PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. alignment job question
  2. a/c getting weird on me
  3. How bad did I mess up my MAX?
  4. EXTREME newbie questions
  5. What is rice/ricer?
  6. Dash kits
  7. clear corners
  8. car wont start
  9. Having Problems with Cardomain site...Please Help
  10. which to do first?
  11. 3rd Generation door locks in cold weather
  12. For anyone that knows some stuff on turbos
  13. 2k2 Muffler
  14. Thinking about a 5 speed manual conversion.
  15. engine stuff
  16. OK, newbie's got some questions
  17. R33 tailights??
  18. CV Boot replacement
  19. Updated the cardomain site w/ new pics>>>
  20. Need your opinions
  21. Speaker
  22. Check out the new website...click on homepage<
  23. Distributer Cap and Rotor
  24. Possible side effect of lowering springs?
  25. is my tranny goin?
  26. apc filter.. wow
  27. timing belt change advice?
  28. what's going on
  29. New Look
  30. Updated my cardomain page! New Pics.
  31. re: repair the defrost light button
  32. WTB: Fuel injectors
  33. Are 95 Max Springs Same As 92????
  34. accident in my maxima today...
  35. A pillar removal?
  36. Help Real Quick!!!!!
  37. Rear brake pads?
  38. Sprint springs and stillen kit.
  39. engine crossmember...
  40. J-spec Gearbox question
  41. Tranny noise?
  42. Got dropped by a cadi
  43. 92 Max Se 5-spd For Sale
  44. Psyched!!!
  45. couple ?'s
  46. Automatic q.
  47. How do replace my shifter bushings??
  48. Remote keyless entry/part of Remote start install
  49. Trunk light location?
  50. New front bumper
  51. problem with amp install w/ bose
  52. Twin turbo Maxima?
  53. What do you think of these springs? Springtech
  54. fog replacements
  55. Replaced my fuel filter today
  56. I think Ball joints are gone need HELP
  57. At cross roads..!! please help...
  58. wow.. flushed ATF...
  59. Struts/Springs/Whatever
  60. WTB: 3rd Gen 5 Speed
  61. how would 17 x 7.5 rims with 205/40 tires fit ?
  62. I finally have created a cardomain page...
  63. Hood Pins 4 my CF hood
  64. ASP UDP Review
  65. Tight Tie-rod end bolt $%&*????
  66. Reverse Lights
  67. Transmission fluid question
  68. Price on Shaving doors?
  69. BMW headlight eyebrows installed
  70. Judge Judy
  71. VTC vs. Timing advance
  72. Do Springs go bad??
  73. Please advise! Periodical vibration...
  74. Pics of 3rd gen cf hoods
  75. *help* Corner Turning Light Istallation!
  76. Help with clutch install
  77. I Have A Gxe But!!
  78. Left corner light and turn signal
  79. 170k and first BIG problem (transmission?)
  80. Some new pics...
  81. exhaust leak
  82. 20in rims
  83. spark plugs again
  84. 90 GXE auto Fuel Gauge doesn't read full
  85. please advise! 225/60/16 too big?
  86. Stillen Body Work
  87. CF hood pics and lots of other pics....
  88. high speed flasher for turn signals
  89. Wing West Body Kit
  90. WSP y-pipe + hi flo cat makes a big diff...
  91. A/C Blower Woes
  92. goto group deals for a stillenbody kit
  93. HIGHLY Recommended CLutch Flywheel setup...
  94. To MOD a GXE, or save for an SE...?
  95. More clutch
  96. hey plz reply
  97. Arg, having some trouble. kind of long
  98. Updated CarDomain page:Nopi & mesh grill
  99. hey yall check out my Web page
  100. the downfall of the maximas...*dun dun dun*
  101. Aftermarket keyless entry, alarm's got mind of its own.
  102. Looking for an FSM for a 93' SE
  103. Nissan Dayz
  104. Security System Question 2
  105. Power window woes
  106. I have two cracks on my dashboard.Can this be repaired?
  107. Perfect newbie question
  108. ATTN: JWT ECU for VE owners!
  109. where are you guys from?
  110. Security System
  111. HeSitation
  112. Updated Pics!!!!!!!!!
  113. New Sunroof window
  114. intake?
  115. Looking for a reasonable bra...
  116. blue leds that suck
  117. I cant take it anymore (n34jz)
  118. Changing your Auto Tranny Fluid...
  119. springs chocks
  120. got "normal" ECU code (55) ... what next?
  121. offset
  122. Headlight Mystery, Can You Solve It??
  123. 10yr matinence?
  124. 92 SE transmission slipping
  125. CF hood is on...
  126. Whatwould be the best clutch
  127. Driver's Window and Lock switch
  128. Main Window and Lock switch
  129. injector blue dot
  130. Sparkplug Wires?
  131. don't know if i should give up...
  132. High flow cat converter???worth it?
  133. Hope battery doesn't explode...
  134. ATTN. guys with advanced timing VE.
  135. Bosch plug junk, do not use.
  136. Diamond Plate Mats
  137. one of ours???
  138. problem!! plz reply
  139. Fuel Injector costs.....
  140. Hey Guys going mod crazy....
  141. Clicking/knocking from front end.
  142. Front Passenger door window malfunction
  143. Definitive answer on electronic to "standard" suspension?
  144. Front Passenger door window malfunction
  145. help me with my checklist guys
  146. Carbon Fiber Door Pillers!!!!
  147. More tranny woes... I need opinions, please!
  148. 92 GXE Maxima Very CHEAP(phoenix only)
  149. VG30ET Turbo Maxima
  150. sus tech and addco sways
  151. important
  152. okay i found out several weeks ago that i need an engine rebuild
  153. Door locks-driver vs. passenger side
  154. nissan sentra outside my house
  155. Can I put stock 2002 17x7" SE rims on my 93 SE?
  156. Stock SE Fogs
  157. Help wanted badly ! please answer question!
  158. O2 voltage
  159. How much performance from each mod?
  160. Remote start tach wire
  161. heads up display
  162. speed cut off?
  163. update on the N/A monster
  164. I Got Pics For You Guys
  165. need advice on sub for my thrid
  166. Checked oil Pressure, and installed WSP Y
  167. Shakey Idle
  168. what model of K&N cone filter?
  169. Power Door lock help? (little long)
  170. Couple New Pics
  171. mixing shocks
  172. Intermittent stall on acceleration 92 Maxima
  173. Need some VG30E advice
  174. stillen kit with no spoiler
  175. Got My Baby Back Today!!!
  176. brakes
  177. Brembo vented and solid rotors.....whats the difference?
  178. ATTN: Lophix
  179. transmission Fluid
  180. WSP Y pipe question
  181. VE ASP udp install questions
  182. $600 for the stillen body kit?
  183. motor and tranny mounts
  184. Right brakelight assembly needed, 94' GXE
  185. ATTN: Sugarhi
  186. help!!! fuel intermittently shuts off after about 1 minute of driving on my 92 se
  187. leather shift boot & knob
  188. busted lifter or sc***d up engine...???
  189. Plugs
  190. window switch
  191. Mechanic is ****in me off.........
  192. KYB GR2's for $172.72 shipped
  193. OBD1 Data Connection To Monitor Car
  194. re: attention for new yorkers - alarm installation
  195. Yet another Maxima for me!!!
  196. Quick ?
  197. Anyone try to have a muffler shop make a custom ypipe?
  198. stock SuspenSion
  199. What brand speaker would put out as much bass + highs in the rear as the bose system?
  200. SuspenSion
  201. Lowering / RimZ
  202. Eyelids on our headlights?
  203. rims
  204. Woohoo
  205. Y pipe?
  206. hit curb, having noise now.------hate Clark
  207. Plug Gapping
  208. 5th Gen Wheels on a 3rd Gen...
  209. How can I remove rear deck 3rd brake light?
  210. 3rd Gen Wallpaper
  211. What dimensions are a 91 bose back speakers?
  212. Vtc Help
  213. I need friggin' intrax springs for CHEEEP!
  214. Bumpstops for eibachs
  215. Ground Points on a VG.
  216. Another wrecked 3rd gen...
  217. maxima or mustang?
  218. Poished items anyone?
  219. Relay
  220. idle at 1000 rpm??
  221. change the bulb color on the odometer dash
  222. yellow check light always on
  223. My CF hood pics
  224. Gettin rid of Max
  225. attn: Stillen bodykit owners!!!! Need help installing
  226. Who happens to know where is the oxygen sensor located on a 90 maxima
  227. Just put on new muffler- Flowmaster is the ish!
  228. 3rd gen owners! ATTN!! Re: Injen GD
  229. re: hood strut
  230. Broken exhaust studs, where to buy new ones??
  231. Power/Comfort switch loose
  232. Clearance problems with Stillen front lip??
  233. Kinda funny, Car and Driver has an article on the maxima this month
  234. another antenna question
  235. what is this grrrrrrrrrrrr sound...!!!
  236. Just bought a 91... now what?
  237. omg.. i think iv lost my mind
  238. 3 wires to the alternator, right...?
  239. I fixed my speed sensor,Thanks to Damion
  240. Taking off Door Panel
  241. So, the valve at the bottom of the EGR is supposed to move?
  242. Who has [e36] BMW lights the cheapest???
  243. Maxima Euro Reverse Gauges
  244. ST Springs
  245. lifter cleaning
  246. strange shifting
  247. help w/ vtc
  248. Cheap suspension setup??
  249. where to get lowest price for stillen body kit
  250. 1 ohms --> 4 ohms, any difference?
