- Tell me what you think?
- How Much For Condensing Unit?
- pulled er out
- How do you check fuel injectors?
- ECU Disconnected?
- thermastat
- Idle/Rough Running When Cold
- I think my water pump just went?.....
- Just got my CF Hood and had some questions?
- Not a Ricer Exaust
- 89 Maxima Radiator swap to with older model rad?
- tire size question
- update on nismo1989 and court
- muffler with the stillen kit
- speedometer acting funny
- Help !!.....bmw Headlight Install.....help !!
- Breather fuel line ... ehgine wouldn't start in moist conditions ...
- Guages
- 300zx Brake Upgrade Questions
- last goodbyes to the best thread on earth!!
- putt-putt noise in exhaust.
- Automatic seatbelt - convert to manual?
- VG idle RPM?
- rough idling, rough running 91 SE.
- Keypad numbers!
- Cd Player Pockey Drawer
- maxima projector headlights ???
- Help - Antilock brake problem
- Gas Tank Leak! -look in this thead-
- Looking at yet ANOTHER
- Temp Gauge Hot... then Not!?!?!?
- headlight and daytime driving light going weird,help.
- Climate Control Units
- Tranny "hunting" for the right gear?
- Decisions Decisions
- Few Questions..Experts Help!
- New Pics of My Max
- Transmission Question
- Suspension Braces
- My key can't open the doors - worn key or worn locks?
- Slippery tranny: a few questions?
- Louder sound..........
- alarm suggestions?
- wierd tranny??
- Vibration when any gear engaged
- Sunroof question
- Updated my cardomain page 30 new pics
- 18' rims...will these tires fit?
- Parts Requests?
- speaker problem
- what spings to get for a 90 gxe with 18s
- Parts questions- need ideas...
- Stupid vtc grounding question
- My beautiful Max!
- Tranny problems.....?
- 90 maxima tell me what you think...this works
- Max on long trip
- xenons not HID
- put in vtc's not it dosent start ?????
- Awesome forum - already learned a bunch
- 92 SE alternator
- Midas Cost Me 275.00 And Didnt Fix S**t!!!!(Kinda long)
- Balance Performance for Daily-Drivabilty
- VTC Dyno?
- Made my own ground kit
- tapping sound under dash..
- Rear Suspension Technique Sway Bar
- timing advance, where?
- axle nut
- Illfated 3rd Generations lately......
- Need exhaust which one?
- seriously angry at my Max
- The trick to taking out a water pump on the VE.
- shifter moves back when accelerating in 1st gear (5-speed)
- new design
- new problem need help asap!!
- radio bracket screws stripped, please help
- Headers
- Question about CV Joint and e36 headlights
- Will these wheels fit my car?
- Noise coming from driver side
- Floor mats...
- Pacesetter Headers-Y-Pipe O2 Sensor Bung size?
- A lil pumpkin treat for everyone......
- PowerLocks why! (help)
- Bought a 3rd gen... again
- 1989 Maxima front/side indicators no blinky
- for sale or parting out 90 se bad transmission
- What if Nissan.........
- Sensors, Corrosion and easy fix
- 93 GXE -- Lumpy idle, fautly fuel gauge.
- Can the wrong kind of spark plug cause a stalling problem?
- KYB or BOGE Front Struts ??
- 2000 GLE rims.......can they fit a 3rd gen SE?
- need your thoughts again
- Crazy Tach?
- UK Spec grille??
- Burning up ECU's
- help my abs ligth keeps coming back
- Mine Totalled.. Lookin at another
- Anyone with Enkei RS-6's on?
- Transmission or Problems????
- How the heck do you...
- radiator fan
- i saw this 3rd gen with this bodykit
- Rear Door Swap - 2 Questions
- '89 VG which Filter type/brand? I searched the stickies and FAQ
- Quick Question...will add more later...
- i need your thoughts about wheels...
- Yet another E36 install
- Thrid gen paradise
- another Bose Issue
- Loud "whirring" that matches RPMs
- 17x7... What size tire with Sprint 1.8?
- 91 SE headlight problems
- anyone like the stock gauges?
- will the interior of a 02 max fix on a 93 max
- just got a Gtech
- turbo ve????????
- Can't get alarm to disarm (I've searched)
- hypothetical engine/tranny swap se to GXE
- Cheezer, installing new suspention
- For those with 18's..
- 2000 Maxima/Infiniti I30t 17x7s on a 3rd generation?
- No Heat on 1989 Maxima
- help on installing a turbo in a 94 max (VG30E)
- Gettin ready for turbo PICS included
- good asking price
- Tranny shifts HARD
- Swapping Parts, compatible? (2 Qs)
- 90 maxima transmission swap
- installing fog lights
- Stupid BOSE
- Best choice and were to get?
- Power or Comfort?
- cost of tuneup and window
- horn troubles
- 89SE question
- What are the best shocks??
- Got compression/gas/dunno about spark
- acceleration
- Bad Jerking when accelerating.....
- thanks maxima.org
- well i hit a curb today
- o2 sensor
- Hard to change harmonic Balancer?
- Insulate water pipe above knock sensor?
- Brand New Pics
- intermittent running rough-check engine lite comes on
- Bad News
- My poor maxima...
- VE 5-speed tranny troubles?
- How hard is it to install clear corner lenses
- aftermarket exhausts for a 91 SE?
- Corner Lense bad luck, but is good now
- 91 Bose Headunit question
- My New Wheels
- What would you pay?
- Pics of my Totaled Maxima...
- Addco Rsb
- clutch problem
- Making me crazy
- you may be fast, but i made a dash for it
- Turbo VE swap into a GXE...
- Thank You to .Orgers/ ......Some New Pix
- !Bad engine problems, please help me ORG!
- Painful Feeling
- How to remove upper air intake manifold for injector service?
- Advancing timing on 89SE
- Cleaning ABS sensors
- wiring harness
- Phat!
- What is this stuff?
- cold air intake for my SOHC, do they make one?
- Radio Problems
- Trans Valvebody Upgrade
- Key Code
- smoke stacks??
- Alarm system questions?
- Keep the BOSE?
- Wheel Stud/Lug Nut problem..........
- VE FSTB Installation?
- test drive of G35 coupe v. modded 3rd gen
- Jim Wolf Technology Cams
- My old max...robbery
- Factory service manual
- idle drops when fan turns on
- Cold air intake for the 89max se??
- Z-MAX?? any feedback on it? should i dump it in my car?
- trouble codes 11(camshaft pos sen) 21 and 33
- Heres a really strange problem....
- Bad Shake when idling
- No Display (Digital Dash) When Cold
- Shaved 3 tenths with new injectors
- Carbon Fiber hood
- Gas gauge inaccurate
- props to all the ppl on the faq post
- switched out Maxes
- need your opinions....please look
- Strong gas smell 1st thing in AM
- muffler questions
- Cruise Control
- transmisson question
- 5speed problems
- Reverse Indiglo Gauges
- throttle lag
- VE30DE Variable Intake LED
- Off the subject
- Updated pix of damaged WW lip.....
- Just bought 91 Max Se 5spd, need some help
- No longer part of the Maxima family.. But I'm still part of the nissan family...
- mesh grill
- Few Pics Of My Max (Not That Clear)
- want to sell max, help
- Power steering problem
- putt, putt, putt.....
- bad gas mileage and more...
- VG motor mounts
- A/C Cup holder question.
- Photos of my new HID kit
- Swapping SOHC to DOHC? 93 GXE
- AAAAA!!!!! my vtc just started clicking
- Severe Drop in Gas Mileage
- Warpspeed Y pipe
- Swapping Bose
- IT's Not a HONDA!!!
- 4 teeth missing from timing belt
- Speedometer just stoped workin? HELP!
- MAF question
- hats off to Matt93SE
- what about old fashioned modding to extant engine?
- Engine Swap Idea!!! Must Read ;)
- how to clean inside of headlight??
- For those of us getting the triple gauge pod pillars...
- taillight ques.?
- Front Strut Brace????
- short throw shifter?????
- rotten exhaust system
- BMW E36 Headlights
- Have a mod budget can you help me decide?
- No Spoiler, Stock Spoiler, Kaminari Spoiler
- I can't open the passenger front door!
- Amp Installation
- Timing Chain
- Timing Chain
- s
- Maxima Inspection Stickers (tranny) !? help plz
- Vg??????????
- i need help
- U11 bluebiord mods needed
