PDA
View Full Version : Nitrous
Pages : [1] 2 3 4 5 6
  1. Can my 2000 maxima gle hold nitrous?
  2. Remove or keep VIAS valve for nitrous?!
  3. J31 max with 2004 4 speed auto
  4. Wet nitrous kit and vafc
  5. Duel Stage Shopping List...
  6. Refilled my Bottle...only air
  7. noob help
  8. Nitrous Noob, a couple questions...
  9. 50shot. dry. ok to runn
  10. can i use the 05 maxima intake manifold to...
  11. Who's sprayin more then 100shot on VQ?
  12. Timing Advanced+Nitrous?
  13. 7th gen nitrous
  14. nos on 02 6speed
  15. Help Wireing 908 window switch
  16. where to buy colder plugs.
  17. Need Help Deciding spray on 01 max 5spd
  18. wiseco 11.1
  19. turbo + nitrous?
  20. This section of the forum is awesome.
  21. Activation Wire-ZEX
  22. Two races left this year, had to try for a 11.99 to run Semi-Pro
  23. ZEX wet kit questions
  24. PNP Standalone for 4th Gens?!
  25. Fuel Tap - Wet N2O - 5th Gen DEK
  26. 350Z fuel tap? Will it work
  27. best jet combo for nos 75 wet shot 5.5 gen?
  28. SC with Nitrous in 4th gear?
  29. nos plus water/methanol injection anyone
  30. Nitrous Turbo Meth 3.5
  31. Nitrous Kit? On UTEC?
  32. ZEX controller...how it actually works
  33. stock fuel pump for higher shots
  34. Which is the Wot wire (4th gen tps)
  35. Something I'm thinking about doing...
  36. Anybody relocate their iat for nitrous?
  37. 2003 maxima Auto - Nitrous Questions.
  38. Trying to stay low cost\simple as possible.
  39. Who has a Dry shot setup?
  40. A Great Book On Nitrous Oxide....
  41. Few technical infos on a NOS setup.
  42. what kit is best
  43. Fuel pressure regulator
  44. bottle warmer ???
  45. Waste Spark and Nitrous backfire
  46. NEW NX Nitrous Solenoids
  47. Link to J&S info...
  48. Nitrous Wiring Diagram
  49. NX single stage limit?
  50. Can the cvt's handle a shot of nitrous?
  51. Sprayed for the first time, got some questions
  52. Question about N.O.S
  53. different kind of bottle heater pad
  54. looking for a bottle warmer
  55. Spark plug questions...
  56. electronic WOT switch for DR mod?
  57. how much can my car take?
  58. Frost on nozzle
  59. 50 shot and 75 shot jets???
  60. nwp plate yes or no?
  61. few questions
  62. ZEX rated at crank?
  63. Any 5th Gen's spraying?
  64. any mods needed pre 75 wet shot??
  65. Nano Nitrous - anyone installed this?
  66. Progressive Nitrous Controller Gen-2
  67. Benefits of exhaust cut-out?
  68. Anything needed with a 35 shot???
  69. 150-shot and pump gas :ugh:
  70. Entering the realm of the nitrous crew, but I have a question first
  71. How will the stock clutch handle the nitrous?
  72. 2 quick questions
  73. Got teh Sauce...(PICS)
  74. Question on nitrous feed line.
  75. Step 2
  76. Wideband 02, Really needed?
  77. Nitrous VS o2 codes?
  78. Spark plug part number for 04 3.5
  79. Upgrading fuel pump on returnless system
  80. can finally retard my timing, just making sure im doing it the right amount
  81. Running E85 with spray?
  82. ? Use nitrous to override the factory rev limiter ?
  83. Looking to shorten my nitrous feed line
  84. 75 shot and 2* advance on 3.5... anybody else?
  85. 125/150 shot. Have the ideas, just want some opinions on specifics. (5.5 gen)
  86. For you nitrous boys who wanna keep it stealth
  87. 5.5Gen and Nitrous
  88. Nitrous questions
  89. Plan on running big shot----few questions
  90. This car doesn't have nitrous.............
  91. Nitrous Qs for my 5.5
  92. Looking for a good Nitrous Kit/Set-up.
  93. Spray off the line
  94. nitrous newbie help !!! well not too much of a newbie
  95. my nitrous setup
  96. NX Incognito?
  97. What size shot should i run
  98. Spraying thru Every gear.
  99. Help- get me in the 13's.....
  100. Testing solenoids?/other concerns
  101. MID 12'S ON 150 wet shot?
  102. installing a nitrous system with an upgraded ECU...
  103. Pulsing n2o
  104. bad day at the track
  105. Swapped Dynotune Kit, Problems! Help!
  106. Question about nitrous kit
  107. Possible 11s This Season?
  108. Oxy-Hydrogen Generator for a Car
  109. well i almost blew it up
  110. Need some help
  111. Few n20 q's
  112. Nitrous Wet Kit
  113. opinions
  114. Are The Zex Wet Kit Jets Making The Advertised WHP!
  115. dynotune EFI kit
  116. 3.5L before and after 1/4...
  117. t6378tp: I'm callin' joo out!!
  118. NX system on a pretty unmodded engine
  119. For those without a bottle heater yet...
  120. ZEX dry nitrous for sell
  121. Need some quick advice...
  122. jwt ecu+nitrous vs stock ecu+nitrous
  123. Best complete Newbie kit?
  124. Solenoid stuck open!!!
  125. 3.5L and Nitrous
  126. Just installed purge and heater *PICS*
  127. Bottle heater
  128. Nitrous with JWT ECU
  129. Wizard of Nos fs.
  130. Ordered some goodies!
  131. Nos jet sizes.
  132. MEVI = about what in the 1/4
  133. I did the inevitable! The VE Auto is no longer NA! (Pics inside)
  134. non max but ran 12's
  135. is this true? retard timing on 3.5 for 75 shot?
  136. Spark Plugs?
  137. Preignition - not good for valves
  138. 75 shot or more?
  139. How do I wire in a relay for my window switch?
  140. most popular nitrious kit for 5.5th gen(3.5)
  141. Can I Tap The Fuel Line From....?
  142. What track times does your max run with nitrous?
  143. dry fogger nozzle forsale
  144. wth had to redo now heater dosnt seem to work?
  145. Q's for those with more than a 100shot
  146. Good Exaust Piping Size for Nitrous
  147. what it cost me to put my n20 kit together
  148. making headway on installing the nitrous
  149. for sale zex nitrous management unit
  150. wiring diagram
  151. Anyone with Zex and 3.5 PLease Step In
  152. Which wire to hook up to TPS for Zex
  153. custom switch panel (for sale)
  154. fjo mini controller
  155. Nozzle fitting adapter
  156. purge
  157. In your opinions how necessary are these?
  158. Nitrous Fuel Line
  159. clean ur jets
  160. Scangauge II is THE BEST!!!!!!
  161. NHRA inspection
  162. Can a direct port do this?
  163. Hitman EFI system
  164. Nitrous issue.
  165. DynoTune Wet kits, who has em?
  166. I need help mounting a micro switch on a 5th gen
  167. Converting a Nitrous Kit to Direct Port?
  168. what would be the easiest way to add fuel pressure gauge?
  169. nitrous bottle
  170. Nitrous + ECU
  171. Dual vs Progressive
  172. jwt set
  173. Please help fuel problems
  174. MSD window switch (8956) wiring question
  175. What wire
  176. Raising shot, Gauges, Etc.
  177. testing nitrous bottle 5 year manufacture date
  178. MSD Digital Switch control 00VI and Nitrous
  179. What octane gas are you nitrous guys running?
  180. Ummm help!
  181. nitrous questions -- non max :)
  182. Nitrous noob question:
  183. ZEX Triple FireT Spark Plugs specifically for nitrous...thoughts?
  184. How good is the fuel fittings/lines in NX Import Kit
  185. Nitrous legal issues
  186. I read the stickies but....
  187. Anyone try this before?
  188. Progressive conrollers
  189. where to buy larger nx jets
  190. Rich Highschool kids are stupid F*CKS
  191. drop resistor
  192. Using stering wheel buttons
  193. soleniods
  194. Nitrous installed!
  195. Murphy's Law Can Suck It!!!
  196. Did not hit 13's :<
  197. Colder Plugs.
  198. Testing Waters.. Zex Nitrous Kit
  199. Need help with window switch.
  200. Nitrous window switches.
  201. Emanage Ultimate and timing advance...
  202. E-Manage Ultimate: Worth it for NA + Nitrous
  203. Nitrous help.
  204. Crankshaft position sensor??
  205. some new toys for my nitrous kit
  206. Water-Methanol Injection
  207. looking for 125 nx jets
  208. which ngk plugs with zex 65 dry
  209. how to read plugs after nitrous
  210. which intake??
  211. safcII w/ nitrous??
  212. question about zex install
  213. Installed my heater and pressure gauge
  214. New to Nitrous
  215. zex dry retard timing
  216. I'm Going To Install Larger Nitrous Plumbing..
  217. Consensus on best plugs
  218. advanced timing with zex
  219. few questions about zex dry
  220. Nozzle input ok??
  221. Selling my nitrous Purge for cheap.
  222. Anyone need a MSD window switch
  223. tps wire??
  224. A couple of questions..
  225. Cutout and Nitrous
  226. Bottle warmers
  227. building my setup, anything im missing?
  228. What's needed to do a nos shot higher than 55?
  229. FS:I still have NX fuel press, N2O press mech gauges
  230. New To No2
  231. Going on the bottle, a few questions.
  232. Anybody know if this is true?
  233. Spraying before MAF?
  234. Zex dry kit on a 97 max
  235. My new Nos Setup
  236. set up question
  237. Any God Deals We Should Know About?
  238. Can I Use a Nisan Kit on Another Make?
  239. any pics of install on a 5.5 gen?
  240. Anyone using an ebay AFPR?
  241. Nitrous Kit
  242. check engine light flickered
  243. Anyone tried this?
  244. Does anyone use 2step colder for daily drive?
  245. purge installed
  246. Anyone have a purge solonoid or kit i can buy?
  247. Mechanical Nitrous Pressure Gauge, Risky?
  248. Advice about 75 on 06...
  249. Shorted out my heater.
  250. Window Switch?
