PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. I need two pistons any one want to sell 2 used pistons?
  2. busted power antenna..............
  3. blah , govener in my 92 limited edition
  4. .org stickers?`
  5. Bose speakers/amps for sale
  6. parts car? what parts?
  7. temperature
  8. swap
  9. 300 ZX Engine
  10. Door touch pad
  11. Disconnect O2 sensor
  12. ?grill?
  13. 300zx wheels
  14. Is this Right?
  15. auto to manual tranny swap
  16. Exhaust stud breakage sound
  17. Steering wheel swap from SE
  18. yeah blah blah some new pics
  19. '92 Se Dohc Sticky Gas Pedal
  20. e-brake not working after replacing rear brakes
  21. Is this for real???
  22. Buying Injectors Suncarb or bbbautomotive?
  23. Drivers door lock being tricky...
  24. you wont believe
  25. tranny swap
  26. Rear Brakes
  27. recalibrating after gauge install HELP !!!!
  28. ok new problem y pipe and cat are on but....
  29. SPEC clutches
  30. Skyline Folding Mirrors
  31. 20 in rims for a maxima
  32. finally replaced my bearing
  33. stanza transmission
  34. fender removal?
  35. 91 Maxima engine swap
  36. Changed P/S hose, now HELP
  37. watch out roads!!
  38. Tires!!
  39. Parts for Sale
  40. toyoto oil filter for vtc noise
  41. 92 SE ut oh, coolant leak
  42. Bushing kits. Where to get them.
  43. Ign Coils
  44. Tires Size
  45. for all with sus. tech. springs
  46. Throttle Body/Stuck gas peddle
  47. VG30DE... typo?
  48. my head temp sensor
  49. Just got my Y pipe and Cat but.........
  50. worrying about stuff vibrating loose
  51. Brake Pad Mystery
  52. vg knock sensor help?
  53. injector install gone bad- help
  54. Blue Headlights
  55. anyone tried BG or GM in a manual
  56. wsp y pipe
  57. check this out
  58. FUNNY, a ricer's story
  59. Guage Cluster Problem
  60. Exhaust question
  61. what year 300zx calipers fit?
  62. Any Two Door Maximas In Existence?????
  63. I searched, but no luck, what is the offset
  64. update on the N/A MONSTER
  65. rattle, rattle...
  66. Fuel Pump
  67. *IMPORTANT* Great new Headlight bulb Retailer, & Info inside
  68. Rear Sway Bar mount reinforcement
  69. corner bulbs
  70. Water pump failures?
  71. Someone scraped my max today?!
  72. Reinforcing the Rear Sway Bar Mount
  73. New indiglos available for our maxima take a look
  74. Hood lift support
  75. 92 SE Tach problem
  76. doing the water pump soon....
  77. DIYS axle
  78. Is there anybody with APC super whites in their clear corners?
  79. Interior Ground points on 3rd Gen
  80. where to buy 3M clear plastic polish ?
  81. got my transmission diagnosis
  82. why I don't like the rain...
  83. ECU Upgrades
  84. vtc's lol
  85. directauto.com
  86. 4th gen MAF?
  87. Shop manual
  88. Shop manual
  89. how do I get to PCV valve ?
  90. Rear hubs
  91. o/d and the trans. button by my sound sys
  92. Fuel Injector, Black or Blue…Please Help!!
  93. Where can I get cheap front struts?
  94. disconnect vtc during boost?
  95. ignition switch fuse
  96. vacuum diagrams for a vg30e
  97. Rear strut "gland nut"
  98. Body Kits
  99. White Face Gauges
  100. HAHAHA funny HONDA RICER joke
  101. Just Had ACT clutch installed......
  102. Help! I need a good mechanic in the Los Angeles area!
  103. Gas in tank when level is on E?
  104. FINNALY my cardomain site is finished
  105. lowering question
  106. O2 sensor
  107. Temp goes down in cold weather?
  108. door locks being screwy
  109. OKay BMW question
  110. speedometer
  111. Keyless???
  112. Control Arm Bushings...Type?
  113. How I fixed my stalling engine problem
  114. va sniper!!
  115. coilovers????
  116. BMW M3 headlight conversion
  117. Heater Motor died please help
  118. Drivers seat back
  119. when i start my car......
  120. Re-painting the side moldings??
  121. I'm new and I have a question
  122. My heat bites
  123. I was slow but I took out some "Uncle Ben's" Boys
  124. Trunk Spoiler Rust
  125. how do i determine the model i have?
  126. how do i determine which model i have?
  127. is there any hope at all for a...
  128. What's going on with my A/T?!
  129. what's the best 1/4 mile for a n/a GXE?
  130. question question question
  131. is advancing the timing only for auto?
  132. Mods and Life expectancy
  133. power steering grinding?
  134. Pull to the left?
  135. 1992 Nissan Maxima SE
  136. Bad mileage, rough idle
  137. diagnostic at mechanics
  138. Installing rear 6x9 speakers HELP!
  139. '93 Maxima Steering
  140. Side Skirts
  141. Recalls
  142. CV boot replacement--Yes, Again
  143. anyone tried PFR5G-11?
  144. Transmission
  145. SE cluster vs GXE cluster
  146. Fuel injector harness help.>>
  147. Bodykit fitting
  148. 89 GXE parts for sale
  149. for the newbies asking for cheap mods...
  150. cup holders
  151. Autometer tranny temp gage still doesn't work
  152. New best 1/4 time but not what expected
  153. Not only is my speedo not work, but my OD as well?
  154. knock sensor removal..what size socket do I need?
  155. Body Work done pics* w/ shaved trunk
  156. Pacesetter STS
  157. What to do with my intake....
  158. VG30 intake, not VG33
  159. Pic of my 89' SE on 18"s...
  160. Muffler fell off today and it sounds awsome!!!
  161. Can BOSE headunit be used in regular Active System Maxima?
  162. Broke window, what to do?
  163. Window problems
  164. hey all, redone my site, check it out?
  165. BMW Headlight conversion and speed dif.
  166. ok i need to know this
  167. Has anyone experienced this problem w/92-93?
  168. new transmission?!
  169. White-grey smoke coming out from muffler for more than 10 minutes in the morning
  170. Car won't start when it rains.
  171. Will SE (white) gauges work perfectly in a GXE??
  172. Place with specifics on installing CAI?
  173. How to remove ABS Sensor
  174. Biggest worry of getting an SE...(VTC)
  175. Accord Intake sucessfully installed on 94 VG
  176. where does my head temp sensor plug in?
  177. Web page for max timing
  178. How do you install an XBox into a max
  179. Which is my '94? SE? GXE? GLE?
  180. Still the VTC grounding problem-Is there a mothed without cutting the wire?
  181. VG33 intake manifold
  182. Possible totaled maxima!
  183. 91 nissan maxima makes a creaky noise
  184. Help my clutch please
  185. My Maxima
  186. Need help someone please help
  187. i know OT, but this is what i gots now
  188. Body Dimensions for 3rd Gen
  189. feeling vibration at idle
  190. Engine stalls/surging at idle/low speed especially at cold
  191. Nopi 2002 Pictures
  192. Heater Core Replacement
  193. best strut for money
  194. How many 5spd SE 3rd gens that are red?
  195. How many 5spd SE 3rd gens that are red?
  196. Loud ticking noise..lifters?
  197. Terrible vibrations when accelerating
  198. HAS ANYONE REPLACED A 5-SPD in92se??
  199. Thanks! Still more problems with SE......
  200. Problems with power steering...
  201. best way to clean engine bay
  202. Cooling fan p/n
  203. Lower control arm
  204. Abs
  205. Bose speaker blown amp?
  206. can i see the lip?
  207. Maxima at the auction
  208. cheap o2 sensors?
  209. intrax fatigue
  210. How to remove factory Bose single-din headunit?
  211. How to remove factory Bose single-din headunit?
  212. vtc grounding
  213. leather seats from 4th or 5th gen?
  214. Clunkiness in rear when shifting....
  215. 92 maxima antenna
  216. how do i remove rust
  217. Light Housing Questions
  218. Tinted Headlight Covers!!!!!!!
  219. G35 rims or 21k 17s ? weight?
  220. Unclipped Air Box = Burnt ECU
  221. ss brake lines
  222. Engine surging/stalling/stuttering.
  223. Waxing Stains
  224. kinda dumb... lost picture
  225. cai
  226. Mirror-Polish Stock Rims...?
  227. If it weren't for bad luck I would have no luck at all :(
  228. 3rd Gen Stillen Kit...Check it out
  229. Lightweight wheels
  230. Pop Question Hotshot!
  231. Engine quits when transmission is engaged
  232. Flushing the radiator
  233. Fuel Injector?
  234. Non Freon Conversion--92 Maxima
  235. Matt did you relocate your cv boot pictures?
  236. Camshaft timing
  237. what kind of kit is that
  238. My speedometer went out...how do I fix it?
  239. cut intrax
  240. My poor side mirror...
  241. Power steering moooaaanns like a B**CH
  242. re-pinting bumper...
  243. Created New Car Domain Page...please See
  244. differences in ypipes
  245. Help with Vapor Recovery System
  246. Max Carpet
  247. HELP !! EGR Valve solenoid
  248. 92 Max w/trans problems $1599 to fix???
  249. fell off ramps
  250. Rear Brake Installation Nightmare
