PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. My 93 VE motor blew
  2. I'm back. Yes Another VE 5 Speed. 1992.
  3. Jumping the fuel pump relay on 92 Maxima GXE
  4. Braided Brake line
  5. 1994 Maxima SE car feels like it's falling apart
  6. Mods
  7. Hub bearing and hub question
  8. Can I add power with adjusting spark plug gap
  9. Any one got any cheap body parts and other small mods . Thanks
  10. Can anyone help me? 90 Maxima 4dsc. Victim of neighborhood kids joy riding
  11. power coil problem
  12. door lock on the driver side
  13. Distributor for 94 GXE v6
  14. Climate control
  15. 93 Maxima Pricing Question
  16. Anyone have factory head unit?
  17. New muffler
  18. Acquired a 93 SE 5spd
  19. 1991, Standard Tranny, how to drain and refill tranny fluid
  20. Recircukate Switch
  21. Need help with transmission codes
  22. Phase II "new style" Injector Conversion?
  23. 3rd Gen Headlights
  24. Car sat for few months now won't start
  25. Damaged hood; what about hinges & latch?
  26. Engine Noise
  27. Need Help!
  28. No spark & no fuel 1991 max
  29. Heater core replacement
  30. front wheels look slightly bowed out. tires worn on inside.
  31. Air only blows from dash vents, not defrost or feet vents
  32. Engine Con 25 amp Fuse blows
  33. 3rd gen parts gone to dump.
  34. Feeling Nostalgic/Possibly Looking for a '94
  35. Timing belt replacement parts or kit recommendation
  36. rotor and brake pad recommendation
  37. 92 SE engine available
  38. Part number for bushings?
  39. 94 maxima se overheating
  40. Fuel rail hose.
  41. Electrical issue - windows, locks, amp
  42. Please help us
  43. Cracked dash repair?
  44. Car runs but all electrical is out.
  45. craigslist UK Maxima in Miami
  46. Adapting Rear Stabilizer Links from 87 to 89
  47. Aquarium door jamb
  48. Do you have to remove intake manifold to change spark plugs?
  49. Transmission mount
  50. Removing motor from window regulator
  51. Where is the best place to find a 3rd GEN SE
  52. New Guy looking at 4DSC
  53. Just got a set of Konis! Springs?
  54. tranny finally bites the dust
  55. 1992 Igntion questiosn
  56. Egr block plate
  57. Help me get my 93 SE on the road
  58. Metallic noise from/around distributor
  59. Who out there has a lousy clock and climate control display?
  60. Matt93se blehm's email?
  61. Missing Fuse Box Cover
  62. replacing ve30de with vq30de-k
  63. Reman power steering pump
  64. Anyone wanting to save some 3rd gen parts?
  65. VE30DE crankshaft seal?
  66. Bose headunit cassette player weird problem
  67. VTC sprocket question
  68. cv dust boots service?
  69. Removing passenger side cv axle help
  70. BIG Problem
  71. passenger side mirror 'short circuit'?
  72. Orlando maximas
  73. Hello from Russia!need your help!
  74. LED Headlamp recommendation
  75. Mysterious Knock
  76. Ve30de oil leak
  77. High-pitched whining/whispering noise
  78. 92 sat for a while now won't start
  79. tranny synchro
  80. Replacing wheel studs
  81. replacement remote key fob
  82. Power window passenger front out?
  83. No heat?
  84. Looking to Buy 92' Maxima, Stalls when Warm
  85. Well.. Finally picked up a new ride though the 3rd gen will be missed.
  86. Fuel Pump Help
  87. Windshield wiper squeaky, arm loose
  88. How does VG respond to knock sensor?
  89. that power antenna rod...any one have a part number?
  90. Parts
  91. 89 automatic transmission problems, no 2nd, 4th or reverse
  92. Fuel Injector???
  93. Plastic inner left front inner fender?
  94. Well it looks like my 3rd gen ride is coming to an end.
  95. idle rpm 94GXE
  96. No start
  97. 1993 Maxima SE 5 Speed Transmission swap for 6 Speed.
  98. Any Interest in a 91 SE?
  99. My Maxima S?
  100. Boss said it's been long enough.
  101. Just wondering if
  102. Gonna sell my car, need some advice
  103. Shift issue
  104. VG manual tranny into a VE auto swap?
  105. Tail lamp fuse blown no tail lights no dash lights no marker lights
  106. Power windows work intermittently?...
  107. Keyless entry buttons stopped working
  108. How tight should the E-Brake handle be.
  109. New member, would like opinions and thoughts on the 3G Maxima
  110. Rear swaybar bushings
  111. Waterpump failure may have saved my motor
  112. Snapping/Popping sound from clutch pedal
  113. Crankshaft Pulley Bolt Dimensions
  114. 23 years and 7 months and calling it a day
  115. Need some help
  116. Crank snout issue
  117. Sad Day
  118. Clutch slave rod travel?
  119. Oil leak question
  120. muffler recommendation.
  121. Engine Miss and error code 13
  122. VE 5 speed transmission parts source
  123. Car won't start in the morning
  124. window problem
  125. Maxima Lift Kit?
  126. Fog lights/ high beams rusted off
  127. rear Radius Rod Bushings
  128. Fog light help
  129. Z31 engine to RE4F02A tranny?
  130. plug wiring question
  131. Wiring Diagram needed
  132. Fuel Injector replacement?
  133. 3rd Gen celebrity
  134. Rear door panel lights
  135. Simple VTC and valve train questions
  136. 1991 Maxima For Sale
  137. 93 maxima se 5 speed problem!!!!
  138. When grabbing parts from a VE30DE Auto, what parts should I grab
  139. Hard start
  140. Key Illumination and Dome Light - Always on, drains battery
  141. Sad day for my ve30de turbo
  142. Problem with headlight switch.
  143. Traxtar's VG Maxima spun a bearing... save it from the parts yard.
  144. Harness part number
  145. Intermittent wah wah wah squeal
  146. Oem 5 pin AFM (airflow meter)
  147. Is this possible? (exhaust)
  148. Halo Lights for 3G Maxima??
  149. Cylinder 3 & 5 misfire but no one knows why
  150. Catalytic converter
  151. Brake lights stuck on and no dash lights
  152. How's interested?
  153. Ve30de ECU for sale
  154. Engine surging
  155. Knock sensor differences
  156. 1994 Maxima 3.0 SOHC no start
  157. Gas tank building pressure
  158. Auto to Manual conversion 1993 Maxima
  159. Hard first Starting
  160. Radiator clean up
  161. Power to radio-CD player ?
  162. Rockauto, HUD and Beck & Arnley???
  163. Heater Hose?
  164. Auto VE transmission mount
  165. Power valve actuator
  166. Reset tps from ecu, I have a 1992 maxima se
  167. What's your New year plans?
  168. Air bag light
  169. Headlight issues
  170. Best center dash vent cupholder
  171. Help with wheel bearing?
  172. Power Windows
  173. Car only starts once
  174. Where to purchase Strut-Shock assembly.
  175. Shock or Strut issue?
  176. Steering wheel off center after brake job?
  177. CEL code 51
  178. I didn't understand what you meant?
  179. BBK's and ABS
  180. I'm new here .
  181. Fuel injectors
  182. New here and it shows.
  183. Brake caliper question.
  184. Transmission VE30DE and VG30E the same?
  185. Trying to start 89 Maxima and the alarm locked my key in!
  186. VG30E Knock sensor
  187. My Cadillac Is Japanese
  188. twin load sensing valve
  189. Battery Terminal exploded while driving
  190. MAF sensor question
  191. Headlight conversion question for 1994 Maxima SEL
  192. Digital climate control isn't showing
  193. Part # confirmation
  194. 3rd gen in shipwreck
  195. Im back
  196. Turbo VG swapped stanza
  197. No heat
  198. Transmission or other drive train issue?
  199. 93 Maxima
  200. How do you drain coolant out the VE block?
  201. Bushings
  202. ABS issue/question
  203. Unorthodox Racing UDP belt sizes for the VG30E
  204. Need help Gxe or Se
  205. "Need more power" brakes
  206. air condition service what freon?
  207. 1993 maxima se problems- need help
  208. Opps, wrong torque spec
  209. 92 GXE Automatic not shifting.
  210. Solved: phantom alarm and dead battery
  211. Digital spedo/HUD not working
  212. Drivers seat advice
  213. Hot exhaust or hot air?
  214. Lower control arm?
  215. Broke the adjustment bolt for the water pump belt
  216. Tein Custom Coilovers?
  217. Door locks
  218. Maxima seats..
  219. Fuel tank strap lengths
  220. Low compression on Cyl 4
  221. Heat/AC slide mechanism only moves slightly.
  222. Removing ball joint without removing drive shaft?
  223. Pimp my ride 89 max
  224. Clutch Replacement
  225. Clutch line dist. Block?
  226. Rear swaybar brackets
  227. No cool
  228. Speedometer acts like tachometer
  229. Injector question
  230. J30 wont select any gears
  231. 1994 Power steering pump a bit of help please
  232. Cooling fans
  233. Steady ringing noise from in the cabin
  234. Maxima injectors question
  235. Aftermarket window regulator and motor. What car did it come from?
  236. Need advice before buying a 92 SE 5spd
  237. 3rd gen not starting
  238. Big Spring above Passenger Front Wheel Broke - Is this fixable
  239. Ebay turbo needs rebuild (video)
  240. Anyone see this 3rd gen for sale on Ebay?
  241. No radio reception
  242. Lowrider 3rd Gen for sale in UK
  243. evap can
  244. 3rd gen energy suspension bushings
  245. Initial Startup After New VTC/Timing Chains/clutch/many new parts..Now crank/no start
  246. What do you guys think? (Pics)
  247. 1989 Nissan Maxima blows black smoke and misses
  248. mechanic recommendation in Myltle Beach, sc
  249. windows stopped working
  250. Not sure where to post this, but found a great Maxima for sale
