PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Spark plugs?
  2. Hole in radiator
  3. Can anyone rebuild VTCs??
  4. 92 se reliability?
  5. Which wire to tap for Valentine 1 hardwire
  6. maxima.org
  7. Anyone have a dyno chart of a VG 5 spd?
  8. HUD questions
  9. need help with search for Snap-On Shop Key #5
  10. White Rims
  11. 1991 5spd....
  12. Higher RPM's
  13. Sunroof Loose?
  14. Battery?
  15. Finished my intake
  16. Power steering fluid leaking
  17. I may have screwed the pooch this time?!?!
  18. Quick!! -what voltage?
  19. Wierd electrical gremlin/problem
  20. clutch question
  21. Update
  22. Hazard light button 1991 SE
  23. Interesting
  24. 5sp swap reverse lights
  25. Robbed...
  26. Fuel Pump Removal Question......
  27. Best Place for Maxima Used or Rebuilt Engines
  28. vent problem
  29. Factory made pheno spacers??????????
  30. Power Mirrors Switch---Light?
  31. intermittant stalling
  32. need some problem solving help. thanks!
  33. addco rsb install q's
  34. Best way to disable Factory Anti Theft
  35. Magnaflow Cat Install Question
  36. CAI for VE...
  37. New Application for E36's!
  38. speedo works up intill 22mph
  39. changed the injectors in my 93, ran great for 10 min, but....
  40. Venom 400 PCM
  41. Ignition Wire Set... any comments?
  42. fixing antenna...few questions
  43. back tires are very slightly rubbing on strut..
  44. D2 coilovers
  45. Good Deal??żż
  46. Engine temp unusually hot
  47. Washed engine - chugging & idling high now
  48. Axle Question
  49. Car loses its balls after its warm
  50. Where's the best place to get a new MAF sensor?
  51. A Question for thoes that have the E36's
  52. testing my ks w/ dmm questions
  53. Remus Muffler
  54. strut stabilizer bars
  55. Rusty Rotor(pics)
  56. Urgent ABS + Brake Bleeing HELP
  57. black marks on your pearl maxima?
  58. Was Corduroy interior a stock option?
  59. fog light help...
  60. opinions from those you have kyb gr2's installed
  61. odometer issue
  62. Anybody here in Socal wanna help me install my E36's when I get them?
  63. climate control
  64. Bringing it back to life....
  65. Finally, new rims (pics inside)
  66. Coolant Temp Sensor
  67. Wheel bearing problems?
  68. Stripped crossmember thread
  69. clear corners
  70. replacing brake lines...
  71. Remote Mounted Turbo
  72. Any luck repairing cigarette burns in Cloth like this?
  73. my ac vents =D
  74. Problem after drilling broken Exhaust Studs.
  75. Injector question
  76. Battery Drain
  77. Need help buying a car
  78. emblems
  79. eyelids or no eyelids
  80. idle air speed problems
  81. Exhaust System shot...a few questions
  82. BIGGER fenders
  83. Random prob wit Door Locks....
  84. another ebay gimmick...
  85. SC or Turbo for VG
  86. black or white?
  87. Trade of the Century
  88. Urgent! Tranny Prob.
  89. another ebay gimmick?.....
  90. blow off valve
  91. HO alt
  92. fuel injectors question
  93. valve cover gasket replace 92 se dohc
  94. Car wont start
  95. found a heads up in a 240
  96. Are the guys that have the S-AFC controller, following some sort of tune.........
  97. shifter acting up
  98. vg30dett cams?
  99. Vacuum leak?
  100. Coil Pack Experiment
  101. Antenna question
  102. Smoking Car..Oil Problem?
  103. exhaust muffler
  104. Front Strut Semi-Nightmare
  105. Direct fit cat?
  106. pathfider head
  107. Some F*** Broke into my car (kind of long)
  108. Rotary maxima?
  109. Better than OEM Disks, but not BBK??
  110. knock sensor on a 91 vg30
  111. Questions for those that have done front BBK
  112. Radio Install
  113. Bose CD err
  114. Different Maximas have Different Side Mirrrors?
  115. Shift Selector won't shift out of Park
  116. Quick question...
  117. Freeking Abs!!!!!
  118. repair manuals
  119. ECU Toaster Shield
  120. short shifter
  121. e36 conversion
  122. carbon fiber door pillars
  123. Water Leak
  124. Follow-up on "The Injector Killer" Vol. 16, Pt. 4, Ch. 3
  125. My Motor Mounts SUCK!
  126. Found some wheels
  127. bad vibrations
  128. confused...
  129. Sounds like marbles in my engine...
  130. JWT pop charger instructions & other queries
  131. Studdering Auto
  132. clutch
  133. Anyone Have pics Murano Weels on a Max
  134. Farewell to all (sort of)...time to move on
  135. headlight issues
  136. ebay question
  137. hey what does the up/down switch on the A/C panel do?
  138. clunky bumpy
  139. Offset question
  140. tranny question
  141. Aiming headlights
  142. try to seal my trunk
  143. Automatic Climate Control question
  144. CV Boot replacement
  145. Head Light-wire Confusion
  146. Possible Blown Fuse?
  147. Non-newbie question about where to find an exhaust system...
  148. sway bar link and exhaust size questions (pics)
  149. Replaced your own VTCs?
  150. painting calipers.....
  151. how to remove airbag steering wheel?
  152. Bolt broke off on me...
  153. sunroof
  154. My first window regulator
  155. any movie clips out there?
  156. Auto Window must be pressed x 3
  157. Opening trunk with key sets off alarm
  158. Odometer reading wrong
  159. Bracing the Crankshaft
  160. 300zx ECU
  161. How many engine/tranmission mounts do we have.
  162. tranmission swap question
  163. installed new vtcs have a few ?s
  164. a few problems
  165. remove spoiler
  166. Wings West pics anyone?
  167. A few new mods looking for them low low 13,s
  168. let see your safc
  169. coil pack cracks
  170. Interior pics please
  171. abs problem
  172. alternator decision
  173. fender removal
  174. OEM windshield wiper blade size
  175. Speedometer Issues - '90 SE 5spd.
  176. Sale over at Nopi
  177. Totaled out my 1993 Se
  178. It's official!!!!!!!!! Amsoil GL-4 comming back
  179. Road Trip!!!
  180. Went to the track today....
  181. so i replaced my belts...
  182. Does the JWT ECU need to be programmed?
  183. Pics
  184. Waxed my Baby Yesterday
  185. VG 5-spd - going into 3rd is a pain
  186. skyline motor = VE?
  187. thinking about stripping/selling the max :(
  188. more problems...
  189. Trouble shooting my new max...
  190. VQ question since my original post was deleted from the VQ section........
  191. CV shaft, NEED HELP!
  192. Clutch problem..........
  193. little vaccume hose?
  194. BOSE CD Lens Cleaners Recommended?
  195. Restoring my '92 SE to original glory! Need advice and encouragement!!!
  196. rpm pulses when accelerating
  197. how many quarts for manual transmissions
  198. Distributor Cap dilemma
  199. Koni Special's
  200. Time for front brakes.. which pads are best?
  201. SS Clutch Line
  202. How many 5 speed GXEs are there?
  203. Master switch problem
  204. Does our stock ECU have a PiggyBack mod available?
  205. have I lost some acceleration power?
  206. Hesitation
  207. Accident pics
  208. Udp?? Vg??
  209. Maximized plasTicks
  210. Will 16" ('98 SE) rims/wheels fit on '92 SE??
  211. Are there two Bose Systems?
  212. Very odd starting problem in the rain
  213. auto tranny problems
  214. Warning
  215. stupid problem
  216. New wheels = 2 new problems
  217. k sport coilovers
  218. Attention MrGone
  219. injectors....
  220. Oil leak!!! Ahhh!!
  221. Vavle
  222. spare engine build
  223. my bad
  224. Wheel Studs
  225. IAC...Idle Air Controll
  226. Just tossing my idea to the org for opinions...
  227. Modified CamShaft
  228. track time for a 3rd gen turbo
  229. Max running cold and still idling at 2000 rpm
  230. 300zx Ecu
  231. yet another headlight mod thread
  232. ABS freaks out al the time, what to do?
  233. So prevenitive maintenance screwed me over...
  234. Headlights
  235. powersteering problem.. big time
  236. radiator fans not kicking on
  237. Check Out My New Pics!
  238. If you haven't lately do this tommrow!!!
  239. Help!!! black smoke, rough idle, studdering engine then dead
  240. my long weekend project - Intrax n Tokico installed
  241. Updated Front : LOOK!!!
  242. radiator fuse blew. not the first time
  243. Air conditioning question
  244. Crazy Idea.
  245. replacing seatbelts
  246. My car is not just nice on the outside anymore (interior pics)
  247. tried seatbelt fix, no luck
  248. i wish i had a mechanical problem...
  249. question for those who have installed remtote starter/alarm combo
  250. So my low fuel light doesn't work
