- My webpage is finally up!!
- Since search is down... more questions
- Muffler Inlet size
- Tokico/Sprint suspension install
- Real quick question...
- Need some Help!
- Is this brake dust?
- electronic rear suspension
- question for 3rd Gen owners
- Battery Problems
- Changed oil this past weekend...
- Window regulator motor.
- WSP setup is on!!
- Tokico Strut Insert Help
- Console in your Maxima?
- looking for parts alot of MAX"S @ bone yard in Jax
- which gives a better performance boost?
- Knock Sensor Replace, heat soak persists
- Anybody have JET ECU experience?
- Very Frustrating 2 weeks!
- Auto Transmission Stuck in 3rd Gear
- car backfiring
- 17" 2000 SE Rims on 3rd Gen
- which one do you think will look better on a 3G
- video game max
- power door locks/factory alarm
- Motor Mounts.
- '89 5 Spd Questions
- Place to view Car Colors?
- First time on the track!
- TPS:how to test?
- Need feedback on spark plugs
- Info on bypassing knock sensor?
- Engine Problems-92 SE(120k)
- rear suspension
- Armrest trunk hole
- my car fail inspection today ; (
- fuel pump
- Any tranny people here?(tried search)
- Is my Auto tranny giving up the ghost?
- search problems
- Temp button
- 3rd gen queens meet
- How to put the pressure back into brake system?
- !@#$!@ steering ball joint thingy!!!!
- Bleach brake fluids?
- Need info for 94 maxima GXE
- No fire, cylinder 1 - VE
- Tokico/Eibach set-up
- Do I have a power antenna?
- Handling
- Auto to Manual Tranny Swap
- Dang on Door locks acting up.....
- http://www.geocities.com/azmalu/interior.htm
- finally fixin my max
- Pics: New Rims, finally
- Finally finished the Big Brake Kit!
- how do these look ?
- Brake fluids for 3rd gen ?
- DRRRive Pics... Finally!!
- car won't start
- Advancing my timing
- Do I need a new tranny?
- what size are the speakers??
- Need Differential!!!
- Quick VTC ?
- Strange engine behaviors, some ???s LONG
- 3rd Tail Light
- Something cool might be in the works for 3rd gens...
- Power antenna question.
- those who have done 2 tone seats or recognize...
- 4th gen kit and bumpers
- Front Lower Control Arm Bushings
- front strut bar
- New Alternator
- what to do, what to get
- its like im driving a 4 banger!! untill about 4k rpm
- Quick Question About Paint. I dont understand.
- putting front speakers in
- Flapping noise??
- well guys my point of decision is here
- Cattman VG30E headers anyone?
- Radius Arm bolt doesnt want to come out
- Maxima Compilation
- how to get correct spark plug wiring?
- Power and rust problem on 89SE
- For those of you curious about CAI filter location...
- Hey guys could you keep an Eye out for me?
- M.A.F. testing on VG?
- Quick Question
- weak front strut towers
- Power Steering Hose and Whinning Noise
- Fuel Filter
- Haynes, Chilton, or FSM, help needed...
- Lookin for a 24v head
- Advice needed....91 running like poop (kinda long)
- Maxima.org 2004 Calendar...Would you like your car to be featured in the calendar?
- maxima 94 se ve
- Front Axels
- need some technical info...
- e36 headlight question and cam question
- 2 Questions: 1 stupid, 1 decent
- Excess wax.....
- Horrible run at the track. Not the results i really wanted
- 1994 maxima se 5spds repairs
- 91 Maxima engine problems
- Noob ? on gas mileage
- goodbye to you guys 3rd gen is gone.
- MAF bad?
- need to pull motor to take heads off ???
- Finally rollin on 17's...
- WINGS WEST 3rd GEN. BODYKIT
- Still in need of help... (VG) Knock sensor
- Oil leak - could it be power steering fluid?
- diagnosed one problem with torque converter...but some other questions
- Power Locks not working
- Mesh grille on a 3rd gen anyone done it?
- please help i might have a bent chassis
- 1991 Maxima Help
- Just purchased 93 Maxima SE 5Spd w/91k miles, couple of ??s
- How much to install tranny?
- (VG) Knock sensor question
- Both keypad went dead,no sound or light
- New Rims, center cap pops off.
- All Fueled Up!
- installed cattman y-pipe
- BMW Conversion page MOVED
- Why so much?!?!
- VG Engine missing, and hesitating Proposed Solutions.
- Learned my lesson
- Stearing Problem
- just replaced my alternator but now my batt light is on?
- tranny conversion
- FSTB installed, but got a quick question
- Freakin Dealership
- occasional starting problem
- New Spark Plugs & Problem
- Calibration for gauges?
- header time
- moving cd player and heater controls
- temperature gauge troubles
- Transmission fluid
- turbo vg question
- Where are the Vaccum HOses?
- Battery
- Question
- Glow Gauges
- High HC emission question
- Could this be the japanise motor with Turbo for VE??
- home built/rigged ram air on VG
- lil acident
- problem with A/C UNIT please help.
- bumper scratches
- left axle removal
- Spark plug gap and heat range for VE
- "Hybrid" Intake for the VE?
- Spark Plug Wiring Diagram 4 1990
- Which Spark PLugs?????????
- Pictures of some mods I did...
- messed up bumper.. need a body kit
- BMW Headlight Conversion
- maxima in video games?
- Its getting colder out, how is your car taking it?
- motor for power window
- Hell Yeah!!
- -Maximized Sentra-
- Oh my fawking god!
- leather repair...please help
- Cold start and Idle
- camaro side skirts
- stalling
- can you believe this is a max
- Muffler Questions
- problem need help!!
- mis-firing
- 3rd gen VS 4th Gen
- 300zx Steering Wheel....duz it fit a 3rd gen max..? if so...got pics?
- Have to Decide on y-pipe
- Tranny flush-does it work?
- lexus GS300 wheels fit?
- SE-r pads on a 3rd gen.
- ignition relay == starter relay?
- 240sx wheels
- Wierd behavior, loss of power... help, please
- Vibrations when exelerating
- rust
- 1989 Maxima Heating Problems
- "Broken Crankshaft"
- Check Engine Light from Warpspeed Y-Pipe?
- Fuel pump dying? help. . . .
- engine temp gets cooler the faster i go
- Door inserts
- Idle Issue on 3rd Gen Max... Common, no SOLUTION??!?!?
- High Preasure hose involved question.
- 1 fog light not working, please help
- Power Steering Issue....grinding sound
- HELP: my clutch fluid is leaking
- Oops! Wasn't the water pump......
- Seatbelt Help!
- Replaced right haft shaft, car won't move
- VE30DE: NVCS ON vs OFF
- 5spd 2 Auto/ Auto 2 5spd conversion Update
- My shortened back bumper
- detailing an older car
- Factory Bose without amps
- A little smelly!
- Ebay Amplifiers
- anyone up to do me a favor? i need a pic of the fuse diogram
- o2 sensor plug, where it be?
- Brakes
- my cardomain!
- I have a few questions!!!!!!
- My Maxima Is Taking It's Shape Again!
- Manual-to-power seat swap (a little long)
- anyone who has installed new brake pads on 3rd gen. HELP
- Cai For Vg?
- Need Help Asap!! Please!!
- question about my car
- got a pimp interior?
- timming belt tension
- How did you fix your stalling problem?
- Heater
- 95 altima injectors = VE injectors?!??
- Cupholders!
- Popping sound
- If you have a funky smell in your ride this could be it
- I fixed my clock!
- Warpspeed Y-Pipe is on!!!
- Warpspeed Template help
- Original Wiring
- Gauge Problem
- Urgent Help with 3rd Gen Suspension Needed!
- air bag light
- Can I call technician out for servicing?
- update on my car and a question
- Dyno
- Installing 4 X 6 front door speakers for a 91 maxima
- what could it be?
- had my max towed again...
- Trunk Not Locking
- Intermittent Wipers
- ATC face problems.
- lights n sensors
- Idle Issues
- Chilton's Online Service Manual !
- Possibly gettin this 3rd Gen...
- Where would you put an aftermarket water temp sensor on a VG30E
- Cup Holder Help?
- a turbo 3rd gen on cardomain
