PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. rear pivot arm?
  2. brake light
  3. Question....just got a 94 SE Auto VTC ticking...
  4. trick for repairing valve cover gasket leak
  5. Fan Speed 4 doesn't work. 1,2,3, are fine. Blower Motor Resistor?
  6. dead coil harness or something
  7. Lightweight wheels...
  8. You may want to check your car too
  9. paint job
  10. battery and E-brake light
  11. the life of a max maybe at end
  12. rim question
  13. FINALLY! The Max is back home...
  14. Ve30de Ecu
  15. The Ultimate n00b Question
  16. Trunk Idea
  17. VE30DE ECU Chip?
  18. ATF Fluid
  19. Home Depot Grill
  20. engine question
  21. Your feedback on springs.
  22. Cylinders 1 and 6 not working
  23. A max with a difference (or three)
  24. Transmission wont shift outta car after rebuild
  25. need AT Shifter bushing help
  26. 90 se, engine control fuse constantly blowing
  27. master cylinder w/ABS
  28. The P/N Thread
  29. got bored.
  30. Headlight problem
  31. Now "Stop" means "STOP"!!
  32. for those with 18's
  33. Tranny Shifting
  34. Strange front suspension noises
  35. slight issue
  36. problem with my gxe tear*
  37. Hid
  38. What is your gas mileage?
  39. Where the $%#* is my coolant going!?!?
  40. Warpspeed Ypipe hanger Q.
  41. Electrical Problem after Fixing AC
  42. Starter kit and Distributor cap and rotor
  43. Just Recieved VG Phenolic Spacers!
  44. never gotten so much love in one night
  45. Long Time Since I have been here
  46. Manual Conversion
  47. paint
  48. Need help with fuel filter
  49. tranny noise 93 ve 5spd
  50. Parting Out!! 1989 Nissan Maxima GXE
  51. clicking when i turn
  52. Goodbye fellow Maxima enthusiats.
  53. M buddies maxima is actin weird possible head gasket??
  54. They finally make coilovers for 3rd gens.....or did you already know that?
  55. CODE 15 Help!
  56. crap....my flux capacitor....no seriously.
  57. leak problem
  58. WTB GXE driver side taillight
  59. 1992 Maxima wont start backfiring HELP
  60. window problem
  61. Engine problem, help please.
  62. Went to Junkyard Today
  63. Serious question
  64. se or gxe grille? (view picture)
  65. TiMiNg BeLt
  66. Injector Insulator Leak
  67. Unorthodox Racing Pulley
  68. new struts, new noise
  69. 3rd gen runs, shifts, won't move.
  70. #4 cylinder dead, I need an electrical genius.:banghead:
  71. clarion wiring diagram- Active
  72. Different Bose Question
  73. VG knock sensor
  74. Best test for vacuum leak?
  75. VTC noise? or lifters? or timing chain?
  76. electric chalenge or dumb problem
  77. 19's
  78. Rust in rear wheel well = Useless seatbelt
  79. Quick Question
  80. Digital dash conversion
  81. fuel pump relay
  82. Plastic Cover
  83. new project with reflector plate
  84. Engine Oil
  85. 2 problems, with sensors
  86. VG to VE transmission
  87. Engine rough chuging when cold
  88. Plastic rivet part # & foam tape ?'s
  89. Blue LED's
  90. 3rd Gen Owner Age Groups
  91. engine stalling
  92. New big undertaking....R34 tails lights on my Maxima. Wish me luck......
  93. Brake and battery indicator lights on dash on.
  94. New symptom after Oil on Plug.
  95. I think MrGone needs to rejoin the club...
  96. Converting to power front seats...
  97. no ground clearance
  98. Good news, and injectors news?
  99. fuel injector leak
  100. Big problems!Maybe ECU?
  101. HIR bulbs, anyone have them?
  102. vacuum lines
  103. finally back up and running
  104. starting problem
  105. q45 retrofits??
  106. GD on Matt's LTB's
  107. engine still stalls everynow and then
  108. auto tranny shift lock thingy broken
  109. cruise control doesn't work, need rewire post
  110. strange morning startup
  111. What's she worth?
  112. instrument cluster swap
  113. after injector install
  114. before putting in new injectors
  115. rpm and clock
  116. RPM Issue...
  117. New Front Speakers
  118. Thinking of converting to SE gauge cluster, had a few questions...
  119. Speedo is not working.
  120. How is everyone?
  121. 1990SE : For those I never got back to....
  122. First Road Trip
  123. where is the trunk light switch
  124. Installed!!
  125. brakes
  126. Two Questions? Keyless entry & Grill.
  127. Interesting problem
  128. Size of rear rotors for BBK
  129. Fun With Starters
  130. koni struts...
  131. sluggish after long drives...
  132. My front right KYB-GR2 strut is dead after hitting a pothole
  133. Oil in #6 spark plug
  134. 2 leaks... which is the most important to fix
  135. black smoke from exhaust
  136. anyone know how to reach MyGreenMax94
  137. New Parts!!!
  138. Leaking something...
  139. Key Pad
  140. Car eating batteries
  141. Valve Cover Gasket-do I HAVE to change it?
  142. Need help and thoughts about overheating problem
  143. Power Sunroof into a non-sunroof car
  144. Question/tranny
  145. Splitting the manual transmission
  146. CAr Will Not Start After Injector Replacement
  147. Car has Slight Chugging Issue
  148. seat
  149. Help with vaccum hose part2
  150. passenger side window regulator/rail
  151. Help with a vacuum hose!!
  152. a/c R-12 conversion to R-134
  153. need pics of chrome intake mans and valve covers
  154. Apexi NEO on a VE
  155. Big Decision! Transmission questions
  156. Starting Problem
  157. Any Computer Chips Or Mods That Work
  158. sounds
  159. door locks lock after let go unlock....
  160. rear hub/bearing
  161. door pillars
  162. Use of gasket maker for fuel injector replacement...
  163. Condensor bolts
  164. wondering why their are not more ve's out there/turbo
  165. will car run with plenum off?
  166. I hate electroincs.
  167. trannys
  168. V-Manage from Greddy or Trust
  169. Taillight problem
  170. Bad injector? just great.....
  171. Clear Blinkers!!
  172. Control Arms
  173. cefiro body kit...fitment issues?
  174. engine conversion help?
  175. Left Headlight
  176. Steering Bushing
  177. injector orings
  178. Cleaning Injectors (Out of Car)
  179. My max
  180. Eliminating the VTC
  181. Pic of 3rd Gen keyless remote....
  182. How many miles daily...
  183. bored, made a vid
  184. Throttle Enigma
  185. I just bought some e36 and a upgraded to h7 harness
  186. ATTN: All 3rd gens NOT at Maxus
  187. Exhaust
  188. Control arm Bushings
  189. Grills
  190. connectors/tranny
  191. sunroof seals
  192. how much your max means to you
  193. AHH! Dash Lights wont work!!
  194. CV Axles again?
  195. HELP!!! 3rd gen keeps dying!
  196. vg motor swap problems
  197. Changing the Distributor
  198. Stereo keeps turning off
  199. Headlight Relay
  200. Bose Headunits different sizes?
  201. 3rd gen Bose, did it change?
  202. 3rd gen?
  203. check engine light...on one second then off
  204. Matt's Stage II LTB
  205. VE + n2o + DRs + track
  206. Pulling VG motor..
  207. Pulling the Engine
  208. power steering question
  209. Transmission problems
  210. Update: Turbo back in with upgrades and Euro Projectors
  211. Help!!!
  212. heater core
  213. Help Needed. Losing water etc.
  214. seatbelt
  215. Bangs into gear out of park
  216. dripping from under dash, passenger side
  217. What is Thermal Transmitter -
  218. Check Engine - code 32 HELP!!!!
  219. What Tools Are Needed For Brakes?
  220. fule pressure regulater hose
  221. Once again.... now engine dies at higher rpms?
  222. James - 1, Rust - 0
  223. Polling for opinions on exhaust change
  224. anyone have coilovers on their car
  225. Maxus SFC sale
  226. Trunk Light - Alarm
  227. no power again but its not knock sensor this time
  228. 300ZX manifolds
  229. vacuum line on top of plenum ve auto
  230. please help. gauge face problem.
  231. BOSE problem - 93 SE
  232. How can I fix small rust spots?
  233. Ripped steering rack boot, now what?
  234. Soo..I changed my timing belt today....
  235. Welding Gland nut?
  236. Painting my plastic pieces in the interior, what should I do next?
  237. How to change brake shoes?
  238. Homemade FSTB
  239. I hate Pot-holes!
  240. help::temperature gauge inside is going out
  241. smoother idle with A/C on??
  242. Pre maxus subframe deal
  243. 94 Gxe...program Keypad On Door Handle
  244. 1157 Blinker Mod WriteUp
  245. SE wheel weight
  246. heat?
  247. o/d light dont work anymore
  248. getting new rims/tires question -no pics-
  249. Alternator VE/VG
  250. 1157 Blinker Mod
