- Warm Shifter Boot normal?
- Alternative fix to expensive Nissan Blow By hose?
- Transmission rebuilt
- Engine bay ?
- I need help (shes on her last legs)
- Relay's
- another max written off because of an idiot
- Bolt hole?
- 3rd gen rad fit other models?
- perma ban impossible
- Noise with NEW TOB & ISB
- Sun Roof Leak Fix?
- Hesitation, missing when engine warm
- Sensor in bottom of tranny
- Alternator tensioner interchange
- Anti-theft issue
- Fuse values?
- Transmission removal ?
- Swap
- Possible Rear Main Oil Seal Replacement
- Flywheel help
- slap/clank noise from block
- 3rd Gen Progress
- Eibach's+monroe Sense-a-trac's=rough ride
- Mid engine Maxima!
- Rebuild is officially started
- What triggers the cont starter relay next to the battery?
- Startup of VG rebuild
- 5spd swap saga...
- Reading spark plug
- Troubleshooting a 92 vg auto tranny swap issue.
- 1993 nissan maxima SE electrical problem!!??
- So, It's really gunna happen...
- need info on 1991 maxima passenger side window fix
- 93 maxima ve30de no spark HELP!!!
- Busted Stud Blues
- Coolant Leak Help
- distributor replacement
- Does anyone have any of my maxi pics?
- Car shakes on acceleration sometimes
- Stutters when hot...
- Leather seats ?
- VE and Vg guys step in
- Bad Cat?
- VG Cooling issues
- Location of Headlight grounding points 91SE VG30E
- Car surges back and forth going downhill
- Another 3rd Gen Coilover Thread
- Could a bad CAT keep car from starting?
- Third gens!
- ignition switch
- Chattering from Compressor
- Fuel Injector
- Got a Ticket!
- 150,000 mile makeover
- Fabric spray
- Anyone used Helix Air Suspension
- PLATE-BAFFLE
- Lost the key/Ignition swap??
- Budget Suspension Fix
- can i swap a 6th gen 6spd trans on my 3rd gen 5spd?
- Mile High club
- 5spd swap...clutch pedal issues
- retractable rear window shade
- automatic shift knob?
- Fuel gauge gets stuck beyond full sometimes ???
- 3rd gen mirror disassembly
- What's this?
- keyless entry prob
- DIY performance mods tips and advice wanted
- 93 maxima is killing me
- Clutch replacement help
- Wheres the AC low side port?
- TPS on a 1989 maxima gxe VG30e
- repair or retire
- 92 VE Stalling/Shutting off
- Engine swap
- Car audio nightmare
- One headlight brighter than the other
- radio swap with '93 Altima factory headunit
- HELP, with ABS LEAKING
- No Power
- anyone know how to fix dash cracks?
- air compressor replacement
- Whats the permanent injector fix?!!
- Rough Running
- Brake line hole... ugh
- Gas leak above 3/4 of the tank, rough idle (intermittent), strong gas smell
- edelbrock cams
- 3rd GEN ECU DECODER!!!! with links
- What is it worth?
- VE Engine Rattle 2-4000 RPM- not VTC
- 1991 automatic transmission interchangability/compatibility help asap!!!
- no trans fill plug on mt vg
- What happened here?
- Help Please!!!
- AC compressor always 'engaged'
- Tranmission
- Starter grinding on flywheel 5 speed SE.
- toqure specs
- Shell V-Power
- Performance Parts????
- 3rd generation maxima 300e wiring diagram
- 3rd gen project rebuild/restoration pictures
- cranking problem
- Another bites the dust.....
- Rebuilt RE4F02A transmission - have steel spacer left over. Need help identify
- Engine Temp Sensor causing fuel system issues
- Engine bay pics needed
- some new stuff
- bushing kits
- 1990 Maxima, 99 problems and a blown motor ain't one.
- sprit lowering springs
- Replacement ve30de?
- Engine misfire/intermittent misfiring
- coolant leak?
- engine r&r
- Fog light rewire with parking lights
- who hates their sunvisors? pics!
- 92 gxe cab fans
- Fuel System Diagnosis??
- Brakes sticking
- Strut broke through strut houseing?
- short throw shifter/ slop is 5 speed
- Look what I did today!!
- Brake Light
- active members?
- Mag-Flow in-line filter for P/S
- is it true?
- My 3G w/OBX Headers/Y-pipe!!
- Getting back on the road after 1.5 years problems...
- Looking for Outer Sills (rocker panel) '93
- Fuseable Link?
- Having issues finding injector connectors!!
- Redlinegoods door panel inserts available
- 3rd gen summary
- White smoke from passenger side of engine bay
- Need quick help with iacv vac line routing.
- Manual Trans Dismantling Help
- Can we adjust line pressure in the auto transmission?
- JDM half mast antenna capabilities
- Vacuum line routing ?
- I think I'm in love please help
- E36 head lights
- Dimmer ?
- Throttle problem
- security light not working
- Test to find bad ignition coils on '92 SE with VE30DE
- side mirror fuse location & sunroof question
- Transmission cooler lines
- Performance Chip?
- 3rd gen maxima clutch pedal support nut broken please help
- warpspeed y pipe ?
- Engine roar
- Transmission Fluid change
- Suspension and Brake swaps
- AT Solenoid Valve Assembley
- My Vg max accel problems
- Do they stillen make the stillen kit?
- 92 maxima with dohc engine problem
- My first accident on my first car.
- Timing belt
- Error 51
- Lambo doors
- First car?
- Trying to get rid of the rasp but create a deeper tone...?
- those with component LEDs..
- Timing VG30E
- HELP! 1989 maxima starter problems
- Kinda dont know what to think
- 92 maxima gxe missin
- Turbo setup help
- GE SPORT Nighthawk 9004 Headlight Bulb $4.29 each at Amazon.com
- PART NEEDED -- VE clutch fork (withdrawal lever)
- Axels
- Changing lower ball joints on a 3rd generation 93 Maxima
- air conditioner
- humming from speakers
- 1991 maxima eng cont relay buzzing
- ECTS help needed!!!!PLEASE!!
- 90 MAXIMA CODE 13 PLEASE HELP!!!
- 3rd Gen OEM Carbon Fiber Hoods / Trunks - Group Buy (yes, seriously)
- Consult
- another dead 3rd gen,
- 89-91 trunk popper
- rebuilding heads, should i replace the piston rings
- VE wont stay running, give gas dies
- Issue with Speed Sensor?
- car died, replaced fuel filter, won't start
- timing belt tensioner
- 1989 Maxima Suspension
- Rocker Panels Weld
- 91 maxima
- to keep or to sale
- God help me, how do I get the passenger cv axle carrier bearing bolts out?!
- Adjustable sways?
- VE A/T Hose Sizes
- Digital Touch Entry System Conversion
- tilt steering loose>93 SE
- rear disc brake conversion help please
- 1993 Maxima Timing chain. V-6 DOHC
- transmission codes
- RIP 89 Maxima
- spoiler
- Can you guys link me to a Few parts?
- It's Time...
- 93 maxima
- Good Thermostat vs. Bad Thermostat
- Oil Pressure Light
- Jacobson power coil????? what can you tell me about them?
- fog lights dont work
- 93 Maxima radio cuts out, clicking in fuse area
- Help.Camshaft seal to disappeared.
- lightened flywheel
- Anyone with the 92 max se
- need help!! weird engine noise
- Please Help - '92 SE idling really high
- ok gona try this again
- Sooo... wrecked the max last thursday
- help me out here guys
- Crazy Clutch Pedal Problem
- What makes the tac needle go crazy?
- I Have Started To Change Timing Belt Myself. Questions...
- Another Power steering Headache
- Buy a 3rd gen or Volvo 850 Turbo
- possible vacuum leak ? (vg)
- Running Rich After Startup / VE ECU Pros Needed
- Front bumper cover?
- Rear Sway Mount Broken!
- sway bar bushing and end link bushing replacement
- Anyone interested in my rare body kit...
- 2 quick questions
- Buying new engine ?'s
- What Octane?
- Engine sometime won't turn
- Clutch leak?
- hit a curb need help
- What's missing here???
- Rise and Shine little guy
- Struts and lowering springs
- Found Some Eibach
- corner light rewire question
- Visual difference between GXE and SE Brake Master Cylinders?
- Custom 3rd Gen For Sale
- White LEDs on a GXE cluster
- caliper question
- ignition switch or starter?
- Maxima wont turn over security prblm
- Opinions on this find please!
- Replace a leaking oil pressure switch
