PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Broke 94 Maxima Key, Need master Key Code
  2. Squeeky New Brakes
  3. Steering Rack Boots?
  4. Car won't start...clicking sound
  5. 200sx fogs on 3rd gen? question...
  6. Engine Control Fuse keeps blowing...
  7. VE cluster on a VG
  8. timing belt ripped
  9. want to change headlights to bmw's
  10. knock sensor erorr code
  11. Brake question...
  12. Somewhat OT - Max to the rescue!
  13. Braking and Cluster light
  14. Exhaust question
  15. Mobil regular engine oil
  16. And the fun shall begin
  17. manual trans not shifting into any gears
  18. daytime running lights 4 Canada
  19. What In The Name Of Motherf****
  20. E36 325I parts
  21. VIN check please?
  22. electric powered max
  23. Maxima vids
  24. Low end torque gone?
  25. Intake question...
  26. 4th gen FOGS on 3rd gen...
  27. Who all has sunroof wind deflectors?
  28. need to wash engine to find oil leek
  29. Door panel question
  30. Argh! Just Missed the Deal of the Century!
  31. PCV vavle
  32. PCV vavle,.....
  33. Nismo Exhaust Hangers
  34. Strange Leak
  35. 4DSC and Canada
  36. engine missing
  37. Stupid Disc Brakes!
  38. Maxima Strut replacement
  39. Maxima A/C
  40. Door Attach Thingies
  41. Idle Hesitation Update
  42. maxima 94 won't start the first time
  43. stall, start, CEL... code 55
  44. Different MAF sensors?
  45. What a weekend...
  46. Best clutch fluid?
  47. Possible end of maxima
  48. Wow, my Max ran in ditch!
  49. Changing a Front Door
  50. Belts
  51. rear brake conversion
  52. New Toyota Oil Filter YZZF1
  53. hey anyone have motorized seatbelts?
  54. need help replacing brake lines under car...
  55. New to the .org & got a question
  56. Weekend projects and stuff
  57. some more info On the vg30
  58. ABS Control Unit
  59. can ya'll help me out.
  60. for the VE fanboys...ok anyone:)
  61. Problem with hesitation/vibration
  62. Starting Issue and smoke from engine bay.
  63. car runs like crap after it warms up - need advice
  64. Hose from Transmission
  65. 5spd ve tranny problem
  66. Non VLSD VE Auto trans???
  67. VG30E Pop Charger
  68. What is this part?
  69. Heater core/vent assembly R&R
  70. timing belt broke
  71. Headlight Not Working Properly
  72. Rear suspension connecting rod issues
  73. hmmm...idea....ricey of course....
  74. Quick Rear Suspension Q
  75. good basic struts?
  76. the mag mod
  77. Where can i find?
  78. factory springs.
  79. Need Help with Fuel Injectors
  80. Hard Jerk from Tranny
  81. Replacing Power Window Module
  82. g35 rims??
  83. Cruise Control Won't work
  84. Anyone use Polarg M4s in their SE guage clusters
  85. help with a VIN check?
  86. replace head gaskets vs entire engine.
  87. Speed sensor or guage cluster
  88. ways to remove crankshaft pulley w/o impact gun
  89. Clutch problem
  90. Gauging interest in 91 max
  91. stock ve time vs stock vq time
  92. Flywheel Issue(I think)
  93. Airbag system recall stuff
  94. VG intake manifold
  95. Flip Flop Trunk Question.....?
  96. Time to say goodbye to the 3rd Gen :sadwavey:
  97. Amazing event today.
  98. Stuck Odometer/Tripometer
  99. Rust repair panel source?
  100. horrible sputtering
  101. Quest engine interference?
  102. Strange shudder when slowing down and speeding up under 55mph
  103. Mystery of O2 Sensors Revealed!!
  104. Difference between VQ, VE, VG
  105. Green Dot Fuel Injector
  106. VE vs VQ (plus a pic to get you to look)
  107. Can someone help me .
  108. Warpspeed Y-pipe Leaking
  109. A/C Comp. not turning on!!!
  110. AMP bypass
  111. Cam Shaft Seals
  112. really bad news for the maxima
  113. Rear Disc Conversion
  114. Cooling System
  115. Radiator fans not working?
  116. How to check if ECU is bad
  117. bbk
  118. MAF or Knock sensor?
  119. adding aftermarket siren
  120. Passenger side Axle/ball joint issue maybe related to ST sway
  121. Just asking?
  122. omg VTC ticking GONE!!!!!!!!!!
  123. Head room?
  124. Dashboard light problem
  125. Drag
  126. .ORG and Maxima New Guy
  127. once you go black, you go back
  128. GXE gauges with SE Gauges write up
  129. K&N Air Intake Install Write-up
  130. digital dash
  131. wierd problem....
  132. Installing new Rotor, and brakes
  133. Gas Odor
  134. A good place to buy struts
  135. ABS Error message
  136. New pis, comments welcome
  137. Question about rust
  138. Vans Skater Freak Parking Lot Madness Video
  139. Exhaust Manifold
  140. Arg!!! Cracked Rear Manifold!
  141. vg30et
  142. Broken Emergency Brake
  143. Window Motors
  144. Changed rear struts, wheel cylinders..
  145. New K&N Air Filter Installed! (photo)
  146. Jack Hammer Vibration/Sound Front Passenger
  147. Need Bolt
  148. How is the ride?
  149. e36 headlight ( sware it's last on this topic for me )
  150. FS: 93 max
  151. Radiator, AC, Heat Question; Overheating
  152. Insurance accident question
  153. BMW Headlight List (L00K)
  154. replacing struts
  155. STB question
  156. sputtering question
  157. brake master cylinder leaking between it and the booster, gasket maybe?
  158. will place racing CAI for VE work with VG?
  159. Steering Wheel coming apart
  160. Adjusting font tires?
  161. Popping noise from front right wheel well
  162. Digital dash not workin when cold...
  163. Happy Easter!
  164. oil on plugs
  165. strange noise w BOSE...help
  166. Rear brake and caliper q's
  167. Idle situation
  168. Replacing Water Pump?
  169. got bored so decided to take some night time pics
  170. switching gauge cluster 125 >> 145
  171. LCA Bushing how to
  172. Digital speed sensor?
  173. Battery Leaking Power
  174. What kind of oil / filter?
  175. ecu self diagnostic
  176. Front Panel Lights...
  177. Fluttering sound between 1500-2000 RPM (manifold studs?)
  178. What kind of tranny fluid
  179. Timing belt question
  180. leaking oil and coolant O.O
  181. Newbie here.......
  182. Ipod
  183. The mysterious box!
  184. Crankshaft pulley
  185. cassette player
  186. Wierd Windows HELP!!!! 90 GXE
  187. Finally!! power locks again
  188. 5 sp Tranny conversion: Component verification
  189. almost sold the black one..
  190. Not sure maybe MAF?
  191. RPM's drop at speed/Bad idle
  192. check this out. a pretty nice deal!
  193. Check it Out! (56k beware)
  194. New VE engine coming.....w00t
  195. cost of a break job?
  196. O/D on auto tranny - when (and if) to turn it off?
  197. Gunna Rice it out.
  198. Bose Woes
  199. Alternator??Charging Problem
  200. Tranny Leaking...Grrrrr
  201. Anybody in the Seattle WA area race a black max
  202. code 33
  203. another oil leak......any help?
  204. what the heck is this?
  205. Ordering new bulbs anynone prefer diff brands?
  206. sun roof leaking?
  207. bye bye to maxima, hello to 240sx
  208. control arm bushings
  209. Hmm Nissan/Infiniti wheel version # 3245687736
  210. Honest Shop for Colorado
  211. Grounded vtcs but they still tick.
  212. 89 max
  213. Maxima and itss overall integrity
  214. window problem
  215. Rewire of overhead map lights
  216. Thumper Antilock Brakes
  217. How hard is it to remove the air intake?
  218. It's ALIVE!!!
  219. ok another gas consumption question
  220. Cleaning the IAC on a 94 Auto
  221. Problem with Swap!
  222. is it the starter?
  223. 35,000 miles on a bent rod..
  224. Fuel Injectors for a 1994 Auto
  225. Transmission Swap Question
  226. A/C & Ash Tray swap?
  227. oil question
  228. Rough Idle/Hesitates off line
  229. Bad Mass Airflow Meter
  230. Disaster!
  231. I keep wasting my 90 SE motor mounts?
  232. would flushing the coolant keep heat warmer while idling?
  233. Custom 4dsc Sticker interest Thread
  234. warpspeed complete 2 1/2 exhaust - worth it??
  235. Aww, isnt it cute?
  236. can someone carfax this for me?
  237. Pictures on your posts
  238. Vibrating Gas Pedal.
  239. ecu upgrade question
  240. Manual transmission questions.
  241. transmission fluid
  242. lost my valve cover thread.......here's a question
  243. might be committing the unforgivable sin....
  244. finally changing my sprakplugs
  245. Can Seafoam damage the engine?
  246. General Lee meets 3rd gen Maxima
  247. changing tranny fluid in my 5 speed
  248. Grounding VTCs quick question!?
  249. jsut a shot of the old 3rd gen
  250. air conditioning a/c compressor noise
