PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. cheap muffler?
  2. "Lake Maxima" Spare tire well is full of water
  3. Engine temp gauge not working...
  4. Heater doesn't work
  5. Major puddle has me scared as hell !!
  6. Grounded VTCs -- car dies, any help
  7. Another DQ
  8. I want to chop an inch off my stick
  9. pics of 3rd gens w/ 17s and NO springs?
  10. Lazy / Lax Shifting
  11. trunk won't open
  12. Power seats
  13. starting problems
  14. 5speed conversion? 92SE
  15. 5-Speed tranny rebuild kit
  16. code 33
  17. Custom Maxima Short Shift???
  18. Hard to start after sitting in rain.
  19. 1993 Maxima VG30E Engines
  20. Door Panel Fabric Replacement?
  21. ISO: FTP guy from yesterday
  22. Fuel problem?
  23. Jeff92se......you were right.......
  24. Rear BBK interest. Custom brackets, Z31 rear rotors 1" larger
  25. ABS Sensors
  26. Need help with intake manifold gasket
  27. Another Ebay CAI installed! Pics!
  28. regular to digital heat/ac controls?
  29. anyone replace steering pump?
  30. Ticking/Clicking noise when car's off
  31. Stereo wiring(Involving lighting too)
  32. Leaky Windshield
  33. Good price for Fidanza Aluminum Flywheel ??
  34. dash cracks
  35. Jim Wolf Tech Cams....
  36. License Plate Lights
  37. made up my mind
  38. Speakers...in the Headrests?
  39. turbo kits
  40. Interesting nugget of info concerning VTCs
  41. Anyone want some carbon fiber
  42. Update my cardomain page...finally
  43. PICS: AE gas pedal and mustang rim fitment
  44. Do I have a LSD?
  45. Performance problems w/ Maxima SE
  46. Shock alarm on keyless entry?
  47. strut tower brace for the VE?
  48. 95-99 bose cd/radio in a pre 95?
  49. what kind of plugs make our VE's "happy"
  50. where to buy a Ve FSTB and udp
  51. replacing bose 6x9 with polk's?
  52. I took night pictures. Check them out, NOW I SAY! NOW!
  53. New Paint Pics
  54. Stereo Install
  55. 3.4L 250hp VG engine..
  56. Where's my armrest?!
  57. Tire size for 18s
  58. Put some pics of the crappy mobile up.
  59. black leather seats on ebay
  60. I wish there was a company that made BMW conversion headlights.....
  61. 6.5" Speaker Pods
  62. Power Door Locks
  63. transmission filter
  64. Maxima Shop
  65. Wiring question
  66. Fstb
  67. temp guage problem need help
  68. took some new pics and installed a cupholder that works!
  69. aftermarket steering wheel
  70. Street Racing
  71. Smallest Tire Size
  72. turning my 93 into a falSE
  73. Help! Blinkers stopped working.
  74. I am an ebay whore
  75. fog light switch dilemma..........
  76. indiglo gauges for "3rd gen maxima"
  77. Radio Interference
  78. Arggggg Asp Udp Bs
  79. re-programing keyless entry
  80. Hydraulic Hood
  81. Help. Can't find fuel pump relay 92 GXE
  82. 2" drop front and back do i need camber kit for front and back?
  83. speaker wiring...
  84. Testing fuel pump?
  85. Where are the EGI/ECCS and start signal relays?
  86. starting problem, please help.
  87. Exhaust help
  88. Fuel filler recall?
  89. Hi!
  90. Getting rims, which finish?, and tire size?
  91. Weird shifting . .
  92. Took some pics today
  93. Got hit today at lunch -- It's the engine swap curse.
  94. white rims on a white max? YES or NO
  95. How to know when to replace cap and rotor?
  96. BMW headlights on a 3rd Gen
  97. 91 w/ 94 VG30E
  98. which springs?
  99. Nismo parts for a 1993 GXE
  100. corner light problem???
  101. location of pcv valve?
  102. how many O2 sensors do our maximas have?
  103. removing headunit
  104. Check it out
  105. Does anyone run 16's on thier max? Input please!
  106. Car idles rough, hesitates, but smooth at high RPMS.
  107. CAI install
  108. sunroof stuck open
  109. Which mod first
  110. Not to bring up a dead subject, but.....
  111. still studdering
  112. misfire & power steer leak
  113. looking for help to solve the problem of 92 AT SOHC
  114. should a engine shake or not during normal idle
  115. 300zx steering wheel.
  116. Shifter boot position...
  117. Powdercoated Intake Pics
  118. cutting shifter rod
  119. NISSAN MAXIMA stickers, back of trunk
  120. Screeching wheels!!!
  121. Breakdown of 3rd gen transmissions
  122. Why doesn't my alarm work?
  123. 3rd Gen Alarm Install Help
  124. Y-pipe and High flow cat gains
  125. Lock Cylinder / Tumbler
  126. finally its going my way
  127. airbag light on intermitently
  128. check out my evilmax
  129. Whats this part? Why's it leaking?
  130. Who's got least mileage on the odo?
  131. Replacing headlamp assy.
  132. very common problem on a vg
  133. Flanges on CAT both same?
  134. Timing Belt Replacement
  135. 2 Really Important Questions!!!
  136. signs of cat failure
  137. 2nd car
  138. How do know if your knock sensor is going out?
  139. Tranny died, now what?
  140. hellllp!!!!!
  141. Why pipe bolts and gaskets
  142. Need help soon with dashlight/gauge question
  143. hesitation(diff. from CCTF's post)
  144. guage pod
  145. whats the link
  146. Hesitating 1994
  147. Transmission causing non-working Speedometer
  148. what r VTC's? sorry, i'm an LS1 guy.
  149. Mass Airflow sensor?
  150. Strange issue
  151. OBD1?? ECU speaks for itself
  152. too good to be true
  153. Taillight Removal?
  154. VE or VG? Is #93 gasoline necessary?
  155. How much for axle replacement?
  156. B-G spring
  157. jet-v-force power control modules
  158. Engine Diagnostic
  159. car takes 2-5min before turning over
  160. FUnny Sounds
  161. Crankshaft pulley nut size
  162. clickity clack, clickity clack..........
  163. Lug pattern size?
  164. Bumped into another car backing out of a parkin space
  165. Interior parts?
  166. Porting questions
  167. help!!!
  168. My car's cool.
  169. Engine timing on 94 Se
  170. Here we go: JDM VE Swap getting underway.
  171. Intake Options
  172. Touchup paint for a black maxima (pics :))
  173. What should I do?????
  174. Spoiler Lift Question
  175. Y-pipe Install
  176. DAMNIT, studder = new problem
  177. Guage install problem
  178. Auto question for 92-94 SE's
  179. N20 question for 92-94 maxima owners...........
  180. the invisible Red 91 SE
  181. Tranny Question
  182. proper oil level on VE
  183. GXE AT Shifting Problem
  184. 3rd gen seat in...
  185. VTec V6?
  186. Good news, the maxima is staying in one piece with me
  187. Flow Master
  188. im loosing my mind !
  189. But its over now....
  190. fuel pump problem?
  191. possibly fixed stalling problem
  192. VE30DE Stainless Steal Brake lines??? GB?
  193. engine swap
  194. 4th Gen Seats in a 3rd Gen.
  195. how do I fix a broken lug stud?
  196. weeeeeeeeeee Paint Pics
  197. New Car!!!
  198. keyless entry
  199. ?? VE ASP UDP belt sizes ??
  200. Speed sensor didn't fix speedometer
  201. DQ [dumb question]
  202. Need help or advice for my max89
  203. New to the 3rd gen forums
  204. CF Trunklid for 3rd Gen
  205. How bad would a straight pipe sound?
  206. GR-2 struts....Springs???Dunno!!!Help!!!
  207. Gentex mirror on 3rd gen.maxima
  208. How fast can u go???
  209. Coil wearing a beard
  210. Lighting !
  211. Drop resistor mod on 3rd gen?
  212. Getting a car?
  213. Udp
  214. 92 maxima ecu
  215. Ve is down for good!!!!
  216. 92 Se Sensor Problem!
  217. Cold Tranmission Problem
  218. ahhh.. what do broken exhaust studs look like
  219. How much is a '93 SE w/ ticking VTC's worth?
  220. no boost for me...
  221. oil sending unit
  222. Valve Cover Gasket ?
  223. Will This Antenna Work?
  224. BlehmCo Lower Tie Bar
  225. Engine replacement
  226. difference between VE and VG
  227. Cold Air Intake Question...
  228. RACK & PINION PROBLEM???
  229. fuel management??
  230. Powdercoating intake manifold
  231. need help changing cv shafts
  232. spoiler question
  233. Maxima Ti info 4 Shane001
  234. stupid VE issues(very long)
  235. Aftermarket headers, and a question about the O2 sensor.
  236. exhaust smell in my car
  237. Splash Guards....do they come OEM?
  238. Re-Building a VE for performance
  239. fuel injector harness
  240. cooling fans
  241. clear corners fix
  242. Better handling package
  243. what size is it
  244. How to obtain the keypad code?
  245. my 90 se VG failed for CO
  246. Did I get ripped off?
  247. electrical prob
  248. headlight problem, need help quick!
  249. hesitates , spudders and stalls in heavy rain
  250. Rear Speaker Inop After Hu Swap
