- body kit info
- Smell gas (rookie needs help)
- lance...about speed sensor (dont know user name)
- Unorthodox Racing Underdrive Pulley Question
- Upper rad. hose leak...
- Basic Info How to Turbo Any Car Properly (NO BS!)
- ? On a Used 89 SE I bought
- anyone here with greddy?
- Broken exhaust manifold stud...is the entire hole threaded?
- How Can Put My Maxs Pics
- lights any idea's
- changing fuel lines
- Shift Kit on a 93 GXE
- Exhaust Manifolds........?
- Water Pump.......?
- Bose system fails intermittently
- 3rd Gen on Fairfax
- Seat belts and power locks out hmm???? help?
- maxima with octane front
- SE wheels
- "ticking noise"
- 19,000 mile maxima
- hey guys, do 3rd gen BOSE SYSTEMS have CD??
- Problems with '90 SE
- A Different Accord intake question
- Fuel Leak
- Wheel Bearings??
- New rotors or just brake pads?
- Eazy Brake Light Fix
- bmw headlight question
- J-30 need assistance
- A little run in with a NJ State Police
- Tranny problems
- Few changes on the max...
- JDM Engines: Where is a good place to get them?
- Any body for a wheel hub ?
- Just Ordered My New Exhaust System
- Oil Switch
- Max sold, who needs a FSM ??
- where to find e36 elipsoids
- new pics with Cobra SVT rims
- Problems with radio and electrical system
- Dame Trees!!! (accident)
- Hit and Run
- Fan Motor Replacement?
- fans not shutting off
- ATF & Filter Replacement
- for Pioneer Radio owners
- Car is freaking out suddenly..
- weird sound
- 4th gen springs on 3rd gen???
- Thermostat replacement??
- Y pipe with B pipe
- hydraulics?
- o2 sensor
- good price on SE?
- Headlight Socket Meltdown
- alignment questiom
- VE rebuild...parts?
- VG30ET proof, for those who need
- Another 3rd gen gone........
- I am totally baffled on this one (a little long)
- Where can I go to learn more about cars?
- Are the ecms interchangeable for 89-94?
- VG30ET for max
- 1992 Nissan Maxima Fuel Pump
- I know this seems to be a bad word but I have a question about Earl Scheib???
- know a good shop to go in Pasadena, California?
- Timing belt replacement
- Question on addco rear sway bar
- MAF Sensor FSM Question
- airbags
- OK, an end to spinning the tires for 3 sec with an auto
- Warpspeed Y pipe / ECU question
- Grounding VTCs actually engages the sprokets
- how to remove windshield trim
- cai intake hole
- c.v. shaft question. . . .
- I guess this is goodbye....
- Max suddenly running poorly - seeking diagnosis
- 15" Alloy Rims
- Do not prompt what oil better...
- Strange o/d button issue...
- trani oil which is the best ?
- Are SS Brake lines worth it?
- someone cracked my plastic trunk "taillight"
- Carbon Fiber hoods
- Another IDLE question
- for all with low profile tires
- Digital Clock in Dash/91MAX
- got cupholder tonight
- installed ypipe
- What's wrong with my alarm?
- will probe rims fit an 89 se?
- Taping sound in dash when key turned to ACC
- greddy...exhaut
- camber
- painted interior
- Steering wheel crooked after aligned????
- CF hood came yesterday!
- NTK sensor in Bosch box please help !!!
- rusted rotors
- Tire Selection.......
- I Ordered My Maxima.org stickers and......
- Problem with 1st gear
- car key is stuck in ignition
- Fuel Smell and o2 sensor, need help
- Please Help!!!
- simple question about gas gauge long explantation can you help
- engine replacement, but how far can it go?
- Rough Idle
- WSP Y-pipe write up
- What is this Cylinder in the Trunk?
- Amsoil 75-90w Synthetic Gear lube
- HELP w/ Wiper Arm Fix...
- About to order a caliper.......but need some help Matt93SE .
- Engine "whirring" noise
- Where is my ECU
- engine vibration after major tune-up
- wheels comming in thursday
- I need a stock y-pipe
- I hate to repost a thread but LEDs in the tailights
- engine swap
- VB mod for 92 SE
- Undiscussed door lock issue
- is it the AXLE or the TRANNY??
- Injectors
- Ok if you didn't like that one then here's a deal!
- Hey guys found a sweet VE 5sp but it has "electrical issues" couple of ?????s
- lights on gauge cluster where can i find
- Body work
- Oh BOY!!!!!!
- MB Quart installed and Valentine 1 report
- How much is it worth??
- re: water leaks in passenger side
- Got Skyline tails??
- My max is on life support
- Manifold leak question?
- important question
- Problems starting car
- Another VE stall mystery
- Another Wasted 3rd gen max
- Can you help a girl that can't figure something out?
- Brougham?
- interior paint vs dash kit
- how many miles on 3rd gen after gas light comes on
- Where Are The Maximas
- Keyless entry
- Please Help With Fuel Gauge Problem
- crazy idea...
- Rear brakes
- Hud Nightmare
- Veenerz brushed alum kit
- Pics of 3rd Gen w Konig Tantrums..LOOK
- BMW vs. Max
- Maxima.org Member Sudden Death
- Halloween has struck my car...
- Talking Chimes
- Intermittent Heat
- HELP! Very Rough idle, stalling wont go above idle speed
- Loud Screeching Noise
- VE Fuel Injector Replacement How-To
- No Power
- if you guys need any welding done..
- Brakes
- Temp Gauge Inop
- Power window (and lock) problems
- ? about a VG30L engine.
- cutting springs
- AIV Valve install
- VASCAR info?
- Maybe it's not the fuel injectors...this is long, sorry
- Where is a good place to buy rear calipers from?
- Help with Heater
- power locks
- car running like crap!!! I need Help
- Anyone know where I can get floor mats for my Max!?
- Chck your thermostat before it's to late!! What happened to me-
- 3rd gen spoiler
- air suspension
- Is it possible to get...
- New Wheels?
- May I borrow your exhaust manifolds?
- Heater Core Follow Up
- Heater/ac Switch Problem
- Has anyone painted a 92 - 94 GXE grill body color?
- Thumping noise only on hard right turns
- california emissions!!!
- Fuel Injector relacement...how long?
- Any suggestions? (please help)
- which pressure gauge
- A/C Compressor Belt? I Need Help Please...
- Need throttle body
- motor mount ????
- intrax vs snow
- just ipgraded to K and N filter - help installing.
- 92-94 Upholder Install In 91 Max??
- I want a 5-speed, what's the $?
- idle air control valve
- this is getting ridicules
- Can "MAXIMA" emblem be removed???
- Thanks Craig B!
- Addco RSB install write up with Pics......
- computer problem
- Ac Control Removal 3rd Gen
- Hardwire Motorola T720 Cellpiece charger
- im lookin at my new max
- I need pistons for 94 nissan MAxima sohc
- going to the track next week...
- ATTN: Any VE's in Kentucky to prodotype turbo kit...
- noisey gearbox!!
- need leather seats
- Camber readings
- Car runs horrible unless fully warmed up
- Digital Dash On A Maxima????
- stock tranny
- 90-93 Infinity Q45 vs 3 Gen Maxima
- bug deflector/guard for 3rd gen
- what fits
- Shifter Bushing...Help>>>
- i need pistons for a 94 maxima
- who is this?
- Interior Seats
- The big bad vtc.
- Any maxima meetings comming up in the tri state area?
- Why is there even a Maxima Soft Top
- I might have a solution to your 92 se drivability problems
- Oh no! Rusting paint
- post whoring
- access to fuel pump
- Question on Lower Control Arms
- question about muffler. hope you guys can help
- Value of 92 SE 5-Speed
- weird noise during steering, could it be the cv boots or rack and pinions?
- Should i get it ?
- New Stereo Problems
- Carbon fiber hood check
- Wheel fell off.
- Keypad LED mod, anyone tried?
- rota wheels
- more on advanced timing...(long)
- cai template
- problems with a/c & heating lever
- rear brake
- Budget Y pipe no more
- What's the difference between....
- HeLp CHeeZer out... tranny q's, exaust q's long and booring dont read!
- Bad experience on buying a 3rd gen!
- Fogs and Wiring
- Misfire again!! AAARGHHHH
