PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Leaky
  2. Low Brake Pedal
  3. Paint Job
  4. Does a 92-94 SOHC CAI fit on a 89 SOHC??
  5. Suspension/handling
  6. Control arm bushings
  7. For people with CAI
  8. Tip question
  9. Need to replace my exhaust system
  10. pilot fog lights
  11. Tired of my ricey muffler and stockish exhaust
  12. Cruise Control not working
  13. intake's
  14. FSM Question
  15. Audio systems
  16. More Climate Control Problmes
  17. ood steering problem
  18. Best spark plug wires for the buck
  19. The problem still continues, here's an update on what has been replaced
  20. Is it worth putting money into?
  21. she may be dying
  22. Cut Sprint Springs?
  23. Help on painting 92-94 GXE grill
  24. Car Alarm keeps going off!
  25. engine
  26. Upgrades
  27. inspection on sat. horn doesn't work
  28. Holding Back
  29. I Need A Pic! Not Suggestions....
  30. Help Help Lots Of Help Please
  31. RSB Links from Matt
  32. Newbie question...3rd Gen factory alarm...
  33. door switch for windows
  34. Rusting Out: Fix or Live With It
  35. Shutting off when put in reverse or drive!?!
  36. Detailed instructions with pics on steering wheel swap?
  37. Winshield Wiper Problems
  38. need some info about Koni struts coversion
  39. need help, car sputtering
  40. Change the CAS?
  41. triple gauge pods
  42. monitoring/diagnostics/data-logging
  43. Having problem with parking/dash lights switch
  44. Dead Pedal Install.
  45. Urethane front lower control arm bushing
  46. Front Fascia Damage???
  47. Suspension Upgrade question:
  48. Can having fun in the snow cause damage?
  49. What's the best product to remove water from gas???
  50. Vaccume hose question
  51. Arco Gas
  52. Llumar tint
  53. winter and key lock.. strange...
  54. BAd News
  55. Pics of 95-99 SE rims on 89-94 Max
  56. Optima wont hold when cold.
  57. 3rd gen with a soft top ??
  58. Touch up paint
  59. thermostat change
  60. Bad injectors???
  61. Other MAF Adapters on the GXE
  62. Does the master cylinder repair kit do any good to 93 Maxima?
  63. Engine Dead, Need New
  64. Is this normal?
  65. How bad is this?
  66. Good H.I.D. Kit?
  67. How to check IACV and Vacuum lines
  68. Idle problems with 1994 maxima
  69. starter problems, take a look please
  70. Car won't start. Fuse blown.
  71. replaced cat, just need to replace o2
  72. Car wont start... starter not starting, its new.... ideas?
  73. Discolored Molding
  74. Mechanic in GA
  75. Eibach Front only Pics
  76. and onother one bites, and another one bites, and anotherone bites the dust!
  77. Stripping Maxima of Transmission and Engine! Easy?, how? help.
  78. National Maxima.org car club?
  79. Couple pics of Wagner Truview's
  80. Interior Paint Question
  81. Bad CV boots on axle - will wheels come off?
  82. Problem with 92 GXE....
  83. Will 92-94 tails fit on a 89-91 Max?
  84. Offset Question
  85. Is anyone experienced with COSTCO batteries???
  86. Helo motor acting up
  87. KYB Struts
  88. She Might Be Toast....
  89. How to Clear Key Pad
  90. Stereo install - What to do with the Amp Signal?
  91. '92 GXE Engine Trouble! Engine Fails Under Load: Heat Guage Fluctuates, Throws CEL
  92. Heater valve not moving at all.......only hot air in the car right now....
  93. Replaced Heater Core Finally..........CHECK THESE PIX OUT!!!!!!!!!!
  94. Loosing Power
  95. interior parts
  96. E36 Headlight Question
  97. questions about posting pics
  98. FIDANZA or Unorthadox Racing Flywheel?
  99. My Silverstars burned out! Grrrr :(
  100. rebuilding calipers
  101. Axle problem....URGENT!
  102. Cardomain site updated...
  103. rear sway bar links broke
  104. Lower Control Arm Bushings
  105. spark plugs
  106. Oil additives?
  107. transmission trouble (swap.how much.where)
  108. windshild wiper
  109. Maxima bites the dust....HARD!! :(
  110. Need help on Calibrating Fuel Gauge
  111. gauge pods
  112. Engine Temp..
  113. Help Me!!!!! Someone!!!!
  114. Best place to punch a hole in my firewall???
  115. don't do what i did. instead, replace all inj at same time.
  116. changing Power steering hoses
  117. Far right Passenger Vent blows cool air
  118. Sunroof control surround
  119. Help identifying part number
  120. WHERE CAN I GET RED LEDS FOR 2 1/16" AUTOMETER PHANTOMS?
  121. new light setup..
  122. angel eyes installed...
  123. Any lowered max's?
  124. bad alternator
  125. engine control fuse blew out twice
  126. Maintenence for 164k mi?
  127. picture of my interior finally put in with ACC
  128. Will removing the resonator help?
  129. fuel filter & diagnosis (long)
  130. 1994 Maxima Manifold
  131. question on cams
  132. HID nightshots
  133. headers
  134. Drivebelt removal
  135. Well, it's been fun
  136. Injectors
  137. running on 5 cylinders
  138. Anti-locks Actuate when cold
  139. Regulator or Motor
  140. broken timing belt
  141. leaky valve cover
  142. 92 SE intermittent stalling
  143. Car does'nt want to accelerate!!??
  144. Finished pics of the BlehmCo RSB Links:
  145. Running Lean, Techs lets see if we can figure this out!!!!!
  146. LSD tranny identification
  147. Nice half dollar sized rust spot on my driver side rear door
  148. Trunk Carpet....
  149. Nope
  150. Tranny problem!!!
  151. Cam
  152. Trunk Ground Location?
  153. who's the person with
  154. need help: oil pan removal?
  155. Hood Struts
  156. Anti-Lock Light (ABS) after CV Joint Swap?
  157. 4th GEN LEather Seats....can they fit in a 3rd gen?
  158. 300zx rims
  159. TRANNY acting weird when braking hard??
  160. Car hickups sometimes when cold!! What??
  161. new tstat but...
  162. Does neone have write ups on the US SPEC BMW Headlights that have the H1or H7 bulbs
  163. Crashed my Maxima.....almost.
  164. Wheel Bearing Question
  165. rstb or sway bar
  166. Low oil pressure light - clean oil pan/replace oil pump?
  167. hey guys
  168. misfire in a vg
  169. has anyone else seen this recall?
  170. Motor Flush
  171. Heater control valve..
  172. dde conversion on e36 conversion
  173. Need to Replace Non-Bose CD Player
  174. strange automatic tranny
  175. Full coverage or liablity?
  176. need some help with installing an alarm
  177. Funky noise coming from heater,fan
  178. Y-pipe?
  179. I'm sofa king we todd did
  180. MaXtuned's dyno explaination?????
  181. Help need with PS pump and pulley issue....ASAP thanks
  182. Ve Dyno Sheet Request
  183. road trip.. need advice.
  184. Idle jumps when stopped....
  185. 92 GXE needs injector Should I get it?
  186. GXE's with spoilers
  187. car running like crap
  188. Headlight Conversion Possible?
  189. What do you guys recommend for brakes?
  190. Replacing Aftermarket Headlights
  191. Electronic Superchargers
  192. aftermarket parts
  193. Noisy when cold
  194. Panel lights
  195. Can you put 19's on our maxs
  196. Got some Pics
  197. what aftermarket fuel pump have you used on your VE
  198. Low fuel light..
  199. What does normal operation of A/F ratio Gauge look like.
  200. spark plug fireing order?
  201. Steel wheels...offset OK?
  202. inspection next month, what can i do?
  203. Tail lights and dash problem
  204. Otto FSTB Installed.... WOW!!!!!
  205. taking apart spoiler light
  206. interior paint?
  207. Apc Aluminum Grand Touring Wing
  208. G-Tech users (VE):
  209. -----New Pics---------
  210. Interior REVAMPED SEE PICS Nubianpupe Its done!!!
  211. front drop only....
  212. proformance on ve 1994
  213. Cranking but won't start
  214. Electrical problem! need help ASAP!
  215. Gas door/lever, help!
  216. Thinking of installing a TV.
  217. The ECU Tuning/Fuel Thread
  218. help! Fuel rail fuel line replacement w/o removing in/manifold?
  219. Vid of Swowlinc's car
  220. power steering pulley fell off.
  221. How do I wire up a horn...
  222. the manual to auto climate control swap has been done
  223. Places To Hook Up Neon Lights
  224. possible blown head
  225. Small wonder host
  226. An unusual light problem.
  227. `headlight problems
  228. Upgrade air cleaner
  229. Good News! I feel like a pioneer now :) 97 - 92 Visor Conversion--->
  230. ********This Thread is Worthless Without Pics!******
  231. Angel/Demon Eyes
  232. Info on Turbo kit from millennium autosports
  233. master cylinder leak
  234. new pics
  235. Drivers Side Door Grommet
  236. Digital Dash Smoked
  237. Clock. Climate control and digital dash
  238. Horrible gas milage....
  239. just installed tranny, think i got a problem, help please
  240. Help! Air/fuel ratio gauge hook up.What color is the wire?
  241. help on instalation of power antana
  242. Igition coil question and more and more
  243. Fsm
  244. Wheel fitament problem...
  245. Tire Size!!!
  246. Videos at e town
  247. Buy a nj 02 se graphite looks like hids popped anyone. Anyone know this car?
  248. What did you pay for work or mod installation?
  249. one MORE road trip with my maxima, Iowa to Texas
  250. does aftermarket y-pipe cause hissing at higher RPMs?
