PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. HELP! 92 GXE SOHC Troubleshoot
  2. Couple of upgrades
  3. Brand new OEM KS and harness - now throwing knock sensor code!
  4. GXE keyless entry on SE, can it be done?
  5. The "whip" : '91 GXE
  6. Stalls out.! help
  7. What do you think?
  8. '90 Coolant overflow tank boiling
  9. Master Window Switch Repair
  10. Big job ahead but hopefully worth it!
  11. New 3rd gen owner
  12. Belts replace on ve30de
  13. VE30DE Oil Pan Question
  14. Very quick question!
  15. 89 maxima window weatherstripping
  16. Maxima.org
  17. ebay front racing seats ?
  18. 1993 w/ Dead Speedometer
  19. Wtf happen
  20. leaky moonroof
  21. Need a little help with this problem
  22. 5 spd tranny oil change
  23. Windshield Washer died.....
  24. new suspention
  25. 1993 Nissan Maxima questions
  26. Speedo and Cruise Control problems
  27. Looking for a fuel pump assembly/fuel tank
  28. Trying to diagnose a slight hesitation upon accelerating.
  29. Fuel Injector Seepage
  30. RPM Jumping w/video
  31. just ordered my y pipe
  32. Brake upgrade ?
  33. Catalytic converter light
  34. 91 maxima manual tranny oil?
  35. 93 Maxima VG30E - Rocker Valve Cover
  36. Ve30de electrical issue?
  37. Multiple Problems.. Help Appreciated
  38. Help with transmission shifting issue
  39. are purple springs are only made by intrax?
  40. Interior mod-custom center console w/cup holder
  41. Is there really a big difference
  42. cannot pull up craig brac's how to...
  43. 90-92 Nissan Stanza AC Compressor Compatible with VE or VG?
  44. Finally! My 4th window regulator went out
  45. Car shuts down when in gear
  46. custom coilovers
  47. Found a connector, unconnected.
  48. Spotted. (not sure if repost)
  49. nissan 1991 distributor rotor
  50. Returning Member
  51. 94 maxima rack & pinion replacement
  52. Distributor Rebuilt ?'s
  53. new pics of my car
  54. Sputtering VG30e, but Tach Remains Steady
  55. Question.
  56. Please help me identify this
  57. Ps leak help
  58. Anyone from central Florida
  59. Motors in!
  60. Rotor not pointed at #1
  61. 3.5 Engine for sale for 3rd gen?
  62. Excited my car is off to paint
  63. VE30 timing chain replacement kit
  64. Radio HELP
  65. How to replace map lights
  66. Looking at new exhaust system
  67. No more Unreliable side feed injectors. Z31 plenum install
  68. No electrical besides headlights, please help!
  69. Where can i buy lowering spring?
  70. MAF or TPS issue (slow accel and surge)
  71. Serpentine belt replacement ?
  72. What color should i paint it?
  73. For GXE eyes only
  74. Replace injectors myself?
  75. Looking for newer generation rims for 93 Maxima
  76. 98 Nissan Maxima, V6
  77. Stalling! Help!
  78. Maxima rims size help
  79. Heat Works.. But Begins To Get Cold When I Drive
  80. what is with japanese wiring?
  81. My Beater
  82. Fog Lights on '90 SE
  83. 89 maxima window weatherstripping
  84. VE30DE megasquirt I issue
  85. Headlight housing material
  86. new here.
  87. factory springs modifying
  88. Transmission problem
  89. Gxe thermostat!
  90. starter
  91. HELP!! Brakes for 93 Maxima!
  92. Oil in Intake Manifold :(
  93. Intermitent Transmission Issue
  94. Finally selling my 1992 Maxima SE 5speed
  95. Windshield wipers sometimes screech briefly
  96. Do stock springs sag?
  97. Lowering on stock struts
  98. I Put My Max Up 4 Sale!!
  99. having problems with 1992 maxima
  100. Do i have to replace my brake caliper? Watch video
  101. My experiance with Trans-go shift kit
  102. bmw e36 lights question
  103. lack power
  104. need some ideas for an improv job
  105. need help identifying hoses
  106. Loud Banging Noise Under Hood
  107. Abs is leaking
  108. Maxima Owner by association.
  109. Ve30DE ECU Pinout
  110. squeal from around steering wheel.
  111. Low Heater Output AND Temp gauge goes to full cold on long downhill
  112. Help with bodykit ?
  113. 1991 Maxima. Cold air intake questions!
  114. No Heat - Loosing Coolant
  115. Tps
  116. Hazdard button
  117. New
  118. Missing belt!
  119. Replaced head gasket, runs like crap periodically
  120. '94 Maxima with barely any interior heat
  121. 92 max tranny swap
  122. so ive got a weird problem
  123. On some occasions, forward feels sluggish
  124. What Is This Engine Part Called?
  125. Driving Problem
  126. Help! New Clutch issues!
  127. Low MPG on a 92 SE
  128. Fuel injector question
  129. Exhaust system
  130. Help with new Maxima?
  131. How Do I Loosen Or Remove This Part
  132. Does Thermostat Go Here?
  133. Does Automatic Tranny Have An Exterior Filter
  134. Door Locks Problem (With Insite)
  135. What Is This Wiring For?
  136. Low Beam Headlight Problem
  137. What Kind Of Heater Core Should I Buy
  138. Can A Heater Core Water Leak Be Repaired
  139. Need Help With Selecting Radio
  140. Car still dies after starting. Now with video
  141. so im going to the junkyard today
  142. Interior question
  143. Coolant Not Circulating-Here Is My Plan
  144. Brake booster hose
  145. Cannot find seat belt chime fix anywhere!!!
  146. Damn interior lights don't work anymore
  147. 3rd Gen Maxima Front End Clunk
  148. 3rd Gen Maxima is Missing
  149. 3rd Gen Fog Light Bracket
  150. Help need injectors
  151. Do any of you remember the turbos in the passenger seat?
  152. Couple questions and remarks-
  153. Pro and cons on lowering springs
  154. Vg vs VE which is better?
  155. one click, no start
  156. pull engine on 93 maxima
  157. Transmission or Suspension?
  158. Labeling the engine before you do a head gasket set install
  159. RH & LH Camshaft sprocket, different?
  160. Seat belt locks under WOT
  161. Head gasket set install on a 1991 Nissan Maxima
  162. Need Name For Engine Hose And Question About Heater Core
  163. Do I Need A Radio Rack For 1991 Maxima SE
  164. Shoulder Harness-Sometimes Doesn't Work
  165. rpm surging
  166. My K&N sucks....
  167. Happy Thanksgiving 2012!!
  168. Car problems again!
  169. Needed driver's door Bose speaker
  170. Just Purchased '91 SE-Going To Pull A Part Sale
  171. 3rd Gen. for sale on ebay
  172. 89 maxima gas door
  173. Odd creaking noise after new suspension install
  174. NEED help! Using PCM to check rear injector ohms.
  175. Engine Management...
  176. Dashlight Indicator Problems
  177. Maxima: Home Again.
  178. No, shtap...
  179. #6 Cylinder Problem
  180. Short vid of my turbo 3rd gen
  181. VE Ignition coil / coil pack replacement
  182. what to do next??
  183. need help with vacumn Line
  184. 5spd Guru's Needed
  185. New kicks for "BuTTa"
  186. Clogged windshield washer nozzle
  187. What am I looking at here?
  188. Google warns me to not come here....
  189. EGR Valve Temperature Sensor Connector Fitment
  190. Check Engine On Codes 13, 34 & 51
  191. Recommendations to remove lower connection of Power Steering HP Hose
  192. Hurricane Sandy beat up my Max!!
  193. Where do these go?
  194. 91 maxima bmw headlight conversion
  195. Changing fuel injectors? Then this is a MUST!
  196. Chiltons 3rd gen manual on disc?
  197. Good Deal?
  198. The Haunted Maxima
  199. Leaking exhaust manifold ? or blown head gasket? - PLEASE HELP !!
  200. new and Getting a 1994 maxima
  201. hid projector retro
  202. vg tensioner pulley
  203. Dem hose are against us!!!!
  204. buying engine parts off ebay, good or bad idea?
  205. electric fan?
  206. Timing belt tensioner broke, valves are bent
  207. new to the board and the world of maxima
  208. Best fuel pump?????????????
  209. Old GXE going 130+
  210. Maxima weight?
  211. Saw a 3rd gen for sale today, it is 5 speed. Is it worth buying?
  212. Doing it right!!
  213. Buried treasure
  214. Lowering spring specs.
  215. Headgasket? Again!?
  216. Brand New Maxima User!
  217. fastscion.com trunk & hood
  218. 90 manual Transmission breakdown
  219. sputtering, surging, rough idle, engine missing
  220. Best/Worst VE Rod and main bearings??
  221. a picture is worth a thousand words.
  222. New 94 SE Slight miss while in drive
  223. Goodbye 2nd gen! Hello 3rd Gen!
  224. Check out this '93 Max!!
  225. GXE Exhaust Flange
  226. New Tokico Suspension... Where was this a month ago??
  227. 94 maxima wants to die at idle, or at lights.
  228. complete strut assembly for 3rd gen.
  229. Who has QTowers installed in their 3gen?
  230. Servicing VG30E Valve Springs While In The Vehicle
  231. Raising the Dead!
  232. What does this go to and is it important?
  233. Rough idle after IACV replacement
  234. 1991 Nissan Maxima rear brake caliper
  235. Amazing Injector Replacement Thread
  236. GXE Header Pipe to Cat Exhaust Stabilizer Bracket
  237. Timing
  238. 3RD GENERATION 1993 MAXIMA (question for a freinds car) need help
  239. Re-Wiring a 1994 VG Fuel Rail to a 1992 GXE Main Wiring Harness
  240. Corner Lights 101
  241. 90 maxima choking at idle and acceleration
  242. Cruise Control Diagnostics
  243. window problem
  244. Bose Audio and Dashboard Problems. Help Please!
  245. Im new, show me around.
  246. Which Brake Pads for our 3rd gen?
  247. What injectors do you have in your 3rd Gen?
  248. 1991 Maxima Tranny Issues, HELP!
  249. Car shaking.
  250. Electrical gremlins abound 93 MAX
