- Todays accomplishments.
- Some E36 and stock Maxima lens pics
- good bye maxima.org
- Sunroof removal at the junkyard (pics)
- Opinions on new clutch choice?
- Third Gen Owners - I made quite a find
- Max rolled into house
- Horn wire on keyless entry install
- Okay....my clutch problem solved?
- (VE) Bad injector or something else?
- wow these got cheap quick!
- need help replacing rear strut
- *MY* custom E36 Install no pics
- Decoding a 3rd gen ecu help
- 1 year, Please read on 9-17-06
- way OT question for the engine/trans freaks
- battery / cv joint questions.
- replacing dashboard/speedometer light
- Just got inpected, emissions question
- 92se 5 speed with a tranny issue!
- VE owners only poll about VTCs
- Hub Dilema
- New E36 vs old E36
- Sagging Intrax?
- Weird sound
- Dysfunc's Turbo'd VG
- Where is the ECU located on an 89 maxima?
- How Long can U Drive In a Leaking CV Boot?
- temp selector for a/c-heater stuck
- painting question
- Steering issue - control arm bushes?
- Orange Sludge in Coolant system
- Axle seal problem
- Hmm. Electrical prob?
- Exedy Stage 1 Clutch Owners
- Problem regarding clock
- CrankShaft?
- desperate need of help for my 93 maxima!!
- turbo VE....video inside
- Oil leacking from lower oil pan
- max idles high after hwy use
- 91 max alarm goes off randomly help!!
- Please Help!! Weird Clutch problem
- possessed max (video)
- OBDI to PC
- VG ENgine miss, diagnosis??
- VE Water Pump biggest PITA
- Observed New Sticker in TN....
- fastest 3rd gen?
- What Cars used the same tranny??
- Koyo Hi- Flow Rad....?
- Rear brake lines
- T/C the VG...
- crank shaft end (front) diameter?
- Master window switch bad?
- painting bumper - Autozone ???
- E36's w/Projectors?
- steering pump
- Driver Side Main Window Switch Repairable?
- Lack of low end power
- I lucked out tonight
- Steering cuts to the right.
- electrical problem?
- Bad fuel injector = wasteful on gas?
- Manual Tranny (original) died @ 549, 010 Miles....
- New Maxima Owner.. Tranny/Engine Help please!
- AC R-134a Retrofit
- Car is hard to start.
- Custom CAI (pics inside)
- Starter wont go
- Radiator fan - constantly full blast
- Were can i get a bigger radiator?
- Center Dask Backlight/illumination
- Black Chamber on Intake?
- Turbo'd 3rd gen RUNS!!!
- Kill switch clarification.....
- brake lines
- Spoiler removal/replacement
- confirm axle seal part #?
- Crank Pulley bent or "unbalanced?"
- how to
- Rest in peace.
- New Rollerz: I got my Crosshairs set on ya Max!
- Smell
- question and opinion on jim wolf product
- Thank God BRAKES!!!
- What do I need to do?
- VTC Grounding Question..
- ALright heres a decision to make Need Input
- fuel issue on Maxima I might purchase
- Shopping list purchased!
- Painted plenum (pic)
- Need help removing Intake Manifold on Max 90
- Anyone Scrapping a VG?
- tranny question
- Left Headlight Assembly Adjustment Broken
- Seatbelt rust.
- Black thing in trunk?
- The cigeratte lighter adaptor is not standard on this car?
- still bad idle
- Need an oil change and new spark plugs
- Rack and Pinion replacement
- Used Fuel Injectors
- Need Lots Of Help!!!! Trunk Not Opening!!!
- Rear defroster repair
- finalllllllllllllllllly the tick is back
- Problems?
- Green or Yellow???
- Buzzing from DRL module
- 3rd gen related thread about MPG
- Rear well rust.
- torque steer
- thank you Nissan finally a easy fix!
- help with automatic tramsnission vg30e
- Lights not turning off
- ABS sensor replacement? Cost/where to get?
- High Mileage 3rd Generation cars
- Coolant leak.................
- a few short ?,idle spd,tps.,test injectors
- ST's Finally Here!!!
- Shifter assembly
- Throttle/Transmission glitching?
- a little control arm question
- Auto tranny not shifting.
- 300zx exhaust stud.
- Clunk Clunk!!!!!!!!!
- Finally got my JDM VE installed........
- Another Video.. but this one made me sad
- Shock Oil (Koni)
- window fell down? Window regulator?
- The 5 speed swap
- My Max totalled! (Pics!!! 56kers beware)
- OEM Throw out bearing. Deffective?
- How much beer fits in a 3rd Gen?
- I'm finally selling my 3rd gen...
- Locking 5Spd Transmission
- security light
- key pad help
- No more MAX
- Fuel Injector Rail
- Bought Another Max!
- 92 sentra se-r
- Fuel Injector Connection
- Shift linkage problem??? Please help
- Modding help
- havent been on in a long time.....
- Timing Belt
- bought used car - plate question
- Checking ABS error code
- Pacesetter headers
- A strange Electrical Problem
- Need help with Remote Start wires!
- Weird sounds from under car
- Engine missing
- Help
- Panel lights
- is the 85 300zx vg30e auto gearbox exactly the same as the 90 nissan maxima vg30e's?
- Installing a Subwoofer
- Is there a difference?
- Opinions needed
- Fuel Pressure Regulator?
- For all!
- Car trouble, need answer ASAP!
- VE power planning?
- Poly Urethane Mounts
- Question about difficulty of swapping
- buying car in Indiana but michigan resident
- question bout vtc not responding when i hit the gas
- Running lean in high rpms
- Cold Air Intake
- Dashboard Light
- Dual Hi/Lo e36 lights.
- lifter tick
- Engine Swap for 92 5spd
- Install kit
- Sponsorship
- Fuel Injector O-ring
- buying car in another state???
- New Headlights (pics) and updated CarDomain
- Zenn Springs
- Clutch Master Cylinder
- 89-94 Euro Crystal Clear Headlights!
- SE vs. GXE Swaybars
- can anyone please tell me what model maxima this is?
- To those that have had new "VE"s installed.......
- Need some friggin help
- Quite the annoyance
- Do GXEs have fog light harnesses? help...
- flywheel compatibility question
- rear wheel bearing help
- Clutch replacement options
- tranny rebuild cost
- Car shuts off please help
- 3rd Gen Production Numbers
- Front end project log.
- Help me a bit...
- Where to find? Wings West spoiler
- Just wanted to show you how im coming along
- control arm replacement
- Rear speakers not working?
- Break In
- CarFax reports
- FSB how much of a diff?
- I may sound silly but bear with me. Power loss or what?
- Teh 300k club: sign in..:-)
- Engine acts likes it's flooding?
- Serious Clutch Problem (again)
- Need Opinion.. Keep It Or Sell It?
- LED spoiler brake light question...help
- Anyone with JWT ECU?
- bought another one
- Chrome trim -> Black trim on 92SE
- 3rd Gen Respect!
- Is it worth it?
- My Maxima = teh suck
- Idle Problem, ive searched. cant find anything
- NA vs Turbo
- Photoshop Anybody???
- Tips/ Instructions for removing back seat
- $200.00 for a COMPLETE VTC's rebuild??
- Need a front exhaust manifold...
- Whirring at certain rpm range = engine mounts?
- need help with courtesy nissan nismo studs
- VG Factory fitted alarm - intermittent sound
- Bright side corner lights?
- Erattic Idle
- fast help please!!!!
- 92SE Perform.Rebuild & Airshifter
- Rear fenders rusted through - to fix or not to fix?
- you could say it was time to change the axle
- Is an CAI Or RAM worth it on 3rd gen SE?
- Big wheel stud problem
- Trunk lift springs
- Running With No Cat = CEL???
- Rear window ALL the way down
- Need to replace windshield wiper motor on 93 GXE
- So i got bored with tail lights...
- Hub Question
- Well, she's finally gone......my first love :(
- Where to get Y-Pipe in Vancouver
- Aftermarket Control Arms wont bolt up!! **pics
- Air wrench monkeys! Argh!
- R-12 substitute?
- Trim Levels, what makes an SE VE GXE ect?
- Car A/C smell
- Race. respond quickly please.
- My car was stollen
- disabling VTC?
- Distributor removal?
- FOG Light Rust
