PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Shifter Bushings
  2. A Maxima Newb
  3. Window regulator going?
  4. Transmission problems
  5. back to the org! Wanted to say hi NEW PICS
  6. Headlights HELP PLEASE
  7. easy to remove rotor on a vg 90 max
  8. bad smoking after injector change??
  9. Messed up the Max's suspension...
  10. Check it out! TRUE or falSE?
  11. How to tint or smoke clear corners
  12. cold air intake adaptor
  13. 5 speed swap and neutral saftey switch rewire
  14. power steering removal question
  15. A few rebuild questions.
  16. 93se Tranny Problem
  17. I have the catalytic converter off -is it bad?
  18. Urgent help needed please
  19. Converted to VE power
  20. Fack!! I Hate My Car It Should Die!!!
  21. Power Window Switch / Wiring Chart?
  22. Pulling Engine on a 1990 Maxima
  23. Where they put the dipstick!
  24. cold air intake
  25. 300zx brakes in 16x6.5 wheels
  26. cooling system problem
  27. seat belt
  28. Some crazy Summer projects done
  29. Bose CD player compatibility
  30. sunroof in 89 maxima se
  31. Just makin sure, these rims will fit
  32. Location of dome light and parking light wires (alarm install)
  33. 3rd Gen Cartoon
  34. Factory Sunroof Problem in 3rd Gen SE
  35. Parking brake cover
  36. help look 4 a carbon fiber dask kit
  37. high expenses for Maxima
  38. disc brakes
  39. Need a knock sensor...
  40. 5-speed lubrication help
  41. What auto tranny mode do you use all the time?
  42. putting
  43. Gas tank to trunk clearance
  44. 93 GXE drum brake locking
  45. Where to Purchase Used Auto Tranny from Japan
  46. Does anyone tune-up their own car?......
  47. Fastest Ve
  48. ABS Sensor Locations????
  49. 300zx engine question
  50. 93 SE hiccuping and stalling at idle
  51. 1992-89 3.0l MAXIMA Air flow meter
  52. firewall?
  53. White stuff inside distributor cap?
  54. Easiest way to get axle mount(?) off?
  55. Are there any 'charger for a 94 se?
  56. Life of an engine??/
  57. I Think It's Dead!
  58. oil in cylinder
  59. Low fuel light always on
  60. Absolute cheapest place to get tune up parts?
  61. Engine Mounts/wheel Sensor Circuit
  62. trans
  63. New Kid n da Heezie:)
  64. Valves on pistons - quick TB question.
  65. 94 se suspension vs 93 gxe suspension
  66. How to remove backseat?
  67. Tube underneath EGR? help identify
  68. Antifreeze drain plugs
  69. Crank bearings part number
  70. Engine Wont start
  71. Y-pipes, short shifters & hot air...
  72. My Accident....Pics
  73. Pic between these two 5th gen Rims
  74. Gts Headlight cover question
  75. So i may have found my 5.5 gen...
  76. Reverse Light Switch
  77. Original 2000 17" Audi TT rims on a 3rd
  78. Bmw Headlights
  79. Chrome Rocker panel stick ons(stickers)
  80. Wierd exhaust leak
  81. Exhaust leak-manifold??
  82. replacing clutch slave and master
  83. craigs taillight re-wire
  84. Auto tranny woes...
  85. Newbie Tutorial
  86. Overheating
  87. Today is a sad day... My Max was stolen!
  88. what kind of body kit is this?
  89. loose steering
  90. Front end creaking on 94 GXE
  91. 94 Max Headliner
  92. eBay "20hp mod" BS?
  93. 91 - Transaxle/diff problem?
  94. cheap name brand fuel injectors???
  95. Water leaking from engine bay? (long)
  96. Shaky wheel
  97. Cig Lighter not working.
  98. Lowering Springs - What's the best?
  99. Getting 10 more years out of a Max
  100. wsp y pipe heat shield issue
  101. 93SE w/18" Nissan Murano Wheel. Finally.
  102. High Output Altenator
  103. My bulbs are weak.....need some suggestions
  104. anyone ever do a VQ swap?
  105. Good Pricing for swap?
  106. new weridness
  107. blinking air bag light
  108. Fog lights
  109. Max was stolen
  110. Replace Cloth Seat Upholstry
  111. Lose shifter and a list ??
  112. ECU question for 89 maxima
  113. odometer question.
  114. rims
  115. 5-Speed Swap Complete - 1 PITA Problem Though
  116. steering rack woes
  117. Egr
  118. Fixed my broken Moonroof shade!
  119. stock rim weight
  120. Yet another speedometer question...
  121. Se..gxe..4dsc?
  122. water pum
  123. I'm New and have a question
  124. Water leakage?!
  125. Antenna Questiono
  126. Timing Belt Blues - Epilogue
  127. Droopy door hinges
  128. WTH new ignition still running rich
  129. cheapo lowering springs
  130. Holey Situation: Radiator Leak
  131. 1991 a/c problem
  132. Strut Rod Bushing
  133. I weighed in at 3680 weight reduction
  134. My Fuel Injectors Suck!
  135. What OCTANE gas do U put in your 3rd Gen
  136. Is there a separate switch for turn signals
  137. Exhaust Question
  138. Best shocks for under 380$
  139. streamling the max
  140. Check out my window switch refab plan.....
  141. Painted engine bay pics
  142. Hey Ya'll
  143. tokico
  144. neon lights
  145. Well The Dream Is Over.....
  146. fill hole on 92 5 spd??
  147. Beater
  148. front caliper, rear caliper..diff?
  149. Replacing the heater core - DIY?
  150. Strut tower torque specs?
  151. 89 manual tranny overhaul?
  152. Rotor Question
  153. pricing...
  154. Cheap Gen 6 Rims???
  155. Valve Gasket\ Seal
  156. Weird flashing lights problem
  157. Bose radio/stereo light out
  158. How many O2 sensors are on the 94 maxima?
  159. How hard is it to fix front motor mount
  160. front speaker mount to replace bose
  161. Normal when cold, sluggish when warm
  162. auto shifter problem
  163. Door locks are possessed......
  164. radiator fans falling
  165. Electrical problems
  166. Fuel Leakage?
  167. No high beam lights
  168. Bose Radio Interference
  169. Sound Diagnosis
  170. new car need some advice
  171. i want more power...
  172. car stalling, again
  173. Sonar Supension System
  174. strange headlight issue
  175. '90 auto trans -> annoying whine
  176. Look! First 92 SE on 22's.
  177. I need help like so bad!!!
  178. Bad fuel injectors worse when warm?
  179. Power Steering hose replacement! *drip*
  180. Window Switches
  181. drive shaft boots
  182. Transmission Shudder in O/D 90SE Auto
  183. seafoam
  184. Wheel Bearings?
  185. VG30E max RPM
  186. resistance injectors, coil pack...
  187. just outta curiosity...
  188. Automatic Heat Conversion
  189. power window regulator
  190. Noise inside the car
  191. fuel pressure at idle
  192. Coolant Temp. Sensor???
  193. Epicenter lighting kit for 1994 Maxima
  194. car won't star
  195. PS fluid problem
  196. driveshaft boot tear?
  197. Trans shifting in and out of overdrive
  198. Foglights+curb=pain in my ***!
  199. '94 Maxima Fuel Injector Questions
  200. GXE to SE auto heat controls
  201. What are symptoms of a Bad Water Pump?
  202. yet another bose question
  203. help, ecu code 1,2,3,4,5
  204. spark plugs
  205. Steering Wheel SWAP!
  206. oem fog lamp help
  207. new maxima owner in da house
  208. White spark plugs?
  209. Vacum diagram
  210. Need a Tranny for a 93 SE automatic
  211. coil packs JDM
  212. Please help new guy out with motor swap!
  213. where to find cai
  214. Tech Help Please !
  215. One step closer
  216. Checking Tranny Fluid
  217. engine swap question
  218. Fix or say g'bye - what major problems to look for in a 10 yr old car?
  219. why dont wheels fit?
  220. blown cat
  221. stickys
  222. Sputtering
  223. Brembo cross drilled rotors
  224. Door MudRunners? Door sills??? ???
  225. OFF SCHEDUAL... as always! SKYLINE UPDATE!
  226. BlehmCo Rear Parallel Links - Review
  227. Bike rack from Avalon on 3d gen Maxima?
  228. Maxima <-> Infiniti
  229. knock sensor harness question
  230. How hard to replace an alternator?
  231. Door Locks
  232. Is this guy serious?
  233. tranny swap or 4th gen?
  234. K&N intakes
  235. Throttle position sensor?
  236. videos?
  237. summer time oil
  238. Tire size change - gas mileage
  239. Inside tire thread wear
  240. body kits
  241. Difference in Short Shifter?
  242. Steering Rack Question
  243. Help? Car dies after 8 miles, cools, restarts.
  244. Steering wheel tilt question
  245. Struts!!!!!!
  246. Calipers
  247. Another Fng
  248. Anyone got a good lead on 92-94 SE rear caliper rebuild kits?
  249. Trunk Lever
  250. Gas smell
