View Full Version : Nitrous
- Are you using a fuel filter?
- jet force power control module good/bad?
- Auto VS Stick
- nitrous refill stations
- spraying on 5spd
- Nitrous system installation
- shifting while spraying
- buying nitrous
- Dry NOS w/ factory ECU ?
- Can I run nitrous with my jim wolf ecu
- What bolt ons are necesary to spray?
- Just had a nitrous scare!!
- question of set-up
- Anyone tried this NX kit? Honda NXL B16A/Type R
- Zex has a new toy!!!!
- Whats the best setup?
- First time at Track with Nitrous, Help
- where to splice WOT switch wire in Zex wet?
- First spray at the track today...
- ZEX vs. NX
- Leak Fix?
- Big Shot + automatic=
- New to nitrous need some help
- NX WET KIT AND ACCESORIES ON EBAY. CHEAP!!END at 10 PM PST TONIGHT
- is NOS proprietary
- where to go through firewall?
- Need help i think i am goin to buy some nitrous
- Two steps colder?
- nozzle filter?
- gapping
- Ready to spray what should i get with my mods!
- Platinum Plugs with 5th Gen Auto / 75 shot
- Hiding your NOS kit.
- can a nissan oem clutch hold 75 shot and all bolt ons?
- Are there any how-to's for installing a wet kit on an auto?
- 5spd guys
- I'm gonna be hitting 13's soon!!!
- slick sizes
- New to Nos, any advice
- NOS dry kit ... to NOS wet kit
- Just installed NX kit... HOLY SH!T!!!
- slicks and rims
- NOS system for 2k2+, help?
- GSS342 Walbro in-tank fuel pump works for VQ35s?
- New G-Tech computer from Escort....
- fuel question
- ZR tires + spray = wheel spin?
- Advantages of DP with a 75-shot.
- Tell of your most exhilarating nitrous moment
- Purge kit metal line ?
- **ATTN JIME: where is your drop resistor mod write up with WOT switch?(org no search)
- which model (part #) of MSD for maxima? how does a MSD RPM switch work?
- how does NX wet kit adjust it's HP rating? what is the part # for 50shot NX wet kit?
- what is purge valve/kit, FPR, EGT, and EFI? what does it do?
- please help me with some n00b nitrous questions...
- quick auto tranny question
- NOS Bottle Pricing...
- What gap for spark plugs are you using?
- Can someone please tell me where to get a Tee fitting for the fuel line??
- fuel pressure regulator
- Autometer guage install questions
- who has direct port nitrous injection on there max
- To all you nitrous pros out there...questions
- Has any body ever heard of cold fusion nitrous kits
- transmission cooler
- Very Important Please Help!!!!
- dry or wet shot? No experience with spray!
- Cheater Nitrious Kit, on Ebay!
- Nitrous Bottle and shot
- Digital Maximizer
- what is safer? wet or dry kit? or easier on your engine?
- purge inside engine bay for cooling?
- Valve-body mod
- how much would i spend? nitrous newbie!
- Auto tranny drop resistor mod with NOS
- Copper or platinum plugs?
- How much do you pay for NOS?
- help nitrous
- Nitrous newbie seeking advice
- what shot can i run with technosquare ecu and colder plugs with stock fuel pump?
- newbie to NO2....few questions...any answer would be great!
- can some one help me please
- ok now honestly
- A kit made for NOS Newbie's
- Where to buy
- To all Nitrous Gurus!!! little help. New with N2O
- NGK bkr6e-11 gapping
- JWT ECU boosted but car is not....yet
- HELP my bottle is leaking....
- how many retard their timing when using n20
- Bottle Pressure???
- best shot?
- Fuel solenoid filter
- auto tranny question
- Not Satisfied
- JWT 65 shot vs. NX 50 shot.....more noobie questions...
- Blew the welds on my radiator
- JIME!.... what was the website you told me about for one step colder plugs for 2k2+
- Damage...
- Nitrous Blanket
- NOS system from Cattman
- question about RPM switch for a 2k2
- modifications for sneaky pete nos kit in 2002 GLE?
- Nitrous requirements?
- Jet for 65 shot?
- Cold fusion kits?
- Does Nitrous Hit as hard when you have 2lbs compared to 10lbs left in the bottle?
- Is spraying with bad o2 sensors harmful?
- Can I safely leave bottle in trunk all the time?
- Add Me to the Nitrous Max's Please :)
- Exhaust? 3 inch
- what is the fuel pressure of my 2k3 at WOT???
- FS: NYC NX kit
- newbie to NO2...
- Nitrous in an Auto.....re: shifting
- zex kit install, need help ?????
- All-in-one gauges?
- Newbe to NOS
- Finished install.. hose tear? Sparkplugs?
- Need help with NX remote bottle opener
- Help, those of you with Nx remote bottle opener
- Fuel Pressure Regulator
- It could be bad news!!! Spark plug reading experts look.
- 13.6 with a 60 shot on a 4th gen 5spd????
- can geforce ecu equipped max ever run N02?
- What clutch are you running?
- Nitrous on 20-03
- Copper Plugs for 02-03 1 step colder
- Questions
- Cool switch panels
- Anyone have some instructions?
- what plugs are needed for my 2k3 planning on up to 75shot??
- Gauges for my wet kit
- dry kit vs. wet kit
- BKR6E Gapping?
- retard timing instead of getting new plugs? is this safe?
- what gauges do i need to monitor my nitrous?
- DO i have to put a hole in my injen for nitrous?
- Nitrous for a 99'max???
- 2002 nitrous help
- NOS purge kit on Nitrous express kit?
- For the record....who has run the highest shots on stock motor?
- zex wet kit question
- ZEX dry kit for $200? good deal??
- Weird Fuel Pressure readings
- Aftermarket fuel pump
- Running NA with an adjustable fuel pressure regulator?
- rpm switch
- Help with NOS system pills...
- Gains with 50 shot!!
- 50 wet shot vs. VI + JWT ECU
- 75 shot of nitrous!!! yes/no??
- First Nitrous install...any suggestions?
- 2002 maxima nitrous guestion ?
- Love nitrous but hate Underpowered motors!
- can u interchange diff. brand parts for nitrous???
- maximum shot for a dry kit?
- NA/Nitrous Idea
- Nitrous and Bypass Jets?...
- will this work?
- Auto spray points
- Quick - 2 1/2" or 3" y pipe?
- NX part # 20923-10 Need help!!!!
- At what point will I need a Walbro 255 with my NX kit
- are all nitrous kits generic?
- NOX? so many choices....
- which n20 is best?
- Purge Kit
- Purge Kit
- Do you need a go button if you're using a window switch?
- Few nitrous questions
- Future buyer...HELP!
- Way to 'trick" knock sensor?
- Custom NOS'd transport
- NX pics
- Installed new fuel TEE
- Liquid Nitrous
- Has anyone taken their high-flow valve off the bottle before?
- NX guys- shark nozzle question
- Fuel Cells???
- Which spark plugs for the 2000 maxima?
- NX install write up?
- Ignition enhancement with nitrous ?
- what system to get?
- What would a 50 shot do?
- Race gas and Nitrous.
- NX wet kit- tapping fuel line location
- Trouble deciding
- finished my first nitrous install...
- want to trade 2 step for 1 step colder
- Basic Question About Why Nitrous Is Used
- Need help ASAP with fuel line leak
- Double bottle setup
- How to route n20 line from engine to pillar guage?
- Nitrous Newbie...
- does anyone have some NX thread sealer they can give me?
- suggested gauges
- Did some runs to monitor EGT.
- Nitrous license?
- NX tread sealant?
- Probably buying nitrous in the near future, trying to gather a little info
- How about this for tunning
- question about VG setup on my car.
- Hey got a question....my friend has a venom kit..
- Nitrous Oxide Kits $750 Canadian
- NX#20923 users
- Questions // NX Nitrous Kit
- $ for a proper setup?
- laughing gas??
- Need directions on how to install NOS#5124
- getting Nitrous on paint bad?
- How to read a Pressure gauge / MEVI Question
- Looking to Juice
- N20 Guages...?
- buying extra autometer EGT bung?
- Helpful nitrous suggestions needed
- Help me find this N20 spray button
- Recommendation on FPR?
- getting sick of the nitrous anyone else?
- Dry Kit Fuel Pressure Rising After I Let Off The Gas
- Question About Refilling Bottle
- drilling for EGT
- Where to buy 100 shot jets for NX kit
- dry kit on 89SE
- NX 35 shot ok on stock ngk plat?
- placement for for nx nozzle in intake
- need nitrous
- Picked up my Nitrous on Sunday
- Looking for a Shark Nozzel for the NX wet kit
- I'm considering buying a NX wet kit, anyone in chicago done the instalation?
- Quick question about the NX 75 shoot
- What to do with nitrous, in nitrous lines?
- Stock Fuel Pump Limit
- OK wise ones teach me about Nitrous
- Gapping Spark Plugs
- kickin around the spray thing...
- Spark Plug Question
- damn first nos post i feel weird but not to sure what to get?
- How high with stock compression ratio
- N2O Problem
- Plug gap
- fastest 1/4 with 50shot
- Idea about using multiple ECU's to run Nitro and a JWT or G-Force
- Zex nitrous plugs
- Help Setting up Nitro in Atlanta area
- The project
- NOS jets in NX shark
- Mobil 1 Synthetic and nitrous?!
- Jetting: What's what??
- NOS Bottle Opener P/N 16058 wiring ?
