- New here, ECU, window regulators...
- What do you think
- Good Looking Wing?
- I have an idea on intermittent stalling.....
- i redid my cardomain site..chx it out
- Different Paints
- This sucks! starter went out and cant put a new one in for a few weeks
- Exhaust Manifold Specs??
- Car won't start!!!!!
- Rocker wear?
- Harder shifts from a rebuilt / remanu tranny?
- The Variable Intake is designed for torque! (PICS)
- In case nobody else says it....
- Removed Upper Intake Manifold *pics*
- Throttle Body Coolant Bypass ??
- Sulfur smell from exhaust system but it's all brand new ??
- Ambient temperature reads -30°
- injectors
- What should be replaced at the 120K service on a VG?
- Is your Maxima loaded, or a striper?
- Brake Dilly
- Looking at getting a Maxima ABS light on
- My Speedo Dont Work!!!!
- I think its time for me to move on...advice?
- Anyone have pics of Magnaflow muffler on their car?
- NOOOO!!! My (2nd) transmission died! :(
- Front Motor Mount Question
- Yet Another fog light issue.
- Voltmeter? I have a good idea...
- installed Matt's RSTB on my car and Izzy's (pics +review )
- picture of a VE Throttle Body?
- cruise control issues
- High CO & HC emissions
- Any nice burgandy Maximas out there
- Stuttering under load
- Removing interior roof (1 Question)
- A/F Gauge where and hot to hook up?!
- 2 maf's + s-afc 2
- Do The Optima Batteries Fit Into The Factoy Location???????
- inevitable threads: fantasy five
- Side Markers.... TO MUCH RICE????
- 2k1 muffler fitment issue
- No Maximas in Jamaica!!
- 1992 Maxima Fuel Economy
- rear breaks
- Tranny Rebuild
- Had timing advanced and now car idle's rough
- Driver side door wont unlock
- 89 Max-Right High Beam Problem
- Help! Can't Put In Reverse!
- Help On Starters
- got a gtech and messed with it tonight
- cars running like crap again :(
- How to relocate a/c controls and fit monitor with PS2
- Where to purchase smoke corners?
- Which Suspension??????
- BMW Headlights and Heater Question
- Gauge Bezel
- water pump
- what else besides poor grounding could fry the alternator?
- is re4f04v an LSD tranny?
- rear sway bar
- Has anyone seen this car?
- Flushing the Radiator
- For Those with Automatics!!!
- just side skirts
- Fuel injector removal from fuel rail.
- Check Engine
- Loss power and extremely low engine temp on highways
- Creating a Custom Angel Eye
- Aftermarket seats
- they broke my rim!
- Oil in Intake manifold and Plenum
- Sunroof Visor Brackets
- widest wheel/tire combo i can run?
- ProCarParts glow gauges - review...
- How much to replace front rotors.
- Shining up that Intake Manifold!
- Car wont start
- Lowering Springs
- Cold Air Intake
- dumb thieves..
- Where do i wire my gauges?
- Any aftermarket distributor caps?
- 3rd gen cleared tail lights/centerpeice
- any nice looking gold 3rd gens
- which muffler?
- sputtering engine
- Looking for a aftermarket maxima website! Help Please
- How to get trouble codes on a 92 Maxima
- HELP, automatic shifter problem
- nissan cefiro for sale on 240 board.
- speedo question
- I'm looking for a guesstamation....
- AUTOZONE Powder Coated Calipers
- couple of b pipe questions
- no power
- Dash lights and tail lights out, any ideas?
- BlehmCo. RSTB Install/Review
- Got bored in Photoshop...
- Steering noise and intermitant loss of power
- any ideas?
- $200 right here!
- Im Back!!
- TV install
- Where, oh where, is my alarm?
- Alternator
- ummmm where's my ...
- headlight problem
- It just couldn't last to the end of the year...
- Windshield Tint Bar
- motor fitment questions
- '94 Diecast Maxima
- turbo ?
- Transmission Problems
- Digital Dash??
- Front End Work: To do or not
- Creaking from front right
- transmission q's
- Alignment question...
- resistor mod question.......
- transmission issues
- Hid System Question
- amplifier to run front,rears,and sub?
- Odometer
- Carbon Fiber trunk lids
- Coolant Leak....Only when it's cold??? (long)
- BlehmCo. Stage II lower tie bar installed and partially reviewed
- need help "89 GXE won't start
- Stillen Short Throw Shifter installed and reviewed
- Shift Lock!!1
- Removing speaker grille(Rear)
- Help!!!!!
- custom LED front bumper lights
- 300zx swap
- Converting Questions
- Speedo Problem
- Accident today :/ (Pics)
- advice plz
- Odometer sticking!!!
- Frenched Antenna Pictures
- GXE vs. SE ABS Sensor, Any Difference?
- Audio System Advice For GXE
- help
- Looking for information on fixing intermittent odometer
- Just picked up my 89 max, its sweeeet!
- 300 Zx
- need some help
- HMMMM noise coming from the rear
- decided on new auxillary battery..
- Window regulator problem??
- lights behind gauge cluster
- Please Help!!!!! Everyone Read I Am Open To All Suggestions!!!!!!!!!!!!!!!!
- scrubbing
- NEED HELP!!About BMW Headlights
- locks preventing door from closing/latching?
- Engine swap 300zx twin turbo
- 9 months later and this is the first time i've compared new color vs stock
- Motor Quiting When Hitting A Bump
- Oil Pressure Warning Light...Help
- What Tire PSI should I go with??
- rusted brake lines leeking
- Any need for new fender screws to attach a bra?
- Specs and how to on the e36 install
- RWD Conversion?!? Tech pls
- Why Can't I Search?
- heat problem with the vents..HELP?!?!
- Carpet Replacement
- motor mounts
- Vac line question
- Location of Master Key Number in glove compartment?
- 94 max question about exhus.
- biting the bullet, took it to a shop
- 92 Tranny issue
- VG auto tranny lag
- Fuel economy
- Stupid!..Yet Intelligent Clock
- Anyone want some extra cash, Need Timing Belt Job CT,MA,NY
- Tire/wheel size Question
- I got a Stillen short throw shifter.
- New to the forum.....looking at a 93' GXE
- HID kits...your impression
- Digi Climate ontrol Blows Cold Air
- removing fuses from box under hood....and removing fuel filter.
- 225's on 7" ok on 3rd gen
- keyless entry systems
- Places to get CAIs
- Help?! No Spark?!
- Sound System specifications
- Transmission rebuilt
- Alternator question???
- Custom Cupholder(s)!
- Hood Strut mounts......HELP
- trunk lock poped/jacked
- Manual/Automatic Climate Control Swap
- Heater only blows on #4
- How do I bleed air out of heater core?
- Tranny Issue's? ( OH GOD NO )
- Finially Got my first set of rims. Now for a drop.
- engine missing
- Car not running right?
- hybrid intake / MAF adapter
- Different headlight conv?
- Saludos
- Major Oil leak... (Long)
- Looking for the wings west body kit?
- Taking Window Tint Off Rear Window.
- 2 problems on 1 3rd gen...how nice?? help me out guys!!
- Windshield washer jets not working !!
- so far so good (long follow-up)..............
- How to Adjust the Handbrake
- Short Throw Shifter
- What kind of kit is this?
- Should I replace Brake fluid?
- Installing the garage door opener on a visor like the newer cars.
- Carbon Fiber Hood
- head light eye brows
- wheres the best place to run amp wiring
- Search function not working for me
- Automotive Accessories Website...
- windshield wipers stopped working
- Hey Look, Shortened Rear Bumper
- Seat Removal
- steering wheel leather
- high beam only sometimes works, where is relay?
- Automatic problems in '92 SE
- tune up question??
- starting questions
- manual swap help
- 0-60 in 4 seconds? video!
- 6x9 speaker conversion Non-Bose
- Motor type?
- foward in neutral
- Tips on buying a used 3rd Gen.
- 27w corner bulbs
- Homemade Shift Boot Installed
- VE Engine Modding. Howto get real power!
- anyone who has done carpet molding reinstall
- radiator flush plug question
- air bag light codes in relation to shorting out stereo system.....
- what is a spindle?
- Per Request: Gauge video.
- change idle???
- Just bought pioneer 3500, considering kove speakers
- Body Kit Question
- Updated CarDomain site... w/ pics finally
- Front speaker pods?
- Any one got Millie Evo5's on thier 3rd gen?
- suspension question
- ac freon recharge
