- Fuel pump gone ? Cause its not worth fixing
- Do I need to go from BKR6 to BKR7 if I advance 15°?
- 28,875 original kilometers on a '92!
- Suspension Possibilities
- Headlights burning out! Time for swap?
- VE33 or VE34?
- The best ride w/ lowered height
- VQ35 3rd Gen?
- Questions
- Cleaning injector conections
- just a maxima
- Idle Sputtering
- Trans: electrical problems next day
- Black or Beige
- Need new leather seats
- Changed brake pads, now soft brakes!?
- Possible to measure rear injectors without taking manifold off?
- new body kit? or remake?
- installed ADDCO RSB
- Sticky rear caliper piston-rebuild easy?
- Sonar Suspension Removal?
- Shift Light Requirements?
- Bet you've never seen or heard this!
- low mileage transmission or rebuild?
- Advice on BBK for 3rd gens
- 6 cylinders vs 4 cylinders
- accident in parking lot
- Car Parts,
- In what order do you bleed the brakes?
- WTB: 3rd gen stock springs WTT: aftermarket springs for stock springs
- Seat belt chimes
- Leaking tires
- Help PLZ! Turbo questions
- I broke my 3rd-4th gear shift fork....
- Back from Trip, Met Some .Orgers
- Stock headlamp Q..
- '93 SE/AT Brakes, Clacking & Manifold
- heat!
- Trans shifting
- What's this hanging from the dash??
- strong wind
- Suspension/Steering overhaul question
- Motor Mounts. where?
- H.i.d.s On The A 3rd Gen Yea Or Nay
- Humming noise from rear
- Is this a good buy
- fuel master?
- 5spd and Neutral Safety Switch
- Brake Help!!!!!
- thumpin noise
- Hard start on humid day
- Help on DIY brake job?
- My baby is gone.
- Ready to KILL someone
- installing gauges
- those who have the infiniti basslink installed, couple of questions...
- Maxima's OEM Anti Theft Alarm
- gret news!!!!!
- Headlights Opinions
- Fate of 89blackse, Advice please.
- What are you driving this winter...
- power lock actuator pinout
- Faulty Gas Gauge!?!?!
- Turn Signal relay question
- exhaust
- GREAT Source for 13" Rotors
- first string of problems from the 3rd gen are here
- 88-94 body style changes?
- Starting is becoming a chore :(
- a strange bogging/vibration noise, muffler related?
- why can't all forums be this helpful?
- lost endlink bolt
- Bad alignmnet after CV boot replacement?
- Engine temp sensor
- Exhaust
- Anyone install 9007 bulbs in their headlights?
- climate control backlights - 3/4 of them just died
- 3rd Gen whoops up on 3 5th gens and an I30 at autocross
- Lights are scaring me
- Do I have limited slip?
- Slight studder....
- p/s problem
- Mass Airflow Sensor Source
- possibly changing out all 6 injectors
- selling whole or piecing out
- Problems with headlight chime
- burnt smell coming through the vent..
- Any Idea Why Fans and Coolaint.....
- 3rd Gen weird noise, need advice.
- tranny went
- Is it a bad idea?
- A.A.C valve on the VG
- New headunit wont turn on :(
- Milky looking oil
- all right, who is a quiter?
- could it be the VSS?
- How Many Have A 3rd Gen With All Options...
- vtc? refresher please
- Tighten the steering
- I HATE my engine!!
- How hard to replace CV joint?
- Timing belt gone?
- This Is Interesting.....
- When Pimp my Ride gets hold of a 3rd Gen...
- Heater Valve
- Rotting front end
- fog light re-wire help
- Painted Interior Trim !?!
- Bose Fix
- Addco RSB hardware
- Sticky: Engine running rough?
- motor problem
- Body Kits
- HELP! Max shut off..No Spark..
- need CV axles
- #4
- Swapped struts today...
- LED Spoiler Brake Light
- Got hit by a F150
- Maxima's Gas consumption
- brake problem please help!!!!
- Bose/Car electrical problem?
- Front door speaker(Bose replacement)
- Possible HP mod for our VE's?
- well... might be getting another max.....
- Bar's leak working ?
- Plug Wire Question
- 1993 Maxima SE
- Tokico Suspension Kit
- Do I fix the body?
- Wierd engine thing...
- 94 Nissan Maxima Shocks
- Crossmember Carnage
- Ebay FSTB
- Head Unit Decission help please.
- Bouncing RPM while going down hill
- Dancing Speedo
- 3rd gen vg manifold set up
- Rough engine -- all conditions
- If alloted $10 G's, what would the best idea?
- Need help transmission fluid pan crack
- Looking For Parts Needed For 5 Speed Swap on VG
- Starting car with timing belt cover removed
- Working on the 3rd gen
- budget CH0
- Cigarette Lighter Ring Light Removal
- Another axle going out.
- Just got Waxed Pics!!!
- Brakelight wiring diagram
- Noisy belts?
- Technical question
- car problems help!
- Euro headlight pics wanted...
- Tail Light/ Blinker Mod
- No acceleration. Looking at 3rd gen for an in-law
- SE Rear Brake proportioning
- Rear Brakes
- HIN show
- Since everyone looks for stock fog's
- turbo question for anyone that done it
- Coolant Leaking
- Ve Rwd?
- Before you change the temp, make sure you....
- Rear sprockets not lining up after VTC rebuild
- weird noise, oil leak & exhaust
- occasionally shaking
- knock sensor?
- stupid mistakes lead to big problems...
- starter question
- Electrical problem...help
- look at my plugs...(pics)
- VB cleaning or else?
- brakes
- ball joints and front motor mount
- sunroof shade stuck
- windows and seatbelts not working
- 3rd gen seats fit in a 95?
- VG30E PICS to identify hose routes, please.
- Battery problem
- Opinion
- weird putting...
- I smell gas....
- parting out 91 Max GXE
- What tells the seatbelt to retract?
- As life of our beloved 3d gens coming to an end...
- Temp Gauge Not Working
- Bose tape deck - unichannel?
- Anyone Ever See This Car Before?
- Hot/Cold Slider Control Sticking
- Does anyone know the EGR pipe nut size?
- VG Autocrpatic
- New Rear end vs Old.
- Bulb question
- had a wierd offer recently
- Rebuilt Transmission whine
- Anyone have pics of new EURO headlights?
- replacing axle
- car vibrates when in reverse or drive gears
- Weird vibration while accelerating
- Fuel leak
- fuel tank straps
- 3rd gen with bose
- Clutch question
- Question about an Auto Tranny issue
- my e36's
- HaTe my locks!! Need part quotes too.
- Mid-page pics
- Clicking Noise from the dash...........
- Just ran into two problems...
- vg30e and vg30de same auto transmission?? need help a.s.a.p.
- Steering Question
- 1989-1991 SE Trunklid Tailpiece Lettering
- Gauge Clusters
- Speedometer problems
- Spoiler...trunk not popping open
- quick ? about trans seal
- Car don't shift 2-3?
- Need help installing a 95 Bose double din into my 92 Max
- twin turbo 3rd generation. with pics.
- VE Thermostat Gasket
- Just picked up a 3rd gen; have a few questions..
- bumper paint - comes up much darker
- car won't start, clicking like machine gun
- Changing power steering hoses?
- The Max took another hit
- Energy Suspension control arm bushings
- Twisted off both bolts for the foglight....
- LED 194 lights
- fog lamps...how in the hell....
- Orange DONK Maxima
- Need help with a strange vibration issue
- Alternator recharge questionaire!!
- Sold another 3rd gen (pic)
- Car cuts out in the midlle of the road
- For those with lowering springs.
- Exhaust Question
- I have a dilemma...
- head problems not VTC's
- Noticed extra heat...
- A mod that isnt "rice"
- Need Help With Brakes
- Broken Mani bolt or just a rotten Exhaust?
- So im thinking of getting a cheap 3rd gen DD !!READ!! !!HELP!!
- Another accident, pics inside
- HELP....ASAP left headlight not.......
- reverse lights not working
- Sqealing brake caliper
- Infinity j30 intake
- Euro headlight pics...
- Front Engine Oil Seal Leaking
