PDA
View Full Version : Audio and Electronics
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83
  1. Opinion on Alpine Subs
  2. Is one 10" enough?
  3. newbie w/ no car audio knowledge...
  4. How many subs???
  5. New project.
  6. Mounting Mono Amp On Sub Box...
  7. What you guys think
  8. Need opinons on upgrade!!
  9. New HU
  10. Need help hooking up my system please. 300zx thread.
  11. Specific HD radio reception question
  12. Plz confirm: Factory battery ground cable not needed after Big 3
  13. Running speaker wire into the door
  14. 1/2 DIN Equalizers (Don, Anyone)
  15. Installing tweeters correctly
  16. Just bought two MTX Blue Thunder 1000w 12s w/ Kenwood 600w amp, boxed for $40
  17. Alpine Amps
  18. eBay tweeters
  19. my weekend project
  20. BOSE aftermarket HU Question
  21. speaker junkies help please
  22. Lanzar Amps
  23. Audio guru's thoughts on this amp?
  24. Dynaudio and TRU amps, I took a good listen
  25. Too sexy to resist ..
  26. Pioneer AVH-P4000?
  27. Opinion on Arc Audio
  28. Question about EV's
  29. What amp with 3 JL 10's
  30. Memory backup trick of HU
  31. Replacing Factory Stereo W/ Another Factory Stereo
  32. Wiring problem? Frying amps
  33. perfect fit sub box
  34. where do i hook the backup signal wire to
  35. Odd thump/buzz from sub woofer
  36. Pyle Driver amps, any good?
  37. Quick n00b question about 12v vs 14.4v amps
  38. Installed amp, Could use advice on good setup
  39. Eclipse AVN6620?
  40. Electrical Gurus, how do I size up the correct size Rheostat to lower voltage??
  41. Valor ITS 700w In dash 7" touchscreen
  42. Grounding a multi-ground terminal?
  43. Opinion on INFINITY REF7541A
  44. Amps to choose from..what ya think?
  45. Wtf is up with eclipse amps?
  46. aftermarket hu with bose system
  47. Adding Speakers to Bose System
  48. Help Jump Starting Alarm won't turn off
  49. Another new toy ..
  50. Bluetooth question
  51. if i bypass the bose amp......
  52. Yay Box dimensions
  53. need advise on a alpine installation
  54. New amp and woofer wireing
  55. ghetto sound deadening idea
  56. Anyone recommend Arc Audio FD6000 component speakers?
  57. In dash navi question
  58. Just need a lil help deciding.
  59. Looking for some HT stuffs ...
  60. Stereo Woes
  61. Looking for an amp
  62. *Can an EXPERT audio guru tell me the specs of this box??*
  63. ipod location
  64. need quick help deciding on which amp...please and thank you
  65. Trying To Install These Tweeters in Door Panels
  66. Can I wire Two 4 ohm dvc subs at 2 ohms from a mono block amp? (pic inside)
  67. Bose headunit question. Yes another one and of course I searched.
  68. Today was a sad day...
  69. 2v vs 4v Preamp outputs what is the difference and which is better
  70. need a new headunit which is better AVH-P4000DVD or DDX512
  71. CD7200 MakII
  72. Window Roll Up or Down module
  73. 5th gen Bose sub question
  74. rd audio
  75. Where to Wire Crossover - 2002 BOSE
  76. Bose amp and subs only 2 pre amp outs how do i hook it up?
  77. Audio Install - Recommendations
  78. What is a good double din in dash DVD player for $400 or under?
  79. Look What I Got...
  80. New Plan of attack - questions
  81. how to series wire subs??
  82. how do i hook an amp to a Headunit without a subwoofer (non fader) pre amp out?
  83. Avic-D3 Bose Wiring
  84. 1/0 gauge adapter
  85. Which Head Unit is better Clarion VRX765VD or Pioneer AVH-P4000DVD
  86. 2002 BOSE HU removal
  87. 2002 Bose Sound system
  88. How do you wire these damn cross-overs?!
  89. 8" midbasses & subs in my doors & deck (log thread)
  90. Slight farting noise from left midbass driver
  91. happy bday to me
  92. Painting dash kit?
  93. hi gays :)
  94. need help removing stock cd player
  95. Put on new wheels, subwoofer now broken
  96. Whats the deal with rainbows?
  97. Mmmm goodies ..
  98. infinity basslink sub
  99. Mounting 10" subs on rear panel
  100. AVIC-F90BT
  101. Just had a wicked good install done: Wanna see?
  102. Blew A Speaker After One Day
  103. Bose Amp Bypass Harness
  104. 4x25 enough to power front channels?
  105. Laying Wire For Speakers
  106. Speaker Wire?
  107. Adding Ipod/Aux input to stock 2003 maxima bose
  108. Prestige APS410 Alarm help
  109. THE orgy GD of the year !
  110. Battery Connections
  111. '63 Corvette build
  112. what needs to be done for rear trunk rattle 5th gen
  113. Keyless Entry Remote
  114. push button/remote start compatiblity?
  115. how do i take out my stupid radio
  116. Replacing the Front Driver Side Speaker
  117. where is the pink wire suppose to go? need help ASAP
  118. New Deck
  119. 8" midbasses in a 4th gen?
  120. Looking For Wiring Diagram...
  121. Wanted: OEM Bose Head Unit for 99.5 SE L
  122. IXOS 4Awg kit GD?
  123. More Rainbow SLCs?
  124. Head unit pre-out voltage
  125. Pioneer Sound Build off...
  126. How to connect Ipod Touch to H/U
  127. Anyone Mess With The Arc Audio FD Series?
  128. need some direction with install
  129. Amp Kept Shutting Off Today...
  130. Dyn Esotar2 has arrived !
  131. best buy sound systems?
  132. Don't know how long this will last v. Amp Kit
  133. Alarm (Ungo brand) Not Working - Replace Main Unit?
  134. punch p3
  135. Best 2002 Single DIN kit?? PICS??
  136. MDF Ring spacers...yes, please.
  137. I am shopping for an amp.
  138. Non-Maxima stereo question...
  139. WOOFER BOX OR TUBE ???
  140. IVA-W505 Compatible With 00 Maxima?
  141. Bettery voltage?
  142. 5.5 Gen High OUtPuT Alts? Ne1 Got ONe?
  143. 04 w/ stock bose...adding sub!
  144. 2004 6th Gen/ w bose..Adding a Sub!
  145. Where to buy MDF?
  146. Been a special week..halfass build log...
  147. Where did you guys ground your system in the trunk?
  148. Using HP/LP filters on amp
  149. No power to H/U
  150. Yay for Scosche. Got my D3 in.
  151. Dim Lights? How do I remove faceplate?
  152. Brainstorm: Poor aftermarket radio reception
  153. Safe to Give 2500watts rms to 2 RL-p15's?
  154. Pioneer FH-P8000BT double din size.
  155. Looking for alittle bit more Bass
  156. Eclipse time-alignment
  157. Bose VS...???
  158. 03 Max Double Din Dash Kit
  159. Running new speaker wires 5th/5.5 gens
  160. quick question
  161. 99 to a 94 bose wiring diagram
  162. Crutchfield Referral Code ($20 Off)
  163. Going to install viper 5900..
  164. microvision + ipod
  165. Larger or custom headrests for LCD screens...
  166. New HU: Bose Speakers Popping
  167. radio problem
  168. adding bose to non bose
  169. ***2008 EAST COAST MEET 5/18 (Queens, NYC)***
  170. Finally some music (pics too)
  171. FS:Rainbow SLC265&SL165
  172. Nakamichi cd-400
  173. ACC wire in trunk?
  174. Feedback from speakers
  175. Help with Equlizers/ Line Drivers
  176. power capacitor burnt up???
  177. Where to buy door speaker trim rings?
  178. Looking for good 6.5" woofers...
  179. Dons paypal??? Anyone Got it???
  180. Alpine HU Trim piece
  181. Directed LE/ Clifford 3.3x inside...
  182. Prices on installs...
  183. Need more headroom
  184. SQ? SQL? Need some help
  185. Clarion Flip out HU screen won't go back in need help
  186. Circuit City tries to install Avic N2, causes $12K in damage
  187. Amplifier and Speaker questions...
  188. Audio Shorting Out
  189. Upgrading OEM nav in 5.5th gen
  190. DOJ Approves XM/Sirius merger
  191. Subs in numbers...
  192. Alpine Wallpapers
  193. 5th gen: AMP power wire, WHERE???
  194. Best place to buy install supplies???
  195. Head unit compatiblity?
  196. 2002 non-bose planning
  197. jl subs
  198. CAPACITOR Help !!
  199. Evaluation needed on future system
  200. Aftermarket Alarm systems info please...
  201. crackling sounds with USB mp3 playback
  202. Horn Tweeter...
  203. Help, No Sound?
  204. Design me a system with $2000
  205. Installing CB Radio. Does anyone else have one?
  206. Tweets
  207. No sound from subwoofer
  208. Jl Setup
  209. Which speakers for my 96?
  210. hertz audio
  211. Need help from you audio guru's on install
  212. front left speaker acting weird.
  213. Eclipse AUX-in
  214. Horn Tweeters...
  215. Speakers on an amp question
  216. question about my avic d2
  217. Responder LE - Directed
  218. Another Remote Start GD?
  219. Factory Bose stereo parts?
  220. Alarm install help....
  221. installing subs to a 99 bose headunit
  222. Some guuidance Please!
  223. Single DIN Adapter
  224. Looking for quality installer worcester ma area
  225. Microvision Owners....Step Inside
  226. Pioneer DEH-P6000UB
  227. need your opinions on hu swap
  228. quick question..
  229. Aftermarket HU install in 04
  230. Input on my Audio System Upgrade
  231. Interesting problem
  232. Eclipse playback USB
  233. Alpine help...
  234. NEED HELP with sterring wheels controls
  235. Where should I have them put my x-overs?
  236. Wiring Front Speakers on 4th gen
  237. Eclipse CD7200 MKII
  238. Amplifier Ground Point
  239. Holy BL !!!! SWEET
  240. Box build log: 12" Fi Audio Q
  241. trunk floorboard
  242. Anyone have experience with QX4?
  243. Assistance Required: HU Not Functioning
  244. Got a present from Don and i can taste teh Rainbow...
  245. forth gen maxima engine managment system cost/pics
  246. Instructions for indiglo gauges
  247. Don't forget your clocks ...
  248. Just installed a Bose pathfinder HU, but I would like to replace speakers, help?
  249. HU replace Eclipse vs Alpine
  250. Intermittant Speaker Whine
