ crank sensors (phase & POS)
- Why is it that only one of my speakers work sometimes?
- Remote start not working need assistance
- audio help
- Pac SWI-PS compatability question
- 5.5 Gen Head Unit mounting question
- How do i remove rear winshield panel
- Aftermarket Stereo Install Gone Wrong
- 02 with bose speaker depth?
- 98 Cluster Wiring Help needed, please help
- very series problem in my 2011 maxima SV Pre
- How do I achieve my audio goal?
- Radio Stopped working after navi removal
- Navigation and Entertainment system
- Audio Build
- Will 99 GXE factory harness fit 00 GXE?
- up-to-date headrest monitor suggestions?
- Adding subs: Please confirm all of this.
- How Should I Go About Adjusting Stereo EQ?
- How do i go about running new antenna wire in 4th gen?
- 2003 Maxima Bose power & ground pins?
- 00 Maxima SE w/ Bose
- Complete stereo install 2004 Maxima SE
- JVC car receiver and iPhone, anyone have this combo?
- CV919 6 Disc changer harness or adaptor
- No subs need help
- link needed (?) aftermarket radio and scosche slc4 install..0.o
- Replaced Starter - Remote Start Issue?
- non-Bose speaker replacement. Want Bose
- Built a new 4th order bandpass box in my 4th gen
- NEED HELP!!!!!
