View Full Version : Nitrous
- nitrous kit
- What preignition-damaged spark plugs look like...
- Went to a 75shot today!!
- I need power!
- Update on my setup.
- This place is dead.
- Highly recomed for us nitrous orgers
- FS: NX nitrous/fuel pressure gauges
- maxima-mizing my new nitrous kit
- Correct spark plug gap question
- Anyone ever blow there motor?
- Do you weigh your bottle after having it filled? Buyer beware!
- NX Nitrous guage not working ?
- Nitrous refill $
- window switch
- Capacity of 5th gen pump?
- Is this IM for a 4th gen?
- nitrous & Jet performance
- 75 shot
- Gauges?
- Anyone here useing a stand alone system?
- Which Plugs to run?
- Well, I'm going to do it again.
- Which bottle warmer brand to go with?
- Largest Safetest Boost Amount for 3.0
- 5.5 gen ZEX installation (TPS question)
- zex dry kit and a window switch
- fuel pressure question
- fpr...set at what pressure
- idling weird after new plugs
- Purge show and new bottle blanket, i love it!
- fuel pressure regulator for 3.5
- Walbro 190 or 255?
- 75 wet shot was running perfect.. but now I am gettong detonation+fuel puddeling? wtf
- nitrous time i need opinions asap
- where to buy, direct port
- a v-afc question
- Most commonly asked questions about nitrous by NX
- Took the new kit for a spin
- New Season Nitrous checkup
- Fuel Pressure Safety Switch?
- jwt ecu's good or bad for wet kits???
- Fuel pump fuse
- Do I have everything I need?
- Question about MSD window switch #8969
- F.S. Cobalt Autometer gauge
- emanage maps...
- Need Nitrous Install Help
- afr and dyno Qs
- 2 step colder plugs, 190 walbro...
- Zex dry nitrous kit
- F.S. Nitrous Components
- methonal injection
- Fuel pump
- Retarding Timing with Nitrous
- Where to put my jet, and TPS; 2000 Max
- Nos Setup for Maxi Complicated?
- Those of you running a 75wet shot step in.
- Is Nitrous street legal?
- What plug to spray 5th Gen
- Maxima A/T and 100 Shot = BAD
- Bottle Heater ?
- Package Came Today..
- Remote bottle opener...
- going with nitrous
- Exhaust cutout when spraying?
- Two quick install questions for NX kit
- question about zex dry 75 shot
- Who has tried 100shot without fuelpump or injector upgrades?
- 50 shot to the motor and intercooler
- How many of you use a fuel cell?
- What octane do you suggest for nitrous
- Melting pistons without detonation?
- Question about JWT nitrous program and a wideband o2
- window switch
- Interesting direct port noszles.
- have a quick relay questions...
- How do you set the fpss? (hobs switch)
- Bottle pressure effect fuel pressure on dry kits?
- Nitrous Explosion in a Maxima
- WTB: 4 10oz Sneeky Pete NOS Valves
- How often do you clean your nitrous filter?
- Got free NOS... now clutch slipping!
- Fuel jet clogged.
- Planning on getting a kit-
- spray...
- I want to run a WET 50 shot, should I buy this dry kit and convert it?
- Want to do over 100 shot
- LC-1 Wideband Air/Fuel Ratio Controller
- please help with jet sizes
- which plugs
- nopi nx wet install questions.....
- Where to tap into fuel line in 4th gen (wet kit)?
- thinking about getting spray.
- Compression Results
- Edelbrock Nitrous kit?
- How much will a 50 shot help me in the 1/4 mile?
- Getting FREE NITROUS!
- Questions for a noob
- need some help picking a kit
- Low dyno #'s ???????????????
- running low 12s high 11s????? how big of a shot????
- Window Switch with Zex Question/Problem
- question about adding zex
- Any 5.5 running bigger than 75 shot
- Home Built Nitrous System
- wat u guys think?!?!
- bouncing off redline...
- Gaugung interest: wireless nitrous button
- 2-Stage Direct Port
- Couldn't wait till next week.
- from 100 to 125!
- fuel pump
- Ran a friends zex kit today :D
- Please help with NX install
- Dyno Numbers With Nitrous
- blowing fuses
- Can Anyone Answer These Two Questions? Not Found In All 24 Pages Of This Forum
- question about clutches
- Sard Fuel Pressure Regulator Thread Size
- For those of you with 5spd/5th Gen's
- Back on the bottle...
- how long does your bottle last
- Cheapest Kit
- Does anyone here use nitrous oxide???
- smaller shot on a direct port setup
- Nitrous and Automatic??
- a few questions about NX install
- Walbro 190lph v. 255lph fuel pump
- Fuel pump for NX wet kit
- Installation Guides - Read before asking!
- installation probs.....
- Because i got NAWZZZZ!
- Setting up for nitrous
- Reingen NoxGen
- What psi to set FPSS?
- 2000 Max..Fuel Line Questions
- Outta ideas, What's wrong??
- Zex Wet Nitrous Kit
- Knock sensors
- i hope someone knows the answer
- has anyone hardwired their fuel pumps?
- 1100psi and wantin more...
- why copper?
- putting my spray in next week
- Needed accesories to run nitrous
- zex nitrous kit
- HELP me understand something....
- zex nitrous question
- Anyone in North East able to help??
- How do you run fuel from a fuel cell without running any fuel from fuel tank??
- New FPR not bumping pressure, wtf?
- Everything for N20?? VIAS Question
- Boost & Nitrous??
- NX kit wirring diagram
- Help picking an RPM activates Window switch
- Considerin Nitrous (a newbie)
- Will this Fit?
- Where to find nos
- What causes intake detenation?
- Step inside....
- Help with nitros!!!!
- Someone buy my Zex Wet Kit dangit!!
- just got my NX kit, still confused...
- Nitrous coming in, but dun wanna ruin stock mid-pipe
- Best N20 plugs for VQ30?
- Poll- So how many of you guys have your jet/jets in your TB?
- 18 degree timing and 75 shot
- Major difference between Zex and NX wet kits
- Have some 4th gen nitrous questions
- Loctite, white paste, or ????
- Opinions/comments on Dynotune warmer?
- Tapping The Intake
- Is a dry nozzle a dry nozzle?
- Decided to purchase a nitrous kit
- Good places for replacement fittings?
- quick spark plug questions
- How long have you been running Nitrous w/out problems?
- NOS in 6th Gen
- a v-afc
- umm...newb here..which kit
- Hiding the Bottle
- Fuel Pressure
- N20 bottle danger in AZ heat?
- Buying USED ZEX #82011???
- Anyone need some Denso's to run with their nitrous?
- 16 year old + nitrous =?
- Walbro 190lph enough for 100 shot??
- Writeup for AFPR intall?
- Any of you guys need a 300TT fuel pump?
- Few Questions
- Part number for plugs?
- Fuel Pump, Nitrous, and Transmission Computer Unit Questions
- Pressure you need for N2O--WOT measurment
- 6th gen nitrous ?
- Which kit is best for a complete newbe? wet prefered
- thinkin of gettin nos do i need to get colder plugs?
- Advance timing or not?
- I need a fuel T!
- what step and gap spark plugs should i run?
- nitrous backfires
- Nitrous Express Hidden Systems
- How much poision is in your ride?
- Zex jet size
- Universal FPR Q's
- do i have too many miles on car for nitrous?
- dont want to kill the max but...
- Fuel Supply Options w/ ZEX Wet Kit
- Alternative enrichment fuels
- questions on other's a/f graphs
- Nitrous doesnt feel like its kicking in
- ZEX Wet Kit. Do I need a Walbro 255 ltr/hr Fuel Pump?
- Nitrous and the Law......
- new fuel pump
- Where to find correct 1/8 nipple
- CEL 0505 after going 75 shot...
- nitrous....
- times???
- HOLY CRAP I just sprayed!!
- Couple of Qs before install....
- Newb Looking For Nitrous...
- Electrical Schematic for NX kit installation w/ MSD & accessories
- Zex vs Nitrous Express
- Bottle heater question???
- Part number and where to get a fuel pump?
- Total NEWBIE to NO2
- Tuning equipment?
- Newbie NOS question
- Suggestion for my setup...
- To J&S or not to J&S??
- FPR question
- Plugs
- Bottle Warmer Warning?
- A new N2O question I think??
- Holy Crap....I finally sprayed in my Mustang...
- pics of WOT switch
- I didnt think it was that dangerous...
- n20 first impressions, and traction question
- Stupid question I know... but what kinda of cars can you beat with a 75-100shot?
- safe to spray??
- Engine literally exploded from spraying nitrous-smoke came from engine-engine shutoff
- Which ZEX part number/kit
- Bad to use a wet kit with MEVI????
- How many of you run blow down tubes?
- CRYO2 Intake Kits
- Anyone using Nitro On a VI
- exhaust and spray
- Fuel questions regarding Zex kit
- Use WOT nitrous switch for drop resister mod?
- Nitrous sytem for '04 Max
