PDA
View Full Version : Audio and Electronics
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83
  1. My Bose speaker is making noise when bass thumps...
  2. Help me identify this alternator?
  3. Noob help (amp interface)
  4. Looking for a 5th gen sub amp
  5. Enclosed vs Non-enclosed Sub box
  6. speaker interchange
  7. Pioneer Introduces Pandora Radio Integration - iPhone App [VIDEO & PICS]
  8. Installing amp and sub without changing the radio- using a spliced RCA wire
  9. CAN SUB CAUSE PROTECT MODE
  10. new double din installed with components question
  11. Are there any 2-channel bridgeable or mono amplifiers that have external crossovers?
  12. Single Din Touchscreen for 4th gen?
  13. Past a certain volume, my sound fades to the right.
  14. have any of you heard of al audio?
  15. 5th Gen Factory Bose Sub replacement question
  16. Kicker Audio
  17. Got a new CD player.....AGAIN
  18. New Headlights?
  19. Need Help With New Stereo System.
  20. New Stereo For My 2002 Infiniti I35 Sport
  21. Hey Don....
  22. Trunk re-build ... Third times a charm
  23. Viper 791xv help
  24. i pad setup/ kinda cool
  25. Happy Birthday Parag!
  26. Another el cheapo kevlo thread: G35 edition
  27. 7inch touch screen too big???
  28. Bluetooth Compataibility- 2007 Mex.
  29. Alt Whine...
  30. New subs + sealed box ?
  31. Wiring an amp & sub into stock bose system, not working right.
  32. Sub / Powered Sub Suggestions - 09' Max w/ Bose
  33. KILAMAX-BUILD THREAD..
  34. Actual users of the PA11-NIS
  35. Sub Enclosure, need advice
  36. Wiring Single 4 ohm DVC sub to a 2 channel amp
  37. Navi/gps antenna
  38. Where to put sounds deadening material(like dynamat) in the car!?
  39. Where should I feed the power wire thru?
  40. 5th gen Keyless Entry Remote with 4th gen Maxima??
  41. IB15A
  42. non-bose Speaker recommendations please
  43. Radar/Laser Detector Recommendations
  44. iPad installed, in-dash, in a Maxima!
  45. GoinDef's 2000 Nissan Maxima Build Log
  46. Help: need tweeters with ~2 1/4" cut-out diameter
  47. Amp installation f up
  48. Stealth stereo system (Pics!)
  49. How much dynamat do I need for my trunk?
  50. Need some advice
  51. Finally a use for the new iPad
  52. Diamond sub
  53. Not for me but my friend needs help for his truck......thx....(eclipse avn5510)
  54. Noisy Sound System after upgrade: Sosche or Clarion?
  55. 2001 Speed sensor wire
  56. Aux outlet through stock bose tape deck
  57. Car Audio Upgrade
  58. Where is the best place to ground 5.5 gen?
  59. Questions in regards to the Viper 5901 2-Way Security and Remote Start System
  60. Pioneer Headunit Install Help
  61. Capacitor life cycle, is it bad?
  62. Calling all hackers: USB into 07 Bose HU
  63. replacing bose system ?
  64. bose sub CB bypass
  65. Custom Enclosure for JL 8W7 - 2009 Max
  66. crutchfield mastersheet
  67. Swapped Amp, no sounds to Subs.
  68. WTB: Double din dvd player
  69. Need help with Autometer Nexus gauges..
  70. Installation questions
  71. New stereo install for the Max
  72. Components for 02?
  73. sub not working
  74. Looking for a great HU for 91 Maxima.
  75. 95 GLE Bose Head Unit Compatability
  76. need help with sub box..
  77. Need help with set up
  78. Looking for a nice component set for my 5th gen
  79. Odd Subwoofer Behavior
  80. Viper 791xv
  81. how to tune your amp...sticky?
  82. Xterra Rockford Fosgate stereo in 4th gen?
  83. Subs in your Max
  84. bose sub/amp
  85. A great list to be on ...
  86. New High Amp Alternator Just Arrived! Pics Inside!
  87. possible skipping Bose HU fix??
  88. preamps
  89. Not quite car audio...
  90. iTrader on ca.com ..
  91. NON Maxima stereo question
  92. Viper 5901 HELP 5.5 gen
  93. Need help with Pinout for Eclipse AVN5500
  94. Another build by Mike@AMIcreations
  95. AMP Shorting
  96. small prob i suppose, sub whines?
  97. Alarm Question! Help!!
  98. New CD Deck Time
  99. Help plz Question regarding in dash tvs
  100. 2002 Maxima 6-Disk Bose - Has anyone figured out how to Hookup I-pod
  101. removing Bose faceplate
  102. Wiring for my power antenna is messed up! Could I get some help?
  103. I found it interesting ...
  104. Time for some fun !
  105. What is this "unit" for my rear speakers of my 4th gen
  106. About toinstall my PAC AAI-NIS2
  107. speakers in the rear deck
  108. Metra 70-7551
  109. Amps and subwoofers
  110. Any1 know of a shop that does fiberglass trunk layout near nj
  111. AVH-P3100DVD bypass help
  112. Reverse sonar comes on with headlights, won't shut off, Bad sensor or switch?
  113. High and Low Beams on at same time
  114. Stock Bose Unit Question
  115. mdf rings
  116. 8w7 enclosure build
  117. Rainbow back in the US ?
  118. Arc Audio 2500-XXK vs. Blown Internal Fuses
  119. Need Help Badly
  120. 4th gen HU removal
  121. Eclipse Radio Jammed
  122. Removing 07' Headunit for Nissan iPod kit install???
  123. Alpine Introduces iDA-X305S, controls Pandora App on your iPhone
  124. Goodbye to youuuuuu
  125. What do I have here?
  126. Happy B-Day Don!
  127. Easy Question....I know I know.... get ready for facepalmin...
  128. 6th Gen Bose w/uninstalled Sat - Aux-in/iPod options?
  129. HD Radio Help
  130. New HU questions
  131. Need a new amp
  132. 2002 Maxima headunit checklist
  133. 2K1 Wire Harness Question
  134. where to install GPS antenna?
  135. quick question
  136. Another Bose question
  137. Low Battery??
  138. Need help picking components on a budget
  139. How do i replace stock audio lights.
  140. Wiring Guru's help needed!
  141. How do i put L.E.D.S in my gauge cluster
  142. A basic "How To" install a remote start. '97 I30
  143. Need VSS color on harness, installing nav
  144. HU question
  145. 5.5 Gen 2002 Maxima SE XK05 vs. PKN2 with Viper 5901
  146. 6.5 inch double din
  147. It's a sad day...I'm putting my entire system up for sale
  148. Thinking of changing my radio
  149. Replacing the entire BOSE system
  150. Factory Satellite Antenna help
  151. Wiring lights to come on when car is unlocked?
  152. iPod Touch Adapter
  153. double din unit?
  154. bose question that I dont believe has been asked
  155. Is this stereo decent?
  156. Need some 16awg wire
  157. New goodies for the sound sytem..
  158. Bose Hiss, HU already replaced once!!! Help
  159. What are these tiny vents for?
  160. To IB or not to IB...
  161. How to re-enable "Trip" button after Bose to aftermarket swap?
  162. Just picked up my new cd player
  163. 96 Max BOSE question
  164. Happy Turkey Day !
  165. Installing 8 or 10 inch free air sub but keep it looking stock
  166. double din in my 4th gen?
  167. 1 ohm sub
  168. The truth about TRU ...
  169. 99 I 30 / maxima cd players???
  170. Question on Wiring Harness for Factory CD Changer
  171. yet another HID question from anomaly
  172. Bose Amp question
  173. Reuse the factory Sirius receiver with new radio?
  174. What about this for BOSE replacement???
  175. quick question about LED's
  176. HELP!!!!!
  177. lightest sound deadening
  178. Satellite hookup with new Headunit
  179. Do I need to Reset my screen?
  180. Aftermarket Head Unit Installation Questions
  181. Looking for Advice on new head unit
  182. Need Recommendation for High-End Front Speakers
  183. Questions about rattling in 5th gen
  184. Good deal on Alpine CDA-9887 ($247 shipped)
  185. Did I Blow a Fuse????
  186. Pioneer AVIC-X710BT vs. Eclipse AVN6620
  187. Ok, Bose confusion
  188. Maxima CD player not taking any CD
  189. Rear door (driver side) is locked from inside and outside .. please help
  190. Pioneer drops 'Premier' line ...
  191. Sirius Antenna on a 06 Maxima
  192. whats on your in-dash's background??
  193. 5th gen NON-BOSE head unit problem
  194. Don't forget to change your clocks back 1 hr...
  195. Swap OEM Non-Bose for OEM Bose?
  196. 99 underseat changer acting up
  197. A few questions for the guru's
  198. Nissan Antenna Adapter Diversity vs. Non-Diversity
  199. Good deal on Viper 5701
  200. Bose Amp Integration Harness Question
  201. Bose to Aftermarket swap
  202. CD Changer - Other Audio Questions
  203. GXE dash kit
  204. 2002 maxima immobilizer
  205. Remote Start
  206. Just finished an install - check it out! (funny)
  207. porting a closed box
  208. Bugatti teams up with Dynaudio ..
  209. Ground Hood switch?
  210. Tweeter Help Whats's What/Differences
  211. Excellent review for Dynaudio/TRU products ...
  212. Your iPhone is now your car key
  213. Car-puter Car PC display question
  214. Wiring Innovate LC-1 Wideband - Help with fuse box
  215. It's Christmas in October!
  216. 2007 Maxima BOSE Door speakers in a 2007 Altima SL
  217. selling pioneer ipod cables.
  218. series 4, always fails on left side speakers?
  219. 5.5th Gen Sub/Amp Question
  220. Does anyone have a spare Eclipse harness laying around?
  221. Custom Fiberglass Sub Box near Chicago ??
  222. Pioneer-DEH-P4100UB
  223. sub and amp on a 2000 max w/ bose
  224. Upgrading Stock Bose...Headunit or Better Amp?
  225. changed hu from bose to kenwood
  226. Eclipse Experts Step Inside
  227. rca bass knob question?
  228. What amp to get in the $200 range ??
  229. crossover location suggestion for 5.5th gen
  230. Microsoft Zune in-car hookups?
  231. Clarion FZ409 - Digital Media Receiver
  232. Setup Kappa Perfect 6.1's...Need a guru!
  233. Bose Sub Inop - Troubleshooting Help!
  234. what ipod mount do you 4th geners use?
  235. CD Magazine Jammed - Stock Changer
  236. SCV aftermarket?
  237. Rear deck on 5th gen
  238. dumb newb question - wire color
  239. inverter help
  240. sub randomly stopped working
  241. Good Power Location Interior Neon?
  242. LED gurus advice?
  243. JL 500.1 W JL 12w7... enough power?
  244. Need MDF Rings
  245. pkn2 question 03 Maxima
  246. Pic of NN1648B Scosche kit please
  247. Question about aftermarket setup
  248. Looking at new HU
  249. Need some amp advice for subs
  250. speaker setup oem
