- stock injectors
- Greddy Muffler
- bodykit sides
- Why my 93 Maxima is a piece of $hit
- spring install
- Power Loss HELP!
- WILL have relatively large financial backing...
- Speakers
- comfort/power/auto switch??
- I should have been paying attention so bare with me, Koni 101 help please
- Failed emissions test
- engine vacuum
- Newbie question
- Climate control lights question
- my window!!
- why are insurance company's so lousy
- remove them or paint??
- Swapped trannies, now hood wont close....
- Dumb tire question
- What Size Lugs
- compression test- bad cylinder?
- Ticking speedo on a '90 GXE HELP!!!
- i want new guages for my '92
- This is bad...right?
- Intermittent NO START _please help_
- z31 rear disc conversion... where is the write up?
- Max O/D bodywork update(pics)-->
- Hot ignition key???
- Need Linkage info/help
- WTF!!! listen to this.
- updates on project
- 6x9 Speakers problem
- Replacing Alternator?
- fuel gauge and low fuel light
- front exhaust pipe
- Help in my area???
- Which ECU Mod?
- Can She Take It?????
- Solenoid?
- side skirts
- Painted Valve Covers
- testing pics
- tps and tranny q's
- 2nd try: Help, tranny died?
- Make a 3d Model for NFS Underground
- tps/tvs testing
- place racing CAI
- What will my 0-60 time be???
- Help: Tranny died?
- Engine shuddering until it cuts off
- Clacking Noise
- springs
- My poor max's first car wreck
- Any VE 5spd guys using a Harlan Shift Light?
- BMW conversion: those who used BMW brackets
- death to the alternator!!!!
- any problems?
- E36's
- Fuses blowing
- Will Seats From A 99 Gle Fit A 92 Se?
- Defective tranny from factory?
- Japanese Engine for 3rd gen maxima
- Acura RL bolt pattern/offset the same???
- Japanise Engine for 3rd gen maxima ( INFO.)
- rusty rockers
- intake question
- does the ADDCO bar some with anything other than the bar?
- Body Shop in ATL - problem with convt top
- Front Speaker sizes
- lookin for control arms/cross drilled slotted rotors
- Sup guys
- 3rdGen Question from 4thGen Owner....
- Electrical Help Please!
- newbie type question: engine differances btwn se and gxe89-91
- Can't time my 89'gxe after valve job, etc
- Parking light fuse???
- 6 sp in a 89 SE?
- Speed Sensor
- Won't Start
- Once I rebuild my tranny what else should I worry about?
- **->Aftermarket Exhaust Question<-**
- Quick tranny question
- If we have front wheel drive why do the back tires go bald first ???
- Help - check engine light and misfiring with VE Engine
- PIc of my bmw headlights.
- Installed Suspension Techniques anti-sway Kit
- goin into shop soon need advice
- Popping sound!! Help
- Bose Cd/cs Help!!!!!
- Sun Roof Problem
- Shocks/Strut suggestion
- 7 Color Angel Eye Foglights
- plugs wire cap a nd rotor
- where's ECU located on 92 GXE
- How many gallons in a 94 gxe gas tank?
- Maxima problem! Not starting in mornings
- bulb question...kinda stupid (im still dumb)
- Engine Mounts
- Need help installing Suspension Techniques anti-sway kit
- ECU threw a code 13 ??!! then code 55 !!
- where is it the cheapest?
- PRND21 Light Bulbs
- Got a window question
- Help me out PLS. Ticking Noise ?
- Any VG guys interested in copper head gaskets?
- What to spend $200-300 on for performance?
- question about APC SUPER WHITE 1156/1157 bulbs..help
- Is my clutch dead??
- Power steering belt troubles
- need help asap!!
- sarona bodykit
- rims and tire sizes
- apexi afc 2 vs jwt reprogramed ecu
- Please Help Me Out
- 5spd conversion or Sell? need advice
- Back to say what's up...
- 3rd gen skyline body kit
- stock vg injector size
- what is it??
- Car won't start ... timing belt?
- bmw halo question
- Bellow Boot? Rack & Pinion? WTF?
- VG intake midpipe
- VG engine- bad hesitation and now will not start!
- how do you keep the door moldings from aging or fading?!?
- Stock 60' for VE auto
- autozone sells 3A Racing Mufflers
- NH Meet (just 3 days away!) July 26th in Manchester - sign up!
- DTES on a SE
- For those Auto-Manual converted owners
- muffler patch
- Hella Supertones installed today
- alternator warning light
- What kind of front lip should I get? Which one is best
- Car died (sort of) please help a dumb kid
- Need major audio advice.
- Autozone Question
- Intermittent misfire at idle
- front door panel removal
- E36 installed... watcha think?
- speaker size for 3rd gen maxs
- Seatbelts
- Fuel Injector out - any ideas for replacement
- What could this be???
- 300zx rear brake fitment
- oem pws hose vs. aftermarket?
- Help!!! No Radio, No Sound, Makes Me Crazy
- CAI for se's
- 5spd tranny question
- Addco RSB Installed, well almost
- nismo1989 again
- stereo install
- fuel pump
- Fan Blows out weird stuff
- why does thid happen
- how to replace axles link please
- Spring suggestions
- what is normal compression for a vg30e?
- grey lock control box removal
- how-to adjust idle?
- Bose Stereo Question?
- what model max?
- Cheapest source for oem manifold?
- GXE tranny stuck in second
- over heated??????
- VG to VE swap...(no, I didn't do it, just got ?s)
- Column stock switch
- Help, cat bolt cracked in half. look at pictures
- 94 Ve Stalls At 140mph..like Whoa?
- transmission flush with amsoil
- Cleaning Intake Manifold on car - Bad Idea?
- Pictures of Wings West Bodykit
- 300 ZX master cylinder
- how to Get the CD out...??
- how much can I haul with my 92 GXE?
- HELP!!!! Parking lights not working!!!!
- Engine Bay Cleaned by Joe (Maximan190) Thanks!!!!!
- 3rd gen owners that have drove a 4th gen..
- Question for the Moderators
- nismo1989
- How can this be
- Question About Window Tint and Proximity Sensor
- Identify this electronic box
- HorsePower?
- Quick Wire Color Check (power antenna)
- timing of timing belt
- Rust!!! Noooooo!!!
- car not starting
- I think my alarm locked me out!! Help!!!
- Interior Swap
- Skipping
- Rear disc brake conversion complete...
- Just got the 411 on my suspension...
- I finally modded my 92GXE's lights to match my 2nd pair of UK corners
- Window switch repair
- High flow Air filter---strange noise now
- climate control light dim
- Not a good start.....
- disabling ABS
- Auto tranny on its last leg.. 2 flush or not?
- Speakers in the rear doors
- clicky/grindy noise
- new info on my troubles
- Radar Detector
- idle messed up after injector change
- ADDCO Rear Sway Bar
- Help with Redmax's Tv
- slave cylinder
- Gauges in your max
- next mod ???
- I got a little carried away, i know i can use one, i need help.!
- my latest "mod"
- Really Quick Tire Size Question.
- cluster question
- Timing Belt Replacement Experience
- electrical problems!!! HELP!!!
- Installing 10 gauge wire through firewall
- wipers don't return to bottom of windshield
- Stay Awake!
- rotor bug
- Proper LED for above radio?
- Please Read. Any help, thank you
- Interior cleaning
- 300zx Parts
- Drum Brake Replacement, Please Help
- Neighbor backed into my max
- Looking for rims for my 90 max!
- headers
- Frankencar intake
- window regulator ?
- Squeaking noise
- Car Starting Question
- KS vs. MPG
- need some help
- One quick question.
- How about the FSM for a 3rd gen?
- Transmission problem
- Man I love a clean car!!!!
- what is the % vlt of the factory tint?
- modified shift knob and e-brake handle...
- Homebrew CAI / MAF Relocation w/Photos
- Is there anybody here that has actually set the timing after a rebuild?
- anyone seen these angel eye foglights?
- power/comfort switch not working?
- Black Cylinder in the Trunk of a 92
- Fuel injector cleaner
- How much for Freeon??
- Engine shakes
- unorthodox pulley
- where can you buy a wraparound headlight cover?
