- How long would it take to...
- body kit parts needed....
- Brakes
- 529,755 miles and counting.....
- inner tie rod
- Wtf?
- 90 SE engine trouble
- custom trunk pics?
- Looking to join the 3rd gen crew!
- Sea Foam & PCV
- Bad Smell
- Trouble with fuel pump/turn signals
- For The Guys Who've Installed Dash Kits
- Gaskets....
- corner bulbs
- failed inspection!!
- speedo cable/sensor???
- Is this rust?
- Got an 89 maxima as my first car
- Throwout bearing
- Statistics Needed, Please Help
- Turbo question
- another question bout a maxima!
- Wanna get a maxima, tranny question!
- what is a tranny problem?
- will a 94 dohc engine work in a 91max
- US guys might get a kick out'a this...
- Tire Brands and Sizes
- Replacing REAR speakers?
- What does the EGRC solenoid do?
- cars going in da shop...pics in a week
- Rough Idle
- $140 for new bumper?!?!
- Cleaning the injector connectors I say...
- Clock
- 89 tranny problems
- 91 GXE Tranny problem
- miles going down down down
- H7 bmw ? will these work for headlight conversion?
- Beam Pattern, screwed up?
- buyer Q
- when do springs and shocks wear out?
- Steering, seems tighter
- Quick Question
- Key Pad code
- Removing the weight in the trunk
- Interior lighting problems?
- Power window question, please help
- big prob with 92 max se
- my Maxima hates me
- Somethings wrong with steering. Help me out?
- Factory spring , plastic?
- re: how to fix minor dent on door panel
- took a road trip to FL saw alot of maximas
- VTC replacement advice
- Diamond Plate....
- mystery leak??!!??
- where to get transmission parts
- Incorrect timing belt replacement
- Tranny removal - 89 auto Max
- spoiler
- any one know how to install a power antenna mast
- anyone know how to fix a power antenna
- quick question
- 3rd Gen Engines....Restore?
- Just got back from a roadtrip...
- Exhaust Manifold Leak
- Where is the ^$*@&^#% transmission fluid filler?
- ecu codes for a 92 se
- Is this VTC failure?
- Brake light comes on after hard braking
- cant search need ahelp with getting a radiator.
- My clutch is clicking ??!!
- Newbie Getting Started
- A Different Tranny Problem
- tranny swap questions
- Bored out the TB (pics)
- Tranny problem unlike others in this forum...
- Heater head unit --- it's not the bulbs -
- more on the knock sensor...
- Add on CD player please help....!!!
- Lowering question
- About to start Axle replacement... I seem to remember something aboutnot pulling?
- My Dad needs some help with his '89 GXE
- Anyone change their knock sensor on VE
- new spoiler
- HELP! My Maxima is always burning fuses!! Has this happen to anyone else??
- farewell 3rd gen...
- Strange ignition problem
- How much?
- Removing side moldings....HELP?!?!?!
- NEW INTERIOR vs OLD INTERIOR
- security system
- "free" checkup from nissan, should I go?
- Engine Miss
- How much is my car worth at the dealer?
- New Pics
- Few mods.
- Rap-Mobile questions
- Update IS300 wheel fitment.
- led in automatic shifter gauge?
- wrecked
- Running Poorly
- Good shop in Western Mass to do exhaust stud?
- turn signal
- update on my car
- Loosing Power
- Would this air filter and adapter fit my VG motor
- How to reduce weight
- Is this all that bad?
- speaker ports
- again with the rebuild...
- turbo oil line ? for VE
- Grill-Tech Grill pics
- 92 se problem pls help
- Digital Climate Control
- Component speakers in Rear Doors.......
- Does anyone have..........
- Digital Gauges
- Well guys my car has cancer......
- Post pics of digital gauges
- brkn exhuaust stud/leak=rough idle?how$to fix?
- Pics if you've got 'em
- What does the Vacuum Delay do?
- How to replace front grill?
- Fender replacement?
- 3rd geners interested in gauge pods
- carbon fiber hood
- Diagnosing Bad VE knock sensor
- bose adapter
- A-Pillar Removal
- Rough running at low RPM
- Interesting issue after tune-up...
- Tranny went South finally.
- VTC gounding
- Silverstars appearance?
- antenna has mind of its own
- Big Problem, Wont Start!!!!
- Need Exaust And Ground Effects
- ? on Trim
- Help needed after strut install
- Lcd display / heater temp on 91 se
- Loud noise
- what year bose to buy
- any ideas?
- Vin
- Knock sensor sub harness part number for VE? I've looked at Rosenken wirte up.
- 4DSC stickers
- Pics of 1994 SOHC PCV Valve Needed
- question to end all my idle questions (long as usual)
- Rear Decklid Removal?
- Power Door Locks
- What Generation Maxima's 5spd's will work on ours, jut 3rd gen or more gens.????
- Does anyone have a FSM for a 90
- wheels
- coil overs
- sunroof
- anyone with a hooked up 3rd gen
- Using stock wires to hook up new speakers
- blue bulbs in auto shifter? apexi rev/speed meter
- Rear strut tower bar
- Can you test the TPS
- What are bad fuel pump symptoms?
- 93' Maxima Security System Overide
- ecu code Question
- which is better?
- What do you think about this deal?
- Seat ?'s
- throttle body...
- coolant leak
- Insert a hyperlink into your message
- what size bulbs?
- how much would u pay/sell this for?
- manual swap question
- cylinder heads
- Checked the ECU today and...
- Climate Control Lights??Part#???
- Sup guys
- Exhaust Manifold stud extraction
- Cardomain setup, plz look
- !! Help !! Fun sound ain't so fun!
- BOOGERS!
- Washed my car today and updated my cardomain.
- Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 911
- removal of thing dooor trim right below door handle?
- Running Hot
- Finished Conversion
- no one knows the answer
- Clutch Fluid Leaking
- My New GReddy SP
- do i really need 2 put spacers on my maxima?
- Another Wheel Bearing Question
- does the VE come stock w/forged pistons?
- Camber kits
- Sunroof cover
- Automatic transmission almost dead..............thinking about the manual swap.......
- exhaust questions
- EXEDY clutch GD $225...
- any one with air horns
- Automatic Climate Control
- Wheel Offset
- Wheel Bearings?
- How to flush radiator?
- tranny trouble this morning? need help
- finally getting my exhaust leak fixed
- tranny help (92SE 5speed)
- losing power 93 maxima
- those with rear disc brakes on '93 gxe's
- Bose Radio Off More Than On
- silver stars
- went in for a clutch install. . .
- Good indepent oil filter study
- Finally Got My Cardomain Page Up
- Bump stops
- It's this a fair price for labor/timing belt
- 1992 SE Mystery Hose... Where does it go?
- WSP Performance Question...
- just purchased...
- Vibriaaaation !
- cefiro a31 corners
- change brake pads after rotor resurfacing?
- need help re: TIMING BELT
- How Much Do I Need.
- I Dont Know What The He// Is Going On
- ALL NJ maxima's car show
- Radiiator Support
- advancing your engine timing
- How To Check 92 Se Ignition Coils???
- Need help re: TIMING BELT replacement
- Does Size Matter Guys?
- Abs
- motor mounts
- Slammed Max's
- Gaskets
- Bad News...any help would be great ASAP
- Custom Grilles
- I think another injector went bad
- Brake Shims
- chicks get attention on this site.
- FSTB for VE
- VG Engine Bucks Like a Bronco. Help me please!!!!
- How to Replace thermostat on a 93 GXE
- Throttle Control Sensor
- squealing noise
- spending the money want more effect
- Need pics of VE Please (out of car)
- Computer question
- Just a quick question that anyone may be able to answer
- HeLp Me Make my 94 gxe auto faster
- 240sx steering wheel
